Can speed dials pause for additional digits?
kbeaton
Our Nortel phone system would allow speed dials like the following
91360
91425
Basically it would allow a speed dial for the first 5 digits and would allow the user to enter the additional 7 digits
Is there such a thinking available in Call Manager?
What I guess the user is askin is a speed dial with a number that pauses the dialing before sending the call to the VG the same way as an old PSTN access code (usually was 0 in EU or 9 in US).
You can achieve this by congifure a route pattern with let's say 91360.! as pattern.
Select discard digits, "pre dot" and select "offnet" as call classification
configure 91360 as speed dial destination .
After that press the speed dial button and you should hear a silence. Keep in mind that users have a limited  time to add extra digits defined in T302 timer Service Parameter which is 18 seconds by default.
Try it and let us know
Carlo
Please rate all helpful posts "The more you help the more you learn"
7 Replies 7
This is something that you could do with old SCCP phones that allow  to dial  a pstn access code. To achieve this with SIP endpoint I can suggest you to setup a call handler on Unity connection with a blank greeting and waits for 7 digits.
Be carefull to avoid to let that call handler to be rachable from outside to avoid toll fraud.
Carlo
b.winter
IIRC, this method only works for speed dials: put the number to be called, then add a comma "," and then the digits you wanna send via DTMF:
"<number to call>,<digits to dtmf dial>" => e.g "4000,1234"
Also check the following link:
https://community.cisco.com/t5/collaboration-knowledge-base/pause-in-speed-dial-cucm-9-x/ta-p/3150844
So the short answer is "Yes". Use a comma (or two) between numbers to insert pauses. The link that @Kaloyan Botev is the current information.
Maren
Let me double-check check I asked the question correctly.
The user wants 91360 as a speed dial and wants to enter the 7-digit phone number manually
For example they want do dial 913605551234.
(speed dial) 91360 (manually enter the 7 digits) 5551234
Will commas in the speed dial allow users to manually enter digits?
If the user should enter the digits manually, then you don't need a speed dial for that. Your question is not related to what you want then.
Just create a speed dial for 91360.
And when the call is connected, the user can send the digits during the call typing on the dial-pad.
Commas in the speed dial are there, to send the additional digits automatically.
Carlo
