Showing results forĀ
Search instead forĀ
Did you mean:Ā
CUAC - Contact Issue with Number
drbabbers
Level 3
Level 3
I have an odd issue whereby we have 1 of 2 operators using CUAC 10.5.2.2804 and on 1 of the consoles, when 1 particular contact is looked up in the directory it is showing an invalid number. The other operator doesn't experience this issue.
The CUAC is setup to sync from CUCM and this is working all OK. On the CUAC + CUCM servers I can see the contact with the correct number. The issue is only with this 1 operator.
Any ideas?
D
drbabbers
Level 3
Level 3
Any idea on this one guys?
D
Try logging in the CUAC client console on a different PC with the operators credentials.
Also check if the client console has the database connected after log in. (check the attachment)
Ankoor Bek
I will try your 1st point, but oddly enough I have another case of this reported for the exact same issue, but it impacts all operator consoles!
I will also check the client console is connected to the db.
D
