08-30-2018 11:39 AM - edited 03-18-2019 02:19 PM
Greetings, we have a few WebEx room kit plus systems running version RoomOS 2018-07-12 9f2c038ae6 and when Speaker Track is set to On, and the camera zooms/ follows the speaker, the picture is far from HD quality. If I disable Speaker Track then the image quality is beautiful. Would this be a bug in the software or is that a limitation of the Speaker track feature? Many thanks!
09-01-2018 01:04 PM
09-04-2018 11:18 PM
It could be a motion/quality tradeoff if there is not enough bandwidth available. Higher motion / FPS on the same bandwidth will be a lower resolution than less motion at a higher resolution.
Please remember to mark helpful responses and to set your question as answered if appropriate.
