09-19-2013 02:01 PM - edited 03-18-2019 01:50 AM
Have a brand new TCS server I am trying to install
licenses are installed but it will will not accept web traffic.
I have turned off all of the firewall settings and I have checked in Services that the IIS server has started.
I did a little checking and it seems like it might be that it is asking for authentication but that never gets sent.
I followed everything in the install guides up to the certificate which I am not going to worry about.
what is missing?
09-19-2013 04:34 PM
What happens if you access it from the windows server part itself?
Either by accessing localhost, the ip or the dns name.
If you have configured a name, is it porperly set up in dns?
Please remember to rate helpful responses and identify helpful or correct answers.
09-19-2013 07:00 PM
Same error either web from pc or on the server itself:
HTTP Error 503. The service is unavailable.
dns is not resolving the name. could that be the problem?
09-20-2013 06:53 AM
Hey Richard,
I believe that you are hitting this bug:
https://tools.cisco.com/bugsearch/bug/CSCui51592
It is a known issue with the new TCS 6.0 software. In the bug details it will show you how you can resolve this issue! If you would like assistance with this fix I would recommend opened up a case with TAC so that we can assist you.
09-20-2013 09:08 AM
Chad,
That solved one problem and at least now I can get to the Web Page.
Now the problem is that when I log in as administrator, I get a Box on the Management Tab that says
Teh overview fior this server cannot be found.
Please go to the Server overview page
and there is a little box to click that just brings me back to the same page.
fustration level on this brand new box is starting to rise.
I am trying to open a TAC case, but that is also proving to be a fustration.
10-14-2013 02:08 AM
Hey Richard
I have the same problem as you... "The overview for this server cannot be found"
Do you have already a solution for this problem ?
10-14-2013 04:49 AM
Finally got corrected.
Problem was that the checksum key that Licensing originally generated was incorrect.
The TAC Licensing engineer had to generate a new one and also played around with some of the registry entries to get it working.
Open a case with Cisco Licensing to get it resolved.
10-14-2013 02:30 AM
I have also receive TCS 6.0 on the new Plattform UCS.
my server came fully installed only activate the WIN2008.
I don't have this problem.
I have other problem with direct playing stream via WMP ( I will open a new discussion about that)
Georg
