12-29-2015 10:12 PM - last edited on 03-25-2019 09:14 PM by ciscomoderator
We are currently using a Cisco sx80 system and need to add a speaker track camera. We are currently using
third party microphones. Will speakertrack work with these microphones?
Thanks in advance
12-29-2015 11:00 PM
The SpeakerTrack 60 is not dependent on what microphone you will be you using for the SX80 codec. The SpeakerTrack60 have its own microphone panel to capture the audio from the participants and used to track who is currently speaking. Just make sure the unit is mounted in the best place for best performance.
Refer to the installation guide:
The microphone for your codec (Shure MX393/O Condenser Microphone - Omni) is for the local audio from the participants to be sent to far end and have no relation to the SpeakerTrack 60.
regards,
Acevirgil
12-31-2015 04:57 AM
Thank you Sir.
