CUPS 8.6(4)SU1 Upgrade seems to hang...
perrymcgrew
Trying to upgrade my CUPS PUB & SUB from 8.6.4.10000-28 to 8.6.4.11900--1 (both under current VM ESXi 5).   MD5sum'd verified ISO then estacted it to DVD, mounted DVD to to VM and did the Upgrade (no reboot / switch) starting with CUP Pub.  Watched the log and it seems to have finished - DVD ejected etc.  But the OS Admin GUI still says it is running.  Went over the the SUB and repeated the process and it is doing the same thing.  Have a TAC case open since Friday but engineer only asked if I verified the md5 hash - and he is probably off for the weekend.  I would really like to have the system upgraded before Monday.  Is it safe to do the switch and reboot startoing with the PUB?  I am attaching the last part of the log I copied from the OS Admin window....
Thx -- Perry
14:46:32 post_upgrade|========================= Upgrade complete. Awaiting switch to version. =========================|<LVL::Info>
09/07/2012 14:46:32 upgrade_manager.sh|Post-upgrade processing complete|<LVL::Info>
09/07/2012 14:46:32 upgrade_manager.sh|Application install on inactive partition complete|<LVL::Info>
09/07/2012 14:46:32 upgrade_manager.sh|Upgrade complete|<LVL::Info>
09/07/2012 14:46:32 upgrade_manager.sh|Final exit processing with result 0|<LVL::Info>
09/07/2012 14:46:32 upgrade_manager.sh|Calling /common/download/8.6.4.11900-1/Cisco/bin/prepare_grub --phase L2 --action update --basepath /mnt/source/Cisco --active_part /partB --logfile /common/log/install/capture.txt|<LVL::Debug>
09/07/2012 14:46:33 upgrade_manager.sh|(CAPTURE) [12/09/07_14:46:32] prepare_grub: Preparing grub for phase: l2!|<LVL::Debug>
09/07/2012 14:46:33 upgrade_manager.sh|(CAPTURE) [12/09/07_14:46:32] prepare_grub: Setting up GRUB for l2 for update action|<LVL::Debug>
09/07/2012 14:46:33 upgrade_manager.sh|(CAPTURE) [12/09/07_14:46:32] prepare_grub: Checking for serial-console |<LVL::Debug>
09/07/2012 14:46:33 upgrade_manager.sh|(CAPTURE) [12/09/07_14:46:32] prepare_grub: Checking for product specific hpet setting|<LVL::Debug>
09/07/2012 14:46:33 upgrade_manager.sh|(CAPTURE) [12/09/07_14:46:33] prepare_grub: Checking platform type for kernel arg.|<LVL::Debug>
09/07/2012 14:46:33 upgrade_manager.sh|(CAPTURE) [12/09/07_14:46:33] prepare_grub: Detected HWModel=VMware|<LVL::Debug>
09/07/2012 14:46:33 upgrade_manager.sh|(CAPTURE) [12/09/07_14:46:33] prepare_grub: Set kernel parm for platform as: clock=pmtmr divider=4|<LVL::Debug>
09/07/2012 14:46:33 upgrade_manager.sh|(CAPTURE) [12/09/07_14:46:33] prepare_grub: Set kernel parm: enforcing=0|<LVL::Debug>
09/07/2012 14:46:33 upgrade_manager.sh|(CAPTURE) [12/09/07_14:46:33] prepare_grub: Adding kernel-param:  clock=pmtmr divider=4 enforcing=0|<LVL::Debug>
09/07/2012 14:46:33 upgrade_manager.sh|IOWAIT monitor stopped|<LVL::Info>
09/07/2012 14:46:33 upgrade_manager.sh|Exit processing with result 0|<LVL::Info>
09/07/2012 14:46:34 preflight|Starting preflight|<LVL::Info>
09/07/2012 14:46:34 preflight|Validate preflight data|<LVL::Info>
09/07/2012 14:46:34 preflight|Preflight data validation complete|<LVL::Info>
09/07/2012 14:46:34 preflight|Determine upgrade type|<LVL::Info>
09/07/2012 14:46:34 preflight|Active RH version = 5Server|<LVL::Debug>
09/07/2012 14:46:34 preflight|New os version(xml) = 5Server|<LVL::Debug>
09/07/2012 14:46:34 preflight|Upgrade type = L2|<LVL::Debug>
09/07/2012 14:46:34 preflight|Obtain product type|<LVL::Info>
09/07/2012 14:46:34 preflight|Obtained product type CallManager|<LVL::Info>
09/07/2012 14:46:34 preflight|Processing preflight cleanup mode|<LVL::Info>
09/07/2012 14:46:34 preflight|Clear preflight cancel utility|<LVL::Info>
09/07/2012 14:46:34 preflight|Removing /common/cancel_upgrade/preflight_cancel|<LVL::Debug>
09/07/2012 14:46:34 preflight|Execute cleanup preflight commands for CallManager:L2 from /mnt/source/Cisco/install/preflight.xml|<LVL::Info>
09/07/2012 14:46:34 preflight|Found 7 preflight commands to execute|<LVL::Debug>
09/07/2012 14:46:34 preflight|Execute preflight command (1/7): rm -rf /usr/local/platform/conf/dynamicConfig.xml|<LVL::Debug>
09/07/2012 14:46:34 preflight|Preflight command returns 0|<LVL::Debug>
09/07/2012 14:46:34 preflight|Execute preflight command (2/7): cp -f /common/preflight/CM/L2/dynamicConfig.xml /usr/local/platform/conf/dynamicConfig.xml|<LVL::Debug>
09/07/2012 14:46:34 preflight|Preflight command returns 1|<LVL::Debug>
09/07/2012 14:46:34 preflight|(CAPTURE) cp: cannot stat `/common/preflight/CM/L2/dynamicConfig.xml': No such file or directory|<LVL::Debug>
09/07/2012 14:46:34 preflight|Preflight command did not complete (1). Continuing command processing...|<LVL::Warn>
09/07/2012 14:46:34 preflight|Execute preflight command (3/7): rm -rf /usr/local/thirdparty/jakarta-tomcat/webapps/cmplatform/WEB-INF/pages/install/dynamic.jsp|<LVL::Debug>
09/07/2012 14:46:34 preflight|Execute preflight command (4/7): cp -f /common/preflight/CM/L2/dynamic.jsp /usr/local/thirdparty/jakarta-tomcat/webapps/cmplatform/WEB-INF/pages/install/dynamic.jsp|<LVL::Debug>
09/07/2012 14:46:34 preflight|(CAPTURE) cp: cannot stat `/common/preflight/CM/L2/dynamic.jsp': No such file or directory|<LVL::Debug>
09/07/2012 14:46:34 preflight|Execute preflight command (5/7): rm -rf /usr/local/thirdparty/jakarta-tomcat/webapps/cmplatform/WEB-INF/pages/install/install-confirm-content.jsp|<LVL::Debug>
09/07/2012 14:46:35 preflight|Execute preflight command (6/7): cp -f /common/preflight/CM/L2/install-confirm-content.jsp /usr/local/thirdparty/jakarta-tomcat/webapps/cmplatform/WEB-INF/pages/install/install-confirm-content.jsp|<LVL::Debug>
09/07/2012 14:46:35 preflight|Preflight command returns 1|<LVL::Debug>
09/07/2012 14:46:35 preflight|(CAPTURE) cp: cannot stat `/common/preflight/CM/L2/install-confirm-content.jsp': No such file or directory|<LVL::Debug>
09/07/2012 14:46:35 preflight|Preflight command did not complete (1). Continuing command processing...|<LVL::Warn>
09/07/2012 14:46:35 preflight|Execute preflight command (7/7): rm -rf /common/preflight/CM/L2|<LVL::Debug>
09/07/2012 14:46:35 preflight|Preflight command returns 0|<LVL::Debug>
09/07/2012 14:46:35 upgrade_manager.sh|Cleanup RAM disk|<LVL::Info>
09/07/2012 14:46:35 upgrade_manager.sh|Unmount /common/mnt/product_img|<LVL::Debug>
09/07/2012 14:46:35 upgrade_manager.sh|Cleanup mounted DVD or ISO|<LVL::Info>
09/07/2012 14:46:35 upgrade_manager.sh|Found mount point "/mnt/source" for source filesystem /dev/hdc|<LVL::Debug>
09/07/2012 14:46:35 upgrade_manager.sh|Unmount /mnt/source|<LVL::Debug>
09/07/2012 14:46:35 upgrade_manager.sh|Ejecting DVD (/dev/hdc)|<LVL::Debug>
09/07/2012 14:46:38 upgrade_manager.sh|Refresh CLI product properties cache|<LVL::Info>
09/07/2012 14:46:38 upgrade_manager.sh|Refresh hardware cache|<LVL::Info>
09/07/2012 14:46:38 ServerApiManager|INITIALIZE: sam_legacy_mode_init=1|<LVL::Debug>
09/07/2012 14:46:42 ServerApiManager|INITIALIZE: sam_hssi_mode_init=0|<LVL::Debug>
09/07/2012 14:46:47 upgrade_manager.sh|Cleanup exiting - Cached Data: [Vendor= VMware, Inc.
HWModel=VMware
CPUCount=1
CPUType= Intel(R) Xeon(R) CPU E5-2690 0 @ 2.90GHz
CPUSpeed=2900
MEMSize=4096
BIOSVer=PhoenixTechnologiesLTD 6.00 09/21/2011
ObjectId=1.3.6.1.4.1.9.1.1348
OSVersion=UCOS 5.0.0.0-2
SerialNumber= VMware-42 37 e4 c8 ec e5 0b f1-77 9f 5e 9a e0 71 dd 38
VendorOID=1.3.6.1.4.1.674]|<LVL::Info>
09/07/2012 14:46:48 upgrade_install.sh|Process interface file|<LVL::Info>
09/07/2012 14:46:48 upgrade_install.sh|switch=no|<LVL::Debug>
09/07/2012 14:46:48 upgrade_install.sh|notify_clm=yes|<LVL::Debug>
09/07/2012 14:46:48 upgrade_install.sh|Process interface file complete|<LVL::Info>
09/07/2012 14:46:48 upgrade_install.sh|Upgrade manager complete|<LVL::Info>
09/07/2012 14:46:48 upgrade_install.sh|System upgrade complete|<LVL::Info>
09/07/2012 14:46:48 upgrade_install.sh|Cleaning up download...|<LVL::Info>
09/07/2012 14:46:48 upgrade_install.sh|Cleanup upgrade source area.|<LVL::Info>
09/07/2012 14:46:48 upgrade_install.sh|Ejecting DVD (/dev/sda2)|<LVL::Debug>
09/07/2012 14:46:48 upgrade_install.sh|Removing /common/download/8.6.4.11900-1|<LVL::Info>
09/07/2012 14:46:49 upgrade_install.sh|Started auditd...|<LVL::Info>
09/07/2012 14:46:50 upgrade_install.sh|Started setroubleshoot...|<LVL::Info>
09/07/2012 14:46:50 upgrade_install.sh|Changed selinux mode to enforcing|<LVL::Info>
09/07/2012 14:46:50 upgrade_install.sh|No switch to new version|<LVL::Info>
09/07/2012 14:46:50 upgrade_install.sh|IOWAIT monitor stopped|<LVL::Info>
09/07/2012 14:46:52 upgrade_install.sh|Initiated cluster manager to send updated publisher data to subscribers|<LVL::Info>
09/07/2012 14:46:52 upgrade_install.sh|Upgrade Complete -- (0)|<LVL::Info>
09/07/2012 14:46:52 upgrade_install.sh|set_upgrade_result: set to 1|<LVL::Debug>
09/07/2012 14:46:52 upgrade_install.sh|is_upgrade_lock_available: Upgrade lock is not available.|<LVL::Debug>
09/07/2012 14:46:52 upgrade_install.sh|is_upgrade_in_progress: Already locked by this process (pid: 12855).|<LVL::Debug>
09/07/2012 14:46:52 upgrade_install.sh|release_upgrade_lock: Releasing lock (pid: 12855)|<LVL::Debug>
11 Replies 11
perrymcgrew
TAC engineer finally contacted me.  He thought the upgrade went.  Switched version to 8.6.4.11900--1 and it hung. Reverted back ... bit have been having issues with my Jabber clients ever since. Now he seems to think that it is because it is running under VM on DL380-G8 servers even though 8.6.4.10000-28 ran fine.
Has anyone done this upgarde or running this release under a VM?
TIA
What kind of issues are you seeing?
pxrondin
I am exactly in the same situation upgrade from 8.6.4.10000-28 to 8.6.4.11900--1 and the last logging message during the installation is the same than you
Its a fresh installation
I have shutdown my server and retry the update .
I will see tomorrow morning if it has been successfull.
If no I will open a TAC Case
I have installed my CUPS on UCS C210M2 , ESXi 5.0
PR
Hi, did you get it working? I am getting the same error when trying to upgrade from 8.6.2.20000-2 to 8.6.2a SU2. I even tried 8.6.2a SU1.I was suspecting it was something to do with licensing maybe but have not logged a tac case yet. Have uploaded the cop file due to no particular reason but I am still having the problem. The cucm is running on a VM created via the OVA template so the server sizing is correct as well.
Nope.  I had a TAC case opened as well.  They went ahead and closed it w/o permission!  I complained and they have reopened the case.  But I have not heard from the new Engineer.
Same thing for me, I had opened a TAC Case and I got a lot of basic questions from the TAC Engineer ( Sometimes I wondered if I was a stupid guy )
At the End he told me to try to shutdown the system, then reload it and then to try a switch version .
It has been successfull.
It seems that this problem is due to a TomCat problem at the end of the upgrade process when the display screen has to be updated to indicate that the upgrade has been successfull.
I have configured Jabber on 2 PC  and all was working fine
Hi Perry,
Did you ever get this resolved? We are stuck pretty much at the same point when updating our cluster from 8.6(4) to 8.6(4)SU2.
Your help is greatly appreciated
/David
Unfortunately no.  We have been playing a bit of phone tag, but it seems lately that TAC is not doing a good job matching tech's workday hours with my schedule -- which I include in all my TAC cases.
Right now, we are holding up mass deployment of Jabber --- 9.1.x Jabber for Windows clients are proving to be prone to crashing.  Getting many complaints from existing users and have sent in 3 Jabber crash dumps just this week.  They attached a bug ID and I have been told it will be fixed in 9.1.3 -- which is months away!  Official WIndows 8 support is also not coming for several months either.
I am still looking to push this case to a resolution...we are examining version 9 Call Manager which as you may know, folds CUPS into the Call Manager.  The way Cisco is attacking my current case, we may be at v9 before they resolve this one!
Perry
I seem to be having the same issue on this is with CUCM. I cantr upgrade my subscriber to 8.6.2. 22900-9 from 8.6.2.20000-2
Has anyone found a solution yet.
Ive had to downgrade my Pub for the time being.
Thanks in advance
see extract of install logs below.
.22900-9.sgn.iso" reboot="no" signed="yes"/>|<:DEBUG>
01/24/2012 18:41:39 file_list.sh|(CAPTURE) |<:DEBUG>
01/24/2012 18:41:39 file_list.sh|success|<:INFO>
01/24/2012 18:41:39 file_list.sh|file_list.sh complete (rc=0)|<:INFO>
01/24/2012 18:41:39 file_list.sh|set_upgrade_result: set to 1|<:DEBUG>
01/24/2012 18:41:39 file_list.sh|is_upgrade_lock_available: Upgrade lock is not available.|<:DEBUG>
01/24/2012 18:41:39 file_list.sh|is_upgrade_in_progress: Already locked by this process (pid: 2521).|<:DEBUG>
01/24/2012 18:41:39 file_list.sh|release_upgrade_lock: Releasing lock (pid: 2521)|<:DEBUG>
01/24/2012 18:41:43 upgrade_validate_file.sh|Starting upgrade_validate_file.sh|<:INFO>
01/24/2012 18:41:43 upgrade_validate_file.sh|Parse argument method=local_dvd|<:DEBUG>
01/24/2012 18:41:43 upgrade_validate_file.sh|Parse argument source_dir=/|<:DEBUG>
01/24/2012 18:41:43 upgrade_validate_file.sh|Parse argument file_name=UCSInstall_UCOS_8.6.2.22900-9.sgn.iso|<:DEBUG>
01/24/2012 18:41:43 upgrade_validate_file.sh|Parse argument file_type=patch|<:DEBUG>
01/24/2012 18:41:43 upgrade_validate_file.sh|Parse argument file_signed=yes|<:DEBUG>
01/24/2012 18:41:43 upgrade_validate_file.sh|is_upgrade_lock_available: Upgrade lock is available.|<:DEBUG>
01/24/2012 18:41:43 upgrade_validate_file.sh|is_upgrade_result_available: Result is not available|<:DEBUG>
01/24/2012 18:41:43 upgrade_validate_file.sh|acquire_upgrade_lock: Lock is free, creating lock (pid: 5602)|<:DEBUG>
01/24/2012 18:41:43 upgrade_validate_file.sh|Process local CD/DVD request|<:INFO>
01/24/2012 18:41:43 upgrade_validate_file.sh|Unmount DVD|<:INFO>
01/24/2012 18:41:43 upgrade_validate_file.sh|Mount /dev/cdrom on /mnt/source|<:DEBUG>
01/24/2012 18:41:43 upgrade_validate_file.sh|Get patch size from /mnt/source|<:DEBUG>
01/24/2012 18:41:43 upgrade_validate_file.sh|patch size is 4819527680|<:DEBUG>
01/24/2012 18:41:43 upgrade_validate_file.sh|Check free space|<:INFO>
01/24/2012 18:41:44 upgrade_validate_file.sh|(CAPTURE) Free space: 41965490176, Needed space: 4819527680|<:DEBUG>
01/24/2012 18:41:44 upgrade_validate_file.sh|There is enough space on device to proceed.|<:INFO>
01/24/2012 18:41:44 upgrade_validate_file.sh|Validate isofilename exists on /mnt/source|<:DEBUG>
01/24/2012 18:41:44 upgrade_validate_file.sh|Validate checksum_file exists on /mnt/source|<:DEBUG>
01/24/2012 18:41:44 upgrade_validate_file.sh|Local CD/DVD request complete|<:INFO>
01/24/2012 18:41:44 upgrade_validate_file.sh|success|<:INFO>
01/24/2012 18:41:44 upgrade_validate_file.sh|upgrade_validate_file.sh complete (rc=0)|<:INFO>
01/24/2012 18:41:44 upgrade_validate_file.sh|set_upgrade_result: set to 1|<:DEBUG>
01/24/2012 18:41:44 upgrade_validate_file.sh|is_upgrade_lock_available: Upgrade lock is not available.|<:DEBUG>
01/24/2012 18:41:44 upgrade_validate_file.sh|is_upgrade_in_progress: Already locked by this process (pid: 5602).|<:DEBUG>
01/24/2012 18:41:44 upgrade_validate_file.sh|release_upgrade_lock: Releasing lock (pid: 5602)|<:DEBUG>
01/24/2012 18:41:44 upgrade_validate_file.sh|Unmount DVD|<:INFO>
01/24/2012 18:41:46 upgrade_get_file.sh|Starting upgrade_get_file.sh|<:INFO>
01/24/2012 18:41:46 upgrade_get_file.sh|Parse argument method=local_dvd|<:DEBUG>
01/24/2012 18:41:46 upgrade_get_file.sh|Parse argument source_dir=/|<:DEBUG>
01/24/2012 18:41:46 upgrade_get_file.sh|Parse argument file_name=UCSInstall_UCOS_8.6.2.22900-9.sgn.iso|<:DEBUG>
01/24/2012 18:41:46 upgrade_get_file.sh|Parse argument dest_dir=/common/download/|<:DEBUG>
01/24/2012 18:41:46 upgrade_get_file.sh|Parse argument version=8.6.2.22900-9|<:DEBUG>
01/24/2012 18:41:46 upgrade_get_file.sh|Parse argument file_type=patch|<:DEBUG>
01/24/2012 18:41:46 upgrade_get_file.sh|Parse argument file_signed=yes|<:DEBUG>
01/24/2012 18:41:46 upgrade_get_file.sh|is_upgrade_lock_available: Upgrade lock is available.|<:DEBUG>
01/24/2012 18:41:46 upgrade_get_file.sh|is_upgrade_result_available: Result is not available|<:DEBUG>
01/24/2012 18:41:46 upgrade_get_file.sh|acquire_upgrade_lock: Lock is free, creating lock (pid: 6628)|<:DEBUG>
01/24/2012 18:41:47 upgrade_get_file.sh|Process local CD/DVD request|<:INFO>
01/24/2012 18:41:47 upgrade_get_file.sh|src_file=/mnt/source//UCSInstall_UCOS_8.6.2.22900-9.sgn.iso, dest_file=/common/download/UCSInstall_UCOS_8.6.2.22900-9.sgn.iso, file_type=patch|<:DEBUG>
01/24/2012 18:41:47 upgrade_get_file.sh|Unmounting /mnt/source incase it is mounted|<:DEBUG>
01/24/2012 18:41:47 upgrade_get_file.sh|Mount /dev/cdrom on /mnt/source|<:DEBUG>
01/24/2012 18:41:47 upgrade_get_file.sh|Local CD/DVD request complete|<:INFO>
01/24/2012 18:41:47 upgrade_get_file.sh|Download of iso file RTMTStart|<:NOTICE>
01/24/2012 18:41:47 upgrade_get_file.sh|Create md5 "/common/download/UCSInstall_UCOS_8.6.2.22900-9.sgn.iso.md5"|<:INFO>
01/24/2012 18:41:47 upgrade_get_file.sh|Create md5 complete|<:INFO>
01/24/2012 18:41:47 upgrade_get_file.sh|Authenticate file "/common/download/8.6.2.22900-9/checksum_file.sgn"|<:INFO>
01/24/2012 18:41:47 upgrade_get_file.sh|File authentication complete|<:DEBUG>
01/24/2012 18:41:47 upgrade_get_file.sh|New Upgrade Software; returning|<:INFO>
01/24/2012 18:41:47 upgrade_get_file.sh|Download of iso file RTMTFinish|<:NOTICE>
01/24/2012 18:41:47 upgrade_get_file.sh|Process preflight|<:INFO>
01/24/2012 18:41:47 upgrade_get_file.sh|Checking for preflight script|<:DEBUG>
01/24/2012 18:41:47 upgrade_get_file.sh|Executing preflight /mnt/source/Cisco/install/bin/preflight isolocation=/mnt/source|<:INFO>
01/24/2012 18:41:47 preflight|Starting preflight|<:INFO>
01/24/2012 18:41:47 preflight|Validate preflight data|<:INFO>
01/24/2012 18:41:47 preflight|Preflight data validation complete|<:INFO>
01/24/2012 18:41:47 preflight|Determine upgrade type|<:INFO>
01/24/2012 18:41:47 preflight|Active RH version = 5Server|<:DEBUG>
01/24/2012 18:41:47 preflight|New os version(xml) = 5Server|<:DEBUG>
01/24/2012 18:41:47 preflight|Upgrade type = L2|<:DEBUG>
01/24/2012 18:41:47 preflight|Obtain product type|<:INFO>
01/24/2012 18:41:48 preflight|Obtained product type CallManager|<:INFO>
01/24/2012 18:41:48 preflight|Processing preflight install mode|<:INFO>
01/24/2012 18:41:48 preflight|Set preflight cancel utility|<:INFO>
01/24/2012 18:41:48 preflight|Execute install preflight commands for CallManager:L2 from /mnt/source/Cisco/install/preflight.xml|<:INFO>
01/24/2012 18:41:48 preflight|Found 10 preflight commands to execute|<:DEBUG>
01/24/2012 18:41:48 preflight|Execute preflight command (1/10): mkdir -p /common/preflight/CM/L2|<:DEBUG>
01/24/2012 18:41:48 preflight|Execute preflight command (2/10): cp -f /usr/local/platform/conf/dynamicConfig.xml /common/preflight/CM/L2/dynamicConfig.xml|<:DEBUG>
01/24/2012 18:41:48 preflight|Preflight command returns 1|<:DEBUG>
01/24/2012 18:41:48 preflight|(CAPTURE) cp: cannot stat `/usr/local/platform/conf/dynamicConfig.xml': No such file or directory|<:DEBUG>
01/24/2012 18:41:48 preflight|Preflight command did not complete (1). Continuing command processing...|<:WARN>
01/24/2012 18:41:48 preflight|Execute preflight command (3/10): cp -f /usr/local/thirdparty/jakarta-tomcat/webapps/cmplatform/WEB-INF/pages/install/dynamic.jsp /common/preflight/CM/L2/dynamic.jsp|<:DEBUG>
01/24/2012 18:41:48 preflight|Preflight command returns 0|<:DEBUG>
01/24/2012 18:41:48 preflight|Execute preflight command (4/10): cp -f /usr/local/thirdparty/jakarta-tomcat/webapps/cmplatform/WEB-INF/pages/install/install-confirm-content.jsp /common/preflight/CM/L2/install-confirm-content.jsp|<:DEBUG>
01/24/2012 18:41:49 preflight|Execute preflight command (5/10): cp -f /mnt/source/Cisco/install/dynamicConfig_L2.xml /usr/local/platform/conf/dynamicConfig.xml|<:DEBUG>
01/24/2012 18:41:49 preflight|Preflight command returns 0|<:DEBUG>
01/24/2012 18:41:49 preflight|Execute preflight command (6/10): mkdir -p /usr/local/thirdparty/jakarta-tomcat/webapps/cmplatform/WEB-INF/pages/install|<:DEBUG>
01/24/2012 18:41:49 preflight|Execute preflight command (7/10): cp -f /mnt/source/Cisco/install/dynamic_L2.jsp /usr/local/thirdparty/jakarta-tomcat/webapps/cmplatform/WEB-INF/pages/install/dynamic.jsp|<:DEBUG>
01/24/2012 18:41:49 preflight|Execute preflight command (8/10): cp -f /mnt/source/Cisco/install/install-confirm-content_L2.jsp /usr/local/thirdparty/jakarta-tomcat/webapps/cmplatform/WEB-INF/pages/install/install-confirm-content.jsp|<:DEBUG>
01/24/2012 18:41:49 preflight|Execute preflight command (9/10): /mnt/source/Cisco/install/bin/tempDynamic.preflight /mnt/source/Cisco/install/dynamic_L2.jsp dynamic.jsp|<:DEBUG>
01/24/2012 18:41:49 preflight|(CAPTURE) 01/24/2012 18:41:49  starting tempDynamic.preflight...|<:DEBUG>
01/24/2012 18:41:49 preflight|(CAPTURE) 01/24/2012 18:41:49  Source dir/file = /mnt/source/Cisco/install/dynamic_L2.jsp|<:DEBUG>
01/24/2012 18:41:49 preflight|(CAPTURE) 01/24/2012 18:41:49  Destination file name = dynamic.jsp|<:DEBUG>
01/24/2012 18:41:49 preflight|(CAPTURE) 01/24/2012 18:41:49  Copying /mnt/source/Cisco/install/dynamic_L2.jsp to /usr/local/thirdparty/jakarta-tomcat/temp/2-cmplatform/WEB-INF/pages/install/dynamic.jsp|<:DEBUG>
01/24/2012 18:41:49 preflight|(CAPTURE) 01/24/2012 18:41:49  added/replaced /usr/local/thirdparty/jakarta-tomcat/temp/2-cmplatform/WEB-INF/pages/install/dynamic.jsp successfully|<:DEBUG>
01/24/2012 18:41:49 preflight|(CAPTURE) 01/24/2012 18:41:49  ... tempDynamic.preflight completed|<:DEBUG>
01/24/2012 18:41:49 preflight|Execute preflight command (10/10): /mnt/source/Cisco/install/bin/tempDynamic.preflight /mnt/source/Cisco/install/install-confirm-content_L2.jsp install-confirm-content.jsp|<:DEBUG>
01/24/2012 18:41:49 preflight|(CAPTURE) 01/24/2012 18:41:49  Source dir/file = /mnt/source/Cisco/install/install-confirm-content_L2.jsp|<:DEBUG>
01/24/2012 18:41:49 preflight|(CAPTURE) 01/24/2012 18:41:49  Destination file name = install-confirm-content.jsp|<:DEBUG>
01/24/2012 18:41:49 preflight|(CAPTURE) 01/24/2012 18:41:49  Copying /mnt/source/Cisco/install/install-confirm-content_L2.jsp to /usr/local/thirdparty/jakarta-tomcat/temp/2-cmplatform/WEB-INF/pages/install/install-confirm-content.jsp|<:DEBUG>
01/24/2012 18:41:49 preflight|(CAPTURE) 01/24/2012 18:41:49  added/replaced /usr/local/thirdparty/jakarta-tomcat/temp/2-cmplatform/WEB-INF/pages/install/install-confirm-content.jsp successfully|<:DEBUG>
01/24/2012 18:41:49 preflight|Exiting with result 0|<:INFO>
01/24/2012 18:41:49 upgrade_get_file.sh|preflight returns 0|<:DEBUG>
01/24/2012 18:41:49 upgrade_get_file.sh|Preflight completed successfully|<:INFO>
01/24/2012 18:41:50 upgrade_get_file.sh|success|<:INFO>
01/24/2012 18:41:50 upgrade_get_file.sh|upgrade_get_file.sh complete (rc=0)|<:INFO>
01/24/2012 18:41:50 upgrade_get_file.sh|set_upgrade_result: set to 1|<:DEBUG>
01/24/2012 18:41:50 upgrade_get_file.sh|is_upgrade_lock_available: Upgrade lock is not available.|<:DEBUG>
01/24/2012 18:41:50 upgrade_get_file.sh|is_upgrade_in_progress: Already locked by this process (pid: 6628).|<:DEBUG>
01/24/2012 18:41:50 upgrade_get_file.sh|release_upgrade_lock: Releasing lock (pid: 6628)|<:DEBUG>
01/24/2012 18:42:09 sd_cancelInstall.sh|Pre-upgrade cancel/clean-up initiated
01/24/2012 18:42:09 sd_cancelInstall.sh|Canceling active side processes
01/24/2012 18:42:09 sd_cancelInstall.sh|Canceling active side processes done
01/24/2012 18:42:09 sd_cancelInstall.sh|Canceling inactive side processes
01/24/2012 18:42:09 sd_cancelInstall.sh|This is not a COP, so will do IDS shared memory clean up if needed on inactive partition
01/24/2012 18:42:09 sd_cancelInstall.sh|Stopping Partition B IDS
01/24/2012 18:42:24 sd_cancelInstall.sh|Stopped Partition B IDS
01/24/2012 18:42:24 sd_cancelInstall.sh|Request to terminate process 21125
01/24/2012 18:42:24 sd_cancelInstall.sh|Cancel process 21125 (atd)
01/24/2012 18:42:24 sd_cancelInstall.sh|Stop process 21125 (atd)
01/24/2012 18:42:24 sd_cancelInstall.sh|Terminate process 21125 (atd)
01/24/2012 18:42:24 sd_cancelInstall.sh|Waiting 1 seconds for 21125 (atd) to terminate
01/24/2012 18:42:25 sd_cancelInstall.sh|Process 21125 (atd) terminated
01/24/2012 18:42:25 sd_cancelInstall.sh|Canceling inactive side processes done
01/24/2012 18:42:30 upgrade_install.sh|Starting Upgrade -- upgrade_install.sh|<:INFO>
01/24/2012 18:42:30 upgrade_install.sh|Parse argument version=8.6.2.22900-9|<:DEBUG>
01/24/2012 18:42:30 upgrade_install.sh|Parse argument dest_dir=/common/download/|<:DEBUG>
01/24/2012 18:42:30 upgrade_install.sh|Parse argument work_dir=/var/log/install|<:DEBUG>
01/24/2012 18:42:30 upgrade_install.sh|is_upgrade_lock_available: Upgrade lock is available.|<:DEBUG>
01/24/2012 18:42:30 upgrade_install.sh|is_upgrade_result_available: Result is not available|<:DEBUG>
01/24/2012 18:42:30 upgrade_install.sh|acquire_upgrade_lock: Lock is free, creating lock (pid: 12774)|<:DEBUG>
01/24/2012 18:42:33 upgrade_install.sh|Selinux mode prior to upgrade is enforcing|<:INFO>
01/24/2012 18:42:33 upgrade_install.sh|Stopped auditd...|<:INFO>
01/24/2012 18:42:33 upgrade_install.sh|Stopped setroubleshoot...|<:INFO>
01/24/2012 18:42:33 upgrade_install.sh|Changed selinux mode to permissive|<:INFO>
01/24/2012 18:42:33 upgrade_install.sh|Upgrade the system|<:INFO>
01/24/2012 18:42:33 upgrade_install.sh|Copy /mnt/source/Cisco/base_scripts/upgrade_manager.sh to /common/download/8.6.2.22900-9/upgrade_manager.sh|<:INFO>
01/24/2012 18:42:33 upgrade_install.sh|Copy /mnt/source/Cisco/base_scripts/upgrade_manager.sh to /common/download/8.6.2.22900-9/upgrade_manager.sh complete|<:INFO>
01/24/2012 18:42:33 upgrade_install.sh|Start upgrade manager|<:INFO>
01/24/2012 18:42:33 upgrade_install.sh|/common/download/8.6.2.22900-9/upgrade_manager.sh type=upgrade basepath=/common/download/8.6.2.22900-9 file_name= logfile=/var/log/install/install_log_2012-01-24.18.41.35.log resultfile=/var/log/install/upgrade-results.xml work_dir=/var/log/install intf_file=/common/download/8.6.2.22900-9/upgrade_manager.xml to_version=8.6.2.22900-9|<:DEBUG>
01/24/2012 18:42:33 upgrade_manager.sh|Parse argument type=upgrade|<:DEBUG>
01/24/2012 18:42:33 upgrade_manager.sh|Parse argument basepath=/common/download/8.6.2.22900-9|<:DEBUG>
01/24/2012 18:42:33 upgrade_manager.sh|Parse argument file_name=|<:DEBUG>
01/24/2012 18:42:33 upgrade_manager.sh|Parse argument logfile=/var/log/install/install_log_2012-01-24.18.41.35.log|<:DEBUG>
01/24/2012 18:42:33 upgrade_manager.sh|Parse argument resultfile=/var/log/install/upgrade-results.xml|<:DEBUG>
01/24/2012 18:42:33 upgrade_manager.sh|Parse argument work_dir=/var/log/install|<:DEBUG>
01/24/2012 18:42:33 upgrade_manager.sh|Parse argument intf_file=/common/download/8.6.2.22900-9/upgrade_manager.xml|<:DEBUG>
01/24/2012 18:42:33 upgrade_manager.sh|Parse argument to_version=8.6.2.22900-9|<:DEBUG>
01/24/2012 18:42:33 upgrade_manager.sh|upgrade_type="upgrade"|<:DEBUG>
01/24/2012 18:42:33 upgrade_manager.sh|L2 upgrade|<:DEBUG>
01/24/2012 18:42:33 upgrade_manager.sh|Initialize install support functions|<:INFO>
01/24/2012 18:42:33 upgrade_manager.sh|Calling "source /mnt/source/Cisco/install/bin/install_func"|<:DEBUG>
01/24/2012 18:42:33 upgrade_manager.sh|Initialize install support functions complete|<:INFO>
01/24/2012 18:42:33 upgrade_manager.sh|Check for Refresh Upgrade|<:INFO>
01/24/2012 18:42:33 upgrade_manager.sh|Check if /mnt/source/upgradeConfig.xml exists|<:DEBUG>
01/24/2012 18:42:33 upgrade_manager.sh|Checking RedHat release version (5Server, 5Server)|<:DEBUG>
01/24/2012 18:42:33 upgrade_manager.sh|Continue normal upgrade processing|<:INFO>
01/24/2012 18:42:33 upgrade_manager.sh|Setting up cisco specific enviroment|<:INFO>
01/24/2012 18:42:33 upgrade_manager.sh|PATH=/common/download/8.6.2.22900-9/Cisco/bin:/usr/kerberos/sbin:/usr/kerberos/bin:/usr/local/sbin:/sbin:/usr/sbin:/bin:/usr/bin:/sbin:/home/sftpuser:/root/.security|<:DEBUG>
01/24/2012 18:42:33 upgrade_manager.sh|LD_LIBRARY_PATH=/common/download/8.6.2.22900-9/Cisco/lib:/opt/cisco/install/lib:|<:DEBUG>
01/24/2012 18:42:33 upgrade_manager.sh|PYTHONPATH=/common/download/8.6.2.22900-9/Cisco/python:/usr/local/cm/lib:/usr/local/cm/lib:/usr/local/cm/lib:|<:DEBUG>
01/24/2012 18:42:33 upgrade_manager.sh|CISCO_INSTALL_CONF_PATH=/common/download/8.6.2.22900-9/Cisco/install/conf|<:DEBUG>
01/24/2012 18:42:33 upgrade_manager.sh|CISCO_INSTALL_BIN_PATH=/common/download/8.6.2.22900-9/Cisco/bin /opt/cisco/install/bin|<:DEBUG>
01/24/2012 18:42:33 upgrade_manager.sh|CISCO_PLATFORMCONF_PATH=/common/cisco /usr/local/platform/conf|<:DEBUG>
01/24/2012 18:42:33 upgrade_manager.sh|Set logging globals for upgrade|<:INFO>
01/24/2012 18:42:33 upgrade_manager.sh|Before: ILOG_CONTEXT="Upgrade", ILOG_FILE="/var/log/install/install_log_2012-01-24.18.41.35.log", ILOG_RESULTS_FILE="/var/log/install/upgrade-results.xml"|<:DEBUG>
01/24/2012 18:42:33 upgrade_manager.sh|After: ILOG_CONTEXT="Upgrade", ILOG_FILE="/common/log/install/install_log_2012-01-24.18.41.35.log", ILOG_RESULTS_FILE="/common/log/install/upgrade-results.xml"|<:DEBUG>
01/24/2012 18:42:33 upgrade_manager.sh|IOWAIT monitor starting|<:INFO>
01/24/2012 18:42:33 upgrade_manager.sh|Checksum the upgrade from /mnt/source|<:INFO>
01/24/2012 18:42:33 upgrade_manager.sh|Calling sha1sum -c /common/download/8.6.2.22900-9/checksum_file|<:DEBUG>
01/24/2012 18:44:31 upgrade_manager.sh|Checksum complete|<:INFO>
01/24/2012 18:44:31 upgrade_manager.sh|Setup RAM disk for upgrade|<:INFO>
01/24/2012 18:44:31 upgrade_manager.sh|Make product.img mount point|<:INFO>
01/24/2012 18:44:31 upgrade_manager.sh|Calling umount /common/mnt/product_img|<:DEBUG>
01/24/2012 18:44:31 upgrade_manager.sh|Create /common/cisco link to the RAM disk|<:INFO>
