Tandberg 3000MXP: converting from NTSC to PAL
Nguyentiendung
Hi all,
I'm using Tandberg 3000MXP. Now I want to connect a recorder to system (via video out port on 3000MXP) but it only works with PAL output. I searched on Internet and there's someone that suggested this way:
Go into the boot-prompt and type the following command:
set-access qwertsys
sys-palntsc pal
res-access
xcommand boot
I'm not sure these commands are correct because I can't find them in any official document of Cisco.
Anyone can confirm this.
Thanks.
Dharmesh Nandoria
Try following ,
https://IP address of codec /setproductversion.ssi
You will find option to change PLA / NTSC , reboot required after that .
Commnad you have mentioned are hidden commnads for codec , you will not find in admin guide .
Kind regards,
Dharmmesh
Http:// xxxx.xxx.xxx.xxx/setproductversion.ssi
xxx- Ip address of codec .
Kind regards,
Dharmmesh
prarawat
Hi Tien,
These are the following procedure to convert the device from a NTSC unit to a PAL unit :
          Using a serial connection:
1.     Connect the RS232 serial cable to the unit.
2.     Open a HyperTerminal (windows std. app) and connect at the correct port @ 9600baud.
3.     Reboot the codec.
4.     Hit CTRL + BREAK when the codec starts.
5.     Wait for the $-sign .
6.     Type " palntsc pal "  to change it to PAL.
                  Using Telnet:  Use the following hidden command to get it converted:
                  NTSC to PAL
             1)      Telnet to the unit.
             2)      Type the following: set-acc qwertsys
             3)      Type the following: sys-palntsc pal
             4)      Type the following: xcommand boot.
                  Using Web GUI:   Use the following ip address to convert:   http://ipaddress/setproductversion.ssi
                  You will get an option to convert NTSC and PAL button.
Prashant Rawat
