speakertrack with 3rd party microphone
perahasan
We are currently using a Cisco sx80 system and need to add a speaker track camera. We are currently using
Shure MX393/O Condenser Microphone - Omni
third party microphones. Will speakertrack work with these microphones?
Thanks in advance
The SpeakerTrack 60 is not dependent on what microphone you will be you using for the SX80 codec. The SpeakerTrack60 have its own microphone panel to capture the audio from the participants and used to track who is currently speaking. Just make sure the unit is mounted in the best place for best performance.
Refer to the installation guide:
 https://www.cisco.com/c/dam/en/us/td/docs/telepresence/endpoint/camera/precisionhd/installation_guide/speakertrack-60-installation-guide.pdf
The microphone for your codec (Shure MX393/O Condenser Microphone - Omni) is for the local audio from the participants to be sent to far end and have no relation to the SpeakerTrack 60.
regards,
Acevirgil
Thank you Sir.