01/24/2012 18:44:31 upgrade_manager.sh|Calling rm -rf /common/cisco|<:DEBUG>
01/24/2012 18:44:31 upgrade_manager.sh|Calling ln -s /common/download/8.6.2.22900-9/Cisco /common/cisco|<:DEBUG>
01/24/2012 18:44:31 upgrade_manager.sh|Copy product.img information to the RAM disk|<:INFO>
01/24/2012 18:44:31 upgrade_manager.sh|Calling cp -f /mnt/source/images/product.img /common/download/8.6.2.22900-9/Cisco|<:DEBUG>
01/24/2012 18:44:31 upgrade_manager.sh|Calling mount -o loop /common/download/8.6.2.22900-9/Cisco/product.img /common/mnt/product_img|<:DEBUG>
01/24/2012 18:44:32 upgrade_manager.sh|Calling cd /common/mnt/product_img; find | cpio -pdu -R root.         /common/download/8.6.2.22900-9/Cisco|<:DEBUG>
01/24/2012 18:44:32 upgrade_manager.sh|Calling umount /common/mnt/product_img|<:DEBUG>
01/24/2012 18:44:32 upgrade_manager.sh|Copy install information to the RAM disk|<:INFO>
01/24/2012 18:44:32 upgrade_manager.sh|Calling mkdir -f /common/download/8.6.2.22900-9/Cisco/install|<:DEBUG>
01/24/2012 18:44:32 upgrade_manager.sh|Calling cp -r /mnt/source/Cisco/install/* /common/download/8.6.2.22900-9/Cisco/install|<:DEBUG>
01/24/2012 18:44:32 upgrade_manager.sh|Initialize APIs|<:INFO>
01/24/2012 18:44:32 upgrade_manager.sh|Initialize logging|<:INFO>
01/24/2012 18:44:32 upgrade_manager.sh|Initializing the product API|<:INFO>
01/24/2012 18:44:33 upgrade_manager.sh|Initializing the hardware API|<:INFO>
01/24/2012 18:44:34 ServerApiManager|INITIALIZE: sam_legacy_mode_init=1|<:DEBUG>
01/24/2012 18:44:46 ServerApiManager|INITIALIZE: sam_hssi_mode_init=0|<:DEBUG>
01/24/2012 18:44:46 upgrade_manager.sh|Initializing the history log API|<:INFO>
01/24/2012 18:44:46 upgrade_manager.sh|Initializing the xplatformconfig API|<:INFO>
01/24/2012 18:44:46 upgrade_manager.sh|Initializing the xproduct API|<:INFO>
01/24/2012 18:44:46 upgrade_manager.sh|Initializing the diagnostic dump interface|<:INFO>
01/24/2012 18:44:46 upgrade_manager.sh|Initialize setup functions|<:INFO>
01/24/2012 18:44:46 upgrade_manager.sh|Calling "source /common/download/8.6.2.22900-9/Cisco/install/setup/utils.sh"|<:DEBUG>
01/24/2012 18:44:46 upgrade_manager.sh|Calling "source /common/download/8.6.2.22900-9/Cisco/install/setup/populate_archive.sh"|<:DEBUG>
01/24/2012 18:44:46 upgrade_manager.sh|Initialize setup functions complete|<:INFO>
01/24/2012 18:44:46 upgrade_manager.sh|Getting deployment ID from active side|<:INFO>
01/24/2012 18:44:46 upgrade_manager.sh|Copy /mnt/source/Cisco/base_bin/PlatformXmlUpg to /common/download/8.6.2.22900-9/Cisco/bin|<:INFO>
01/24/2012 18:44:46 upgrade_manager.sh|Calling "cp /mnt/source/Cisco/base_bin/PlatformXmlUpg /common/download/8.6.2.22900-9/Cisco/bin"|<:DEBUG>
01/24/2012 18:44:46 upgrade_manager.sh|Calling /common/download/8.6.2.22900-9/Cisco/bin/PlatformXmlUpg /usr/local/platform/conf/platformConfig.xml /common/cisco/platformConfig.xml|<:DEBUG>
01/24/2012 18:44:46 PlatformXmlUpg|Migrating to version main/5.|<:INFO>
01/24/2012 18:44:46 PlatformXmlUpg|Source file is "/usr/local/platform/conf/platformConfig.xml"|<:INFO>
01/24/2012 18:44:46 PlatformXmlUpg|Destination file is "/common/cisco/platformConfig.xml"|<:INFO>
01/24/2012 18:44:46 PlatformXmlUpg|Found /usr/local/platform/conf/platformConfig.xml.|<:DEBUG>
01/24/2012 18:44:46 PlatformXmlUpg|Copying /usr/local/platform/conf/platformConfig.xml to /common/cisco/platformConfig.xml prior to possible migration.|<:DEBUG>
01/24/2012 18:44:46 PlatformXmlUpg|Populating from /usr/local/platform/conf/platformConfig.xml.|<:INFO>
01/24/2012 18:44:46 PlatformXmlUpg|Wrote 6326 bytes to /common/cisco/platformConfig.xml.|<:DEBUG>
01/24/2012 18:44:46 PlatformXmlUpg|Migrating from version main/5.|<:INFO>
01/24/2012 18:44:46 PlatformXmlUpg|Timezone Tag found: Europe/London, nothing to migrate.|<:WARN>
01/24/2012 18:44:46 PlatformXmlUpg|Migrating application user name...|<:INFO>
01/24/2012 18:44:46 PlatformXmlUpg|Mandatory tag ApplUserUsername not found.  Adding tag using default value of CCMAdministrator|<:INFO>
01/24/2012 18:44:46 PlatformXmlUpg|Migrating NIC settings...|<:INFO>
01/24/2012 18:44:46 PlatformXmlUpg|NIC Auto Negotiate enabled.|<:INFO>
01/24/2012 18:44:46 PlatformXmlUpg|Removing unnecessary tag LocalHostNICSpeed|<:INFO>
01/24/2012 18:44:46 PlatformXmlUpg|Removing unnecessary tag LocalHostNICDuplex|<:INFO>
01/24/2012 18:44:46 PlatformXmlUpg|Removing obsolete NTP client data ...|<:INFO>
01/24/2012 18:44:46 PlatformXmlUpg|First node in the cluster 'no'|<:INFO>
01/24/2012 18:44:46 PlatformXmlUpg|Migrating non-primary node NTP data ...|<:INFO>
01/24/2012 18:44:46 PlatformXmlUpg|Host Name for DataBase 'Colo-LonCCM-01'|<:INFO>
01/24/2012 18:44:46 PlatformXmlUpg|Host IP Addr for DataBase '172.22.97.20'|<:INFO>
01/24/2012 18:44:46 PlatformXmlUpg|Migrating DNS data ...|<:INFO>
01/24/2012 18:44:46 PlatformXmlUpg|Removing transient tags.|<:INFO>
01/24/2012 18:44:46 PlatformXmlUpg|Removing obsolete tags.|<:INFO>
01/24/2012 18:44:46 PlatformXmlUpg|Setting version to main/5.|<:INFO>
01/24/2012 18:44:46 PlatformXmlUpg|Wrote 6536 bytes to /common/cisco/platformConfig.xml.|<:DEBUG>
01/24/2012 18:44:46 PlatformXmlUpg|Migration success|<:DEBUG>
01/24/2012 18:44:46 PlatformXmlUpg|Exiting with code 0|<:DEBUG>
01/24/2012 18:44:47 upgrade_manager.sh|Upgrade (L2) Starting|<:INFO>
01/24/2012 18:44:47 upgrade_manager.sh|(CAPTURE) Mail notification cancelled - smtp server address for email not found! [/common/cisco/platformConfig.xml]|<:DEBUG>
01/24/2012 18:44:47 upgrade_manager.sh|Check if the upgrade is allowed|<:INFO>
01/24/2012 18:44:47 upgrade_manager.sh|Validate hardware for the upgrade|<:INFO>
01/24/2012 18:44:48 upgrade_manager.sh|Hardware is supported for the upgrade|<:INFO>
01/24/2012 18:44:50 upgrade_manager.sh|Validate hardware for "callmanager" deployment|<:INFO>
01/24/2012 18:44:50 upgrade_manager.sh|Hardware is supported for "callmanager" deployment|<:INFO>
01/24/2012 18:44:51 upgrade_manager.sh|Validate from version 8.6.2.20000-2|<:INFO>
01/24/2012 18:44:51 upgrade_manager.sh|Upgrade from 8.6.2.20000-2 allowed|<:INFO>
01/24/2012 18:44:51 upgrade_manager.sh|Validate free space for the upgrade|<:INFO>
01/24/2012 18:44:52 upgrade_manager.sh|(CAPTURE) Free space: 44543241220, Needed space: 5392796535|<:DEBUG>
01/24/2012 18:44:52 upgrade_manager.sh|Free space validation complete|<:INFO>
01/24/2012 18:44:52 upgrade_manager.sh|New version is 8.6.2.22900-9|<:INFO>
01/24/2012 18:44:53 upgrade_manager.sh|Not a restricted to unrestricted upgrade|<:INFO>
01/24/2012 18:44:53 upgrade_manager.sh|Cleanup data from a prior upgrade attempt|<:INFO>
01/24/2012 18:44:53 upgrade_manager.sh|Removing any /grub/boot/grub/grub.conf.recovery|<:DEBUG>
01/24/2012 18:44:53 upgrade_manager.sh|Invalidate upgrade partition|<:INFO>
01/24/2012 18:44:53 upgrade_manager.sh|Clean up rpm any stale __db. files in rpmdb on the to side|<:DEBUG>
01/24/2012 18:44:53 upgrade_manager.sh|Removing any master RPM from /partB|<:DEBUG>
01/24/2012 18:44:54 upgrade_manager.sh|Removing any /partB/etc/opt/cisco/install.conf|<:DEBUG>
01/24/2012 18:44:54 upgrade_manager.sh|Invalidate any product configuration file|<:DEBUG>
01/24/2012 18:44:54 upgrade_manager.sh|Setting product and deployment version attributes in /partB/etc/opt/cisco/install/conf/callmanager_product.conf to 0.0.0.0000-0000|<:DEBUG>
01/24/2012 18:44:54 upgrade_manager.sh|Populate RPMs in RPM archive|<:INFO>
01/24/2012 18:44:54 populate_rpm_archive|Initializing xproduct API|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Initializing xcomponent API|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Initializing xplatformconfig API|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Calling "source /common/cisco/install/setup/utils.sh"|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Parse argument type=os|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Parse argument mode=upgrade|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Parse argument archive_version=8.6.2.22900-9|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Parse argument src_base=/mnt/source|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Parse argument archive_base=/common/rpm-archive|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Parse argument rpms=acpid-1.0.4-9.el5_4.2.i386.rpm audit-1.7.17-3.el5.i386.rpm audit-libs-1.7.17-3.el5.i386.rpm audit-libs-python-1.7.17-3.el5.i386.rpm authconfig-5.3.21-6.el5.i386.rpm basesystem-8.0-5.1.1.noarch.rpm bash-3.2-32.el5.i386.rpm beecrypt-4.1.2-10.1.1.i386.rpm bzip2-libs-1.0.3-6.el5_5.i386.rpm chkconfig-1.3.30.2-2.el5.i386.rpm coreutils-5.97-23.el5_4.2.i386.rpm cpio-2.6-23.el5_4.1.i386.rpm cracklib-2.8.9-3.3.i386.rpm cracklib-dicts-2.8.9-3.3.i386.rpm cryptsetup-luks-1.0.3-5.el5.i386.rpm cyrus-sasl-lib-2.1.22-5.el5_4.3.i386.rpm db4-4.3.29-10.el5.i386.rpm dbus-1.1.2-16.el5_7.i386.rpm dbus-glib-0.73-10.el5_5.i386.rpm dbus-libs-1.1.2-16.el5_7.i386.rpm dbus-python-0.70-9.el5_4.i386.rpm device-mapper-1.02.39-1.el5.i386.rpm device-mapper-event-1.02.39-1.el5.i386.rpm device-mapper-multipath-0.4.7-34.el5.i386.rpm dmraid-1.0.0.rc13-63.el5.i386.rpm dmraid-events-1.0.0.rc13-63.el5.i386.rpm e2fsprogs-1.39-23.el5.i386.rpm e2fsprogs-libs-1.39-23.el5.i386.rpm elfutils-libelf-0.137-3.el5.i386.rpm elfutils-libs-0|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Populate RPM archive for os type, mode upgrade|<:INFO>
01/24/2012 18:44:54 populate_rpm_archive|Populate RPM archive for os type , mode upgrade RTMTStart|<:NOTICE>
01/24/2012 18:44:54 populate_rpm_archive|Initialize global data, mode upgrade|<:INFO>
01/24/2012 18:44:54 populate_rpm_archive|Initialize global data, mode upgrade complete|<:INFO>
01/24/2012 18:44:54 populate_rpm_archive|Initialize command list|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Initialize component data, mode upgrade|<:INFO>
01/24/2012 18:44:54 populate_rpm_archive|Initialize component data, mode upgrade complete|<:INFO>
01/24/2012 18:44:54 populate_rpm_archive|Build the command list for os|<:INFO>
01/24/2012 18:44:54 populate_rpm_archive|Calling "mkdir -p /common/rpm-archive/8.6.2.22900-9/RPMS"|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Copy acpid-1.0.4-9.el5_4.2.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:54 populate_rpm_archive|Located acpid-1.0.4-9.el5_4.2.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/acpid-1.0.4-9.el5_4.2.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/acpid-1.0.4-9.el5_4.2.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Copy audit-1.7.17-3.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:54 populate_rpm_archive|Located audit-1.7.17-3.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/audit-1.7.17-3.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/audit-1.7.17-3.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Copy audit-libs-1.7.17-3.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:54 populate_rpm_archive|Located audit-libs-1.7.17-3.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/audit-libs-1.7.17-3.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/audit-libs-1.7.17-3.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Copy audit-libs-python-1.7.17-3.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:54 populate_rpm_archive|Located audit-libs-python-1.7.17-3.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/audit-libs-python-1.7.17-3.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/audit-libs-python-1.7.17-3.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Copy authconfig-5.3.21-6.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:54 populate_rpm_archive|Located authconfig-5.3.21-6.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/authconfig-5.3.21-6.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/authconfig-5.3.21-6.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Copy basesystem-8.0-5.1.1.noarch.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:54 populate_rpm_archive|Located basesystem-8.0-5.1.1.noarch.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/basesystem-8.0-5.1.1.noarch.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/basesystem-8.0-5.1.1.noarch.rpm" to command list|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Copy bash-3.2-32.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:54 populate_rpm_archive|Located bash-3.2-32.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/bash-3.2-32.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/bash-3.2-32.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Copy beecrypt-4.1.2-10.1.1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:54 populate_rpm_archive|Located beecrypt-4.1.2-10.1.1.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/beecrypt-4.1.2-10.1.1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/beecrypt-4.1.2-10.1.1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Copy bzip2-libs-1.0.3-6.el5_5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:54 populate_rpm_archive|Located bzip2-libs-1.0.3-6.el5_5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/bzip2-libs-1.0.3-6.el5_5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/bzip2-libs-1.0.3-6.el5_5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Copy chkconfig-1.3.30.2-2.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:54 populate_rpm_archive|Located chkconfig-1.3.30.2-2.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/chkconfig-1.3.30.2-2.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/chkconfig-1.3.30.2-2.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Copy coreutils-5.97-23.el5_4.2.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:54 populate_rpm_archive|Located coreutils-5.97-23.el5_4.2.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/coreutils-5.97-23.el5_4.2.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/coreutils-5.97-23.el5_4.2.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Copy cpio-2.6-23.el5_4.1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:54 populate_rpm_archive|Located cpio-2.6-23.el5_4.1.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/cpio-2.6-23.el5_4.1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/cpio-2.6-23.el5_4.1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Copy cracklib-2.8.9-3.3.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:54 populate_rpm_archive|Located cracklib-2.8.9-3.3.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/cracklib-2.8.9-3.3.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/cracklib-2.8.9-3.3.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Copy cracklib-dicts-2.8.9-3.3.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:54 populate_rpm_archive|Located cracklib-dicts-2.8.9-3.3.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/cracklib-dicts-2.8.9-3.3.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/cracklib-dicts-2.8.9-3.3.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Copy cryptsetup-luks-1.0.3-5.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:54 populate_rpm_archive|Located cryptsetup-luks-1.0.3-5.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/cryptsetup-luks-1.0.3-5.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/cryptsetup-luks-1.0.3-5.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Copy cyrus-sasl-lib-2.1.22-5.el5_4.3.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:54 populate_rpm_archive|Located cyrus-sasl-lib-2.1.22-5.el5_4.3.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/cyrus-sasl-lib-2.1.22-5.el5_4.3.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/cyrus-sasl-lib-2.1.22-5.el5_4.3.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Copy db4-4.3.29-10.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:54 populate_rpm_archive|Located db4-4.3.29-10.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/db4-4.3.29-10.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/db4-4.3.29-10.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Copy dbus-1.1.2-16.el5_7.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:54 populate_rpm_archive|Located dbus-1.1.2-16.el5_7.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/dbus-1.1.2-16.el5_7.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/dbus-1.1.2-16.el5_7.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Copy dbus-glib-0.73-10.el5_5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:54 populate_rpm_archive|Located dbus-glib-0.73-10.el5_5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/dbus-glib-0.73-10.el5_5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/dbus-glib-0.73-10.el5_5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Copy dbus-libs-1.1.2-16.el5_7.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:54 populate_rpm_archive|Located dbus-libs-1.1.2-16.el5_7.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/dbus-libs-1.1.2-16.el5_7.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/dbus-libs-1.1.2-16.el5_7.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Copy dbus-python-0.70-9.el5_4.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:54 populate_rpm_archive|Located dbus-python-0.70-9.el5_4.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/dbus-python-0.70-9.el5_4.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/dbus-python-0.70-9.el5_4.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Copy device-mapper-1.02.39-1.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:54 populate_rpm_archive|Located device-mapper-1.02.39-1.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/device-mapper-1.02.39-1.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/device-mapper-1.02.39-1.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Copy device-mapper-event-1.02.39-1.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:54 populate_rpm_archive|Located device-mapper-event-1.02.39-1.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/device-mapper-event-1.02.39-1.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/device-mapper-event-1.02.39-1.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Copy device-mapper-multipath-0.4.7-34.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:54 populate_rpm_archive|Located device-mapper-multipath-0.4.7-34.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/device-mapper-multipath-0.4.7-34.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/device-mapper-multipath-0.4.7-34.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Copy dmraid-1.0.0.rc13-63.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:54 populate_rpm_archive|Located dmraid-1.0.0.rc13-63.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/dmraid-1.0.0.rc13-63.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/dmraid-1.0.0.rc13-63.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Copy dmraid-events-1.0.0.rc13-63.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:54 populate_rpm_archive|Located dmraid-events-1.0.0.rc13-63.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/dmraid-events-1.0.0.rc13-63.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/dmraid-events-1.0.0.rc13-63.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Located e2fsprogs-1.39-23.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/e2fsprogs-1.39-23.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/e2fsprogs-1.39-23.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Copy e2fsprogs-libs-1.39-23.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:54 populate_rpm_archive|Located e2fsprogs-libs-1.39-23.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/e2fsprogs-libs-1.39-23.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/e2fsprogs-libs-1.39-23.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Copy elfutils-libelf-0.137-3.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:54 populate_rpm_archive|Located elfutils-libelf-0.137-3.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/elfutils-libelf-0.137-3.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/elfutils-libelf-0.137-3.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Copy elfutils-libs-0.137-3.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:54 populate_rpm_archive|Located elfutils-libs-0.137-3.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/elfutils-libs-0.137-3.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/elfutils-libs-0.137-3.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Copy expat-1.95.8-8.3.el5_4.2.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:54 populate_rpm_archive|Located expat-1.95.8-8.3.el5_4.2.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/expat-1.95.8-8.3.el5_4.2.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/expat-1.95.8-8.3.el5_4.2.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Copy file-4.17-15.el5_3.1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:54 populate_rpm_archive|Located file-4.17-15.el5_3.1.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/file-4.17-15.el5_3.1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/file-4.17-15.el5_3.1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Copy filesystem-2.4.0-3.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:54 populate_rpm_archive|Located filesystem-2.4.0-3.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/filesystem-2.4.0-3.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/filesystem-2.4.0-3.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Copy findutils-4.2.27-6.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:54 populate_rpm_archive|Located findutils-4.2.27-6.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/findutils-4.2.27-6.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/findutils-4.2.27-6.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Copy fipscheck-lib-1.2.0-1.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:54 populate_rpm_archive|Located fipscheck-lib-1.2.0-1.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/fipscheck-lib-1.2.0-1.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/fipscheck-lib-1.2.0-1.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Copy gawk-3.1.5-14.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:54 populate_rpm_archive|Located gawk-3.1.5-14.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/gawk-3.1.5-14.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/gawk-3.1.5-14.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Copy gdbm-1.8.0-26.2.1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:54 populate_rpm_archive|Located gdbm-1.8.0-26.2.1.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/gdbm-1.8.0-26.2.1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/gdbm-1.8.0-26.2.1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Copy glib2-2.12.3-4.el5_3.1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:54 populate_rpm_archive|Located glib2-2.12.3-4.el5_3.1.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/glib2-2.12.3-4.el5_3.1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/glib2-2.12.3-4.el5_3.1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Copy glibc-2.5-81.el5_8.1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:54 populate_rpm_archive|Located glibc-2.5-81.el5_8.1.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/glibc-2.5-81.el5_8.1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/glibc-2.5-81.el5_8.1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Copy glibc-common-2.5-81.el5_8.1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:54 populate_rpm_archive|Located glibc-common-2.5-81.el5_8.1.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/glibc-common-2.5-81.el5_8.1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/glibc-common-2.5-81.el5_8.1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Copy gmp-4.1.4-10.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:54 populate_rpm_archive|Located gmp-4.1.4-10.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/gmp-4.1.4-10.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/gmp-4.1.4-10.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Copy gnutls-1.4.1-3.el5_4.8.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:54 populate_rpm_archive|Located gnutls-1.4.1-3.el5_4.8.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/gnutls-1.4.1-3.el5_4.8.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/gnutls-1.4.1-3.el5_4.8.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Copy grep-2.5.1-55.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:54 populate_rpm_archive|Located grep-2.5.1-55.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/grep-2.5.1-55.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/grep-2.5.1-55.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Copy grub-0.97-13.5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:54 populate_rpm_archive|Located grub-0.97-13.5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/grub-0.97-13.5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/grub-0.97-13.5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Copy gzip-1.3.5-11.el5_4.1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:54 populate_rpm_archive|Located gzip-1.3.5-11.el5_4.1.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/gzip-1.3.5-11.el5_4.1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/gzip-1.3.5-11.el5_4.1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Copy hal-0.5.8.1-59.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:54 populate_rpm_archive|Located hal-0.5.8.1-59.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/hal-0.5.8.1-59.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/hal-0.5.8.1-59.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Copy hdparm-6.6-2.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:54 populate_rpm_archive|Located hdparm-6.6-2.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/hdparm-6.6-2.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/hdparm-6.6-2.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Copy hmaccalc-0.9.6-3.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:54 populate_rpm_archive|Located hmaccalc-0.9.6-3.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/hmaccalc-0.9.6-3.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/hmaccalc-0.9.6-3.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Copy hwdata-0.213.18-1.el5.1.noarch.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:54 populate_rpm_archive|Located hwdata-0.213.18-1.el5.1.noarch.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/hwdata-0.213.18-1.el5.1.noarch.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/hwdata-0.213.18-1.el5.1.noarch.rpm" to command list|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Copy info-4.8-14.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:54 populate_rpm_archive|Located info-4.8-14.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/info-4.8-14.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/info-4.8-14.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Copy initscripts-8.45.42-1.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:54 populate_rpm_archive|Located initscripts-8.45.42-1.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/initscripts-8.45.42-1.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/initscripts-8.45.42-1.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Copy iproute-2.6.18-11.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:54 populate_rpm_archive|Located iproute-2.6.18-11.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/iproute-2.6.18-11.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/iproute-2.6.18-11.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Copy iputils-20020927-46.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:54 populate_rpm_archive|Located iputils-20020927-46.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/iputils-20020927-46.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/iputils-20020927-46.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Copy kbd-1.12-21.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:54 populate_rpm_archive|Located kbd-1.12-21.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/kbd-1.12-21.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/kbd-1.12-21.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Copy kernel-PAE-2.6.18-194.26.1.el5.i686.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:54 populate_rpm_archive|Located kernel-PAE-2.6.18-194.26.1.el5.i686.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/kernel-PAE-2.6.18-194.26.1.el5.i686.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/kernel-PAE-2.6.18-194.26.1.el5.i686.rpm" to command list|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Copy keyutils-libs-1.2-1.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:54 populate_rpm_archive|Located keyutils-libs-1.2-1.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/keyutils-libs-1.2-1.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/keyutils-libs-1.2-1.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Copy kpartx-0.4.7-34.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:54 populate_rpm_archive|Located kpartx-0.4.7-34.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/kpartx-0.4.7-34.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/kpartx-0.4.7-34.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Copy krb5-libs-1.6.1-70.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:54 populate_rpm_archive|Located krb5-libs-1.6.1-70.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/krb5-libs-1.6.1-70.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/krb5-libs-1.6.1-70.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Copy kudzu-1.2.57.1.24-1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:54 populate_rpm_archive|Located kudzu-1.2.57.1.24-1.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/kudzu-1.2.57.1.24-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/kudzu-1.2.57.1.24-1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Copy less-436-2.