FXO lines stuck/hang (2801 CME)
nareh84
Level 3
Level 3
hi,
I have a 2801 CME and 2 fxo lines. Some times when both lines are seized (because of incoming and outgoing call) and after the phones are on hook the lines are still seized and are not released mostly i have to unplug and replug the fxo line from pstn. following is the configuration on the voice-port. any suggestions!!??
voice-port 0/0/0
supervisory disconnect dualtone mid-call
input gain 14
compand-type a-law
cptone BE
timeouts call-disconnect 5
timeouts wait-release 5
connection plar opx 121
impedance complex2
caller-id alerting dsp-pre-allocate
10 Replies 10
paolo bevilacqua
Try
voice-card 0
no local-bypass
Note pre-requiste for that to work, is having disconnect supervision working.
Karthik Sivaram
Level 4
Level 4
This is a supervisory disconnect issue ..
1)In which country is the Telco in?
2) can you upload your show version and show run as well?
3)Have you tried with " no battery reversal" under the voice port and done ashut and no shut on the voice port ?What is the result of this?
Karthik
hi,
the country is oman but cptone BE only works. if i put any other country cli dont work. i havent entered battery reversal command. can this be ios bug???
hi following is the sh run and sh version. cme output portion is removed
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2011.02.03 14:27:39 =~=~=~=~=~=~=~=~=~=~=~=
User Access Verification
Username: admin
Password:
Router_Home>en
Password:
Router_Home#term
Router_Home#terminal le
Router_Home#terminal length n   512
Router_Home#sh run
Building configuration...
Current configuration : 15203 bytes
! Last configuration change at 14:41:02 UTC Thu Feb 3 2011 by admin
! NVRAM config last updated at 14:38:09 UTC Thu Feb 3 2011 by admin
version 12.4
hostname Router_Home
boot-start-marker
boot-end-marker
enable password cisco
no aaa new-model
clock calendar-valid
crypto pki trustpoint TP-self-signed-2416845307
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2416845307
revocation-check none
rsakeypair TP-self-signed-2416845307
crypto pki certificate chain TP-self-signed-2416845307
certificate self-signed 01
  30820243 308201AC A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 32343136 38343533 3037301E 170D3131 30323032 31373332
  34335A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 34313638
  34353330 3730819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100DFAC E4312F46 0F2BF242 E55FE0C1 73DC95F2 B2844295 DA691CE3 D9A202B1
  77B1B0C3 5AE3D936 C4D786DB 7CFA6624 024C6A82 A29B3AAC 3BA89A77 5425A97A
  6D79A88A C1327171 C88AA5E0 AB52F461 87FB472E A7622955 17C8F22C 58842EF4
  4DFA422A 54E6B96A FA536C59 BD93FDCD 872C0586 08117535 2D13F1E0 A53E65AB
  FE470203 010001A3 6B306930 0F060355 1D130101 FF040530 030101FF 30160603
  551D1104 0F300D82 0B526F75 7465725F 486F6D65 301F0603 551D2304 18301680
  14E940B0 E437790B 4B825CD2 0FA9020F 63C9ED3A ED301D06 03551D0E 04160414
  E940B0E4 37790B4B 825CD20F A9020F63 C9ED3AED 300D0609 2A864886 F70D0101
  04050003 8181006B D6136D19 6EF4DDCD B3AF591E 57B9B831 79578799 03862FCF
  4AF772DE AC72FC85 3F6B6B20 81F528F0 F7B2CBD0 E9795060 C46AB102 AE2CDF53
  11C39D67 B49A7AE8 FB619A0F 525543F7 8BA1D52C CABEFFEB 9E5EC7E7 938AA602
  84F1ECD2 303E8609 A9AB0699 9078051B 1853BC9A 4B45F2A2 204310D5 8B34B5DD
  2FA51064 EFF5D4
   quit
dot11 syslog
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.168.0.1
ip dhcp excluded-address 10.168.0.2
