CCM 6.1 Compatibility with Unity 4.x
asomanya
Does anyone know if CM 6.1 is compatible with Unity 4.0 Build 4.0(4)?, I have been looking for the compatibility matrix and cannot locate one on Cisco's site addressing this question.
Thanks.
2 Accepted Solutions
Jaime Valencia
just make sure you have the right TSP
SCCP Compatibility Matrix: Cisco Unity, the Cisco Unity-CM TSP, Cisco Unified CM, and Cisco Unified CM Express
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/compatibility/matrix/cutspmtx.html
javalenc
if this helps, please rate
java
Brandon Buffin
Yes, Unity 4.0(4) is supported with CM 6.1. Take a look at the following link.
Hope this helps. If so, please rate the post.
Brandon
Jaime Valencia
javalenc
java
Thanks considerably for the quick response.
Brandon Buffin
Brandon