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:54 populate_rpm_archive|Located less-436-2.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/less-436-2.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/less-436-2.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Located libacl-2.2.39-6.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/libacl-2.2.39-6.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/libacl-2.2.39-6.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Copy libattr-2.4.32-1.1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:54 populate_rpm_archive|Located libattr-2.4.32-1.1.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/libattr-2.4.32-1.1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/libattr-2.4.32-1.1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Copy libgcc-4.1.2-50.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:54 populate_rpm_archive|Located libgcc-4.1.2-50.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/libgcc-4.1.2-50.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/libgcc-4.1.2-50.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Copy libgcrypt-1.4.4-5.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:54 populate_rpm_archive|Located libgcrypt-1.4.4-5.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:54 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/libgcrypt-1.4.4-5.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/libgcrypt-1.4.4-5.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy libgpg-error-1.4-2.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located libgpg-error-1.4-2.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/libgpg-error-1.4-2.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/libgpg-error-1.4-2.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy libidn-0.6.5-1.1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located libidn-0.6.5-1.1.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/libidn-0.6.5-1.1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/libidn-0.6.5-1.1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy libselinux-1.33.4-5.5.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located libselinux-1.33.4-5.5.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/libselinux-1.33.4-5.5.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/libselinux-1.33.4-5.5.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy libselinux-python-1.33.4-5.5.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located libselinux-python-1.33.4-5.5.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/libselinux-python-1.33.4-5.5.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/libselinux-python-1.33.4-5.5.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy libselinux-utils-1.33.4-5.5.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located libselinux-utils-1.33.4-5.5.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/libselinux-utils-1.33.4-5.5.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/libselinux-utils-1.33.4-5.5.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy libsemanage-1.9.1-4.4.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located libsemanage-1.9.1-4.4.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/libsemanage-1.9.1-4.4.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/libsemanage-1.9.1-4.4.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy libsepol-1.15.2-3.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located libsepol-1.15.2-3.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/libsepol-1.15.2-3.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/libsepol-1.15.2-3.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy libsysfs-2.0.0-6.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located libsysfs-2.0.0-6.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/libsysfs-2.0.0-6.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/libsysfs-2.0.0-6.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy libtermcap-2.0.8-46.1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located libtermcap-2.0.8-46.1.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/libtermcap-2.0.8-46.1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/libtermcap-2.0.8-46.1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy libusb-0.1.12-5.1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located libusb-0.1.12-5.1.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/libusb-0.1.12-5.1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/libusb-0.1.12-5.1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy libuser-0.54.7-2.1.el5_5.2.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located libuser-0.54.7-2.1.el5_5.2.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/libuser-0.54.7-2.1.el5_5.2.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/libuser-0.54.7-2.1.el5_5.2.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy libutempter-1.1.4-4.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located libutempter-1.1.4-4.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/libutempter-1.1.4-4.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/libutempter-1.1.4-4.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy libvolume_id-095-14.21.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located libvolume_id-095-14.21.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/libvolume_id-095-14.21.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/libvolume_id-095-14.21.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy lm_sensors-2.10.7-9.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located lm_sensors-2.10.7-9.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/lm_sensors-2.10.7-9.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/lm_sensors-2.10.7-9.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy lsscsi-0.17-3.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located lsscsi-0.17-3.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/lsscsi-0.17-3.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/lsscsi-0.17-3.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy lvm2-2.02.56-8.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located lvm2-2.02.56-8.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/lvm2-2.02.56-8.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/lvm2-2.02.56-8.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy MAKEDEV-3.23-1.2.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located MAKEDEV-3.23-1.2.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/MAKEDEV-3.23-1.2.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/MAKEDEV-3.23-1.2.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy mcstrans-0.2.11-3.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located mcstrans-0.2.11-3.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/mcstrans-0.2.11-3.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/mcstrans-0.2.11-3.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy mingetty-1.07-5.2.2.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located mingetty-1.07-5.2.2.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/mingetty-1.07-5.2.2.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/mingetty-1.07-5.2.2.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy mkinitrd-5.1.19.6-61.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located mkinitrd-5.1.19.6-61.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/mkinitrd-5.1.19.6-61.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/mkinitrd-5.1.19.6-61.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy mktemp-1.5-23.2.2.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located mktemp-1.5-23.2.2.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/mktemp-1.5-23.2.2.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/mktemp-1.5-23.2.2.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy module-init-tools-3.3-0.pre3.1.60.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located module-init-tools-3.3-0.pre3.1.60.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/module-init-tools-3.3-0.pre3.1.60.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/module-init-tools-3.3-0.pre3.1.60.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy nash-5.1.19.6-61.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located nash-5.1.19.6-61.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/nash-5.1.19.6-61.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/nash-5.1.19.6-61.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy ncurses-5.5-24.20060715.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located ncurses-5.5-24.20060715.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/ncurses-5.5-24.20060715.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ncurses-5.5-24.20060715.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy net-tools-1.60-81.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located net-tools-1.60-81.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/net-tools-1.60-81.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/net-tools-1.60-81.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy newt-0.52.2-15.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located newt-0.52.2-15.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/newt-0.52.2-15.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/newt-0.52.2-15.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy nspr-4.8.8-1.el5_7.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located nspr-4.8.8-1.el5_7.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/nspr-4.8.8-1.el5_7.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/nspr-4.8.8-1.el5_7.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy nss-3.12.10-7.el5_7.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located nss-3.12.10-7.el5_7.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/nss-3.12.10-7.el5_7.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/nss-3.12.10-7.el5_7.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy nss-tools-3.12.10-7.el5_7.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located nss-tools-3.12.10-7.el5_7.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/nss-tools-3.12.10-7.el5_7.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/nss-tools-3.12.10-7.el5_7.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy OpenIPMI-2.0.16-7.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located OpenIPMI-2.0.16-7.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/OpenIPMI-2.0.16-7.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/OpenIPMI-2.0.16-7.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Located OpenIPMI-libs-2.0.16-7.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/OpenIPMI-libs-2.0.16-7.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/OpenIPMI-libs-2.0.16-7.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy openldap-2.3.43-12.el5_6.7.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located openldap-2.3.43-12.el5_6.7.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/openldap-2.3.43-12.el5_6.7.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/openldap-2.3.43-12.el5_6.7.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy openssl-0.9.8e-22.el5_8.3.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located openssl-0.9.8e-22.el5_8.3.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/openssl-0.9.8e-22.el5_8.3.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/openssl-0.9.8e-22.el5_8.3.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy openswan-2.6.21-5.el5_4.3.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located openswan-2.6.21-5.el5_4.3.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/openswan-2.6.21-5.el5_4.3.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/openswan-2.6.21-5.el5_4.3.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy pam-0.99.6.2-6.el5_5.2.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located pam-0.99.6.2-6.el5_5.2.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/pam-0.99.6.2-6.el5_5.2.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/pam-0.99.6.2-6.el5_5.2.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy passwd-0.73-1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located passwd-0.73-1.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/passwd-0.73-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/passwd-0.73-1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy pcre-6.6-2.el5_1.7.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located pcre-6.6-2.el5_1.7.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/pcre-6.6-2.el5_1.7.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/pcre-6.6-2.el5_1.7.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy pm-utils-0.99.3-10.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located pm-utils-0.99.3-10.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/pm-utils-0.99.3-10.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/pm-utils-0.99.3-10.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy policycoreutils-1.33.12-14.8.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located policycoreutils-1.33.12-14.8.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/policycoreutils-1.33.12-14.8.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/policycoreutils-1.33.12-14.8.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy policycoreutils-newrole-1.33.12-14.8.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located policycoreutils-newrole-1.33.12-14.8.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/policycoreutils-newrole-1.33.12-14.8.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/policycoreutils-newrole-1.33.12-14.8.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy popt-1.10.2.3-22.el5_7.2.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located popt-1.10.2.3-22.el5_7.2.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/popt-1.10.2.3-22.el5_7.2.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/popt-1.10.2.3-22.el5_7.2.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy portmap-4.0-65.2.2.1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located portmap-4.0-65.2.2.1.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/portmap-4.0-65.2.2.1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/portmap-4.0-65.2.2.1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy procps-3.2.7-16.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located procps-3.2.7-16.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/procps-3.2.7-16.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/procps-3.2.7-16.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy psmisc-22.2-7.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located psmisc-22.2-7.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/psmisc-22.2-7.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/psmisc-22.2-7.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy pygobject2-2.12.1-5.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located pygobject2-2.12.1-5.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/pygobject2-2.12.1-5.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/pygobject2-2.12.1-5.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy python-2.4.3-44.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located python-2.4.3-44.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/python-2.4.3-44.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/python-2.4.3-44.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy python-libs-2.4.3-44.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located python-libs-2.4.3-44.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/python-libs-2.4.3-44.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/python-libs-2.4.3-44.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy PyXML-0.8.4-4.el5_4.2.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located PyXML-0.8.4-4.el5_4.2.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/PyXML-0.8.4-4.el5_4.2.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/PyXML-0.8.4-4.el5_4.2.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy readline-5.1-3.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located readline-5.1-3.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/readline-5.1-3.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/readline-5.1-3.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy redhat-logos-4.9.16-1.noarch.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located redhat-logos-4.9.16-1.noarch.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/redhat-logos-4.9.16-1.noarch.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/redhat-logos-4.9.16-1.noarch.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy redhat-release-5Server-5.5.0.2.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located redhat-release-5Server-5.5.0.2.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/redhat-release-5Server-5.5.0.2.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/redhat-release-5Server-5.5.0.2.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy rootfiles-8.1-1.1.1.noarch.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located rootfiles-8.1-1.1.1.noarch.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/rootfiles-8.1-1.1.1.noarch.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/rootfiles-8.1-1.1.1.noarch.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy rpm-4.4.2.3-28.el5_8.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located rpm-4.4.2.3-28.el5_8.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/rpm-4.4.2.3-28.el5_8.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/rpm-4.4.2.3-28.el5_8.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy rpm-libs-4.4.2.3-28.el5_8.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located rpm-libs-4.4.2.3-28.el5_8.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/rpm-libs-4.4.2.3-28.el5_8.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/rpm-libs-4.4.2.3-28.el5_8.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy rpm-python-4.4.2.3-28.el5_8.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located rpm-python-4.4.2.3-28.el5_8.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/rpm-python-4.4.2.3-28.el5_8.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/rpm-python-4.4.2.3-28.el5_8.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy sed-4.1.5-5.fc6.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located sed-4.1.5-5.fc6.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/sed-4.1.5-5.fc6.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/sed-4.1.5-5.fc6.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy selinux-policy-2.4.6-279.el5.noarch.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located selinux-policy-2.4.6-279.el5.noarch.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/selinux-policy-2.4.6-279.el5.noarch.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/selinux-policy-2.4.6-279.el5.noarch.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy selinux-policy-strict-2.4.6-279.el5.noarch.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located selinux-policy-strict-2.4.6-279.el5.noarch.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/selinux-policy-strict-2.4.6-279.el5.noarch.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/selinux-policy-strict-2.4.6-279.el5.noarch.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy setroubleshoot-plugins-2.0.4-2.el5.noarch.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located setroubleshoot-plugins-2.0.4-2.el5.noarch.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/setroubleshoot-plugins-2.0.4-2.el5.noarch.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/setroubleshoot-plugins-2.0.4-2.el5.noarch.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy setroubleshoot-server-2.0.5-5.el5_8.1.noarch.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located setroubleshoot-server-2.0.5-5.el5_8.1.noarch.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/setroubleshoot-server-2.0.5-5.el5_8.1.noarch.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/setroubleshoot-server-2.0.5-5.el5_8.1.noarch.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy setserial-2.17-19.2.2.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located setserial-2.17-19.2.2.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/setserial-2.17-19.2.2.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/setserial-2.17-19.2.2.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy setup-2.5.58-7.el5.noarch.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located setup-2.5.58-7.el5.noarch.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/setup-2.5.58-7.el5.noarch.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/setup-2.5.58-7.el5.noarch.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy sg3_utils-libs-1.25-4.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located sg3_utils-libs-1.25-4.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/sg3_utils-libs-1.25-4.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/sg3_utils-libs-1.25-4.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy sgpio-1.2.0_10-2.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located sgpio-1.2.0_10-2.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/sgpio-1.2.0_10-2.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/sgpio-1.2.0_10-2.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Located shadow-utils-4.0.17-15.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/shadow-utils-4.0.17-15.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/shadow-utils-4.0.17-15.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy slang-2.0.6-4.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located slang-2.0.6-4.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/slang-2.0.6-4.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/slang-2.0.6-4.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy squashfs-tools-3.0-4.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located squashfs-tools-3.0-4.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/squashfs-tools-3.0-4.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/squashfs-tools-3.0-4.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy sqlite-3.3.6-5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located sqlite-3.3.6-5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/sqlite-3.3.6-5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/sqlite-3.3.6-5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy sysfsutils-2.0.0-6.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located sysfsutils-2.0.0-6.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/sysfsutils-2.0.0-6.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/sysfsutils-2.0.0-6.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy sysklogd-1.4.1-46.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located sysklogd-1.4.1-46.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/sysklogd-1.4.1-46.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/sysklogd-1.4.1-46.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy sysstat-7.0.2-11.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located sysstat-7.0.2-11.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/sysstat-7.0.2-11.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/sysstat-7.0.2-11.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy SysVinit-2.86-15.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located SysVinit-2.86-15.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/SysVinit-2.86-15.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/SysVinit-2.86-15.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy tar-1.15.1-30.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located tar-1.15.1-30.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/tar-1.15.1-30.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/tar-1.15.1-30.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy termcap-5.5-1.20060701.1.noarch.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located termcap-5.5-1.20060701.1.noarch.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/termcap-5.5-1.20060701.1.noarch.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/termcap-5.5-1.20060701.1.noarch.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy tzdata-2012c-1.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located tzdata-2012c-1.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/tzdata-2012c-1.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/tzdata-2012c-1.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy udev-095-14.21.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located udev-095-14.21.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/udev-095-14.21.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/udev-095-14.21.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy usbutils-0.71-2.1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located usbutils-0.71-2.1.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/usbutils-0.71-2.1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/usbutils-0.71-2.1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy usermode-1.88-3.el5.2.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located usermode-1.88-3.el5.2.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/usermode-1.88-3.el5.2.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/usermode-1.88-3.el5.2.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy util-linux-2.13-0.59.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located util-linux-2.13-0.59.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/util-linux-2.13-0.59.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/util-linux-2.13-0.59.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy vim-minimal-7.0.109-6.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located vim-minimal-7.0.109-6.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/vim-minimal-7.0.109-6.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/vim-minimal-7.0.109-6.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy which-2.16-7.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located which-2.16-7.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/which-2.16-7.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/which-2.16-7.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy words-3.0-9.1.noarch.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located words-3.0-9.1.noarch.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/words-3.0-9.1.noarch.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/words-3.0-9.1.noarch.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy xinetd-2.3.14-10.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located xinetd-2.3.14-10.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/xinetd-2.3.14-10.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/xinetd-2.3.14-10.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy zlib-1.2.3-3.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located zlib-1.2.3-3.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/zlib-1.2.3-3.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/zlib-1.2.3-3.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy kexec-tools-1.102pre-154.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located kexec-tools-1.102pre-154.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/kexec-tools-1.102pre-154.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/kexec-tools-1.102pre-154.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy busybox-1.2.0-13.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located busybox-1.2.0-13.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/busybox-1.2.0-13.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/busybox-1.2.0-13.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy ipt-hashlimit-1.2-0.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located ipt-hashlimit-1.2-0.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/ipt-hashlimit-1.2-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ipt-hashlimit-1.2-0.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy unixODBC-2.2.11-7.1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located unixODBC-2.2.11-7.1.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/unixODBC-2.2.11-7.1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/unixODBC-2.2.11-7.1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy ntp-4.2.2p1-9.el5_4.1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located ntp-4.2.2p1-9.el5_4.1.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/ntp-4.2.2p1-9.el5_4.1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ntp-4.2.2p1-9.el5_4.1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy libpcap-0.9.4-15.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located libpcap-0.9.4-15.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/libpcap-0.9.4-15.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/libpcap-0.9.4-15.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy libxml2-python-2.6.26-2.1.15.el5_8.2.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located libxml2-python-2.6.26-2.1.15.el5_8.2.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/libxml2-python-2.6.26-2.1.15.el5_8.2.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/libxml2-python-2.6.26-2.1.15.el5_8.2.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy vim-enhanced-7.0.109-6.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located vim-enhanced-7.0.109-6.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/vim-enhanced-7.0.109-6.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/vim-enhanced-7.0.109-6.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy screen-4.0.3-1.el5_4.1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located screen-4.0.3-1.el5_4.1.