SX10 with CMR
Leonardo Santana
SX10 in standalone  can call CMR Cloud?
Leonardo Santana
Leonardo Santana
*** Rate All Helpful Responses***
This is unfortunately a limitation of the offering,  see page 6 of the CMR-Cloud deployment guide:
http://www.cisco.com/c/dam/en/us/td/docs/telepresence/infrastructure/solutions/cmrcloud/CMRCloudEnterpriseDeployment.pdf
-Jonathan
5 Replies 5
Patrick Sparkman
I haven't tested it, but I don't think an SX10 operating as a standalone system can dial into a CMR Cloud, due to how the SX10 has to dial alias@IP because it isn't registered to a SIP registrar as designed.  In order to dial into a CMR Cloud meeting, you'd have to dial the full URI address of the CMR session.
It should be able to do that. Might have to give it a SIP URI based on your systems IP address, but it should be able to do URI dialling without being registered to a SIP proxy, at least I could do that with one of our SX10 units after taking it off the SIP registrar, running software version TC7.2.1.
/jens
Please rate replies and mark question(s) as "answered" if applicable.
Hi Jens,
I have a question about this Topic.
We have here a SX10 - standalone on a DSL Router - and I configured it with a SIP URI with the IP-Address. I can make calls to Test Video Systems and it is working fine. But when I call my WebEx CMR, it connects to the room and "tries" to send and receive anything, but is then "kicked" out of the room. The Connection to WebEx is still established, but I cannot see or hear anything.
Do you have an advice, what I can do to use it with the CMR?
Thanks in advance
Kind regards,
DrM
P.s.: Webex Support says, this is not working without a Proxy like CUCM or VCS. :(
-Jonathan
Hi Jonathan,
thank you for the advice. :)
Kind regards,
Matthias
