CUCM install with data import using different hostname and domain
HusseinLTD
I have CUCM 12.5, IMP 12.5, CUC 12.5 & CCX 12.0.
I'm planning to do fresh install with data import for CUCM, IMP & CUC but I need to have the new installs to be on different IPs, hostnames & domain.
is this doable?
I previously have done "install with data import" using the same IPs, hostnames and domain, but not sure if I can do it with different IP and domain.
if it's doable, is there anything additional I need to do? like in CUC do I need to change any of the configuration manually after the install?
b.winter
Have you checked the corresponding documents?
I don't see anything mentioned about that.
I checked and no mention for changing domain, the only thing mentioned is changing IP and hostname