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/screen-4.0.3-1.el5_4.1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/screen-4.0.3-1.el5_4.1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy strace-4.5.18-5.el5_4.1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located strace-4.5.18-5.el5_4.1.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/strace-4.5.18-5.el5_4.1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/strace-4.5.18-5.el5_4.1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy gdb-7.0.1-23.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located gdb-7.0.1-23.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/gdb-7.0.1-23.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/gdb-7.0.1-23.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy compat-libstdc++-33-3.2.3-61.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located compat-libstdc++-33-3.2.3-61.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/compat-libstdc++-33-3.2.3-61.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/compat-libstdc++-33-3.2.3-61.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy struts-1.1-3.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located struts-1.1-3.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/struts-1.1-3.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/struts-1.1-3.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy tomcat-6.0.29-0.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located tomcat-6.0.29-0.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/tomcat-6.0.29-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/tomcat-6.0.29-0.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy xmlstarlet-1.0.1-1.i586.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located xmlstarlet-1.0.1-1.i586.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/xmlstarlet-1.0.1-1.i586.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/xmlstarlet-1.0.1-1.i586.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy cactus-12.1.5-3.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located cactus-12.1.5-3.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/cactus-12.1.5-3.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/cactus-12.1.5-3.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy ecs-1.4.2-3.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located ecs-1.4.2-3.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/ecs-1.4.2-3.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ecs-1.4.2-3.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy elixir-4.2-3.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located elixir-4.2-3.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/elixir-4.2-3.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/elixir-4.2-3.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy jaxm-1.1.2-3.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located jaxm-1.1.2-3.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/jaxm-1.1.2-3.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/jaxm-1.1.2-3.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy log4j-1.2.8-3.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located log4j-1.2.8-3.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/log4j-1.2.8-3.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/log4j-1.2.8-3.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy mail-1.0.0-3.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located mail-1.0.0-3.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/mail-1.0.0-3.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/mail-1.0.0-3.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy pgjdbc-7.3.3-3.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located pgjdbc-7.3.3-3.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/pgjdbc-7.3.3-3.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/pgjdbc-7.3.3-3.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy regexp-1.3-3.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located regexp-1.3-3.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/regexp-1.3-3.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/regexp-1.3-3.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy activation-1.0.0-3.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located activation-1.0.0-3.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/activation-1.0.0-3.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/activation-1.0.0-3.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy saaj-1.3-4.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located saaj-1.3-4.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/saaj-1.3-4.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/saaj-1.3-4.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy xerces-2.6.2-3.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located xerces-2.6.2-3.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/xerces-2.6.2-3.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/xerces-2.6.2-3.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy xalan-2.7.0-3.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located xalan-2.7.0-3.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/xalan-2.7.0-3.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/xalan-2.7.0-3.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy acl-2.2.39-6.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located acl-2.2.39-6.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/acl-2.2.39-6.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/acl-2.2.39-6.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy at-3.1.8-84.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located at-3.1.8-84.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/at-3.1.8-84.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/at-3.1.8-84.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy attr-2.4.32-1.1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located attr-2.4.32-1.1.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/attr-2.4.32-1.1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/attr-2.4.32-1.1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy bc-1.06-21.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located bc-1.06-21.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/bc-1.06-21.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/bc-1.06-21.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy bind-libs-9.3.6-16.P1.el5_7.1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located bind-libs-9.3.6-16.P1.el5_7.1.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/bind-libs-9.3.6-16.P1.el5_7.1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/bind-libs-9.3.6-16.P1.el5_7.1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy bind-utils-9.3.6-16.P1.el5_7.1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located bind-utils-9.3.6-16.P1.el5_7.1.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/bind-utils-9.3.6-16.P1.el5_7.1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/bind-utils-9.3.6-16.P1.el5_7.1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy binutils-2.17.50.0.6-14.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located binutils-2.17.50.0.6-14.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/binutils-2.17.50.0.6-14.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/binutils-2.17.50.0.6-14.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy bzip2-1.0.3-6.el5_5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located bzip2-1.0.3-6.el5_5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/bzip2-1.0.3-6.el5_5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/bzip2-1.0.3-6.el5_5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy cpufreq-utils-005-1.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located cpufreq-utils-005-1.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/cpufreq-utils-005-1.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/cpufreq-utils-005-1.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy cpuspeed-1.2.1-9.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located cpuspeed-1.2.1-9.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/cpuspeed-1.2.1-9.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/cpuspeed-1.2.1-9.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy crontabs-1.10-8.noarch.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located crontabs-1.10-8.noarch.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/crontabs-1.10-8.noarch.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/crontabs-1.10-8.noarch.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy curl-7.15.5-9.el5_6.3.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located curl-7.15.5-9.el5_6.3.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/curl-7.15.5-9.el5_6.3.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/curl-7.15.5-9.el5_6.3.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy dhclient-3.0.5-29.el5_7.1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located dhclient-3.0.5-29.el5_7.1.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/dhclient-3.0.5-29.el5_7.1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/dhclient-3.0.5-29.el5_7.1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy dhcpv6-client-1.0.10-18.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located dhcpv6-client-1.0.10-18.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/dhcpv6-client-1.0.10-18.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/dhcpv6-client-1.0.10-18.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy diffutils-2.8.1-15.2.3.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located diffutils-2.8.1-15.2.3.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/diffutils-2.8.1-15.2.3.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/diffutils-2.8.1-15.2.3.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy dmidecode-2.10-3.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located dmidecode-2.10-3.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/dmidecode-2.10-3.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/dmidecode-2.10-3.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy dos2unix-3.1-27.2.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located dos2unix-3.1-27.2.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/dos2unix-3.1-27.2.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/dos2unix-3.1-27.2.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy dosfstools-2.11-9.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located dosfstools-2.11-9.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/dosfstools-2.11-9.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/dosfstools-2.11-9.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy eject-2.1.5-4.2.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/eject-2.1.5-4.2.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/eject-2.1.5-4.2.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy elfutils-0.137-3.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located elfutils-0.137-3.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/elfutils-0.137-3.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/elfutils-0.137-3.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy ethtool-6-4.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located ethtool-6-4.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/ethtool-6-4.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ethtool-6-4.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy fipscheck-1.2.0-1.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located fipscheck-1.2.0-1.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/fipscheck-1.2.0-1.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/fipscheck-1.2.0-1.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy gnupg-1.4.5-14.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located gnupg-1.4.5-14.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/gnupg-1.4.5-14.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/gnupg-1.4.5-14.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy gpm-1.20.1-74.1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located gpm-1.20.1-74.1.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/gpm-1.20.1-74.1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/gpm-1.20.1-74.1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy ipsec-tools-0.6.5-13.el5_3.1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located ipsec-tools-0.6.5-13.el5_3.1.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/ipsec-tools-0.6.5-13.el5_3.1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ipsec-tools-0.6.5-13.el5_3.1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy iptables-1.3.5-5.3.el5_4.1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located iptables-1.3.5-5.3.el5_4.1.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/iptables-1.3.5-5.3.el5_4.1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/iptables-1.3.5-5.3.el5_4.1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy iptables-ipv6-1.3.5-5.3.el5_4.1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located iptables-ipv6-1.3.5-5.3.el5_4.1.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/iptables-ipv6-1.3.5-5.3.el5_4.1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/iptables-ipv6-1.3.5-5.3.el5_4.1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy irqbalance-0.55-15.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located irqbalance-0.55-15.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/irqbalance-0.55-15.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/irqbalance-0.55-15.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy krb5-workstation-1.6.1-70.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located krb5-workstation-1.6.1-70.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/krb5-workstation-1.6.1-70.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/krb5-workstation-1.6.1-70.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy logrotate-3.7.4-9.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located logrotate-3.7.4-9.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/logrotate-3.7.4-9.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/logrotate-3.7.4-9.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy lsof-4.78-3.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located lsof-4.78-3.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/lsof-4.78-3.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/lsof-4.78-3.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy make-3.81-3.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located make-3.81-3.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/make-3.81-3.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/make-3.81-3.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:55 populate_rpm_archive|Copy mgetty-1.1.33-9.fc6.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:55 populate_rpm_archive|Located mgetty-1.1.33-9.fc6.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/mgetty-1.1.33-9.fc6.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/mgetty-1.1.33-9.fc6.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Copy mt-st-0.9b-2.2.2.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:56 populate_rpm_archive|Located mt-st-0.9b-2.2.2.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/mt-st-0.9b-2.2.2.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/mt-st-0.9b-2.2.2.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Copy nc-1.84-10.fc6.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:56 populate_rpm_archive|Located nc-1.84-10.fc6.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/nc-1.84-10.fc6.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/nc-1.84-10.fc6.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Copy nscd-2.5-65.el5_7.1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:56 populate_rpm_archive|Located nscd-2.5-65.el5_7.1.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/nscd-2.5-65.el5_7.1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/nscd-2.5-65.el5_7.1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Copy nss_ldap-253-25.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:56 populate_rpm_archive|Located nss_ldap-253-25.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/nss_ldap-253-25.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/nss_ldap-253-25.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Copy pam_krb5-2.2.14-15.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:56 populate_rpm_archive|Located pam_krb5-2.2.14-15.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/pam_krb5-2.2.14-15.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/pam_krb5-2.2.14-15.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Copy patch-2.5.4-29.2.3.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:56 populate_rpm_archive|Located patch-2.5.4-29.2.3.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/patch-2.5.4-29.2.3.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/patch-2.5.4-29.2.3.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Copy pciutils-2.2.3-8.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:56 populate_rpm_archive|Located pciutils-2.2.3-8.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/pciutils-2.2.3-8.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/pciutils-2.2.3-8.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Copy pdksh-5.2.14-36.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:56 populate_rpm_archive|Located pdksh-5.2.14-36.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/pdksh-5.2.14-36.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/pdksh-5.2.14-36.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Copy radvd-0.9.1-4.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:56 populate_rpm_archive|Located radvd-0.9.1-4.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/radvd-0.9.1-4.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/radvd-0.9.1-4.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Copy readahead-1.3-8.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:56 populate_rpm_archive|Located readahead-1.3-8.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/readahead-1.3-8.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/readahead-1.3-8.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Copy rsync-2.6.8-3.1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:56 populate_rpm_archive|Located rsync-2.6.8-3.1.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/rsync-2.6.8-3.1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/rsync-2.6.8-3.1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Copy setarch-2.0-1.1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:56 populate_rpm_archive|Located setarch-2.0-1.1.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/setarch-2.0-1.1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/setarch-2.0-1.1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Copy sg3_utils-1.25-4.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:56 populate_rpm_archive|Located sg3_utils-1.25-4.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/sg3_utils-1.25-4.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/sg3_utils-1.25-4.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Copy sos-1.7-9.62.el5.noarch.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:56 populate_rpm_archive|Located sos-1.7-9.62.el5.noarch.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/sos-1.7-9.62.el5.noarch.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/sos-1.7-9.62.el5.noarch.rpm" to command list|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Copy star-1.5a75-3.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:56 populate_rpm_archive|Located star-1.5a75-3.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/star-1.5a75-3.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/star-1.5a75-3.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Copy stunnel-4.15-2.el5.1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:56 populate_rpm_archive|Located stunnel-4.15-2.el5.1.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/stunnel-4.15-2.el5.1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/stunnel-4.15-2.el5.1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Copy sudo-1.7.2p1-8.el5_5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:56 populate_rpm_archive|Located sudo-1.7.2p1-8.el5_5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/sudo-1.7.2p1-8.el5_5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/sudo-1.7.2p1-8.el5_5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Copy tcpdump-3.9.4-15.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:56 populate_rpm_archive|Located tcpdump-3.9.4-15.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/tcpdump-3.9.4-15.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/tcpdump-3.9.4-15.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Copy tcp_wrappers-7.6-40.7.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:56 populate_rpm_archive|Located tcp_wrappers-7.6-40.7.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/tcp_wrappers-7.6-40.7.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/tcp_wrappers-7.6-40.7.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Copy tcsh-6.14-17.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:56 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/tcsh-6.14-17.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/tcsh-6.14-17.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Copy tftp-0.49-2.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:56 populate_rpm_archive|Located tftp-0.49-2.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/tftp-0.49-2.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/tftp-0.49-2.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Copy time-1.7-27.2.2.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:56 populate_rpm_archive|Located time-1.7-27.2.2.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/time-1.7-27.2.2.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/time-1.7-27.2.2.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Copy tmpwatch-2.9.7-1.1.el5.2.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:56 populate_rpm_archive|Located tmpwatch-2.9.7-1.1.el5.2.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/tmpwatch-2.9.7-1.1.el5.2.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/tmpwatch-2.9.7-1.1.el5.2.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Copy traceroute-2.0.1-5.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:56 populate_rpm_archive|Located traceroute-2.0.1-5.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/traceroute-2.0.1-5.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/traceroute-2.0.1-5.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Copy unzip-5.52-3.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:56 populate_rpm_archive|Located unzip-5.52-3.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/unzip-5.52-3.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/unzip-5.52-3.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Copy vim-common-7.0.109-6.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:56 populate_rpm_archive|Located vim-common-7.0.109-6.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/vim-common-7.0.109-6.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/vim-common-7.0.109-6.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Copy vixie-cron-4.1-81.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:56 populate_rpm_archive|Located vixie-cron-4.1-81.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/vixie-cron-4.1-81.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/vixie-cron-4.1-81.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Copy zip-2.31-2.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:56 populate_rpm_archive|Located zip-2.31-2.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/zip-2.31-2.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/zip-2.31-2.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Copy tcl-8.4.13-4.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:56 populate_rpm_archive|Located tcl-8.4.13-4.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/tcl-8.4.13-4.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/tcl-8.4.13-4.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Copy expect-5.43.0-5.1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:56 populate_rpm_archive|Located expect-5.43.0-5.1.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/expect-5.43.0-5.1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/expect-5.43.0-5.1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Copy libstdc++-4.1.2-48.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:56 populate_rpm_archive|Located libstdc++-4.1.2-48.el5.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/libstdc++-4.1.2-48.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/libstdc++-4.1.2-48.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Copy compat-db-4.2.52-5.1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:56 populate_rpm_archive|Located compat-db-4.2.52-5.1.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/compat-db-4.2.52-5.1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/compat-db-4.2.52-5.1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Copy compat-libstdc++-296-2.96-138.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:56 populate_rpm_archive|Located compat-libstdc++-296-2.96-138.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/compat-libstdc++-296-2.96-138.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/compat-libstdc++-296-2.96-138.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Copy dhcp-3.0.5-29.el5_7.1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:56 populate_rpm_archive|Located dhcp-3.0.5-29.el5_7.1.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/dhcp-3.0.5-29.el5_7.1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/dhcp-3.0.5-29.el5_7.1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Copy perl-5.8.8-32.el5_7.6.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:56 populate_rpm_archive|Located perl-5.8.8-32.el5_7.6.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/perl-5.8.8-32.el5_7.6.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/perl-5.8.8-32.el5_7.6.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Copy libxml2-2.6.26-2.1.15.el5_8.2.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:56 populate_rpm_archive|Located libxml2-2.6.26-2.1.15.el5_8.2.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/libxml2-2.6.26-2.1.15.el5_8.2.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/libxml2-2.6.26-2.1.15.el5_8.2.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Copy libxslt-1.1.17-2.el5_2.2.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:56 populate_rpm_archive|Located libxslt-1.1.17-2.el5_2.2.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/libxslt-1.1.17-2.el5_2.2.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/libxslt-1.1.17-2.el5_2.2.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Copy libcap-1.10-26.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:56 populate_rpm_archive|Located libcap-1.10-26.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/libcap-1.10-26.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/libcap-1.10-26.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Copy os-ver-5.0.0.0-2.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:56 populate_rpm_archive|Located os-ver-5.0.0.0-2.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/os-ver-5.0.0.0-2.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/os-ver-5.0.0.0-2.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Copy platform-install-2.0.0.1-1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:56 populate_rpm_archive|Located platform-install-2.0.0.1-1.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/platform-install-2.0.0.1-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/platform-install-2.0.0.1-1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Copy jdk-1.6.0_31-fcs.i586.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:56 populate_rpm_archive|Located jdk-1.6.0_31-fcs.i586.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/jdk-1.6.0_31-fcs.i586.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/jdk-1.6.0_31-fcs.i586.rpm" to command list|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Copy java-provides-1.0.0.2-0.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:56 populate_rpm_archive|Located java-provides-1.0.0.2-0.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/java-provides-1.0.0.2-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/java-provides-1.0.0.2-0.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Copy ndisc6-0.7.1-1.el5.rf.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:44:56 populate_rpm_archive|Located ndisc6-0.7.1-1.el5.rf.i386.rpm in /mnt/source/RedHat/RPMS|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Add "cp /mnt/source/RedHat/RPMS/ndisc6-0.7.1-1.el5.rf.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ndisc6-0.7.1-1.el5.rf.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Building the command list for os is complete|<:INFO>
01/24/2012 18:44:56 populate_rpm_archive|Execute commands in the command list|<:INFO>
