10-14-2014 08:39 PM - edited 03-18-2019 03:31 AM
In MX300 G2 TC 7.1.4 device i am getting following error in GUI and "Touch Panel requires IPV4" in display.
What is the cause, solution and troubleshooting.
Solved! Go to Solution.
10-21-2015 09:10 PM
How would this help to solve the issue.
And problem has been resolved after replacing the cat5 cable between codec and touch panel.
10-14-2014 09:02 PM
At a quick guess, it's because you've disabled IPv4 on the device (ie, you've set it to IPv6 only)?
To fix it, re-enable IPv4. In the Web Interface, go to Configuration > System Configuration. Click on the Network menu item and change the IPStack to IPv4 (for IPv4 only) or Dual (for IPv4 and IPv6) depending on your network's requirements.
The other message, regarding the Indicators suggest the SystemUnit MenuType is set to "Indicators" rather than "Interactive" - which would be correct when using a touch panel - but it's complaining about it because it can't see the touch.
PS - Due to the well published ShellShock security vulnerabilities in TC7.1.4 (and other versions), I'd recomend you consider upgrading to TC7.2.1.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Please remember to mark helpful responses and to set your question as answered if appropriate.
10-14-2014 09:06 PM
Thanks for the reply Wayne,
But we never use IPv6, the issue occurred all of sudden. Any suggestions.
10-14-2014 09:56 PM
Check the settings on the G2, and if they all look right, try factory resetting and re-pairing the touch.
Procedure for resetting the Touch 10:
1) Press and hold the "Mute" button until it starts blinking (red and green) - this takes about 10 seconds.
2) Press the "Volume Down" button twice.
The Touch 10 will revert to default settings and restart.
You will then need to re-pair the touch to the endpoint.
Wayne
11-06-2014 09:42 PM
After couple of days of reset again issue occured.
11-06-2014 10:52 PM
How are you assigning the IP addresses to the units? Static or DHCP? And if DHCP, are they reservations so the devices always get the same addresses? If the endpoint and/or touch are getting different ip addresses each boot, that can cause the errors you're seeing.
Wayne
11-10-2014 03:25 AM
We are using static ip address.
04-29-2015 04:19 AM
Try entering this command
xConfiguration Peripherals Profile TouchPanels: 0
This configuration sets how many touch panels the codec should expect. Setting it to "0" will remove
the "Touch panel required" warning message.
10-21-2015 07:24 PM
Go to Configuration --> System Configuration and search for indicators in the upper left search box. This will bring up the SystemUnit MenuType in the Experimental section. Change the setting from Indicators to Interactive.
10-21-2015 09:10 PM
10-22-2015 07:03 AM
In my case we weren't using touch panels, so the error was telling me exactly what was wrong. No touch panel was detected when the SystemUnit MenuType setting was set to Indicators, i.e. indicators were being forced by that config setting. Changing it to Interactive eliminated the GUI error.
