ā09-19-2012 01:12 PM - edited ā03-17-2019 11:49 PM
I haver TMS v13.1.2.
I havƩ added two phone book sources (manually + Active directory)
The manual list is searchable from Jabber or Movi but Active directory source is ont accessible from iPad nor Movi.
Note : when i click on vies contacts tab on phone book source (AD), i saw all contacts but i couldn't see them from client.
Driss
ā09-19-2012 01:43 PM
Even if you see the contacts in the source you need to add the source to a phonebook. Can you still see the contacts in the phonebook? If you can see the contacts in the phonebook, you have to expand the contacts and see if they have a contact method. If they do not have an address, there is your answer on why you do not see the contacts in the jabber when searching.
Make sure you have provided access to the jabber clients in the access control tab.
/Magnus
ā09-19-2012 03:15 PM
ā09-19-2012 11:10 PM
Thanks but this did not answer all of my questions.
What kind of contact method is attached to the contacts you see? Can you expand them, if they are blank then it won't show up in the phonebook.
But another thing is also that the users you are logging in with are part of the test2 group. The test2 group has to have the correct phonebok settings in the provisioning configuration. But I assume they are correct since the same user can see the manual list?
/Magnus
ā09-20-2012 04:26 PM
i didn't find something called 'contact method' (refer to attachment). Please, let me know from where i can find it.
For the other question, i confirm that Provisionning directory group is associated to phone book for manual list and it's working but for test2 source it didn't work.
Driss
ā09-29-2012 11:27 PM
Any update regarding this issue ?
Driss