01/24/2012 18:44:56 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/acpid-1.0.4-9.el5_4.2.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/acpid-1.0.4-9.el5_4.2.i386.rpm"|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/audit-1.7.17-3.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/audit-1.7.17-3.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/audit-libs-1.7.17-3.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/audit-libs-1.7.17-3.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/audit-libs-python-1.7.17-3.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/audit-libs-python-1.7.17-3.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/authconfig-5.3.21-6.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/authconfig-5.3.21-6.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/basesystem-8.0-5.1.1.noarch.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/basesystem-8.0-5.1.1.noarch.rpm"|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/bash-3.2-32.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/bash-3.2-32.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/beecrypt-4.1.2-10.1.1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/beecrypt-4.1.2-10.1.1.i386.rpm"|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/bzip2-libs-1.0.3-6.el5_5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/bzip2-libs-1.0.3-6.el5_5.i386.rpm"|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/chkconfig-1.3.30.2-2.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/chkconfig-1.3.30.2-2.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/coreutils-5.97-23.el5_4.2.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/coreutils-5.97-23.el5_4.2.i386.rpm"|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/cpio-2.6-23.el5_4.1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/cpio-2.6-23.el5_4.1.i386.rpm"|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/cracklib-2.8.9-3.3.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/cracklib-2.8.9-3.3.i386.rpm"|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/cracklib-dicts-2.8.9-3.3.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/cracklib-dicts-2.8.9-3.3.i386.rpm"|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/cryptsetup-luks-1.0.3-5.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/cryptsetup-luks-1.0.3-5.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/cyrus-sasl-lib-2.1.22-5.el5_4.3.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/cyrus-sasl-lib-2.1.22-5.el5_4.3.i386.rpm"|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/db4-4.3.29-10.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/db4-4.3.29-10.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/dbus-1.1.2-16.el5_7.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/dbus-1.1.2-16.el5_7.i386.rpm"|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/dbus-glib-0.73-10.el5_5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/dbus-glib-0.73-10.el5_5.i386.rpm"|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/dbus-libs-1.1.2-16.el5_7.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/dbus-libs-1.1.2-16.el5_7.i386.rpm"|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/dbus-python-0.70-9.el5_4.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/dbus-python-0.70-9.el5_4.i386.rpm"|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/device-mapper-1.02.39-1.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/device-mapper-1.02.39-1.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/device-mapper-event-1.02.39-1.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/device-mapper-event-1.02.39-1.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/device-mapper-multipath-0.4.7-34.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/device-mapper-multipath-0.4.7-34.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/dmraid-1.0.0.rc13-63.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/dmraid-1.0.0.rc13-63.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/dmraid-events-1.0.0.rc13-63.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/dmraid-events-1.0.0.rc13-63.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/e2fsprogs-1.39-23.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/e2fsprogs-1.39-23.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/e2fsprogs-libs-1.39-23.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/e2fsprogs-libs-1.39-23.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/elfutils-libelf-0.137-3.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/elfutils-libelf-0.137-3.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/expat-1.95.8-8.3.el5_4.2.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/expat-1.95.8-8.3.el5_4.2.i386.rpm"|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/file-4.17-15.el5_3.1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/file-4.17-15.el5_3.1.i386.rpm"|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/filesystem-2.4.0-3.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/filesystem-2.4.0-3.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:44:56 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/findutils-4.2.27-6.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/findutils-4.2.27-6.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:44:57 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/fipscheck-lib-1.2.0-1.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/fipscheck-lib-1.2.0-1.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:44:57 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/gawk-3.1.5-14.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/gawk-3.1.5-14.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:44:57 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/gdbm-1.8.0-26.2.1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/gdbm-1.8.0-26.2.1.i386.rpm"|<:DEBUG>
01/24/2012 18:44:57 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/glib2-2.12.3-4.el5_3.1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/glib2-2.12.3-4.el5_3.1.i386.rpm"|<:DEBUG>
01/24/2012 18:44:57 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/glibc-2.5-81.el5_8.1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/glibc-2.5-81.el5_8.1.i386.rpm"|<:DEBUG>
01/24/2012 18:44:57 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/glibc-common-2.5-81.el5_8.1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/glibc-common-2.5-81.el5_8.1.i386.rpm"|<:DEBUG>
01/24/2012 18:44:58 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/gmp-4.1.4-10.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/gmp-4.1.4-10.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:44:58 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/gnutls-1.4.1-3.el5_4.8.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/gnutls-1.4.1-3.el5_4.8.i386.rpm"|<:DEBUG>
01/24/2012 18:44:58 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/grep-2.5.1-55.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/grep-2.5.1-55.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:44:58 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/grub-0.97-13.5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/grub-0.97-13.5.i386.rpm"|<:DEBUG>
01/24/2012 18:44:58 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/gzip-1.3.5-11.el5_4.1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/gzip-1.3.5-11.el5_4.1.i386.rpm"|<:DEBUG>
01/24/2012 18:44:58 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/hal-0.5.8.1-59.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/hal-0.5.8.1-59.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:44:58 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/hdparm-6.6-2.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/hdparm-6.6-2.i386.rpm"|<:DEBUG>
01/24/2012 18:44:58 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/hmaccalc-0.9.6-3.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/hmaccalc-0.9.6-3.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:44:58 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/hwdata-0.213.18-1.el5.1.noarch.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/hwdata-0.213.18-1.el5.1.noarch.rpm"|<:DEBUG>
01/24/2012 18:44:58 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/info-4.8-14.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/info-4.8-14.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:44:58 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/initscripts-8.45.42-1.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/initscripts-8.45.42-1.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:44:58 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/iproute-2.6.18-11.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/iproute-2.6.18-11.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:44:58 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/iputils-20020927-46.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/iputils-20020927-46.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:44:58 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/kbd-1.12-21.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/kbd-1.12-21.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:44:58 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/kernel-PAE-2.6.18-194.26.1.el5.i686.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/kernel-PAE-2.6.18-194.26.1.el5.i686.rpm"|<:DEBUG>
01/24/2012 18:44:58 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/keyutils-libs-1.2-1.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/keyutils-libs-1.2-1.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:44:58 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/kpartx-0.4.7-34.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/kpartx-0.4.7-34.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:44:58 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/krb5-libs-1.6.1-70.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/krb5-libs-1.6.1-70.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:44:58 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/kudzu-1.2.57.1.24-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/kudzu-1.2.57.1.24-1.i386.rpm"|<:DEBUG>
01/24/2012 18:44:58 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/less-436-2.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/less-436-2.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:44:58 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/libacl-2.2.39-6.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/libacl-2.2.39-6.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:44:58 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/libattr-2.4.32-1.1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/libattr-2.4.32-1.1.i386.rpm"|<:DEBUG>
01/24/2012 18:44:58 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/libgcc-4.1.2-50.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/libgcc-4.1.2-50.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:44:58 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/libgcrypt-1.4.4-5.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/libgcrypt-1.4.4-5.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:44:58 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/libgpg-error-1.4-2.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/libgpg-error-1.4-2.i386.rpm"|<:DEBUG>
01/24/2012 18:44:58 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/libidn-0.6.5-1.1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/libidn-0.6.5-1.1.i386.rpm"|<:DEBUG>
01/24/2012 18:44:58 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/libselinux-1.33.4-5.5.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/libselinux-1.33.4-5.5.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:44:58 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/libselinux-python-1.33.4-5.5.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/libselinux-python-1.33.4-5.5.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:44:58 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/libselinux-utils-1.33.4-5.5.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/libselinux-utils-1.33.4-5.5.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:44:58 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/libsemanage-1.9.1-4.4.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/libsemanage-1.9.1-4.4.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:44:58 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/libsepol-1.15.2-3.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/libsepol-1.15.2-3.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:44:58 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/libsysfs-2.0.0-6.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/libsysfs-2.0.0-6.i386.rpm"|<:DEBUG>
01/24/2012 18:44:58 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/libtermcap-2.0.8-46.1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/libtermcap-2.0.8-46.1.i386.rpm"|<:DEBUG>
01/24/2012 18:44:58 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/libusb-0.1.12-5.1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/libusb-0.1.12-5.1.i386.rpm"|<:DEBUG>
01/24/2012 18:44:58 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/libuser-0.54.7-2.1.el5_5.2.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/libuser-0.54.7-2.1.el5_5.2.i386.rpm"|<:DEBUG>
01/24/2012 18:44:58 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/libutempter-1.1.4-4.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/libutempter-1.1.4-4.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:44:58 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/libvolume_id-095-14.21.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/libvolume_id-095-14.21.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:44:58 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/lm_sensors-2.10.7-9.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/lm_sensors-2.10.7-9.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:44:58 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/lsscsi-0.17-3.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/lsscsi-0.17-3.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:44:58 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/lvm2-2.02.56-8.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/lvm2-2.02.56-8.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:44:59 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/MAKEDEV-3.23-1.2.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/MAKEDEV-3.23-1.2.i386.rpm"|<:DEBUG>
01/24/2012 18:44:59 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/mcstrans-0.2.11-3.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/mcstrans-0.2.11-3.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:44:59 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/mingetty-1.07-5.2.2.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/mingetty-1.07-5.2.2.i386.rpm"|<:DEBUG>
01/24/2012 18:44:59 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/mkinitrd-5.1.19.6-61.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/mkinitrd-5.1.19.6-61.i386.rpm"|<:DEBUG>
01/24/2012 18:44:59 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/mktemp-1.5-23.2.2.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/mktemp-1.5-23.2.2.i386.rpm"|<:DEBUG>
01/24/2012 18:44:59 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/module-init-tools-3.3-0.pre3.1.60.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/module-init-tools-3.3-0.pre3.1.60.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:44:59 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/nash-5.1.19.6-61.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/nash-5.1.19.6-61.i386.rpm"|<:DEBUG>
01/24/2012 18:44:59 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/ncurses-5.5-24.20060715.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ncurses-5.5-24.20060715.i386.rpm"|<:DEBUG>
01/24/2012 18:44:59 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/net-tools-1.60-81.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/net-tools-1.60-81.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:44:59 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/newt-0.52.2-15.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/newt-0.52.2-15.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:44:59 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/nspr-4.8.8-1.el5_7.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/nspr-4.8.8-1.el5_7.i386.rpm"|<:DEBUG>
01/24/2012 18:44:59 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/nss-3.12.10-7.el5_7.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/nss-3.12.10-7.el5_7.i386.rpm"|<:DEBUG>
01/24/2012 18:44:59 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/nss-tools-3.12.10-7.el5_7.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/nss-tools-3.12.10-7.el5_7.i386.rpm"|<:DEBUG>
01/24/2012 18:44:59 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/OpenIPMI-2.0.16-7.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/OpenIPMI-2.0.16-7.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:44:59 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/OpenIPMI-libs-2.0.16-7.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/OpenIPMI-libs-2.0.16-7.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:44:59 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/openldap-2.3.43-12.el5_6.7.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/openldap-2.3.43-12.el5_6.7.i386.rpm"|<:DEBUG>
01/24/2012 18:44:59 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/openssl-0.9.8e-22.el5_8.3.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/openssl-0.9.8e-22.el5_8.3.i386.rpm"|<:DEBUG>
01/24/2012 18:44:59 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/openswan-2.6.21-5.el5_4.3.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/openswan-2.6.21-5.el5_4.3.i386.rpm"|<:DEBUG>
01/24/2012 18:44:59 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/pam-0.99.6.2-6.el5_5.2.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/pam-0.99.6.2-6.el5_5.2.i386.rpm"|<:DEBUG>
01/24/2012 18:44:59 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/passwd-0.73-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/passwd-0.73-1.i386.rpm"|<:DEBUG>
01/24/2012 18:44:59 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/pcre-6.6-2.el5_1.7.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/pcre-6.6-2.el5_1.7.i386.rpm"|<:DEBUG>
01/24/2012 18:44:59 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/pm-utils-0.99.3-10.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/pm-utils-0.99.3-10.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:44:59 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/policycoreutils-1.33.12-14.8.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/policycoreutils-1.33.12-14.8.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:44:59 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/policycoreutils-newrole-1.33.12-14.8.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/policycoreutils-newrole-1.33.12-14.8.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:44:59 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/popt-1.10.2.3-22.el5_7.2.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/popt-1.10.2.3-22.el5_7.2.i386.rpm"|<:DEBUG>
01/24/2012 18:44:59 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/portmap-4.0-65.2.2.1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/portmap-4.0-65.2.2.1.i386.rpm"|<:DEBUG>
01/24/2012 18:44:59 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/procps-3.2.7-16.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/procps-3.2.7-16.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:44:59 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/psmisc-22.2-7.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/psmisc-22.2-7.i386.rpm"|<:DEBUG>
01/24/2012 18:44:59 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/pygobject2-2.12.1-5.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/pygobject2-2.12.1-5.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:44:59 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/python-2.4.3-44.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/python-2.4.3-44.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:44:59 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/python-libs-2.4.3-44.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/python-libs-2.4.3-44.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:44:59 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/PyXML-0.8.4-4.el5_4.2.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/PyXML-0.8.4-4.el5_4.2.i386.rpm"|<:DEBUG>
01/24/2012 18:44:59 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/readline-5.1-3.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/readline-5.1-3.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:44:59 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/redhat-logos-4.9.16-1.noarch.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/redhat-logos-4.9.16-1.noarch.rpm"|<:DEBUG>
01/24/2012 18:45:00 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/redhat-release-5Server-5.5.0.2.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/redhat-release-5Server-5.5.0.2.i386.rpm"|<:DEBUG>
01/24/2012 18:45:00 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/rootfiles-8.1-1.1.1.noarch.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/rootfiles-8.1-1.1.1.noarch.rpm"|<:DEBUG>
01/24/2012 18:45:00 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/rpm-4.4.2.3-28.el5_8.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/rpm-4.4.2.3-28.el5_8.i386.rpm"|<:DEBUG>
01/24/2012 18:45:00 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/rpm-libs-4.4.2.3-28.el5_8.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/rpm-libs-4.4.2.3-28.el5_8.i386.rpm"|<:DEBUG>
01/24/2012 18:45:00 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/rpm-python-4.4.2.3-28.el5_8.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/rpm-python-4.4.2.3-28.el5_8.i386.rpm"|<:DEBUG>
01/24/2012 18:45:00 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/sed-4.1.5-5.fc6.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/sed-4.1.5-5.fc6.i386.rpm"|<:DEBUG>
01/24/2012 18:45:00 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/selinux-policy-2.4.6-279.el5.noarch.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/selinux-policy-2.4.6-279.el5.noarch.rpm"|<:DEBUG>
01/24/2012 18:45:00 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/selinux-policy-strict-2.4.6-279.el5.noarch.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/selinux-policy-strict-2.4.6-279.el5.noarch.rpm"|<:DEBUG>
01/24/2012 18:45:00 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/setroubleshoot-plugins-2.0.4-2.el5.noarch.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/setroubleshoot-plugins-2.0.4-2.el5.noarch.rpm"|<:DEBUG>
01/24/2012 18:45:00 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/setroubleshoot-server-2.0.5-5.el5_8.1.noarch.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/setroubleshoot-server-2.0.5-5.el5_8.1.noarch.rpm"|<:DEBUG>
01/24/2012 18:45:00 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/setserial-2.17-19.2.2.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/setserial-2.17-19.2.2.i386.rpm"|<:DEBUG>
01/24/2012 18:45:00 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/setup-2.5.58-7.el5.noarch.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/setup-2.5.58-7.el5.noarch.rpm"|<:DEBUG>
01/24/2012 18:45:00 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/sg3_utils-libs-1.25-4.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/sg3_utils-libs-1.25-4.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:45:00 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/sgpio-1.2.0_10-2.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/sgpio-1.2.0_10-2.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:45:00 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/shadow-utils-4.0.17-15.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/shadow-utils-4.0.17-15.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:45:00 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/slang-2.0.6-4.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/slang-2.0.6-4.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:45:00 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/squashfs-tools-3.0-4.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/squashfs-tools-3.0-4.i386.rpm"|<:DEBUG>
01/24/2012 18:45:00 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/sqlite-3.3.6-5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/sqlite-3.3.6-5.i386.rpm"|<:DEBUG>
01/24/2012 18:45:00 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/sysfsutils-2.0.0-6.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/sysfsutils-2.0.0-6.i386.rpm"|<:DEBUG>
01/24/2012 18:45:00 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/sysklogd-1.4.1-46.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/sysklogd-1.4.1-46.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:45:00 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/sysstat-7.0.2-11.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/sysstat-7.0.2-11.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:45:00 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/SysVinit-2.86-15.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/SysVinit-2.86-15.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:45:00 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/tar-1.15.1-30.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/tar-1.15.1-30.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:45:00 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/termcap-5.5-1.20060701.1.noarch.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/termcap-5.5-1.20060701.1.noarch.rpm"|<:DEBUG>
01/24/2012 18:45:00 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/tzdata-2012c-1.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/tzdata-2012c-1.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:45:00 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/udev-095-14.21.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/udev-095-14.21.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:45:00 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/usbutils-0.71-2.1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/usbutils-0.71-2.1.i386.rpm"|<:DEBUG>
01/24/2012 18:45:00 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/usermode-1.88-3.el5.2.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/usermode-1.88-3.el5.2.i386.rpm"|<:DEBUG>
01/24/2012 18:45:00 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/util-linux-2.13-0.59.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/util-linux-2.13-0.59.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:45:00 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/vim-minimal-7.0.109-6.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/vim-minimal-7.0.109-6.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:45:00 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/which-2.16-7.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/which-2.16-7.i386.rpm"|<:DEBUG>
01/24/2012 18:45:01 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/words-3.0-9.1.noarch.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/words-3.0-9.1.noarch.rpm"|<:DEBUG>
01/24/2012 18:45:01 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/xinetd-2.3.14-10.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/xinetd-2.3.14-10.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:45:01 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/zlib-1.2.3-3.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/zlib-1.2.3-3.i386.rpm"|<:DEBUG>
01/24/2012 18:45:01 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/kexec-tools-1.102pre-154.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/kexec-tools-1.102pre-154.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:45:01 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/busybox-1.2.0-13.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/busybox-1.2.0-13.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:45:01 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/ipt-hashlimit-1.2-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ipt-hashlimit-1.2-0.i386.rpm"|<:DEBUG>
01/24/2012 18:45:01 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/unixODBC-2.2.11-7.1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/unixODBC-2.2.11-7.1.i386.rpm"|<:DEBUG>
01/24/2012 18:45:01 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/ntp-4.2.2p1-9.el5_4.1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ntp-4.2.2p1-9.el5_4.1.i386.rpm"|<:DEBUG>
01/24/2012 18:45:01 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/libpcap-0.9.4-15.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/libpcap-0.9.4-15.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:45:01 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/libxml2-python-2.6.26-2.1.15.el5_8.2.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/libxml2-python-2.6.26-2.1.15.el5_8.2.i386.rpm"|<:DEBUG>
01/24/2012 18:45:01 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/vim-enhanced-7.0.109-6.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/vim-enhanced-7.0.109-6.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:45:01 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/screen-4.0.3-1.el5_4.1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/screen-4.0.3-1.el5_4.1.i386.rpm"|<:DEBUG>
01/24/2012 18:45:01 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/strace-4.5.18-5.el5_4.1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/strace-4.5.18-5.el5_4.1.i386.rpm"|<:DEBUG>
01/24/2012 18:45:01 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/gdb-7.0.1-23.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/gdb-7.0.1-23.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:45:01 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/compat-libstdc++-33-3.2.3-61.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/compat-libstdc++-33-3.2.3-61.i386.rpm"|<:DEBUG>
