VC from TC4.2.x to 5.x
ajmadriaga
When upgrading an endpoint from TC4.2.x to 5.x, will I need to apply a new license?
Jens Didriksen
Level 9
Level 9
Yes, you need a new release key for this upgrade.
Only minor upgrades can be done with current release key, i.e. 4.0 to 4.2 etc.
To obtain a new release key the end-point(s) must have a valid service contract in place, if this is the case then a new key can be obtained either through the licensing portal or you can get it from TAC.
/jens
Please rate replies and mark question(s) as "answered" if applicable.
Jens Didriksen
Level 9
Level 9
/jens
Tomonori Taniguchi
For new release key, you should... (instead of contact TAC, Cisco Global License team handle license relate case including new RK request for Endpoint).
