05-28-2013 02:59 AM - edited 03-18-2019 01:11 AM
Hi All,
We have one c series endpoint with ISDN link. How can I dial a audio call from C -series endpoint. Currently we are able place video calls to other video endpoints, but calls to telephones/mobiles were not going.
Please guide me is there any settings to be changed to initiate audio call or it will be automatically negotiated.
Thanks.
Solved! Go to Solution.
05-28-2013 04:03 AM
05-28-2013 04:03 AM
05-28-2013 05:51 PM
Hi Binesh,
It is possible from remote control also .
Use 4th softkey to select callrate .
Kind regards,
Dharmmesh
05-28-2013 03:24 AM
Hi Binesh.
To call audio only calls, you will have to set the bandwidth for the call to "Audio" .
This can be done on the on screen display menu, on the touch panel or even if you are trying to call from the http interface.
Hope this helped.
Marius
05-28-2013 03:58 AM
Hi Marius,
Could you please add screen shot/ picture selecting "audio" option. I couldn't find the same on OSD / web interface.
Thanks.
05-28-2013 04:03 AM
This is snapshot on TC6.2.0beta3.
05-28-2013 04:03 AM
//Marius
05-28-2013 05:18 AM
HI Marius,
Thank you. Got it. we are able to place call through web interface.
But through remote control , is this setting is available. please confirm
Thanks.
05-28-2013 05:51 PM
Hi Binesh,
Kind regards,
Dharmmesh
