call manager 12.5 8800 phone registration issue
Dino Carota
when changes are made to 8800phone they  will not fully register unless i  reset phone   on the phone it self   settings /admin settings /reset /reset all  this is speratic  and only happening at  our remote sites  also i noticed  can not do a bulk update to a group of phones  cluster just rebooted in sepetember  also that the time i first  started seing the registration issue
I believe there is a firewall in between. If true make sure if the SIP inspection is disabled.
Response Signature
You could also have trust list issues, possibly caused by expired certificates. Look at the the status messages on the phone gui and look for 'trust list update failed' type issues.
I would also check database replication. If you are issuing the reset from the Pub and the phone is registered to a Sub that is not fully in sync I can see what you are describing happening.
Maren
RachelGomez161999
Check for the Incorrect MAC Address on the Phone Label. Cisco CallManager and TFTP Services Do Not Run. Delete and Recreate a Phone. Understand a Network Trace File.
Rachel Gomez
