Error on TMSPE conductor configuration
aneesh.abraham
I am trying to configure conductor in TMSPE for CMR configuration, I am getting "Failed to create CMR. Please contact your administrator" error.
 i tried to search on the form couldn't find any solution.
version
TMS -15.6.1
TMSPE -1.12.0
Conductor- 4.3.2
Aneesh
5 Replies 5
Make sure you have created a user with API access in Conductor to be used by TMSPE.
Take a look on Cisco Collaboration Meeting Rooms (CMR) Premises Deployment Guide Release 7.0 - Primary (for Unified CM) under Enabling Personal CMRs - Process on page 55.
Thanks and regards,
ACEVIRGIL
Hi Acevirgil,
     I have already created a user in conductor with API access permission. Even I tried with the admin user account in conductor but no luck.
Aneesh
Did you ever figure this out? Having the same issue
Schpice
did you find the solution to this issue ?
I got the same problem.
Thx
I had the same issue.
Summary: Looks like the Java version was updated and there was a vital piece of information missing from the security config file.
Found this out by collecting the TMS logs and seeing this error everywhere.
2019-05-29 10:02:10,691 [common] [JettyThread-280196] ERROR U: VMR::ConductorConnector - TelePresence Conductor failure with: Could not generate DH keypair
2019-05-29 10:02:10,691 [common] [JettyThread-280196] ERROR U: VMR::ConductorSetting - Failed to get service preferences from TelePresence Conductor. Reason: Failed to create CMR. Please contact your administrator
This then lead me to the following config guide.
https://www.cisco.com/c/dam/en/us/td/docs/telepresence/infrastructure/tmspe/release_note/Cisco-TMSPE-release-notes-1-7.pdf
Page 3-4, java requirements! Located the java installation (latest one because that's the one being used) and edited the below line into the java.security file via Notepad++
Restarted the TMSPE service, waited 10 - 15 mins, and all was fine.
Hope this helps,
David
