12-30-2021 03:22 AM - edited 01-02-2022 02:16 PM
Hello all,
At client’s sites and at our office we have several codec's, Roomkit, Roomkit Plus, SX80, that is giving a Certificate Expiration issue. I read the admin guides and tried to find similar issues online and here in the Cisco Community but could not find a solution to fix this issue.
Any one any idea?
PS: That is not an operational issue I know, but it is visible on the touchscreen, and I am getting questions. And users are getting nerves.
Best regards, Bert
Solved! Go to Solution.
02-09-2022 10:41 PM
BW Dijk already has figured out which certificate is about to expire!!! The self signed for HTTPS.
But there is no buton to regenerate it. You can only view it.
The good news is:
Just reboot the device and the certificate will regenerate during this process...
04-04-2022 01:42 PM
Sorry for getting back very late.
The solution is indeed reboot the codec and the will regenerate the certificate.
12-30-2021 03:26 AM
Forgot to mention the firmware version: ce 9.15.3.22
12-30-2021 04:16 AM
Have you checked what certificate that is about to expire?
12-30-2021 09:05 AM - edited 12-30-2021 09:10 AM
Yes I checked, is for the WEB interface (HTTPS) of the unit.
12-30-2021 10:24 AM
If you’re using the standard self signed certificate it’s just to renew it on the device and if you’re using CA signed certificates you would generate a CSR on the device and have it signed by the CA of choice and then upload the signed certificate on the device.
01-02-2022 02:15 PM
All I can find about (self-signed) certificates, is that they request a hostname or domain, the codec has neither one, it just has a IP address and that is not even a fixed IP address.....
Any other tips or idea’s
05-16-2023 09:58 AM
I am unbale to delete the old expired cert. It is greyed out.. I need to generate a new CSR for CA signature.
12-30-2021 04:29 AM
Go to Admin guide and refer the topic manage certificates.
12-30-2021 09:12 AM - edited 12-30-2021 09:14 AM
On page 31 of the [D15374.15 Room Kit Administrator Guide CE9.14, OCTOBER 2020] there is a chapter regarding managing certificates.
>>> But not how to get a new one. <<<
That is my issue.
01-04-2022 06:19 PM
If you log in to the web interface of the SX80 and go to the Security, then Certificates, you can see a list of which ones are on the unit. You can click on the View Certificate button and see the expiry date - that will then let you work out which one has expired. Depending on which one it is, and whether it's critical to your environment, you can make a choice as to whether you can just delete it, or whether you need to add a new one.
Please remember to mark helpful responses and to set your question as answered if appropriate.
02-09-2022 10:41 PM
The good news is:
05-15-2023 01:23 PM
How do I delete it if it is greyed out.. How would I generate a new one?
05-17-2023 02:48 AM
The solution is to boot the codec and the will regenerate the certificate. Or instal a new software immage
05-17-2023 04:31 AM
Rebooting the Codec didn't work, so I am leaning towards a factory reset..
05-17-2023 05:56 AM
