VCS equivalent of Calling Party Transformation Mask in the CUCM
I am trying to change the calling party ID using a VCS.  This can be done easily with a CUCM by creating a Route Pattern and using the "Calling Party Transformation Mask".  Does anyone know how to do this same thing via a VCS?
2 Accepted Solutions
gubadman
Level 3
Level 3
Hi Rachel,
This post might help - https://supportforums.cisco.com/thread/2128626 as it has some suggestions.
Guy
awinter2
Level 7
Level 7
Hi Rachel,
with the current VCS software (X7) you have two options, FindMe Source Rewrite and CPL-based static source rewrite.
FindMe Source rewrite is described in more detail in the VCS Administrator's guide.
For CPL-based static source rewrite, please check out the following forum post for more information:
https://supportforums.cisco.com/message/3711482#3711482
In the upcoming X8 software for the VCS, it will become possible to perform dynamic regex-based source rewrite through CPL, which adds a lot more flexibility.
gubadman
Level 3
Level 3
Hi Rachel,
Guy
Thank you both for your quick responses!  This was very helpful.
awinter2
Level 7
Level 7
Hi Rachel,
