03-20-2016 09:45 AM - edited 03-18-2019 05:43 AM
Hello Friends
I had a question about TX9000,During a conference meeting can i see my self in the screen as a small pictureI(PIP),How to achieve this。Best Regards
Donke xu
03-20-2016 05:55 PM
Template wide advanced parameter configured within the template on conductor, all participants would see a self view image - in active presence (filmstrip) it will be one of the small panels:
{"callAttributes":{"displaySelfView": true}}
You may want to test this out and see if it fits what you are trying to accomplish, it may not be exactly what you want as it will affect all video endpoints in the conference.
-Jonathan
03-20-2016 06:48 PM
HI Jonathan Robb
I can't found {"callAttributes":{"displaySelfView": true} ,
but i found ActivePresence Mode in Single-screen layout and Multiscreen layout
Is this a right way to solve this question?
Donke xu
03-20-2016 06:54 PM
copy the following line in that 'custom parameters' box at the bottom of your screen shot, check the box to enable it and save the template:
and try that out as a test.
-Jonathan
03-21-2016 10:25 AM
Hi Jonathan
I had do the test,I can see my self during the conference like this:
But i found Left right upside down
In 1 small screen we can see C area
In 2 small screen we can see B area
