06-08-2022 01:58 AM
Does any one know if its possible to add a script that makes the Room Kit Mini restart once a week?
Mathias
06-08-2022 04:01 AM
Very likely you should be able to achieve this with a macro on the device. I have no suggestion for how to craft this macro, but with a little bit of search you should be able to to find the API documentation and it should contain the needed information.
06-08-2022 04:51 AM
This link should be able to get you started.
06-08-2022 05:36 AM
Maybe xCommand https://roomos.cisco.com/xapi/Command.SystemUnit.FactoryReset/? . test and play first locally 🙂
06-08-2022 05:56 AM
Looks like you can use this command to restart it: xCommand SystemUnit Boot Action: restart, Force: true
Only need to find a way for it to do it once a week.
08-16-2023 06:45 AM
02-21-2024 01:21 PM
I attempted to use this script, but keep getting a compile Error when I upload the macro. Points to line 35| const friday = 5. Do you see anything wrong with this? Also, Do you know what it should look like if I want to reboot everyday?
33 |
34 | const token = //https://github.com/CiscoDevNet/roomdevices-macros-samples/blob/master/Library%20-%20Send%20Webex%20Message/README.md
> 35 | const friday = 5;
36 | //sunday=0;monday=1;tuesday=2;wednesday=3;thursday=4;friday=5;saturday=6
37 | const rebootTime = "06:00";
03-04-2024 07:15 PM
The error is not with the "const friday = 5" line, it is that there is no token provided after the "const token =", the rest of that line is a comment, so there is nothing being defined as the token.
Please remember to mark helpful responses and to set your question as answered if appropriate.
03-04-2024 07:20 PM
If you want a Daily Reboot script - take a look at roomdevices-macros-samples/Daily Reboot/DailyReboot.js at master · CiscoDevNet/roomdevices-macros-samples · GitHub
02-26-2024 08:25 AM
Hi mgriff,
I'm attaching:
- a procedure ("configuration_scheduled-reboot.pdf"), written by me, which you can follow;
- also, the n.2 scripts-files(txt);.
Regarding the everyday-reboot, mmmhh...I think:
- you can (spartanly) copy the "reboot" function and paste ut for each day;
- alternatively, you can write a for/while cycle.
Let me know.
Have a Great Day;
Ciao,
Matteo
03-17-2024 07:21 PM
Hi mgriff, I'm wondering why you need the codec rebooted weekly? I'm exploring to see if anyone is having output issues same as I am.
