09-24-2014 09:04 PM - edited 03-20-2019 06:09 AM
Dear Sr
It is possible to reduce the delay before Cisco Paging System (Informacast basic paging) start streaming to the phone. We are getting two seconds delay right now.
Version: 9.0.2
Alex
09-25-2014 10:47 PM
Are you using DialCast, you can setup delays under Dialcast - I would check there.
09-25-2014 11:35 PM
On the basic Informacast?
02-15-2018 08:09 AM
Did you ever figure out the issue? Our CUCM version is 11.5
Sometimes there is no audio delay, sometimes there is a 10+ second audio delay, and sometimes there is no audio at all. The phones also don't always get the signal from informacast to join the multicast group and start receiving the led blink and/or audio. It's very inconsistent.
06-29-2018 02:08 PM
Having same issues. Have opened a TAC case and got packet captures for them but they are not finding an issue but there is definitely something causing a random delay in the multicast. Please let me know if your were able to find root cause of this.
Thank you
10-01-2024 05:59 AM - edited 10-01-2024 05:59 AM
Our problem turned out to be an issue with SSDP multicasts flooding our switches. We put in a multicast group filter to filter out the SSDP using this command ip multicast group-range "access-list"
In the ACL we just deny 239.255.255.250, and allow any any for the second line of the ACL.
Hope this helps someone.
