Attendant consele advance problem
ozden ozdugun
Hi;
ı installed attadent console and call manager,and entegrated .when ı open attedant cllient on my pc ;ı couldn't call ,call forward ,call pick up vs
and only ı can open attedant console with my cti number not did number.and ı didn't install presence server
call manager versiyon 11.5
11 Replies 11
ozden ozdugun
this error on the screen
Hi Ozden,
Can you first check the config as per the CUAC standard Install and administration guide below
http://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/cucmac/cuacs/11_0_1/install_admin_guide/CUACS110101GUIDE.pdf
Manish
Hi Manish ,
I installed advanced attedant server and attedant console.and i was installing this , we look cuac advanced administration guide
The screenshot you attached was for CUAc standard, you can first verify the config as per the admin guide whether it is CUAC Standard or Advanced. If the issue persists then you can post the version of CUAC, screenshot of the error and the client logs.
Manish
Hi Manish
Call Manager version 11.5
CUAC versiyon advanced 11.0.1.10
there is no im & presence server in the system
there is no active directory in the system
IM&P is not mandatory if you do not need Presence capability, however rest of the config on cucm should be verified as per the following guide ( Deployment checklist is given on page 25 )
http://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/cucmac/cuaca/10_5_1/install_admin_guide/CUACA1051WAG.pdf
Manish
ı use this guide when installed.when ı set up client ,on the server thsi screen error
The error states the server cannot be contacted.
Probably you can try testing by installing the client on the CUAC server itself.
-Atul
when ı open advanced console on the server ,this screen
none of your CTI devices seem to be registered. Check the status on call manager once. If not registered then, you need to get them registered first.
check TSP config on the CUAC server.
-Atul
hi atul ;
my cti device register with subscriber call manager 1.