ip dhcp excluded-address 10.168.10.1
ip dhcp excluded-address 10.168.10.2
ip dhcp excluded-address 10.168.111.1 10.168.111.6
ip dhcp pool Data
   network 10.168.0.0 255.255.255.0
   default-router 10.168.0.1
   option 150 ip 10.168.10.1
   dns-server 212.72.1.186 212.72.23.4
ip dhcp pool VOICE
   network 10.168.10.0 255.255.255.0
   default-router 10.168.10.1
ip dhcp pool WLAN
   network 10.168.111.0 255.255.255.0
   default-router 10.168.111.1
ip host members.dyndns.org 204.13.248.112
ip name-server 212.72.1.186
ip name-server 212.72.23.4
ip ddns update method example_dyndns
HTTP
  add http://whatisthis:whatisthis@members.dyndns.org/nic/update?system=dyndns&hostname=&myip=>
interval maximum 28 0 0 0
interval minimum 28 0 0 0
voice-card 0
dsp services dspfarm
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service h450.2
no supplementary-service h450.3
supplementary-service h450.12
h323
sip
  registrar server expires max 600 min 60
username xxxxx password 0 xxxx
archive
log config
  hidekeys
interface FastEthernet0/0
no ip address
ip nat inside
ip virtual-reassembly
speed auto
full-duplex
no keepalive
interface FastEthernet0/0.2
description ***** Voice LAN ******
encapsulation dot1Q 2
ip address 10.168.10.1 255.255.255.0
ip nat inside
interface FastEthernet0/0.3
description ***** Data LAN ******
encapsulation dot1Q 3
ip address 10.168.0.1 255.255.255.0
ip nat inside
interface FastEthernet0/0.4
description ***** Wireless LAN ******
encapsulation dot1Q 4
ip address 10.168.111.1 255.255.255.0
ip nat inside
interface FastEthernet0/1
description $ES_WAN$
no ip address
shutdown
duplex auto
speed auto
interface ATM0/1/0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0/1/0.1 point-to-point
pvc 0/35
  pppoe-client dial-pool-number 1
interface Dialer0
no ip address
interface Dialer1
mtu 1492
ip address negotiated
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1452
ip nat outside
encapsulation ppp
ip route-cache flow
ip tcp adjust-mss 1412
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname xxxx
ppp chap password 0 xxxxx
ppp pap sent-username xxxx password 0 xxxxx
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer1
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip dns server
ip nat inside source list 101 interface Dialer1 overload
ip nat inside source route-map NAT_RMAP interface Dialer0 overload
access-list 101 permit ip 10.168.0.0 0.0.0.255 any
access-list 101 permit ip 10.168.111.0 0.0.0.255 any
route-map NAT_RMAP permit 10
match ip address 101
control-plane
voice-port 0/0/0
supervisor disconnect dualtone mid-call
input gain 14
compand-type a-law
cptone BE
impedance complex2
voice-port 0/0/1
input gain 14
compand-type a-law
cptone BE
impedance complex2
voice-port 0/0/2
input gain 14
compand-type a-law
cptone BE
impedance complex2
voice-port 0/0/3
input gain 14
compand-type a-law
cptone BE
impedance complex2
dial-peer cor custom
name local
name longdistance
dial-peer cor list call-local
member local
dial-peer cor list call-longdistance
member longdistance
dial-peer cor list manager
member local
member longdistance
dial-peer cor list other
member local
dial-peer voice 1 pots
corlist outgoing call-longdistance
destination-pattern 0.T
port 0/0/0
dial-peer voice 2 pots
port 0/0/1
dial-peer voice 3 pots
port 0/0/2
dial-peer voice 4 pots
port 0/0/3
dial-peer voice 5 pots
corlist outgoing call-local
destination-pattern 0[2,9].......
