Cisco Expressway SSH tunnel failure for UC traversal zone
ragz3000
uniSSH tunnel status is failed however the UC traversal zone is active.
Below is the error message on expressway c
2020-02-04T17:01:44.444+11:00
portforwarding: Level="ERROR" Detail="Client control socket open failed" forwarding="localhost:8191:localhost:8192" user="_pfwd" host="expresswaye01.xyz.com.au" id="d21dfe99-4713-11ea-8b7b-005056010a53" retcode="255" err="ssh_x509store_cb: subject='C=AU,ST=Victoria,L=Richmond,O=xyz pvt Ltd,CN=expresswaye01.xyz.com.au', error 20 at 0 depth lookup:unable to get local issuer certificate
ssh_verify_cert: verify error, code=20, msg='unable to get local issuer certificate'
" UTCTime="2020-02-04 06:01:44,443"
2020-02-04T17:01:44.443+11:00ssh: Event="sshd" Module="openssh" Level="INFO" Detail="ssh_dispatch_run_fatal: Connection to 10.30.136.29 port 2222: invalid certificate" UTCTime="2020-02-04 06:01:44"
2020-02-04T17:01:44.441+11:00ssh: Event="sshd" Module="openssh" Level="INFO" Detail="RSA+cert host key for IP address '10.30.136.29' not in list of known hosts." UTCTime="2020-02-04 06:01:44"
2020-02-04T17:01:44.328+11:00portforwarding: Level="WARN" Event="Alarm Raised" Id="35013" UUID="a19a462a-cf7e-4b6f-b333-33b2e502ec0b" Severity="warning" Detail="Unified Communications SSH tunnel failure: This system cannot communicate with one or more remote hosts: expresswaye01.xyz.com.au" UTCTime="2020-02-04 06:01:44,327"
7 Replies 7
Adam Pawlowski
It appears to be upset that it’s a locally issued cert or doesn’t have the CA certificate in trust
The secure traversal test results success under UC traversal zone.
The zone status itself is Active.
I generated CSR from exp-c and have this signed by internal CA.
Downloaded signed server certificate and uploaded it to exp-c.
Also I uploaded CA root into Trusted CA certificate in both exp-c and exp-e.
Any more pointers to check will be helpful, thanks.
Hi,  Im having the same issue.  Have you made any progress with this?
HI
Just verify the CA confg as per the below link  nic video my Mr. Jamie
https://www.youtube.com/watch?v=FIqh3rSIUmA
and recreate certificate for both the server and check  and verfiy the FQDN created in local dns server  .
I have expressway-edge server certified by public CA. However I did not install those root certs onto the expressway-core server. Due to this exp-c was complaining about the certificate error. Once I uploaded the public root CAs on exp-c, issue resolved. hope this helps.
Have a look at this excellent document. It covers pretty much all things about certificates in Expressway.
https://www.cisco.com/c/en/us/support/docs/unified-communications/expressway/213872-configure-and-troubleshoot-collaboration.html
Response Signature
There's a note about using self signed certificates for things where I think you can't use them for everything in a MRA setup - I don't know off the top of my head where that point is.
You would have to look in the actual debug logging to see if it had a complaint about the certificate validation.
