Movi client call detail record
Arbenjamin
Dear All,
We would like to collect the call history and duration of the movi client.
Using the User CDR report function, the tms report total duration and count within certain period of time. Anyone knows how to collect a more detailed report that included the call information per call.
However, we are failed to search the call detail report that is over 3 months. Is it possible to keep call detail report for a longer period of time?
Best Regards.
Benjamin
Jens Didriksen
Level 9
Level 9
Check your statistics settings in TMS; Administrative Tools\Configuration\Statistics Setting - you can specify how many days you want there.
As for more detailed records, take a look at the TMS Analytics extension, it might do it for you.
/jens
Please rate replies and mark question(s) as "answered" if applicable.
Jens Didriksen
Level 9
Level 9
/jens
Dear Jens,
Thank for your answer.
It is accurate and efficient.
We are appreciated on your help.
Best Regards,
Benjamin Lai
Patrick Sparkman
On top of what Jens has said, make sure the VCS that the Jabber Video (Movi) clients are calling through are managed by TMS, as if I recall the CDR data comes from the VCS since the Jabber Video client doesn't report CDR data itself.