01/24/2012 18:45:01 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/struts-1.1-3.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/struts-1.1-3.i386.rpm"|<:DEBUG>
01/24/2012 18:45:01 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/tomcat-6.0.29-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/tomcat-6.0.29-0.i386.rpm"|<:DEBUG>
01/24/2012 18:45:02 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/xmlstarlet-1.0.1-1.i586.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/xmlstarlet-1.0.1-1.i586.rpm"|<:DEBUG>
01/24/2012 18:45:02 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/cactus-12.1.5-3.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/cactus-12.1.5-3.i386.rpm"|<:DEBUG>
01/24/2012 18:45:02 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/ecs-1.4.2-3.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ecs-1.4.2-3.i386.rpm"|<:DEBUG>
01/24/2012 18:45:02 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/elixir-4.2-3.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/elixir-4.2-3.i386.rpm"|<:DEBUG>
01/24/2012 18:45:02 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/jaxm-1.1.2-3.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/jaxm-1.1.2-3.i386.rpm"|<:DEBUG>
01/24/2012 18:45:02 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/log4j-1.2.8-3.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/log4j-1.2.8-3.i386.rpm"|<:DEBUG>
01/24/2012 18:45:02 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/mail-1.0.0-3.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/mail-1.0.0-3.i386.rpm"|<:DEBUG>
01/24/2012 18:45:02 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/pgjdbc-7.3.3-3.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/pgjdbc-7.3.3-3.i386.rpm"|<:DEBUG>
01/24/2012 18:45:02 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/regexp-1.3-3.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/regexp-1.3-3.i386.rpm"|<:DEBUG>
01/24/2012 18:45:02 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/activation-1.0.0-3.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/activation-1.0.0-3.i386.rpm"|<:DEBUG>
01/24/2012 18:45:02 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/saaj-1.3-4.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/saaj-1.3-4.i386.rpm"|<:DEBUG>
01/24/2012 18:45:03 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/xerces-2.6.2-3.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/xerces-2.6.2-3.i386.rpm"|<:DEBUG>
01/24/2012 18:45:03 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/xalan-2.7.0-3.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/xalan-2.7.0-3.i386.rpm"|<:DEBUG>
01/24/2012 18:45:03 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/acl-2.2.39-6.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/acl-2.2.39-6.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:45:03 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/at-3.1.8-84.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/at-3.1.8-84.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:45:03 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/attr-2.4.32-1.1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/attr-2.4.32-1.1.i386.rpm"|<:DEBUG>
01/24/2012 18:45:03 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/bc-1.06-21.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/bc-1.06-21.i386.rpm"|<:DEBUG>
01/24/2012 18:45:03 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/bind-libs-9.3.6-16.P1.el5_7.1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/bind-libs-9.3.6-16.P1.el5_7.1.i386.rpm"|<:DEBUG>
01/24/2012 18:45:03 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/bind-utils-9.3.6-16.P1.el5_7.1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/bind-utils-9.3.6-16.P1.el5_7.1.i386.rpm"|<:DEBUG>
01/24/2012 18:45:03 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/binutils-2.17.50.0.6-14.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/binutils-2.17.50.0.6-14.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:45:03 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/bzip2-1.0.3-6.el5_5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/bzip2-1.0.3-6.el5_5.i386.rpm"|<:DEBUG>
01/24/2012 18:45:03 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/cpufreq-utils-005-1.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/cpufreq-utils-005-1.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:45:03 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/cpuspeed-1.2.1-9.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/cpuspeed-1.2.1-9.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:45:03 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/crontabs-1.10-8.noarch.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/crontabs-1.10-8.noarch.rpm"|<:DEBUG>
01/24/2012 18:45:03 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/curl-7.15.5-9.el5_6.3.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/curl-7.15.5-9.el5_6.3.i386.rpm"|<:DEBUG>
01/24/2012 18:45:03 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/dhclient-3.0.5-29.el5_7.1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/dhclient-3.0.5-29.el5_7.1.i386.rpm"|<:DEBUG>
01/24/2012 18:45:03 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/dhcpv6-client-1.0.10-18.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/dhcpv6-client-1.0.10-18.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:45:03 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/diffutils-2.8.1-15.2.3.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/diffutils-2.8.1-15.2.3.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:45:03 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/dmidecode-2.10-3.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/dmidecode-2.10-3.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:45:03 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/dos2unix-3.1-27.2.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/dos2unix-3.1-27.2.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:45:03 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/dosfstools-2.11-9.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/dosfstools-2.11-9.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:45:03 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/eject-2.1.5-4.2.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/eject-2.1.5-4.2.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:45:03 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/elfutils-0.137-3.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/elfutils-0.137-3.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:45:03 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/ethtool-6-4.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ethtool-6-4.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:45:03 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/fipscheck-1.2.0-1.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/fipscheck-1.2.0-1.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:45:03 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/gnupg-1.4.5-14.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/gnupg-1.4.5-14.i386.rpm"|<:DEBUG>
01/24/2012 18:45:03 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/gpm-1.20.1-74.1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/gpm-1.20.1-74.1.i386.rpm"|<:DEBUG>
01/24/2012 18:45:03 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/ipsec-tools-0.6.5-13.el5_3.1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ipsec-tools-0.6.5-13.el5_3.1.i386.rpm"|<:DEBUG>
01/24/2012 18:45:03 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/iptables-1.3.5-5.3.el5_4.1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/iptables-1.3.5-5.3.el5_4.1.i386.rpm"|<:DEBUG>
01/24/2012 18:45:03 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/iptables-ipv6-1.3.5-5.3.el5_4.1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/iptables-ipv6-1.3.5-5.3.el5_4.1.i386.rpm"|<:DEBUG>
01/24/2012 18:45:03 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/irqbalance-0.55-15.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/irqbalance-0.55-15.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:45:03 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/krb5-workstation-1.6.1-70.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/krb5-workstation-1.6.1-70.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:45:03 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/logrotate-3.7.4-9.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/logrotate-3.7.4-9.i386.rpm"|<:DEBUG>
01/24/2012 18:45:03 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/lsof-4.78-3.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/lsof-4.78-3.i386.rpm"|<:DEBUG>
01/24/2012 18:45:03 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/make-3.81-3.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/make-3.81-3.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:45:03 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/mgetty-1.1.33-9.fc6.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/mgetty-1.1.33-9.fc6.i386.rpm"|<:DEBUG>
01/24/2012 18:45:03 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/mt-st-0.9b-2.2.2.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/mt-st-0.9b-2.2.2.i386.rpm"|<:DEBUG>
01/24/2012 18:45:03 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/nc-1.84-10.fc6.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/nc-1.84-10.fc6.i386.rpm"|<:DEBUG>
01/24/2012 18:45:03 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/nscd-2.5-65.el5_7.1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/nscd-2.5-65.el5_7.1.i386.rpm"|<:DEBUG>
01/24/2012 18:45:03 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/nss_ldap-253-25.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/nss_ldap-253-25.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:45:03 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/pam_krb5-2.2.14-15.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/pam_krb5-2.2.14-15.i386.rpm"|<:DEBUG>
01/24/2012 18:45:03 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/patch-2.5.4-29.2.3.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/patch-2.5.4-29.2.3.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:45:03 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/pciutils-2.2.3-8.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/pciutils-2.2.3-8.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:45:03 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/pdksh-5.2.14-36.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/pdksh-5.2.14-36.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:45:03 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/radvd-0.9.1-4.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/radvd-0.9.1-4.i386.rpm"|<:DEBUG>
01/24/2012 18:45:03 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/readahead-1.3-8.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/readahead-1.3-8.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:45:03 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/rsync-2.6.8-3.1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/rsync-2.6.8-3.1.i386.rpm"|<:DEBUG>
01/24/2012 18:45:03 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/setarch-2.0-1.1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/setarch-2.0-1.1.i386.rpm"|<:DEBUG>
01/24/2012 18:45:03 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/sg3_utils-1.25-4.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/sg3_utils-1.25-4.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:45:03 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/sos-1.7-9.62.el5.noarch.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/sos-1.7-9.62.el5.noarch.rpm"|<:DEBUG>
01/24/2012 18:45:03 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/star-1.5a75-3.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/star-1.5a75-3.i386.rpm"|<:DEBUG>
01/24/2012 18:45:03 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/stunnel-4.15-2.el5.1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/stunnel-4.15-2.el5.1.i386.rpm"|<:DEBUG>
01/24/2012 18:45:03 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/sudo-1.7.2p1-8.el5_5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/sudo-1.7.2p1-8.el5_5.i386.rpm"|<:DEBUG>
01/24/2012 18:45:03 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/tcpdump-3.9.4-15.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/tcpdump-3.9.4-15.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:45:03 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/tcp_wrappers-7.6-40.7.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/tcp_wrappers-7.6-40.7.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:45:03 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/tcsh-6.14-17.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/tcsh-6.14-17.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:45:03 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/tftp-0.49-2.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/tftp-0.49-2.i386.rpm"|<:DEBUG>
01/24/2012 18:45:03 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/time-1.7-27.2.2.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/time-1.7-27.2.2.i386.rpm"|<:DEBUG>
01/24/2012 18:45:03 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/tmpwatch-2.9.7-1.1.el5.2.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/tmpwatch-2.9.7-1.1.el5.2.i386.rpm"|<:DEBUG>
01/24/2012 18:45:03 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/traceroute-2.0.1-5.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/traceroute-2.0.1-5.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:45:03 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/unzip-5.52-3.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/unzip-5.52-3.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:45:03 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/vim-common-7.0.109-6.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/vim-common-7.0.109-6.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:45:03 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/vixie-cron-4.1-81.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/vixie-cron-4.1-81.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:45:03 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/zip-2.31-2.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/zip-2.31-2.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:45:03 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/tcl-8.4.13-4.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/tcl-8.4.13-4.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:45:03 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/expect-5.43.0-5.1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/expect-5.43.0-5.1.i386.rpm"|<:DEBUG>
01/24/2012 18:45:03 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/libstdc++-4.1.2-48.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/libstdc++-4.1.2-48.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:45:03 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/compat-db-4.2.52-5.1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/compat-db-4.2.52-5.1.i386.rpm"|<:DEBUG>
01/24/2012 18:45:04 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/compat-libstdc++-296-2.96-138.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/compat-libstdc++-296-2.96-138.i386.rpm"|<:DEBUG>
01/24/2012 18:45:04 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/dhcp-3.0.5-29.el5_7.1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/dhcp-3.0.5-29.el5_7.1.i386.rpm"|<:DEBUG>
01/24/2012 18:45:04 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/perl-5.8.8-32.el5_7.6.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/perl-5.8.8-32.el5_7.6.i386.rpm"|<:DEBUG>
01/24/2012 18:45:04 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/libxml2-2.6.26-2.1.15.el5_8.2.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/libxml2-2.6.26-2.1.15.el5_8.2.i386.rpm"|<:DEBUG>
01/24/2012 18:45:04 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/libxslt-1.1.17-2.el5_2.2.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/libxslt-1.1.17-2.el5_2.2.i386.rpm"|<:DEBUG>
01/24/2012 18:45:04 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/libcap-1.10-26.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/libcap-1.10-26.i386.rpm"|<:DEBUG>
01/24/2012 18:45:04 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/os-ver-5.0.0.0-2.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/os-ver-5.0.0.0-2.i386.rpm"|<:DEBUG>
01/24/2012 18:45:04 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/platform-install-2.0.0.1-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/platform-install-2.0.0.1-1.i386.rpm"|<:DEBUG>
01/24/2012 18:45:04 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/jdk-1.6.0_31-fcs.i586.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/jdk-1.6.0_31-fcs.i586.rpm"|<:DEBUG>
01/24/2012 18:45:04 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/java-provides-1.0.0.2-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/java-provides-1.0.0.2-0.i386.rpm"|<:DEBUG>
01/24/2012 18:45:04 populate_rpm_archive|Calling "cp /mnt/source/RedHat/RPMS/ndisc6-0.7.1-1.el5.rf.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ndisc6-0.7.1-1.el5.rf.i386.rpm"|<:DEBUG>
01/24/2012 18:45:04 populate_rpm_archive|Command execution is complete|<:INFO>
01/24/2012 18:45:04 populate_rpm_archive|Populate RPM archive for os type complete|<:INFO>
01/24/2012 18:45:04 populate_rpm_archive|Populate RPM archive for os type RTMTFinish|<:NOTICE>
01/24/2012 18:45:04 populate_rpm_archive|Initializing xproduct API|<:DEBUG>
01/24/2012 18:45:04 populate_rpm_archive|Initializing xcomponent API|<:DEBUG>
01/24/2012 18:45:04 populate_rpm_archive|Initializing xplatformconfig API|<:DEBUG>
01/24/2012 18:45:04 populate_rpm_archive|Calling "source /common/cisco/install/setup/utils.sh"|<:DEBUG>
01/24/2012 18:45:04 populate_rpm_archive|Parse argument type=hw|<:DEBUG>
01/24/2012 18:45:04 populate_rpm_archive|Parse argument mode=upgrade|<:DEBUG>
01/24/2012 18:45:04 populate_rpm_archive|Parse argument archive_version=8.6.2.22900-9|<:DEBUG>
01/24/2012 18:45:04 populate_rpm_archive|Parse argument src_base=/mnt/source|<:DEBUG>
01/24/2012 18:45:04 populate_rpm_archive|Parse argument archive_base=/common/rpm-archive|<:DEBUG>
01/24/2012 18:45:04 populate_rpm_archive|Parse argument rpms= alsa-lib-1.0.17-1.el5.i386.rpm
alsa-utils-1.0.17-1.el5.i386.rpm
apcupsd-3.14.0-1.el4.i386.rpm
apcupsd-3.14.0-1.el4.i386.rpm_post
apcupsd-3.14.8-1.el5.i386.rpm
cciss-1.1-0.i386.rpm
cpld-110426.tgz
cpld-110426.tgz_post
dir5.20.02pfmagent.rpm
dir5.20.02pfmagent.rpm_post
dir5.20.02pfmagent.rpm_pre
dir5.20.02su2agent.rpm
dir5.20.02su2agent.rpm_post
dir5.20.02su2agent.rpm_pre
ehci-hcd-1.0.1-custom.rhel4.i686.rpm
hpadu-8.26-1.noarch.rpm
hp-finish
hp-health-8.7.0.22-20.rhel5.i386.rpm
hp-ilo-8.5.0-2.custom.rhel5.i386.rpm
hponcfg-1.9.0-3.noarch.rpm
hp-OpenIPMI-8.5.2-86.custom.rhel5.i386.rpm
hp-snmp-agents-8.7.0.23-18.custom.17.i386.rpm
hp_watchdog
ibm_da_cleanup.sh
ibm_da_install
ibm_dsa-3.20-rhel5.i386.rpm
ibm_raid_battery_learn_cycle
ibm_sw_dir_5.20.02pfn_linux_i386_06_19_09.sh
ibm_sw_dir_5.20.02pfp_linux_i386.sh
iLO2_flash
iLO2_flash_post
init_wrapper.sh
install_cimserverd.sh
lsi_mr_hhr-00.05.0503-1.rhel5.i386_06_19_09.rpm
migrateVMwareTools.sh
mptlinux-redhat4.0-3.13.04.00-2.i686.rpm
net-snmp|<:DEBUG>
01/24/2012 18:45:04 populate_rpm_archive|Populate RPM archive for hw type, mode upgrade|<:INFO>
01/24/2012 18:45:04 populate_rpm_archive|Populate RPM archive for hw type , mode upgrade RTMTStart|<:NOTICE>
01/24/2012 18:45:04 populate_rpm_archive|Initialize global data, mode upgrade|<:INFO>
01/24/2012 18:45:04 populate_rpm_archive|Initialize global data, mode upgrade complete|<:INFO>
01/24/2012 18:45:04 populate_rpm_archive|Initialize command list|<:DEBUG>
01/24/2012 18:45:04 populate_rpm_archive|Initialize component data, mode upgrade|<:INFO>
01/24/2012 18:45:04 populate_rpm_archive|Initialize component data, mode upgrade complete|<:INFO>
01/24/2012 18:45:04 populate_rpm_archive|Build the command list for hw|<:INFO>
01/24/2012 18:45:04 populate_rpm_archive|Copy alsa-lib-1.0.17-1.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:45:04 populate_rpm_archive|Located alsa-lib-1.0.17-1.el5.i386.rpm in /mnt/source/Cisco/hssi/install_pool|<:DEBUG>
01/24/2012 18:45:04 populate_rpm_archive|Add "cp /mnt/source/Cisco/hssi/install_pool/alsa-lib-1.0.17-1.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/alsa-lib-1.0.17-1.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:04 populate_rpm_archive|Copy alsa-utils-1.0.17-1.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:45:04 populate_rpm_archive|Located alsa-utils-1.0.17-1.el5.i386.rpm in /mnt/source/Cisco/hssi/install_pool|<:DEBUG>
01/24/2012 18:45:04 populate_rpm_archive|Add "cp /mnt/source/Cisco/hssi/install_pool/alsa-utils-1.0.17-1.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/alsa-utils-1.0.17-1.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:04 populate_rpm_archive|Copy apcupsd-3.14.0-1.el4.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:45:04 populate_rpm_archive|Located apcupsd-3.14.0-1.el4.i386.rpm in /mnt/source/Cisco/hssi/install_pool|<:DEBUG>
01/24/2012 18:45:04 populate_rpm_archive|Add "cp /mnt/source/Cisco/hssi/install_pool/apcupsd-3.14.0-1.el4.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/apcupsd-3.14.0-1.el4.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:04 populate_rpm_archive|Copy apcupsd-3.14.0-1.el4.i386.rpm_post to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:45:04 populate_rpm_archive|Located apcupsd-3.14.0-1.el4.i386.rpm_post in /mnt/source/Cisco/hssi/install_pool|<:DEBUG>
01/24/2012 18:45:04 populate_rpm_archive|Add "cp /mnt/source/Cisco/hssi/install_pool/apcupsd-3.14.0-1.el4.i386.rpm_post /common/rpm-archive/8.6.2.22900-9/RPMS/apcupsd-3.14.0-1.el4.i386.rpm_post" to command list|<:DEBUG>
01/24/2012 18:45:04 populate_rpm_archive|Copy apcupsd-3.14.8-1.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:45:04 populate_rpm_archive|Located apcupsd-3.14.8-1.el5.i386.rpm in /mnt/source/Cisco/hssi/install_pool|<:DEBUG>
01/24/2012 18:45:04 populate_rpm_archive|Add "cp /mnt/source/Cisco/hssi/install_pool/apcupsd-3.14.8-1.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/apcupsd-3.14.8-1.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:04 populate_rpm_archive|Copy cciss-1.1-0.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:45:04 populate_rpm_archive|Located cciss-1.1-0.i386.rpm in /mnt/source/Cisco/hssi/install_pool|<:DEBUG>
01/24/2012 18:45:04 populate_rpm_archive|Add "cp /mnt/source/Cisco/hssi/install_pool/cciss-1.1-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/cciss-1.1-0.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:04 populate_rpm_archive|Copy cpld-110426.tgz to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:45:04 populate_rpm_archive|Located cpld-110426.tgz in /mnt/source/Cisco/hssi/install_pool|<:DEBUG>
01/24/2012 18:45:04 populate_rpm_archive|Add "cp /mnt/source/Cisco/hssi/install_pool/cpld-110426.tgz /common/rpm-archive/8.6.2.22900-9/RPMS/cpld-110426.tgz" to command list|<:DEBUG>
01/24/2012 18:45:04 populate_rpm_archive|Copy cpld-110426.tgz_post to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:45:04 populate_rpm_archive|Located cpld-110426.tgz_post in /mnt/source/Cisco/hssi/install_pool|<:DEBUG>
01/24/2012 18:45:04 populate_rpm_archive|Add "cp /mnt/source/Cisco/hssi/install_pool/cpld-110426.tgz_post /common/rpm-archive/8.6.2.22900-9/RPMS/cpld-110426.tgz_post" to command list|<:DEBUG>
01/24/2012 18:45:04 populate_rpm_archive|Copy dir5.20.02pfmagent.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:45:04 populate_rpm_archive|Located dir5.20.02pfmagent.rpm in /mnt/source/Cisco/hssi/install_pool|<:DEBUG>
01/24/2012 18:45:04 populate_rpm_archive|Add "cp /mnt/source/Cisco/hssi/install_pool/dir5.20.02pfmagent.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/dir5.20.02pfmagent.rpm" to command list|<:DEBUG>
01/24/2012 18:45:04 populate_rpm_archive|Copy dir5.20.02pfmagent.rpm_post to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:45:04 populate_rpm_archive|Located dir5.20.02pfmagent.rpm_post in /mnt/source/Cisco/hssi/install_pool|<:DEBUG>
01/24/2012 18:45:04 populate_rpm_archive|Add "cp /mnt/source/Cisco/hssi/install_pool/dir5.20.02pfmagent.rpm_post /common/rpm-archive/8.6.2.22900-9/RPMS/dir5.20.02pfmagent.rpm_post" to command list|<:DEBUG>
01/24/2012 18:45:04 populate_rpm_archive|Copy dir5.20.02pfmagent.rpm_pre to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:45:04 populate_rpm_archive|Located dir5.20.02pfmagent.rpm_pre in /mnt/source/Cisco/hssi/install_pool|<:DEBUG>
01/24/2012 18:45:04 populate_rpm_archive|Add "cp /mnt/source/Cisco/hssi/install_pool/dir5.20.02pfmagent.rpm_pre /common/rpm-archive/8.6.2.22900-9/RPMS/dir5.20.02pfmagent.rpm_pre" to command list|<:DEBUG>
01/24/2012 18:45:04 populate_rpm_archive|Copy dir5.20.02su2agent.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:45:04 populate_rpm_archive|Located dir5.20.02su2agent.rpm in /mnt/source/Cisco/hssi/install_pool|<:DEBUG>
01/24/2012 18:45:04 populate_rpm_archive|Add "cp /mnt/source/Cisco/hssi/install_pool/dir5.20.02su2agent.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/dir5.20.02su2agent.rpm" to command list|<:DEBUG>
01/24/2012 18:45:04 populate_rpm_archive|Copy dir5.20.02su2agent.rpm_post to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:45:04 populate_rpm_archive|Located dir5.20.02su2agent.rpm_post in /mnt/source/Cisco/hssi/install_pool|<:DEBUG>
01/24/2012 18:45:04 populate_rpm_archive|Add "cp /mnt/source/Cisco/hssi/install_pool/dir5.20.02su2agent.rpm_post /common/rpm-archive/8.6.2.22900-9/RPMS/dir5.20.02su2agent.rpm_post" to command list|<:DEBUG>
01/24/2012 18:45:04 populate_rpm_archive|Copy dir5.20.02su2agent.rpm_pre to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:45:04 populate_rpm_archive|Located dir5.20.02su2agent.rpm_pre in /mnt/source/Cisco/hssi/install_pool|<:DEBUG>
01/24/2012 18:45:04 populate_rpm_archive|Add "cp /mnt/source/Cisco/hssi/install_pool/dir5.20.02su2agent.rpm_pre /common/rpm-archive/8.6.2.22900-9/RPMS/dir5.20.02su2agent.rpm_pre" to command list|<:DEBUG>
01/24/2012 18:45:04 populate_rpm_archive|Located ehci-hcd-1.0.1-custom.rhel4.i686.rpm in /mnt/source/Cisco/hssi/install_pool|<:DEBUG>
01/24/2012 18:45:04 populate_rpm_archive|Add "cp /mnt/source/Cisco/hssi/install_pool/ehci-hcd-1.0.1-custom.rhel4.i686.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ehci-hcd-1.0.1-custom.rhel4.i686.rpm" to command list|<:DEBUG>
01/24/2012 18:45:04 populate_rpm_archive|Copy hpadu-8.26-1.noarch.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:45:04 populate_rpm_archive|Located hpadu-8.26-1.noarch.rpm in /mnt/source/Cisco/hssi/install_pool|<:DEBUG>
01/24/2012 18:45:04 populate_rpm_archive|Add "cp /mnt/source/Cisco/hssi/install_pool/hpadu-8.26-1.noarch.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/hpadu-8.26-1.noarch.rpm" to command list|<:DEBUG>
01/24/2012 18:45:04 populate_rpm_archive|Copy hp-finish to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:45:04 populate_rpm_archive|Located hp-finish in /mnt/source/Cisco/hssi/install_pool|<:DEBUG>
01/24/2012 18:45:04 populate_rpm_archive|Add "cp /mnt/source/Cisco/hssi/install_pool/hp-finish /common/rpm-archive/8.6.2.22900-9/RPMS/hp-finish" to command list|<:DEBUG>
01/24/2012 18:45:04 populate_rpm_archive|Copy hp-health-8.7.0.22-20.rhel5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:45:04 populate_rpm_archive|Located hp-health-8.7.0.22-20.rhel5.i386.rpm in /mnt/source/Cisco/hssi/install_pool|<:DEBUG>
01/24/2012 18:45:04 populate_rpm_archive|Add "cp /mnt/source/Cisco/hssi/install_pool/hp-health-8.7.0.22-20.rhel5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/hp-health-8.7.0.22-20.rhel5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:04 populate_rpm_archive|Copy hp-ilo-8.5.0-2.custom.rhel5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:45:04 populate_rpm_archive|Located hp-ilo-8.5.0-2.custom.rhel5.i386.rpm in /mnt/source/Cisco/hssi/install_pool|<:DEBUG>
01/24/2012 18:45:04 populate_rpm_archive|Add "cp /mnt/source/Cisco/hssi/install_pool/hp-ilo-8.5.0-2.custom.rhel5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/hp-ilo-8.5.0-2.custom.rhel5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:04 populate_rpm_archive|Copy hponcfg-1.9.0-3.noarch.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:45:04 populate_rpm_archive|Located hponcfg-1.9.0-3.noarch.rpm in /mnt/source/Cisco/hssi/install_pool|<:DEBUG>
01/24/2012 18:45:04 populate_rpm_archive|Add "cp /mnt/source/Cisco/hssi/install_pool/hponcfg-1.9.0-3.noarch.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/hponcfg-1.9.0-3.noarch.rpm" to command list|<:DEBUG>
01/24/2012 18:45:04 populate_rpm_archive|Copy hp-OpenIPMI-8.5.2-86.custom.rhel5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:45:04 populate_rpm_archive|Located hp-OpenIPMI-8.5.2-86.custom.rhel5.i386.rpm in /mnt/source/Cisco/hssi/install_pool|<:DEBUG>
01/24/2012 18:45:04 populate_rpm_archive|Add "cp /mnt/source/Cisco/hssi/install_pool/hp-OpenIPMI-8.5.2-86.custom.rhel5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/hp-OpenIPMI-8.5.2-86.custom.rhel5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:04 populate_rpm_archive|Copy hp-snmp-agents-8.7.0.23-18.custom.17.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:45:04 populate_rpm_archive|Located hp-snmp-agents-8.7.0.23-18.custom.17.i386.rpm in /mnt/source/Cisco/hssi/install_pool|<:DEBUG>
