07-30-2013 02:32 AM - edited 03-18-2019 01:32 AM
We are running TMSPE on TMS v. 13.2.1. After loading the schemas onto the TMS, I wanted to allocate these templates to the relevant groups.
I click the "Assign Templates" at the bottom of the "Configuration Templates" pane, the "Assign Templates" dialogue box appears, but does not populate as it should, after about 10 seconds the dialogue box disappears, leaving the Users page greyed out.
Is there anything I've missed, or is this a fault that should be logged to TAC?
Solved! Go to Solution.
07-30-2013 03:59 AM
Hi Paul,
Could you take a look at the TMSPE diagnostics page in TMS (Administrative Tools > Provisioning Extension Diagnostics) and see if all Status' are in green state? Also try to do the Cleanup on all services?
You could also take a look in the TMSPE database (with SQL Management Studio) and verify that the templates really are in that database.
It could also be a browser problem (I've seen some problems with IE previously), so try another browser as well.
If you still cannot assign templates after these checks (and a reboot of the TMS server as well), then I would recommend you to open a case with TAC.
Hope this helps,
Arne
07-30-2013 03:19 AM
Just to cover all bases, I take it you have actually created templates from the schemas?
/jens
Please rate replies and mark question(s) "answered" if applicable.
07-30-2013 03:35 AM
Yes, all created, and checked, the thing is the earlier versions are still there, and configured, but as soon as I try to add the new, they don't appear on the "Assign Templates" dialogue box, before it disappears:
07-30-2013 03:59 AM
Hi Paul,
Hope this helps,
Arne
07-30-2013 04:09 AM
Thanks Arne, went in via a Firefox and it worked a treat .... you live and learn!
07-30-2013 04:41 AM
Great! And thanks for the feedback
Br,
Arne
