SX20 CONFERENCE FAILURE
echiyahya
I have SX20(without multisite license), SX10, DX80 and JABBER for iphone Registred on CUCM and IM&presence,
I tried to make a video call with Jabber then i added the second participant DX80 with voice only but when i try to add third participant SX10 with voice only to conference the call failed.
You can't, not without having the MS license installed.
The SX20 allows for the addition of one audio call when in a point-point video conference without the MS license.
It does not allow two audio calls. So, if you are connecting point-point video, then you can add one audio call.
If you connect point-point audio, then you cannot add a second audio only call. This is a hardware limitation, not software.
/jens
Please rate replies and mark question(s) as "answered" if applicable,
Please rate replies and mark question(s) as "answered" if applicable.
11 Replies 11
Jens Didriksen
Level 9
Level 9
"I have SX20(without multisite license)"
...and there is your problem - you need the multisite licence for this to work if you want to host this multisite conference on the SX20 - regardless of it being audio only.
/jens
As Jens mentions, you need the Multisite option key installed on the SX20, or use an MCU/TelePresence Server to host the conference.
yes i know without multisite license i can't make video conf but My question was why the third participant when i try to to add with voice only the call fail
What is the current version of your SX20?
If no multisite license you should be able to add an audio call only participant. I have tested before but not sure if its a SX20. No MS option installed on the system and when adding additional participant, it falls to audio call only.
Hows the Conference Multipoint Mode configured on the SX20?
  • Auto
  • Off
  • MultiSite
  • CUCMMediaResourceGroupList
regards,
Acevirgil
Multipoint Mode on SX20 configured to "Multisite" and on CUCM configured to "USEENDPOINT"
Try adding the first audio call from SX20  and your second audio call from SX10 .  you should be able to have these four endpoints ( two video and two audio) now.
I tried all combinations but i have the same result 2 video call with one audio call and the fourth audio call fail
anything from the traces on why it fails for the above scenario.
Probably it is a hardware limitation as there is a audio call already .
Sundar
I thinks it is a Hardware Limitation i must add the multisite license thanks for your help
My situation now is conference between:
SX20 VIDEO
SX10 VIDEO
DX80 AUDIO
when i try to add JABBER Mobile Voice call only the call fail.
/jens
