How to call SX10 to another one on LAN
LE SON
Hi. I was wondering if you can use the SX10 to call on LAN to another SX10 using either SIP or H323 protocol? If so then can someone help me out on the setting? Thanks you
Sure you can. You just call to the SIP uri or the H.323 address.
Response Signature
You can dial by IP address.
Response Signature
Wayne DeNardi
If you don't have a call control platform to enable you to do this easily, you would need to configure each of the devices as "standalone" endpoints.  You should then be able to make a H.323 call from one to the other using their publicly accessible IP address.
Have a read through the "SX20 as Standalone" thread - it contains the information on how to configure the devices so they can be used this way (the configuration on the SX10 is the same as the SX20, so you can ignore that they are different models for this purpose).
Note: you will also need to configure any firewalls present for each of the networks to allow the traffic on the required ports.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
