Installing DX80 Firmware
StevenLynn9406
I am looking for a step by step guide for updating the firmware on a Cisco Telepresence DX80 if there is one available and someone can point me in the right direction in getting one.
8 Replies 8
Magnus Ohm
The DX80 runs either android software or CE software. Which of these is your DX running?
It is running CE software.
Thank you. I will look at implementing this solution.
How I can change the DX80 android os to CE Software
Please find the below link-
https://www.cisco.com/c/dam/en/us/td/docs/telepresence/endpoint/ce94/dx80-dx70-convert-between-ce-android-based-software-ce94.pdf
Its very good document regarding converting a DX between android and CE versions with/without CUCM.
Please rate if it is helpful..
Thanks for your information
How I can convert individually not all the dx80. So that I can test it and later I can convert to CE software one by one.
Thanks.
Hi there
Please do the following from page 10 in this guide from Cisco:
https://www.cisco.com/c/dam/en/us/td/docs/telepresence/endpoint/ce82/dx80-dx70-convert-between-CE-android-based-software.pdf
1. Tap the Settings icon in the upper right corner of the DX device.
2. Open the Settings application and navigate to More... > TFTP Server.
3. Enter the IP address of the Cloud Upgrader tool:
1. TFTP Server 1: upgrade.cisco.com or 128.107.1.157
2. When prompted, erase and Trust List files.
3. TFTP Server 2:
4. When prompted, erase and Trust List files.
The DX device will restart and the upgrade process will start.
Hope this Helps
Cheers
Rath!
***Please rate helpful posts***
