T1 PRI- Channel ds0 vs times slots
Hi I am reading a cisco book right now and I have a little question regarding a PRI.
in the book it says :
"when using T1 interfaces, channel 23 (time-slot 24) is always the signaling channel. "
So I guess Channels start from 0 to 23  and time-slot 1 to 24 ? is that right ?
also If I do a "show voice port summary"  I guess the Port 0/0/0:23 is the Chnnel-D. Channel #23 wich is the times slot 24 but there is no sens if the row CH is the Channel, there would be a sens if CH would be for Times-slot because we can see that CH 23 can be used as voice port
Can some one give me a track on that...
controller T1 0/0/0
framing esf
linecode b8zs
cablelength short 133
pri-group timeslots 1-24
2811-RTR#sh voice port summary
                                          IN       OUT
PORT           CH   SIG-TYPE   ADMIN OPER STATUS   STATUS   EC
0/0/0:23       01  isdn-voice  up    dorm none     none     y
0/0/0:23       02  isdn-voice  up    dorm none     none     y
0/0/0:23       03  isdn-voice  up    dorm none     none     y
0/0/0:23       04  isdn-voice  up    dorm none     none     y
0/0/0:23       05  isdn-voice  up    dorm none     none     y
0/0/0:23       06  isdn-voice  up    dorm none     none     y
0/0/0:23       07  isdn-voice  up    dorm none     none     y
0/0/0:23       08  isdn-voice  up    dorm none     none     y
0/0/0:23       09  isdn-voice  up    dorm none     none     y
0/0/0:23       10  isdn-voice  up    dorm none     none     y
0/0/0:23       11  isdn-voice  up    dorm none     none     y
0/0/0:23       12  isdn-voice  up    dorm none     none     y
0/0/0:23       13  isdn-voice  up    dorm none     none     y
0/0/0:23       14  isdn-voice  up    dorm none     none     y
0/0/0:23       15  isdn-voice  up    dorm none     none     y
0/0/0:23       16  isdn-voice  up    dorm none     none     y
0/0/0:23       17  isdn-voice  up    dorm none     none     y
0/0/0:23       18  isdn-voice  up    dorm none     none     y
0/0/0:23       19  isdn-voice  up    dorm none     none     y
0/0/0:23       20  isdn-voice  up    dorm none     none     y
0/0/0:23       21  isdn-voice  up    dorm none     none     y
0/0/0:23       22  isdn-voice  up    dorm none     none     y
0/0/0:23       23  isdn-voice  up    dorm none     none     y
paolo bevilacqua
Cisco use x/y:23 (T1), or x/y:15 (T1), or x/y:D (AS5xxx) to indicate a PRI voice or data port.
That's all.
The question is, why are there 23 channels, where channel 0 should be?... it would make sense if those were TS because of TS 24 is used for signaling.
+5 Paolo
Gary I take it as you're curious as to how Cisco references channels and time slots. The "CH" are the 23 "B Channels"
Yosh
HTH Regards, Yosh
Thank you... It makes sense, but I still confused because of this:
http://www.aculab.com/questions/how-many-voice-channels-does-a-t1-primary-rate-interface-pri-have/
Channel 0-22     -           B-Channel (Voice)
Channel 23         -           D-Channel (Signalling)
channel 23 is a D-Channel so it shouldn't be shown on the output.