01/24/2012 18:45:04 populate_rpm_archive|Add "cp /mnt/source/Cisco/hssi/install_pool/hp-snmp-agents-8.7.0.23-18.custom.17.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/hp-snmp-agents-8.7.0.23-18.custom.17.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:04 populate_rpm_archive|Copy hp_watchdog to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:45:04 populate_rpm_archive|Located hp_watchdog in /mnt/source/Cisco/hssi/install_pool|<:DEBUG>
01/24/2012 18:45:04 populate_rpm_archive|Add "cp /mnt/source/Cisco/hssi/install_pool/hp_watchdog /common/rpm-archive/8.6.2.22900-9/RPMS/hp_watchdog" to command list|<:DEBUG>
01/24/2012 18:45:04 populate_rpm_archive|Copy ibm_da_cleanup.sh to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:45:04 populate_rpm_archive|Located ibm_da_cleanup.sh in /mnt/source/Cisco/hssi/install_pool|<:DEBUG>
01/24/2012 18:45:04 populate_rpm_archive|Add "cp /mnt/source/Cisco/hssi/install_pool/ibm_da_cleanup.sh /common/rpm-archive/8.6.2.22900-9/RPMS/ibm_da_cleanup.sh" to command list|<:DEBUG>
01/24/2012 18:45:04 populate_rpm_archive|Copy ibm_da_install to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:45:04 populate_rpm_archive|Located ibm_da_install in /mnt/source/Cisco/hssi/install_pool|<:DEBUG>
01/24/2012 18:45:04 populate_rpm_archive|Add "cp /mnt/source/Cisco/hssi/install_pool/ibm_da_install /common/rpm-archive/8.6.2.22900-9/RPMS/ibm_da_install" to command list|<:DEBUG>
01/24/2012 18:45:04 populate_rpm_archive|Copy ibm_dsa-3.20-rhel5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:45:04 populate_rpm_archive|Located ibm_dsa-3.20-rhel5.i386.rpm in /mnt/source/Cisco/hssi/install_pool|<:DEBUG>
01/24/2012 18:45:04 populate_rpm_archive|Add "cp /mnt/source/Cisco/hssi/install_pool/ibm_dsa-3.20-rhel5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ibm_dsa-3.20-rhel5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:04 populate_rpm_archive|Copy ibm_raid_battery_learn_cycle to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:45:04 populate_rpm_archive|Located ibm_raid_battery_learn_cycle in /mnt/source/Cisco/hssi/install_pool|<:DEBUG>
01/24/2012 18:45:04 populate_rpm_archive|Add "cp /mnt/source/Cisco/hssi/install_pool/ibm_raid_battery_learn_cycle /common/rpm-archive/8.6.2.22900-9/RPMS/ibm_raid_battery_learn_cycle" to command list|<:DEBUG>
01/24/2012 18:45:04 populate_rpm_archive|Copy ibm_sw_dir_5.20.02pfn_linux_i386_06_19_09.sh to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:45:04 populate_rpm_archive|Located ibm_sw_dir_5.20.02pfn_linux_i386_06_19_09.sh in /mnt/source/Cisco/hssi/install_pool|<:DEBUG>
01/24/2012 18:45:04 populate_rpm_archive|Add "cp /mnt/source/Cisco/hssi/install_pool/ibm_sw_dir_5.20.02pfn_linux_i386_06_19_09.sh /common/rpm-archive/8.6.2.22900-9/RPMS/ibm_sw_dir_5.20.02pfn_linux_i386_06_19_09.sh" to command list|<:DEBUG>
01/24/2012 18:45:05 populate_rpm_archive|Copy ibm_sw_dir_5.20.02pfp_linux_i386.sh to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:45:05 populate_rpm_archive|Located ibm_sw_dir_5.20.02pfp_linux_i386.sh in /mnt/source/Cisco/hssi/install_pool|<:DEBUG>
01/24/2012 18:45:05 populate_rpm_archive|Add "cp /mnt/source/Cisco/hssi/install_pool/ibm_sw_dir_5.20.02pfp_linux_i386.sh /common/rpm-archive/8.6.2.22900-9/RPMS/ibm_sw_dir_5.20.02pfp_linux_i386.sh" to command list|<:DEBUG>
01/24/2012 18:45:05 populate_rpm_archive|Copy iLO2_flash to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:45:05 populate_rpm_archive|Located iLO2_flash in /mnt/source/Cisco/hssi/install_pool|<:DEBUG>
01/24/2012 18:45:05 populate_rpm_archive|Add "cp /mnt/source/Cisco/hssi/install_pool/iLO2_flash /common/rpm-archive/8.6.2.22900-9/RPMS/iLO2_flash" to command list|<:DEBUG>
01/24/2012 18:45:05 populate_rpm_archive|Copy iLO2_flash_post to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:45:05 populate_rpm_archive|Located iLO2_flash_post in /mnt/source/Cisco/hssi/install_pool|<:DEBUG>
01/24/2012 18:45:05 populate_rpm_archive|Add "cp /mnt/source/Cisco/hssi/install_pool/iLO2_flash_post /common/rpm-archive/8.6.2.22900-9/RPMS/iLO2_flash_post" to command list|<:DEBUG>
01/24/2012 18:45:05 populate_rpm_archive|Copy init_wrapper.sh to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:45:05 populate_rpm_archive|Located init_wrapper.sh in /mnt/source/Cisco/hssi/install_pool|<:DEBUG>
01/24/2012 18:45:05 populate_rpm_archive|Add "cp /mnt/source/Cisco/hssi/install_pool/init_wrapper.sh /common/rpm-archive/8.6.2.22900-9/RPMS/init_wrapper.sh" to command list|<:DEBUG>
01/24/2012 18:45:05 populate_rpm_archive|Copy install_cimserverd.sh to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:45:05 populate_rpm_archive|Located install_cimserverd.sh in /mnt/source/Cisco/hssi/install_pool|<:DEBUG>
01/24/2012 18:45:05 populate_rpm_archive|Add "cp /mnt/source/Cisco/hssi/install_pool/install_cimserverd.sh /common/rpm-archive/8.6.2.22900-9/RPMS/install_cimserverd.sh" to command list|<:DEBUG>
01/24/2012 18:45:05 populate_rpm_archive|Copy lsi_mr_hhr-00.05.0503-1.rhel5.i386_06_19_09.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:45:05 populate_rpm_archive|Located lsi_mr_hhr-00.05.0503-1.rhel5.i386_06_19_09.rpm in /mnt/source/Cisco/hssi/install_pool|<:DEBUG>
01/24/2012 18:45:05 populate_rpm_archive|Add "cp /mnt/source/Cisco/hssi/install_pool/lsi_mr_hhr-00.05.0503-1.rhel5.i386_06_19_09.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/lsi_mr_hhr-00.05.0503-1.rhel5.i386_06_19_09.rpm" to command list|<:DEBUG>
01/24/2012 18:45:05 populate_rpm_archive|Copy migrateVMwareTools.sh to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:45:05 populate_rpm_archive|Located migrateVMwareTools.sh in /mnt/source/Cisco/hssi/install_pool|<:DEBUG>
01/24/2012 18:45:05 populate_rpm_archive|Add "cp /mnt/source/Cisco/hssi/install_pool/migrateVMwareTools.sh /common/rpm-archive/8.6.2.22900-9/RPMS/migrateVMwareTools.sh" to command list|<:DEBUG>
01/24/2012 18:45:05 populate_rpm_archive|Copy mptlinux-redhat4.0-3.13.04.00-2.i686.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:45:05 populate_rpm_archive|Located mptlinux-redhat4.0-3.13.04.00-2.i686.rpm in /mnt/source/Cisco/hssi/install_pool|<:DEBUG>
01/24/2012 18:45:05 populate_rpm_archive|Add "cp /mnt/source/Cisco/hssi/install_pool/mptlinux-redhat4.0-3.13.04.00-2.i686.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/mptlinux-redhat4.0-3.13.04.00-2.i686.rpm" to command list|<:DEBUG>
01/24/2012 18:45:05 populate_rpm_archive|Copy net-snmp-5.3.2.2-9.el5_5.1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:45:05 populate_rpm_archive|Located net-snmp-5.3.2.2-9.el5_5.1.i386.rpm in /mnt/source/Cisco/hssi/install_pool|<:DEBUG>
01/24/2012 18:45:05 populate_rpm_archive|Add "cp /mnt/source/Cisco/hssi/install_pool/net-snmp-5.3.2.2-9.el5_5.1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/net-snmp-5.3.2.2-9.el5_5.1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:05 populate_rpm_archive|Copy net-snmp-libs-5.3.2.2-9.el5_5.1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:45:05 populate_rpm_archive|Located net-snmp-libs-5.3.2.2-9.el5_5.1.i386.rpm in /mnt/source/Cisco/hssi/install_pool|<:DEBUG>
01/24/2012 18:45:05 populate_rpm_archive|Add "cp /mnt/source/Cisco/hssi/install_pool/net-snmp-libs-5.3.2.2-9.el5_5.1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/net-snmp-libs-5.3.2.2-9.el5_5.1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:05 populate_rpm_archive|Copy net-snmp-utils-5.3.2.2-9.el5_5.1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:45:05 populate_rpm_archive|Located net-snmp-utils-5.3.2.2-9.el5_5.1.i386.rpm in /mnt/source/Cisco/hssi/install_pool|<:DEBUG>
01/24/2012 18:45:05 populate_rpm_archive|Add "cp /mnt/source/Cisco/hssi/install_pool/net-snmp-utils-5.3.2.2-9.el5_5.1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/net-snmp-utils-5.3.2.2-9.el5_5.1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:05 populate_rpm_archive|Copy smartmontools-5.38-2.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:45:05 populate_rpm_archive|Located smartmontools-5.38-2.el5.i386.rpm in /mnt/source/Cisco/hssi/install_pool|<:DEBUG>
01/24/2012 18:45:05 populate_rpm_archive|Add "cp /mnt/source/Cisco/hssi/install_pool/smartmontools-5.38-2.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/smartmontools-5.38-2.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:05 populate_rpm_archive|Copy syslog-ng-3.0.7-1.tgz to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:45:05 populate_rpm_archive|Located syslog-ng-3.0.7-1.tgz in /mnt/source/Cisco/hssi/install_pool|<:DEBUG>
01/24/2012 18:45:05 populate_rpm_archive|Add "cp /mnt/source/Cisco/hssi/install_pool/syslog-ng-3.0.7-1.tgz /common/rpm-archive/8.6.2.22900-9/RPMS/syslog-ng-3.0.7-1.tgz" to command list|<:DEBUG>
01/24/2012 18:45:05 populate_rpm_archive|Copy syslog-ng-3.0.7-1.tgz_post to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:45:05 populate_rpm_archive|Located syslog-ng-3.0.7-1.tgz_post in /mnt/source/Cisco/hssi/install_pool|<:DEBUG>
01/24/2012 18:45:05 populate_rpm_archive|Add "cp /mnt/source/Cisco/hssi/install_pool/syslog-ng-3.0.7-1.tgz_post /common/rpm-archive/8.6.2.22900-9/RPMS/syslog-ng-3.0.7-1.tgz_post" to command list|<:DEBUG>
01/24/2012 18:45:05 populate_rpm_archive|Copy TRANS.TBL to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:45:05 populate_rpm_archive|Located TRANS.TBL in /mnt/source/Cisco/hssi/install_pool|<:DEBUG>
01/24/2012 18:45:05 populate_rpm_archive|Add "cp /mnt/source/Cisco/hssi/install_pool/TRANS.TBL /common/rpm-archive/8.6.2.22900-9/RPMS/TRANS.TBL" to command list|<:DEBUG>
01/24/2012 18:45:05 populate_rpm_archive|Copy uname_mapper_cleanup.sh to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:45:05 populate_rpm_archive|Located uname_mapper_cleanup.sh in /mnt/source/Cisco/hssi/install_pool|<:DEBUG>
01/24/2012 18:45:05 populate_rpm_archive|Add "cp /mnt/source/Cisco/hssi/install_pool/uname_mapper_cleanup.sh /common/rpm-archive/8.6.2.22900-9/RPMS/uname_mapper_cleanup.sh" to command list|<:DEBUG>
01/24/2012 18:45:05 populate_rpm_archive|Copy uname_mapper_setup.sh to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:45:05 populate_rpm_archive|Located uname_mapper_setup.sh in /mnt/source/Cisco/hssi/install_pool|<:DEBUG>
01/24/2012 18:45:05 populate_rpm_archive|Add "cp /mnt/source/Cisco/hssi/install_pool/uname_mapper_setup.sh /common/rpm-archive/8.6.2.22900-9/RPMS/uname_mapper_setup.sh" to command list|<:DEBUG>
01/24/2012 18:45:05 populate_rpm_archive|Copy volaris-fga-2.0.2-1.i386_rh5.5.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:45:05 populate_rpm_archive|Located volaris-fga-2.0.2-1.i386_rh5.5.rpm in /mnt/source/Cisco/hssi/install_pool|<:DEBUG>
01/24/2012 18:45:05 populate_rpm_archive|Add "cp /mnt/source/Cisco/hssi/install_pool/volaris-fga-2.0.2-1.i386_rh5.5.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/volaris-fga-2.0.2-1.i386_rh5.5.rpm" to command list|<:DEBUG>
01/24/2012 18:45:05 populate_rpm_archive|Copy volaris-fga-2.0.2-1.i386_rh5.5.rpm_pre to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:45:05 populate_rpm_archive|Located volaris-fga-2.0.2-1.i386_rh5.5.rpm_pre in /mnt/source/Cisco/hssi/install_pool|<:DEBUG>
01/24/2012 18:45:05 populate_rpm_archive|Add "cp /mnt/source/Cisco/hssi/install_pool/volaris-fga-2.0.2-1.i386_rh5.5.rpm_pre /common/rpm-archive/8.6.2.22900-9/RPMS/volaris-fga-2.0.2-1.i386_rh5.5.rpm_pre" to command list|<:DEBUG>
01/24/2012 18:45:05 populate_rpm_archive|Copy vos_ibm_da.5.20.2-1.0-rhel5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS|<:INFO>
01/24/2012 18:45:05 populate_rpm_archive|Located vos_ibm_da.5.20.2-1.0-rhel5.i386.rpm in /mnt/source/Cisco/hssi/install_pool|<:DEBUG>
01/24/2012 18:45:05 populate_rpm_archive|Add "cp /mnt/source/Cisco/hssi/install_pool/vos_ibm_da.5.20.2-1.0-rhel5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/vos_ibm_da.5.20.2-1.0-rhel5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:05 populate_rpm_archive|Execute commands in the command list|<:INFO>
01/24/2012 18:45:05 populate_rpm_archive|Calling "cp /mnt/source/Cisco/hssi/install_pool/alsa-lib-1.0.17-1.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/alsa-lib-1.0.17-1.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:45:05 populate_rpm_archive|Calling "cp /mnt/source/Cisco/hssi/install_pool/alsa-utils-1.0.17-1.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/alsa-utils-1.0.17-1.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:45:05 populate_rpm_archive|Calling "cp /mnt/source/Cisco/hssi/install_pool/apcupsd-3.14.0-1.el4.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/apcupsd-3.14.0-1.el4.i386.rpm"|<:DEBUG>
01/24/2012 18:45:05 populate_rpm_archive|Calling "cp /mnt/source/Cisco/hssi/install_pool/apcupsd-3.14.0-1.el4.i386.rpm_post /common/rpm-archive/8.6.2.22900-9/RPMS/apcupsd-3.14.0-1.el4.i386.rpm_post"|<:DEBUG>
01/24/2012 18:45:05 populate_rpm_archive|Calling "cp /mnt/source/Cisco/hssi/install_pool/apcupsd-3.14.8-1.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/apcupsd-3.14.8-1.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:45:05 populate_rpm_archive|Calling "cp /mnt/source/Cisco/hssi/install_pool/cciss-1.1-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/cciss-1.1-0.i386.rpm"|<:DEBUG>
01/24/2012 18:45:05 populate_rpm_archive|Calling "cp /mnt/source/Cisco/hssi/install_pool/cpld-110426.tgz /common/rpm-archive/8.6.2.22900-9/RPMS/cpld-110426.tgz"|<:DEBUG>
01/24/2012 18:45:05 populate_rpm_archive|Calling "cp /mnt/source/Cisco/hssi/install_pool/cpld-110426.tgz_post /common/rpm-archive/8.6.2.22900-9/RPMS/cpld-110426.tgz_post"|<:DEBUG>
01/24/2012 18:45:05 populate_rpm_archive|Calling "cp /mnt/source/Cisco/hssi/install_pool/dir5.20.02pfmagent.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/dir5.20.02pfmagent.rpm"|<:DEBUG>
01/24/2012 18:45:05 populate_rpm_archive|Calling "cp /mnt/source/Cisco/hssi/install_pool/dir5.20.02pfmagent.rpm_post /common/rpm-archive/8.6.2.22900-9/RPMS/dir5.20.02pfmagent.rpm_post"|<:DEBUG>
01/24/2012 18:45:05 populate_rpm_archive|Calling "cp /mnt/source/Cisco/hssi/install_pool/dir5.20.02pfmagent.rpm_pre /common/rpm-archive/8.6.2.22900-9/RPMS/dir5.20.02pfmagent.rpm_pre"|<:DEBUG>
01/24/2012 18:45:05 populate_rpm_archive|Calling "cp /mnt/source/Cisco/hssi/install_pool/dir5.20.02su2agent.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/dir5.20.02su2agent.rpm"|<:DEBUG>
01/24/2012 18:45:05 populate_rpm_archive|Calling "cp /mnt/source/Cisco/hssi/install_pool/dir5.20.02su2agent.rpm_post /common/rpm-archive/8.6.2.22900-9/RPMS/dir5.20.02su2agent.rpm_post"|<:DEBUG>
01/24/2012 18:45:05 populate_rpm_archive|Calling "cp /mnt/source/Cisco/hssi/install_pool/dir5.20.02su2agent.rpm_pre /common/rpm-archive/8.6.2.22900-9/RPMS/dir5.20.02su2agent.rpm_pre"|<:DEBUG>
01/24/2012 18:45:05 populate_rpm_archive|Calling "cp /mnt/source/Cisco/hssi/install_pool/ehci-hcd-1.0.1-custom.rhel4.i686.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ehci-hcd-1.0.1-custom.rhel4.i686.rpm"|<:DEBUG>
01/24/2012 18:45:05 populate_rpm_archive|Calling "cp /mnt/source/Cisco/hssi/install_pool/hpadu-8.26-1.noarch.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/hpadu-8.26-1.noarch.rpm"|<:DEBUG>
01/24/2012 18:45:05 populate_rpm_archive|Calling "cp /mnt/source/Cisco/hssi/install_pool/hp-finish /common/rpm-archive/8.6.2.22900-9/RPMS/hp-finish"|<:DEBUG>
01/24/2012 18:45:05 populate_rpm_archive|Calling "cp /mnt/source/Cisco/hssi/install_pool/hp-health-8.7.0.22-20.rhel5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/hp-health-8.7.0.22-20.rhel5.i386.rpm"|<:DEBUG>
01/24/2012 18:45:05 populate_rpm_archive|Calling "cp /mnt/source/Cisco/hssi/install_pool/hp-ilo-8.5.0-2.custom.rhel5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/hp-ilo-8.5.0-2.custom.rhel5.i386.rpm"|<:DEBUG>
01/24/2012 18:45:05 populate_rpm_archive|Calling "cp /mnt/source/Cisco/hssi/install_pool/hponcfg-1.9.0-3.noarch.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/hponcfg-1.9.0-3.noarch.rpm"|<:DEBUG>
01/24/2012 18:45:05 populate_rpm_archive|Calling "cp /mnt/source/Cisco/hssi/install_pool/hp-OpenIPMI-8.5.2-86.custom.rhel5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/hp-OpenIPMI-8.5.2-86.custom.rhel5.i386.rpm"|<:DEBUG>
01/24/2012 18:45:05 populate_rpm_archive|Calling "cp /mnt/source/Cisco/hssi/install_pool/hp-snmp-agents-8.7.0.23-18.custom.17.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/hp-snmp-agents-8.7.0.23-18.custom.17.i386.rpm"|<:DEBUG>
01/24/2012 18:45:05 populate_rpm_archive|Calling "cp /mnt/source/Cisco/hssi/install_pool/hp_watchdog /common/rpm-archive/8.6.2.22900-9/RPMS/hp_watchdog"|<:DEBUG>
01/24/2012 18:45:05 populate_rpm_archive|Calling "cp /mnt/source/Cisco/hssi/install_pool/ibm_da_cleanup.sh /common/rpm-archive/8.6.2.22900-9/RPMS/ibm_da_cleanup.sh"|<:DEBUG>
01/24/2012 18:45:05 populate_rpm_archive|Calling "cp /mnt/source/Cisco/hssi/install_pool/ibm_da_install /common/rpm-archive/8.6.2.22900-9/RPMS/ibm_da_install"|<:DEBUG>
01/24/2012 18:45:05 populate_rpm_archive|Calling "cp /mnt/source/Cisco/hssi/install_pool/ibm_dsa-3.20-rhel5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ibm_dsa-3.20-rhel5.i386.rpm"|<:DEBUG>
01/24/2012 18:45:05 populate_rpm_archive|Calling "cp /mnt/source/Cisco/hssi/install_pool/ibm_raid_battery_learn_cycle /common/rpm-archive/8.6.2.22900-9/RPMS/ibm_raid_battery_learn_cycle"|<:DEBUG>
01/24/2012 18:45:05 populate_rpm_archive|Calling "cp /mnt/source/Cisco/hssi/install_pool/ibm_sw_dir_5.20.02pfn_linux_i386_06_19_09.sh /common/rpm-archive/8.6.2.22900-9/RPMS/ibm_sw_dir_5.20.02pfn_linux_i386_06_19_09.sh"|<:DEBUG>
01/24/2012 18:45:05 populate_rpm_archive|Calling "cp /mnt/source/Cisco/hssi/install_pool/ibm_sw_dir_5.20.02pfp_linux_i386.sh /common/rpm-archive/8.6.2.22900-9/RPMS/ibm_sw_dir_5.20.02pfp_linux_i386.sh"|<:DEBUG>
01/24/2012 18:45:05 populate_rpm_archive|Calling "cp /mnt/source/Cisco/hssi/install_pool/iLO2_flash /common/rpm-archive/8.6.2.22900-9/RPMS/iLO2_flash"|<:DEBUG>
01/24/2012 18:45:05 populate_rpm_archive|Calling "cp /mnt/source/Cisco/hssi/install_pool/iLO2_flash_post /common/rpm-archive/8.6.2.22900-9/RPMS/iLO2_flash_post"|<:DEBUG>
01/24/2012 18:45:05 populate_rpm_archive|Calling "cp /mnt/source/Cisco/hssi/install_pool/init_wrapper.sh /common/rpm-archive/8.6.2.22900-9/RPMS/init_wrapper.sh"|<:DEBUG>
01/24/2012 18:45:05 populate_rpm_archive|Calling "cp /mnt/source/Cisco/hssi/install_pool/install_cimserverd.sh /common/rpm-archive/8.6.2.22900-9/RPMS/install_cimserverd.sh"|<:DEBUG>
01/24/2012 18:45:05 populate_rpm_archive|Calling "cp /mnt/source/Cisco/hssi/install_pool/lsi_mr_hhr-00.05.0503-1.rhel5.i386_06_19_09.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/lsi_mr_hhr-00.05.0503-1.rhel5.i386_06_19_09.rpm"|<:DEBUG>
01/24/2012 18:45:06 populate_rpm_archive|Calling "cp /mnt/source/Cisco/hssi/install_pool/migrateVMwareTools.sh /common/rpm-archive/8.6.2.22900-9/RPMS/migrateVMwareTools.sh"|<:DEBUG>
01/24/2012 18:45:06 populate_rpm_archive|Calling "cp /mnt/source/Cisco/hssi/install_pool/mptlinux-redhat4.0-3.13.04.00-2.i686.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/mptlinux-redhat4.0-3.13.04.00-2.i686.rpm"|<:DEBUG>
01/24/2012 18:45:06 populate_rpm_archive|Calling "cp /mnt/source/Cisco/hssi/install_pool/net-snmp-5.3.2.2-9.el5_5.1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/net-snmp-5.3.2.2-9.el5_5.1.i386.rpm"|<:DEBUG>
01/24/2012 18:45:06 populate_rpm_archive|Calling "cp /mnt/source/Cisco/hssi/install_pool/net-snmp-libs-5.3.2.2-9.el5_5.1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/net-snmp-libs-5.3.2.2-9.el5_5.1.i386.rpm"|<:DEBUG>
01/24/2012 18:45:06 populate_rpm_archive|Calling "cp /mnt/source/Cisco/hssi/install_pool/net-snmp-utils-5.3.2.2-9.el5_5.1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/net-snmp-utils-5.3.2.2-9.el5_5.1.i386.rpm"|<:DEBUG>
01/24/2012 18:45:06 populate_rpm_archive|Calling "cp /mnt/source/Cisco/hssi/install_pool/smartmontools-5.38-2.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/smartmontools-5.38-2.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:45:06 populate_rpm_archive|Calling "cp /mnt/source/Cisco/hssi/install_pool/syslog-ng-3.0.7-1.tgz /common/rpm-archive/8.6.2.22900-9/RPMS/syslog-ng-3.0.7-1.tgz"|<:DEBUG>
01/24/2012 18:45:06 populate_rpm_archive|Calling "cp /mnt/source/Cisco/hssi/install_pool/syslog-ng-3.0.7-1.tgz_post /common/rpm-archive/8.6.2.22900-9/RPMS/syslog-ng-3.0.7-1.tgz_post"|<:DEBUG>
01/24/2012 18:45:06 populate_rpm_archive|Calling "cp /mnt/source/Cisco/hssi/install_pool/TRANS.TBL /common/rpm-archive/8.6.2.22900-9/RPMS/TRANS.TBL"|<:DEBUG>
01/24/2012 18:45:06 populate_rpm_archive|Calling "cp /mnt/source/Cisco/hssi/install_pool/uname_mapper_cleanup.sh /common/rpm-archive/8.6.2.22900-9/RPMS/uname_mapper_cleanup.sh"|<:DEBUG>
01/24/2012 18:45:06 populate_rpm_archive|Calling "cp /mnt/source/Cisco/hssi/install_pool/uname_mapper_setup.sh /common/rpm-archive/8.6.2.22900-9/RPMS/uname_mapper_setup.sh"|<:DEBUG>
01/24/2012 18:45:06 populate_rpm_archive|Calling "cp /mnt/source/Cisco/hssi/install_pool/volaris-fga-2.0.2-1.i386_rh5.5.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/volaris-fga-2.0.2-1.i386_rh5.5.rpm"|<:DEBUG>
01/24/2012 18:45:06 populate_rpm_archive|Calling "cp /mnt/source/Cisco/hssi/install_pool/volaris-fga-2.0.2-1.i386_rh5.5.rpm_pre /common/rpm-archive/8.6.2.22900-9/RPMS/volaris-fga-2.0.2-1.i386_rh5.5.rpm_pre"|<:DEBUG>
01/24/2012 18:45:06 populate_rpm_archive|Calling "cp /mnt/source/Cisco/hssi/install_pool/vos_ibm_da.5.20.2-1.0-rhel5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/vos_ibm_da.5.20.2-1.0-rhel5.i386.rpm"|<:DEBUG>
01/24/2012 18:45:07 populate_rpm_archive|Command execution is complete|<:INFO>
01/24/2012 18:45:07 populate_rpm_archive|Populate RPM archive for hw type complete|<:INFO>
01/24/2012 18:45:07 populate_rpm_archive|Populate RPM archive for hw type RTMTFinish|<:NOTICE>
01/24/2012 18:45:07 populate_rpm_archive|Initializing xproduct API|<:DEBUG>
01/24/2012 18:45:07 populate_rpm_archive|Initializing xcomponent API|<:DEBUG>
01/24/2012 18:45:07 populate_rpm_archive|Initializing xplatformconfig API|<:DEBUG>
01/24/2012 18:45:07 populate_rpm_archive|Calling "source /common/cisco/install/setup/utils.sh"|<:DEBUG>
01/24/2012 18:45:07 populate_rpm_archive|Parse argument type=deployment|<:DEBUG>
01/24/2012 18:45:07 populate_rpm_archive|Parse argument mode=upgrade|<:DEBUG>
01/24/2012 18:45:07 populate_rpm_archive|Parse argument archive_version=8.6.2.22900-9|<:DEBUG>
01/24/2012 18:45:07 populate_rpm_archive|Parse argument src_base=/mnt/source|<:DEBUG>
01/24/2012 18:45:07 populate_rpm_archive|Parse argument archive_base=/common/rpm-archive|<:DEBUG>
01/24/2012 18:45:07 populate_rpm_archive|Populate RPM archive for deployment type, mode upgrade|<:INFO>
01/24/2012 18:45:07 populate_rpm_archive|Populate RPM archive for deployment type , mode upgrade RTMTStart|<:NOTICE>
01/24/2012 18:45:07 populate_rpm_archive|Initialize global data, mode upgrade|<:INFO>
01/24/2012 18:45:07 populate_rpm_archive|Initialize global data, mode upgrade complete|<:INFO>
01/24/2012 18:45:07 populate_rpm_archive|Initialize command list|<:DEBUG>
01/24/2012 18:45:07 populate_rpm_archive|Initialize component data, mode upgrade|<:INFO>
01/24/2012 18:45:07 populate_rpm_archive|Initialize component data, mode upgrade complete|<:INFO>
01/24/2012 18:45:07 populate_rpm_archive|Build the command list for ucos|<:INFO>
01/24/2012 18:45:07 populate_rpm_archive|Read ucos component for RPMs|<:DEBUG>
01/24/2012 18:45:07 populate_rpm_archive|Processing ucos package element|<:DEBUG>
01/24/2012 18:45:07 populate_rpm_archive|Add RPM master-8.6.2.22900-9.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:07 populate_rpm_archive|Add RPM ucfips-openssl-2.0.0.1-1.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:07 populate_rpm_archive|Add RPM openssh-5.1p1-3.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:07 populate_rpm_archive|Add RPM openssh-clients-5.1p1-3.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:07 populate_rpm_archive|Add RPM openssh-server-5.1p1-3.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:07 populate_rpm_archive|Add RPM ipv6-kmod-update-2-1.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:07 populate_rpm_archive|Calling "mkdir -p /common/rpm-archive/8.6.2.22900-9/RPMS/ucos"|<:DEBUG>
01/24/2012 18:45:07 populate_rpm_archive|Copy master-8.6.2.22900-9.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/ucos|<:INFO>
01/24/2012 18:45:07 populate_rpm_archive|Located master-8.6.2.22900-9.i386.rpm in /mnt/source/Cisco/ucos/RPMS|<:DEBUG>
01/24/2012 18:45:07 populate_rpm_archive|Add "cp /mnt/source/Cisco/ucos/RPMS/master-8.6.2.22900-9.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucos/master-8.6.2.22900-9.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:07 populate_rpm_archive|Copy ucfips-openssl-2.0.0.1-1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/ucos|<:INFO>
01/24/2012 18:45:07 populate_rpm_archive|Located ucfips-openssl-2.0.0.1-1.i386.rpm in /mnt/source/Cisco/ucos/RPMS|<:DEBUG>
01/24/2012 18:45:07 populate_rpm_archive|Add "cp /mnt/source/Cisco/ucos/RPMS/ucfips-openssl-2.0.0.1-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucos/ucfips-openssl-2.0.0.1-1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:07 populate_rpm_archive|Copy openssh-5.1p1-3.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/ucos|<:INFO>
01/24/2012 18:45:07 populate_rpm_archive|Located openssh-5.1p1-3.i386.rpm in /mnt/source/Cisco/ucos/RPMS|<:DEBUG>
01/24/2012 18:45:07 populate_rpm_archive|Add "cp /mnt/source/Cisco/ucos/RPMS/openssh-5.1p1-3.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucos/openssh-5.1p1-3.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:07 populate_rpm_archive|Copy openssh-clients-5.1p1-3.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/ucos|<:INFO>
01/24/2012 18:45:07 populate_rpm_archive|Located openssh-clients-5.1p1-3.i386.rpm in /mnt/source/Cisco/ucos/RPMS|<:DEBUG>
01/24/2012 18:45:07 populate_rpm_archive|Add "cp /mnt/source/Cisco/ucos/RPMS/openssh-clients-5.1p1-3.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucos/openssh-clients-5.1p1-3.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:07 populate_rpm_archive|Copy openssh-server-5.1p1-3.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/ucos|<:INFO>
01/24/2012 18:45:07 populate_rpm_archive|Located openssh-server-5.1p1-3.i386.rpm in /mnt/source/Cisco/ucos/RPMS|<:DEBUG>
01/24/2012 18:45:07 populate_rpm_archive|Add "cp /mnt/source/Cisco/ucos/RPMS/openssh-server-5.1p1-3.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucos/openssh-server-5.1p1-3.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:07 populate_rpm_archive|Copy ipv6-kmod-update-2-1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/ucos|<:INFO>
01/24/2012 18:45:07 populate_rpm_archive|Located ipv6-kmod-update-2-1.i386.rpm in /mnt/source/Cisco/ucos/RPMS|<:DEBUG>
01/24/2012 18:45:07 populate_rpm_archive|Add "cp /mnt/source/Cisco/ucos/RPMS/ipv6-kmod-update-2-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucos/ipv6-kmod-update-2-1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:07 populate_rpm_archive|Building the command list for ucos is complete|<:INFO>
01/24/2012 18:45:07 populate_rpm_archive|Build the command list for ucplatform|<:INFO>
01/24/2012 18:45:07 populate_rpm_archive|Read ucplatform component for RPMs|<:DEBUG>
01/24/2012 18:45:07 populate_rpm_archive|Processing ucplatform phase element|<:DEBUG>
01/24/2012 18:45:07 populate_rpm_archive|Processing ucplatform package element|<:DEBUG>
01/24/2012 18:45:07 populate_rpm_archive|Add RPM platform-libs-1.0.0.0-1.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:08 populate_rpm_archive|Processing ucplatform package element|<:DEBUG>
01/24/2012 18:45:08 populate_rpm_archive|Add RPM platform-preferences-1.0.1-8.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:08 populate_rpm_archive|Add RPM platform-adminsftp-1.0.0.0-1.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:08 populate_rpm_archive|Add RPM platform-ver-2.0.0.1-1.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:08 populate_rpm_archive|Add RPM platform-selinux-2.0.0.0-1.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:08 populate_rpm_archive|Add RPM platform-ui-2.0.0.1-1.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:08 populate_rpm_archive|Add RPM platform-licensing-2.0.0.0-1.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:08 populate_rpm_archive|Add RPM platform-drf-2.0.0.2-2.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:08 populate_rpm_archive|Add RPM platform-remotesupport-2.0.0.1-3.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:08 populate_rpm_archive|Add RPM platform-servM-2.0.0.1-1.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:08 populate_rpm_archive|Add RPM service-registration-2.0.0.1-1.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:08 populate_rpm_archive|Add RPM platform-sec-2.0.0.1-1.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:08 populate_rpm_archive|Add RPM platform-cm-2.0.0.0-1.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:08 populate_rpm_archive|Add RPM platform-api-3.0.0.0-6.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:09 populate_rpm_archive|Processing ucplatform package element|<:DEBUG>
01/24/2012 18:45:09 populate_rpm_archive|Add RPM platform-util-2.0.0.1-1.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:09 populate_rpm_archive|Add RPM os-services-1.2-1.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:09 populate_rpm_archive|Add RPM fiostats-0.99.2-4.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:09 populate_rpm_archive|Add RPM fior-0.99.1-3.el5.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:09 populate_rpm_archive|Add RPM platform-dbcfs-0.3-1.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:09 populate_rpm_archive|Add RPM platform-tomcat-1.0.0.0-1.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:09 populate_rpm_archive|Add RPM ucfips-selftest-1.0.0.0-1.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:09 populate_rpm_archive|Add RPM platform-fipsutil-1.0.0.0-1.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:09 populate_rpm_archive|Add RPM platform-snmp-1.0.0.0-0.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:09 populate_rpm_archive|Add RPM platform-tzdata-2012c-1.el5.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:09 populate_rpm_archive|Add RPM platform-ipsec-1.0.0.0-1.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:09 populate_rpm_archive|Processing ucplatform phase element|<:DEBUG>
