Unable to share my laptop with a cable on Room Kit
bruno zenkri
Hi everyone!
I've got a strange issue on a webex room kit: when I connect laptops on the Cisco HDMI cable, the touch10 panel don't find the laptop. The HDMI input is set to laptop, on 1080p60. The cable is OK (I test it)), and when I connect a laptop, the second screen is recognized as CS-KIT...
Have you ever heard of this issue, and do you know how to fix it?
Thanks!
Bruno
PJMack
Level 7
Level 7
The HDMI cable that comes with the system is directional - do you have it hooked up correctly? Take a look at each end, one end says "Cisco" on it, the other does not. The laptop needs to be on the Cisco end, the other end in the codec, or it will not work.
5 Replies 5
You don't mention what software release you are running on your device.  Have you updated to the latest software release?
You also don't mention what your "laptop" device is, nor what sort of content you are trying to display.   There are issues with some devices which try to mark what they are displaying as HDCP content, and the codec will correctly disable the input when it detects HDCP content.
Currently the only endpoint that will display HDCP content locally is the Room55.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
The room kit runs under CE9.1 software. I tried with different laptops: native HDMI and Displayport with an adaptator.
I use an HDMI cable provided by Cisco.
Is there a way to disable HDCP on laptop?
PJMack
Level 7
Level 7
I didn't check this point... I will do it on site. Thanks!
Bruno.
Spoiler
Hi there!
Effectively, the HDMI cable was hooked in the wrong way...
Thanks for the support!
