EX90's calling each other
rfrome
Team,
I have two EX90's, not VCS yet. Custoemr want to set them up to call each other. Is this possible, if sow what configurations are required?
thx,
Robert
epicolo
Level 3
Level 3
In theory, two Endpoints running TC4.x can call each other withou registrations. You need to enable H.323 and SIP and not point to any server. You will need to dial using IP address.
thobonho
Hi Robert,
The most important is to set the H323 CallSetup mode to Direct. This will allow you to make H323 calls by dialling an IP address.
Other option using cisco call manager to register those both endpoints without the need to use vcs
Hope this help
If helpful rate
