01-27-2019 04:15 PM - edited 03-18-2019 02:36 PM
I have a probem. i have been using IX5000 system with MIC button.
One day, the MIC button works anomally.
As far as i know, LED works only green or red color. (green status when properly hearing, led status when mute state)
But it works green and red simultaneously.
I'll attach pics file.
why this symptoms occurs? how can i resolve this issue?
Solved! Go to Solution.
01-28-2019 05:58 AM
Apart from this LED "anomaly" performance, does the videoendpoint work ie, is it registered to the CUCM and are you able to place and receive calls with audio?
If everything works fine, then you may just consider contacting TAC, open a case and request for replacement -in necessary-
George
01-28-2019 05:58 AM
George
