IX5000
siwar.ziadi1
I found IX5000 unregistered today and I do not know why, on the tablet I had this error "connecion to telepresence system is lost), I can not accredit either via SSH or WEB.How can I get it back, and check from where come this problem please? someone has an idea
Once you get that IP along with that you will get a gateway address as well.
So you need to browse the gateway IP address and it will open the IX5000 webGUI and from there you can click on logs then generate logs.
Once the logs are generated, click the download logs and it will download a tar.gz file.
Please rate if it is helpful...
Anurag Srivastava
Hello Siwar,
Please remove the touch 10 and connect your laptop with the same and enable DHCP on your laptop.
You will see a IP assigned by Host CPU in range of 169.254.x.x.
Please try to access through gateway IP and collect the logs first from IX.
Then you can power reset the complete unit and see if it comes back normally.
You can open a TAC case with the logs for a RCA.
hello Anurag Srivastava,
Thank you for reply, juste question when i get the adress 169.254.x.x, how can i get a log from IX Please? Thank you
siwar.ziadi1
Thank you so much , i will try to do this
