CME with Asa Proxy Phone
jfernandorosa
Hi friends,
I'm configuring a CME in order to use ASA phone proxy and I am not finding any guides to configure, does any one could help me ?
7 Replies 7
testeven
Hi!
I believe this is what you are looking for:
https://www.myciscocommunity.com/docs/DOC-10763
The document provides a step-by-step configuration guide for setting up Cisco ASA Phone Proxy& CME.
HTH,
Teresa.
If it helps, please rate
Regards, Tere. If you find this post helpful, please rate! :)
hI Teresa
Do you have a working link for this setup
shameer
Hi Mohamed,
I see the document was deleted, which is weird. Please provide your CCO id and mail and let me see if I can get this doc for you.
Tere.
Hi Teresa
Thank for your reply.
I'm trying to accomplish this remote SSL ipphone with ASA & CME but getting authentication error as soon as I entered user/pass on ipphone VPN config. SSL web Vpn is working fine from the PC. But not authenticating on ipphone for some reason.
So need a proper document for troubleshooting.
My Cisco id - sharose123
Email - shameer.fareed@unificomms.com
Thanks for your help
Shameer
Sent from my HTC
What firmware you are using. Minimum firmware n phone should be 9.0 or later.
Also what Phone you are using.
Other requirement and configuration example are given in below link
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmevpn.html
Ronak patel
Plese rate helpful posts.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Hi Tere/Patel
Thank you very much for your support
I've managed to fix it.
It's working fine.
shameer
Hello Teresa, would you  be able to share the document with me to set up a vpn phone. Thanks...
