SIPV2 support under dial-peer
czerewacz
Dear Community:
I have an old H323 GW on a Cisco 1760 (32MB  Flash and 16 MB RAM) that would like to test with SIP protocol.
This GW has the IOS: c1700-sv3y-mz.123-13b.bin which as per this link " http://www.cisco.com/en/US/docs/interfaces_modules/cable/line_cards/voice_adapter/cva122_122e/feature/guide/SIP_fm.html " should support the command: session protocol sipv2
The issue is when I try to run that command it does not work:
GW(config-dial-peer)#session protocol sipv2
% Invalid input detected at '^' marker.
GW(config-dial-peer)#session protocol ?
cisco      Cisco Session Protocol
multicast  Multicast Session Protocol(voice conferencing)
Does anybody knows since which IOS version sipv2 is supported?
Thanks!!
C1700-sv3y-mz is an IP/VOICE PLUS IOS.
Try an IP VOICE c1700-ipvoice-mz.
Regard.
Regard.
Thanks!!
