CUCM 11.5 with AD 2016?
rfrome
HI,
Wondering if CUCm 11.5 will intigrate with AD 2016? All the docs and release notes still show only 2012R2. Hoping that the documentation teams are lagging behind.
thanks,
rob
Slavik Bialik
Level 7
Level 7
A simple question... did you try and got an error?
I would try first. I can't see any reason why it won't work. Most probably the documents are not well updated to have this information about AD 2016.
Jaime Valencia
Haven't heard anything about support on anything below 12, see page 59
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/rel_notes/12_0_1/cucm_b_release-notes-for-cucm-imp-1201.pdf
java
if this helps, please rate
Has there been any update on this in the last year??
No, answer remains the same, AD 2016 is supported on CUCM 12.x+ only
java
