SX20 - Error Message "Touch Panel Required"
smcintosh
I have a Cisco SX20 and the following message has just appeared "Touch Panel Required - IPV4: (IP Address) - Please see the attached screenshot for error message - I am unable to use the remote with the device. Any advice would be much appreciated?
I'm not 100% sure about that old version (CE8.2.2), but with the newer software (CE9.7.2) you can certainly fix it.
Set Configuration > Peripherals > Profile TouchPanels to 0.
You can then hide all the feature buttons on the screen under the UserInterface settings.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
5 Replies 5
Anurag Srivastava1
Login through Web GUI and navigate to Configuration-->peripherals (or in search box type "touch")
and turn off the Pairing ciscotouchpanels remote pairing to off and profile touchpanel to 0.
Thanks.
Please rate if it is helpful...
Please rate if it is helpful and mark as accepted solution if applicable....
Thank you for your reply and help - The message has now disappeared however, the main screen is still missing the "Call, Share, Video and Settings" icons - Which is strange. Please see the attached.
Note - If I use the admin panel or proximity app I am still able to make a call.
What SW version are you running?
The software version is ce 8.2.2 Final 3263c59  - Thank you.
Wayne
