Telepresence SNMP v1
Graeme Kay
Is there anyway of updating the SNMP on codian / tandberg products? I believe as stardard these are SNMP v1, can they be updated to SNMP v3?
Any assistance is greatly appreciated.
GK
2 Accepted Solutions
Saurabh Gupta
Level 3
Level 3
Hi Graeme,
Hope you are doing well and remember me. I Still remember working with you on TAC Cases.
As far as SNMP is concerned, unfortunately, Tandberg MCU only Supports SNMP v1 currently. Although, VCS and TMS do support SNMPv3.
And you cannot upgrade SNMP from v1 to v3 in Codian products.
Hope it helps.
Saurabh
Small correction: TMS only supports SNMP v2.
Kjetil
Saurabh Gupta
Level 3
Level 3
Hi Graeme,
Hope it helps.
Saurabh
Kjetil