port 0/0/0
dial-peer voice 6 pots
port 0/0/1
dial-peer voice 7 pots
port 0/0/2
dial-peer voice 8 pots
port 0/0/3
dial-peer voice 9 pots
destination-pattern 0800T
port 0/0/0
prefix 800
dial-peer voice 10 pots
port 0/0/1
prefix 800
dial-peer voice 11 pots
port 0/0/2
prefix 800
dial-peer voice 12 pots
port 0/0/3
prefix 800
telephony-service
no auto-reg-ephone
max-ephones 25
max-dn 25
ip source-address 10.168.10.1 port 2000
auto assign 1 to 20
timeouts interdigit 5
system message Home
max-conferences 8 gain -6
call-forward pattern .T
dn-webedit
transfer-system full-consult dss
transfer-pattern .T
ephone-dn  1  dual-line
number 101
label M.M Office (101)
description M.M Office (101)
name M.M Office
ephone 1
device-security-mode none
video
mac-address 1C17.D3C3.7A31
speed-dial 1 102 label "abc"
speed-dial 2 103 label "def"
speed-dial 3 104 label "hij"
speed-dial 4 113 label "klm"
speed-dial 5 104 label "nop"
speed-dial 6 105 label "qrst"
speed-dial 7 105 label "uvw"
type 7975
button  1:1 2:21
ephone-hunt 1 sequential
pilot 150
list 121
line con 0
exec-timeout 0 0
logging synchronous
login local
line aux 0
line vty 0 4
login local
transport input telnet
scheduler allocate 20000 1000
ntp master 2
ntp update-calendar
end
Router_Home#sh di
Router_Home#sh dia
% Ambiguous command:  "sh dia"
Router_Home#sh ds
Router_Home#sh dsv   p
Router_Home#sh dspfarm
% Incomplete command.
Router_Home#sh dspfarm ?
  all      Display all DSPFARM global info
  dsp      Display DSPFARM DSPs information
  profile  Display DSPFARM profiles
Router_Home#sh dspfarm ds
Router_Home#sh dspfarm dsp
Router_Home#sh dspfarm dsp             all
Total number of DSPFARM DSP channel(s) 0
Router_Home#sh ver
Router_Home#sh version
Cisco IOS Software, 2801 Software (C2801-ADVIPSERVICESK9-M), Version 12.4(15)T10, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Mon 14-Sep-09 14:51 by prod_rel_team
ROM: System Bootstrap, Version 12.3(8r)T9, RELEASE SOFTWARE (fc1)
Router_Home uptime is 21 hours, 11 minutes
System restarted at 17:31:27 UTC Wed Feb 2 2011
System image file is "flash:c2801-advipservicesk9-mz.124-15.T10.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 2801 (revision 6.0) with 237568K/24576K bytes of memory.
Processor board ID FCZ10491208
2 FastEthernet interfaces
1 ATM interface
2 Virtual Private Network (VPN) Modules
4 Voice FXO interfaces
1 DSP, 8 Voice resources
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
62720K bytes of ATA CompactFlash (Read/Write)
Router_Home#exit
hi,
Why are you using cptone BE?
There is a cptone for Oman  called cptone OM.
The above command will probably require a higher IOS ver.
Karthik
hi,
I have chosen cptone BE because of caller id. if i chose any other cptone caller id dont come..Actually i opened tac case for caller id issue and he set cptone BE after which callerid started working..
nareh84
Level 3
Level 3
any suggestions ??
nareh84
Level 3
Level 3
does dsp pre allocate command can cause any effect as there are only 8-dsp.
nareh84
Level 3
Level 3
hi,
I visited the site and today the same thing happened. the lines were stuck. and when i removed the cables from fxo port the led on each port started to blink in sequence and then when i reconnected, the port was busy again.. so i had to reboot the router to make it work. i changed the slot but dont think that it will cause any difference..do i need to upgrade the ios or some other issue..when i am calling the disconnect is fine but it happens some time when the line get stuck i have to reboot the router. one more thing when i changed the slot of the card the router didnt detected the change of slot and was showing fxo port on old slot. i rebooted the router to detect the fxo card on the right slot..
You need to configure custom disconnect cptones.
You can search the forum for the very many threads on the very same subject.
