04-02-2024 11:00 PM
Hello everyone,
I've recently been tasked with managing the Cisco telephone system, and I'm currently in the process of familiarizing myself with it. I've encountered an issue regarding Route Patterns, as the title suggests.
The Route Pattern seems to be blocking certain numbers that shouldn't be blocked. Specifically, it's blocking a service hotline number starting with 00800xxxxxxxx. In our case, our colleagues need to dial a 0 before making external calls, so they dial 000800xxxxxxxx, which gets blocked by the Route Pattern +8![0-9#].
I've already gone through the documentation and am starting to grasp the concept of wildcards, but I'm still a bit perplexed in this particular case. Is there a way to adjust the Route Pattern to allow the mentioned number, or do I need to create a new Route Pattern for it?
Any assistance would be greatly appreciated.
Solved! Go to Solution.
04-02-2024 11:56 PM - edited 04-02-2024 11:57 PM
What happens with the leading zeroes "00"?
"00800..." needs to match a different pattern first, it cannot match "\+8..." as the first pattern, because "00" obviously doesn't start with a "+" sign.
My guess: the leading zeroes "00" are replaced with a "+" sign first, and then "+8..." matches your block pattern.
But it's hard to say, because every CUCM is configured differently and without a look on my own, or without logs it's just guessing and pointing to possible config parts.
04-02-2024 11:36 PM
What's the pattern therefore? And why is it blocking the call, if it maybe should be used for external calls? A route or translation pattern can be set to block the calls --> check the settings.
If you need to route everything starting with 0 to something external, you need a route pattern starting with "0".
E.g. "0.[1-9]!", "00.[1-9]!", or "000.[1-9]!" depending on different dialing habits.
04-02-2024 11:47 PM
Thank you for your reply, i really appreciate it.
\+8![0-9#] is supposed to block expensive service numbers here in germany (which it does just fine) but it blocks those 00800 numbers too (guess the one who made that pattern did not think of those numbers) and i was thinking best practice would be to alter that route-pattern so it wouldnt block those anymore.
we have multiple patterns with "0" and they SEEM to work fine.
04-03-2024 12:36 AM
First of all: thank you so much for leading me into the right direction.
You are absolutely right... the Translation Pattern 000.![0-9#] translated the 000800 into +800 which in turn matched the Routing-Pattern +8![0-9#] and is blocked.
I'll look into the translation-pattern 000.![0-9#] and see if i can make it work.
Thanks alot for your help.
04-03-2024 03:29 AM
If you want to allow specific destination patterns you’ll need to create a more specific match than the block pattern to let the call go through.
04-03-2024 12:00 AM
The pattern starting with "+" indicates that there is some E.164 transformation going on. That said, you could build a pattern that is more specific for service you do want to allow. I can't tell you exactly how to do it without seeing more of how user dialed digits are translated into E.164.
