ā12-06-2023 08:41 PM
Hi, I have an Mx300-g2 and while all other funtions on my TV remote control operate as expected with my tv box, the volume does not and can only be controlled via the volume buttons on the small touch screen control pad connected to the Mx300-g2.
Regards Eamon
Solved! Go to Solution.
ā12-11-2023 01:48 PM
Thanks for letting me know Pj.
ā12-07-2023 08:07 AM
I'm not clear on your setup, but there are no remote controls for an MX300, the volume control is on the Touch 10. Any third party remote you have won't work.
ā12-07-2023 02:03 PM
Hi Pj, I have a tv box connected to the MX300-G2 and watch netflex through it, the TV remote can control all functions except volume.
Regards Eamon
ā12-11-2023 05:38 AM
got it - thanks for the clarification, but there's nothing you can do, the MX doesn't even have IR sensors, you can only adjust the volume from the Web GUI with a browser and the touch 10.