01/24/2012 18:45:10 populate_rpm_archive|Processing ucplatform phase element|<:DEBUG>
01/24/2012 18:45:10 populate_rpm_archive|Calling "mkdir -p /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform"|<:DEBUG>
01/24/2012 18:45:10 populate_rpm_archive|Copy platform-libs-1.0.0.0-1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform|<:INFO>
01/24/2012 18:45:10 populate_rpm_archive|Located platform-libs-1.0.0.0-1.i386.rpm in /mnt/source/Cisco/ucplatform/RPMS|<:DEBUG>
01/24/2012 18:45:10 populate_rpm_archive|Add "cp /mnt/source/Cisco/ucplatform/RPMS/platform-libs-1.0.0.0-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-libs-1.0.0.0-1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:10 populate_rpm_archive|Copy platform-preferences-1.0.1-8.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform|<:INFO>
01/24/2012 18:45:10 populate_rpm_archive|Located platform-preferences-1.0.1-8.i386.rpm in /mnt/source/Cisco/ucplatform/RPMS|<:DEBUG>
01/24/2012 18:45:10 populate_rpm_archive|Add "cp /mnt/source/Cisco/ucplatform/RPMS/platform-preferences-1.0.1-8.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-preferences-1.0.1-8.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:10 populate_rpm_archive|Copy platform-adminsftp-1.0.0.0-1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform|<:INFO>
01/24/2012 18:45:10 populate_rpm_archive|Located platform-adminsftp-1.0.0.0-1.i386.rpm in /mnt/source/Cisco/ucplatform/RPMS|<:DEBUG>
01/24/2012 18:45:10 populate_rpm_archive|Add "cp /mnt/source/Cisco/ucplatform/RPMS/platform-adminsftp-1.0.0.0-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-adminsftp-1.0.0.0-1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:10 populate_rpm_archive|Copy platform-ver-2.0.0.1-1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform|<:INFO>
01/24/2012 18:45:10 populate_rpm_archive|Located platform-ver-2.0.0.1-1.i386.rpm in /mnt/source/Cisco/ucplatform/RPMS|<:DEBUG>
01/24/2012 18:45:10 populate_rpm_archive|Add "cp /mnt/source/Cisco/ucplatform/RPMS/platform-ver-2.0.0.1-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-ver-2.0.0.1-1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:10 populate_rpm_archive|Copy platform-selinux-2.0.0.0-1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform|<:INFO>
01/24/2012 18:45:10 populate_rpm_archive|Located platform-selinux-2.0.0.0-1.i386.rpm in /mnt/source/Cisco/ucplatform/RPMS|<:DEBUG>
01/24/2012 18:45:10 populate_rpm_archive|Add "cp /mnt/source/Cisco/ucplatform/RPMS/platform-selinux-2.0.0.0-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-selinux-2.0.0.0-1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:10 populate_rpm_archive|Copy platform-ui-2.0.0.1-1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform|<:INFO>
01/24/2012 18:45:10 populate_rpm_archive|Located platform-ui-2.0.0.1-1.i386.rpm in /mnt/source/Cisco/ucplatform/RPMS|<:DEBUG>
01/24/2012 18:45:10 populate_rpm_archive|Add "cp /mnt/source/Cisco/ucplatform/RPMS/platform-ui-2.0.0.1-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-ui-2.0.0.1-1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:10 populate_rpm_archive|Copy platform-licensing-2.0.0.0-1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform|<:INFO>
01/24/2012 18:45:10 populate_rpm_archive|Located platform-licensing-2.0.0.0-1.i386.rpm in /mnt/source/Cisco/ucplatform/RPMS|<:DEBUG>
01/24/2012 18:45:10 populate_rpm_archive|Add "cp /mnt/source/Cisco/ucplatform/RPMS/platform-licensing-2.0.0.0-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-licensing-2.0.0.0-1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:10 populate_rpm_archive|Copy platform-drf-2.0.0.2-2.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform|<:INFO>
01/24/2012 18:45:10 populate_rpm_archive|Located platform-drf-2.0.0.2-2.i386.rpm in /mnt/source/Cisco/ucplatform/RPMS|<:DEBUG>
01/24/2012 18:45:10 populate_rpm_archive|Add "cp /mnt/source/Cisco/ucplatform/RPMS/platform-drf-2.0.0.2-2.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-drf-2.0.0.2-2.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:10 populate_rpm_archive|Copy platform-remotesupport-2.0.0.1-3.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform|<:INFO>
01/24/2012 18:45:10 populate_rpm_archive|Located platform-remotesupport-2.0.0.1-3.i386.rpm in /mnt/source/Cisco/ucplatform/RPMS|<:DEBUG>
01/24/2012 18:45:10 populate_rpm_archive|Add "cp /mnt/source/Cisco/ucplatform/RPMS/platform-remotesupport-2.0.0.1-3.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-remotesupport-2.0.0.1-3.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:10 populate_rpm_archive|Copy platform-servM-2.0.0.1-1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform|<:INFO>
01/24/2012 18:45:10 populate_rpm_archive|Located platform-servM-2.0.0.1-1.i386.rpm in /mnt/source/Cisco/ucplatform/RPMS|<:DEBUG>
01/24/2012 18:45:10 populate_rpm_archive|Add "cp /mnt/source/Cisco/ucplatform/RPMS/platform-servM-2.0.0.1-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-servM-2.0.0.1-1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:10 populate_rpm_archive|Copy service-registration-2.0.0.1-1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform|<:INFO>
01/24/2012 18:45:10 populate_rpm_archive|Located service-registration-2.0.0.1-1.i386.rpm in /mnt/source/Cisco/ucplatform/RPMS|<:DEBUG>
01/24/2012 18:45:10 populate_rpm_archive|Add "cp /mnt/source/Cisco/ucplatform/RPMS/service-registration-2.0.0.1-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/service-registration-2.0.0.1-1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:10 populate_rpm_archive|Copy platform-sec-2.0.0.1-1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform|<:INFO>
01/24/2012 18:45:10 populate_rpm_archive|Located platform-sec-2.0.0.1-1.i386.rpm in /mnt/source/Cisco/ucplatform/RPMS|<:DEBUG>
01/24/2012 18:45:10 populate_rpm_archive|Add "cp /mnt/source/Cisco/ucplatform/RPMS/platform-sec-2.0.0.1-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-sec-2.0.0.1-1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:10 populate_rpm_archive|Copy platform-cm-2.0.0.0-1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform|<:INFO>
01/24/2012 18:45:10 populate_rpm_archive|Located platform-cm-2.0.0.0-1.i386.rpm in /mnt/source/Cisco/ucplatform/RPMS|<:DEBUG>
01/24/2012 18:45:10 populate_rpm_archive|Add "cp /mnt/source/Cisco/ucplatform/RPMS/platform-cm-2.0.0.0-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-cm-2.0.0.0-1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:10 populate_rpm_archive|Copy platform-api-3.0.0.0-6.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform|<:INFO>
01/24/2012 18:45:10 populate_rpm_archive|Located platform-api-3.0.0.0-6.i386.rpm in /mnt/source/Cisco/ucplatform/RPMS|<:DEBUG>
01/24/2012 18:45:10 populate_rpm_archive|Add "cp /mnt/source/Cisco/ucplatform/RPMS/platform-api-3.0.0.0-6.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-api-3.0.0.0-6.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:10 populate_rpm_archive|Copy platform-util-2.0.0.1-1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform|<:INFO>
01/24/2012 18:45:10 populate_rpm_archive|Located platform-util-2.0.0.1-1.i386.rpm in /mnt/source/Cisco/ucplatform/RPMS|<:DEBUG>
01/24/2012 18:45:10 populate_rpm_archive|Add "cp /mnt/source/Cisco/ucplatform/RPMS/platform-util-2.0.0.1-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-util-2.0.0.1-1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:10 populate_rpm_archive|Copy os-services-1.2-1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform|<:INFO>
01/24/2012 18:45:10 populate_rpm_archive|Located os-services-1.2-1.i386.rpm in /mnt/source/Cisco/ucplatform/RPMS|<:DEBUG>
01/24/2012 18:45:10 populate_rpm_archive|Add "cp /mnt/source/Cisco/ucplatform/RPMS/os-services-1.2-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/os-services-1.2-1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:10 populate_rpm_archive|Copy fiostats-0.99.2-4.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform|<:INFO>
01/24/2012 18:45:10 populate_rpm_archive|Located fiostats-0.99.2-4.i386.rpm in /mnt/source/Cisco/ucplatform/RPMS|<:DEBUG>
01/24/2012 18:45:10 populate_rpm_archive|Add "cp /mnt/source/Cisco/ucplatform/RPMS/fiostats-0.99.2-4.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/fiostats-0.99.2-4.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:10 populate_rpm_archive|Copy fior-0.99.1-3.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform|<:INFO>
01/24/2012 18:45:10 populate_rpm_archive|Located fior-0.99.1-3.el5.i386.rpm in /mnt/source/Cisco/ucplatform/RPMS|<:DEBUG>
01/24/2012 18:45:10 populate_rpm_archive|Add "cp /mnt/source/Cisco/ucplatform/RPMS/fior-0.99.1-3.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/fior-0.99.1-3.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:10 populate_rpm_archive|Copy platform-dbcfs-0.3-1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform|<:INFO>
01/24/2012 18:45:10 populate_rpm_archive|Located platform-dbcfs-0.3-1.i386.rpm in /mnt/source/Cisco/ucplatform/RPMS|<:DEBUG>
01/24/2012 18:45:10 populate_rpm_archive|Add "cp /mnt/source/Cisco/ucplatform/RPMS/platform-dbcfs-0.3-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-dbcfs-0.3-1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:10 populate_rpm_archive|Copy platform-tomcat-1.0.0.0-1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform|<:INFO>
01/24/2012 18:45:10 populate_rpm_archive|Located platform-tomcat-1.0.0.0-1.i386.rpm in /mnt/source/Cisco/ucplatform/RPMS|<:DEBUG>
01/24/2012 18:45:10 populate_rpm_archive|Add "cp /mnt/source/Cisco/ucplatform/RPMS/platform-tomcat-1.0.0.0-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-tomcat-1.0.0.0-1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:10 populate_rpm_archive|Copy ucfips-selftest-1.0.0.0-1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform|<:INFO>
01/24/2012 18:45:10 populate_rpm_archive|Located ucfips-selftest-1.0.0.0-1.i386.rpm in /mnt/source/Cisco/ucplatform/RPMS|<:DEBUG>
01/24/2012 18:45:10 populate_rpm_archive|Add "cp /mnt/source/Cisco/ucplatform/RPMS/ucfips-selftest-1.0.0.0-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/ucfips-selftest-1.0.0.0-1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:10 populate_rpm_archive|Copy platform-fipsutil-1.0.0.0-1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform|<:INFO>
01/24/2012 18:45:10 populate_rpm_archive|Located platform-fipsutil-1.0.0.0-1.i386.rpm in /mnt/source/Cisco/ucplatform/RPMS|<:DEBUG>
01/24/2012 18:45:10 populate_rpm_archive|Add "cp /mnt/source/Cisco/ucplatform/RPMS/platform-fipsutil-1.0.0.0-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-fipsutil-1.0.0.0-1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:10 populate_rpm_archive|Copy platform-snmp-1.0.0.0-0.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform|<:INFO>
01/24/2012 18:45:10 populate_rpm_archive|Located platform-snmp-1.0.0.0-0.i386.rpm in /mnt/source/Cisco/ucplatform/RPMS|<:DEBUG>
01/24/2012 18:45:10 populate_rpm_archive|Add "cp /mnt/source/Cisco/ucplatform/RPMS/platform-snmp-1.0.0.0-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-snmp-1.0.0.0-0.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:10 populate_rpm_archive|Copy platform-tzdata-2012c-1.el5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform|<:INFO>
01/24/2012 18:45:10 populate_rpm_archive|Located platform-tzdata-2012c-1.el5.i386.rpm in /mnt/source/Cisco/ucplatform/RPMS|<:DEBUG>
01/24/2012 18:45:10 populate_rpm_archive|Add "cp /mnt/source/Cisco/ucplatform/RPMS/platform-tzdata-2012c-1.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-tzdata-2012c-1.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:10 populate_rpm_archive|Copy platform-ipsec-1.0.0.0-1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform|<:INFO>
01/24/2012 18:45:10 populate_rpm_archive|Located platform-ipsec-1.0.0.0-1.i386.rpm in /mnt/source/Cisco/ucplatform/RPMS|<:DEBUG>
01/24/2012 18:45:10 populate_rpm_archive|Add "cp /mnt/source/Cisco/ucplatform/RPMS/platform-ipsec-1.0.0.0-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-ipsec-1.0.0.0-1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:10 populate_rpm_archive|Building the command list for ucplatform is complete|<:INFO>
01/24/2012 18:45:10 populate_rpm_archive|Initialize component data, mode upgrade|<:INFO>
01/24/2012 18:45:10 populate_rpm_archive|Initialize component data, mode upgrade complete|<:INFO>
01/24/2012 18:45:10 populate_rpm_archive|Build the command list for ucplatform_cluster|<:INFO>
01/24/2012 18:45:10 populate_rpm_archive|Read ucplatform_cluster component for RPMs|<:DEBUG>
01/24/2012 18:45:10 populate_rpm_archive|Processing ucplatform_cluster package element|<:DEBUG>
01/24/2012 18:45:10 populate_rpm_archive|Add RPM platform-clm-2.0.0.1-1.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:10 populate_rpm_archive|Add RPM platform-sso-2.0.0.0-1.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:10 populate_rpm_archive|Calling "mkdir -p /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform_cluster"|<:DEBUG>
01/24/2012 18:45:10 populate_rpm_archive|Copy platform-clm-2.0.0.1-1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform_cluster|<:INFO>
01/24/2012 18:45:10 populate_rpm_archive|Located platform-clm-2.0.0.1-1.i386.rpm in /mnt/source/Cisco/ucplatform_cluster/RPMS|<:DEBUG>
01/24/2012 18:45:10 populate_rpm_archive|Add "cp /mnt/source/Cisco/ucplatform_cluster/RPMS/platform-clm-2.0.0.1-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform_cluster/platform-clm-2.0.0.1-1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:10 populate_rpm_archive|Copy platform-sso-2.0.0.0-1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform_cluster|<:INFO>
01/24/2012 18:45:10 populate_rpm_archive|Located platform-sso-2.0.0.0-1.i386.rpm in /mnt/source/Cisco/ucplatform_cluster/RPMS|<:DEBUG>
01/24/2012 18:45:10 populate_rpm_archive|Add "cp /mnt/source/Cisco/ucplatform_cluster/RPMS/platform-sso-2.0.0.0-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform_cluster/platform-sso-2.0.0.0-1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:10 populate_rpm_archive|Building the command list for ucplatform_cluster is complete|<:INFO>
01/24/2012 18:45:10 populate_rpm_archive|Build the command list for thirdparty|<:INFO>
01/24/2012 18:45:10 populate_rpm_archive|Read thirdparty component for RPMs|<:DEBUG>
01/24/2012 18:45:10 populate_rpm_archive|Processing thirdparty package element|<:DEBUG>
01/24/2012 18:45:10 populate_rpm_archive|Add RPM cm-lib-1.0.0.0-1.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:10 populate_rpm_archive|Calling "mkdir -p /common/rpm-archive/8.6.2.22900-9/RPMS/thirdparty"|<:DEBUG>
01/24/2012 18:45:10 populate_rpm_archive|Copy cm-lib-1.0.0.0-1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/thirdparty|<:INFO>
01/24/2012 18:45:10 populate_rpm_archive|Add "cp /mnt/source/Cisco/thirdparty/RPMS/cm-lib-1.0.0.0-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/thirdparty/cm-lib-1.0.0.0-1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:10 populate_rpm_archive|Building the command list for thirdparty is complete|<:INFO>
01/24/2012 18:45:10 populate_rpm_archive|Build the command list for serviceability_core|<:INFO>
01/24/2012 18:45:10 populate_rpm_archive|Read serviceability_core component for RPMs|<:DEBUG>
01/24/2012 18:45:10 populate_rpm_archive|Processing serviceability_core package element|<:DEBUG>
01/24/2012 18:45:10 populate_rpm_archive|Add RPM cm-pi-0.0.0.1-0.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:10 populate_rpm_archive|Calling "mkdir -p /common/rpm-archive/8.6.2.22900-9/RPMS/serviceability_core"|<:DEBUG>
01/24/2012 18:45:10 populate_rpm_archive|Copy cm-pi-0.0.0.1-0.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/serviceability_core|<:INFO>
01/24/2012 18:45:10 populate_rpm_archive|Located cm-pi-0.0.0.1-0.i386.rpm in /mnt/source/Cisco/serviceability_core/RPMS|<:DEBUG>
01/24/2012 18:45:10 populate_rpm_archive|Add "cp /mnt/source/Cisco/serviceability_core/RPMS/cm-pi-0.0.0.1-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/serviceability_core/cm-pi-0.0.0.1-0.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:10 populate_rpm_archive|Building the command list for serviceability_core is complete|<:INFO>
01/24/2012 18:45:10 populate_rpm_archive|Build the command list for database|<:INFO>
01/24/2012 18:45:10 populate_rpm_archive|Read database component for RPMs|<:DEBUG>
01/24/2012 18:45:11 populate_rpm_archive|Processing database package element|<:DEBUG>
01/24/2012 18:45:11 populate_rpm_archive|Add RPM cm-dbms-1.0.0.0-1.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:11 populate_rpm_archive|Add RPM cm-dbl-1.0.0.0-1.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:11 populate_rpm_archive|Processing database phase element|<:DEBUG>
01/24/2012 18:45:11 populate_rpm_archive|Calling "mkdir -p /common/rpm-archive/8.6.2.22900-9/RPMS/database"|<:DEBUG>
01/24/2012 18:45:11 populate_rpm_archive|Copy cm-dbms-1.0.0.0-1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/database|<:INFO>
01/24/2012 18:45:11 populate_rpm_archive|Located cm-dbms-1.0.0.0-1.i386.rpm in /mnt/source/Cisco/database/RPMS|<:DEBUG>
01/24/2012 18:45:11 populate_rpm_archive|Add "cp /mnt/source/Cisco/database/RPMS/cm-dbms-1.0.0.0-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/database/cm-dbms-1.0.0.0-1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:11 populate_rpm_archive|Copy cm-dbl-1.0.0.0-1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/database|<:INFO>
01/24/2012 18:45:11 populate_rpm_archive|Located cm-dbl-1.0.0.0-1.i386.rpm in /mnt/source/Cisco/database/RPMS|<:DEBUG>
01/24/2012 18:45:11 populate_rpm_archive|Add "cp /mnt/source/Cisco/database/RPMS/cm-dbl-1.0.0.0-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/database/cm-dbl-1.0.0.0-1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:11 populate_rpm_archive|Building the command list for database is complete|<:INFO>
01/24/2012 18:45:11 populate_rpm_archive|Initialize component data, mode upgrade|<:INFO>
01/24/2012 18:45:11 populate_rpm_archive|Initialize component data, mode upgrade complete|<:INFO>
01/24/2012 18:45:11 populate_rpm_archive|Build the command list for serviceability_common|<:INFO>
01/24/2012 18:45:11 populate_rpm_archive|Read serviceability_common component for RPMs|<:DEBUG>
01/24/2012 18:45:11 populate_rpm_archive|Processing serviceability_common package element|<:DEBUG>
01/24/2012 18:45:11 populate_rpm_archive|Add RPM snmp-mon-0.0.0.21-5.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:12 populate_rpm_archive|Processing serviceability_common package element|<:DEBUG>
01/24/2012 18:45:12 populate_rpm_archive|Add RPM cm-cdp-0.0.0.1-0.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:12 populate_rpm_archive|Add RPM cm-sysapp-1.0.0.0-1.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:12 populate_rpm_archive|Add RPM cm-amc-0.0.0.1-0.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:12 populate_rpm_archive|Add RPM cm-tct-svc-0.0.0.1-1.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:12 populate_rpm_archive|Add RPM cm-lpm-0.0.0.1-0.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:12 populate_rpm_archive|Add RPM cm-syslog-0.0.0.1-0.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:12 populate_rpm_archive|Add RPM cm-RIS-0.0.0.1-0.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:12 populate_rpm_archive|Add RPM cm-auditlogd-0.0.0.1-0.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:12 populate_rpm_archive|Add RPM serviceability_common-migration-8.6.2.22900-9.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:12 populate_rpm_archive|Processing serviceability_common phase element|<:DEBUG>
01/24/2012 18:45:13 populate_rpm_archive|Processing serviceability_common package element|<:DEBUG>
01/24/2012 18:45:13 populate_rpm_archive|Add RPM serviceability_common-postinstall-8.6.2.22900-9.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:13 populate_rpm_archive|Processing serviceability_common phase element|<:DEBUG>
01/24/2012 18:45:13 populate_rpm_archive|Add RPM serviceability_common-final-8.6.2.22900-9.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:13 populate_rpm_archive|Calling "mkdir -p /common/rpm-archive/8.6.2.22900-9/RPMS/serviceability_common"|<:DEBUG>
01/24/2012 18:45:13 populate_rpm_archive|Copy snmp-mon-0.0.0.21-5.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/serviceability_common|<:INFO>
01/24/2012 18:45:13 populate_rpm_archive|Located snmp-mon-0.0.0.21-5.i386.rpm in /mnt/source/Cisco/serviceability_common/RPMS|<:DEBUG>
01/24/2012 18:45:13 populate_rpm_archive|Add "cp /mnt/source/Cisco/serviceability_common/RPMS/snmp-mon-0.0.0.21-5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/serviceability_common/snmp-mon-0.0.0.21-5.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:13 populate_rpm_archive|Copy cm-cdp-0.0.0.1-0.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/serviceability_common|<:INFO>
01/24/2012 18:45:13 populate_rpm_archive|Located cm-cdp-0.0.0.1-0.i386.rpm in /mnt/source/Cisco/serviceability_common/RPMS|<:DEBUG>
01/24/2012 18:45:13 populate_rpm_archive|Add "cp /mnt/source/Cisco/serviceability_common/RPMS/cm-cdp-0.0.0.1-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/serviceability_common/cm-cdp-0.0.0.1-0.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:13 populate_rpm_archive|Copy cm-sysapp-1.0.0.0-1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/serviceability_common|<:INFO>
01/24/2012 18:45:13 populate_rpm_archive|Located cm-sysapp-1.0.0.0-1.i386.rpm in /mnt/source/Cisco/serviceability_common/RPMS|<:DEBUG>
01/24/2012 18:45:13 populate_rpm_archive|Add "cp /mnt/source/Cisco/serviceability_common/RPMS/cm-sysapp-1.0.0.0-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/serviceability_common/cm-sysapp-1.0.0.0-1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:13 populate_rpm_archive|Copy cm-amc-0.0.0.1-0.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/serviceability_common|<:INFO>
01/24/2012 18:45:13 populate_rpm_archive|Located cm-amc-0.0.0.1-0.i386.rpm in /mnt/source/Cisco/serviceability_common/RPMS|<:DEBUG>
01/24/2012 18:45:13 populate_rpm_archive|Add "cp /mnt/source/Cisco/serviceability_common/RPMS/cm-amc-0.0.0.1-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/serviceability_common/cm-amc-0.0.0.1-0.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:13 populate_rpm_archive|Copy cm-tct-svc-0.0.0.1-1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/serviceability_common|<:INFO>
01/24/2012 18:45:13 populate_rpm_archive|Located cm-tct-svc-0.0.0.1-1.i386.rpm in /mnt/source/Cisco/serviceability_common/RPMS|<:DEBUG>
01/24/2012 18:45:13 populate_rpm_archive|Add "cp /mnt/source/Cisco/serviceability_common/RPMS/cm-tct-svc-0.0.0.1-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/serviceability_common/cm-tct-svc-0.0.0.1-1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:13 populate_rpm_archive|Copy cm-lpm-0.0.0.1-0.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/serviceability_common|<:INFO>
01/24/2012 18:45:13 populate_rpm_archive|Located cm-lpm-0.0.0.1-0.i386.rpm in /mnt/source/Cisco/serviceability_common/RPMS|<:DEBUG>
01/24/2012 18:45:13 populate_rpm_archive|Add "cp /mnt/source/Cisco/serviceability_common/RPMS/cm-lpm-0.0.0.1-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/serviceability_common/cm-lpm-0.0.0.1-0.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:13 populate_rpm_archive|Copy cm-syslog-0.0.0.1-0.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/serviceability_common|<:INFO>
01/24/2012 18:45:13 populate_rpm_archive|Located cm-syslog-0.0.0.1-0.i386.rpm in /mnt/source/Cisco/serviceability_common/RPMS|<:DEBUG>
01/24/2012 18:45:13 populate_rpm_archive|Add "cp /mnt/source/Cisco/serviceability_common/RPMS/cm-syslog-0.0.0.1-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/serviceability_common/cm-syslog-0.0.0.1-0.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:13 populate_rpm_archive|Copy cm-RIS-0.0.0.1-0.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/serviceability_common|<:INFO>
01/24/2012 18:45:13 populate_rpm_archive|Located cm-RIS-0.0.0.1-0.i386.rpm in /mnt/source/Cisco/serviceability_common/RPMS|<:DEBUG>
01/24/2012 18:45:13 populate_rpm_archive|Add "cp /mnt/source/Cisco/serviceability_common/RPMS/cm-RIS-0.0.0.1-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/serviceability_common/cm-RIS-0.0.0.1-0.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:13 populate_rpm_archive|Copy cm-auditlogd-0.0.0.1-0.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/serviceability_common|<:INFO>
01/24/2012 18:45:13 populate_rpm_archive|Located cm-auditlogd-0.0.0.1-0.i386.rpm in /mnt/source/Cisco/serviceability_common/RPMS|<:DEBUG>
01/24/2012 18:45:13 populate_rpm_archive|Add "cp /mnt/source/Cisco/serviceability_common/RPMS/cm-auditlogd-0.0.0.1-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/serviceability_common/cm-auditlogd-0.0.0.1-0.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:13 populate_rpm_archive|Copy serviceability_common-migration-8.6.2.22900-9.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/serviceability_common|<:INFO>
01/24/2012 18:45:13 populate_rpm_archive|Located serviceability_common-migration-8.6.2.22900-9.i386.rpm in /mnt/source/Cisco/serviceability_common/RPMS|<:DEBUG>
01/24/2012 18:45:13 populate_rpm_archive|Add "cp /mnt/source/Cisco/serviceability_common/RPMS/serviceability_common-migration-8.6.2.22900-9.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/serviceability_common/serviceability_common-migration-8.6.2.22900-9.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:13 populate_rpm_archive|Copy serviceability_common-postinstall-8.6.2.22900-9.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/serviceability_common|<:INFO>
01/24/2012 18:45:13 populate_rpm_archive|Located serviceability_common-postinstall-8.6.2.22900-9.i386.rpm in /mnt/source/Cisco/serviceability_common/RPMS|<:DEBUG>
01/24/2012 18:45:13 populate_rpm_archive|Add "cp /mnt/source/Cisco/serviceability_common/RPMS/serviceability_common-postinstall-8.6.2.22900-9.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/serviceability_common/serviceability_common-postinstall-8.6.2.22900-9.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:13 populate_rpm_archive|Copy serviceability_common-final-8.6.2.22900-9.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/serviceability_common|<:INFO>
01/24/2012 18:45:13 populate_rpm_archive|Located serviceability_common-final-8.6.2.22900-9.i386.rpm in /mnt/source/Cisco/serviceability_common/RPMS|<:DEBUG>
01/24/2012 18:45:13 populate_rpm_archive|Add "cp /mnt/source/Cisco/serviceability_common/RPMS/serviceability_common-final-8.6.2.22900-9.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/serviceability_common/serviceability_common-final-8.6.2.22900-9.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:13 populate_rpm_archive|Building the command list for serviceability_common is complete|<:INFO>
01/24/2012 18:45:13 populate_rpm_archive|Initialize component data, mode upgrade|<:INFO>
01/24/2012 18:45:13 populate_rpm_archive|Initialize component data, mode upgrade complete|<:INFO>
01/24/2012 18:45:13 populate_rpm_archive|Build the command list for serviceability_callmanager|<:INFO>
01/24/2012 18:45:13 populate_rpm_archive|Read serviceability_callmanager component for RPMs|<:DEBUG>
01/24/2012 18:45:13 populate_rpm_archive|Processing serviceability_callmanager package element|<:DEBUG>
01/24/2012 18:45:13 populate_rpm_archive|Add RPM cm-alarm-0.0.0.1-0.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:13 populate_rpm_archive|Add RPM cm-rtmt-servlet-8.9.1.0-0.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:13 populate_rpm_archive|Add RPM cm-rtmt-client-plugin-8.9.1.0-0.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:13 populate_rpm_archive|Add RPM cm-log4jinit-servlet-0.0.0.1-0.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:13 populate_rpm_archive|Add RPM cli-ucmserviceability-1.0.0.0-0.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:13 populate_rpm_archive|Add RPM cm-soap-dpservice-0.0.0.1-0.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:13 populate_rpm_archive|Add RPM cm-svc-web-0.0.0.1-1.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:14 populate_rpm_archive|Processing serviceability_callmanager package element|<:DEBUG>
01/24/2012 18:45:14 populate_rpm_archive|Add RPM cm-soap-logcollectionservice-0.0.0.1-0.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:14 populate_rpm_archive|Add RPM cm-soap-realtimeservice-0.0.0.1-0.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:14 populate_rpm_archive|Add RPM cm-soap-perfmonservice-0.0.0.1-0.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:14 populate_rpm_archive|Add RPM cm-soap-callrecordservice-0.0.0.1-0.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:14 populate_rpm_archive|Add RPM cm-auditeventresponder-0.0.0.1-1.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:14 populate_rpm_archive|Add RPM cm-sch-0.0.0.1-0.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:14 populate_rpm_archive|Add RPM serviceability_callmanager-postinstall-8.6.2.22900-9.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:14 populate_rpm_archive|Processing serviceability_callmanager phase element|<:DEBUG>
01/24/2012 18:45:14 populate_rpm_archive|Calling "mkdir -p /common/rpm-archive/8.6.2.22900-9/RPMS/serviceability_callmanager"|<:DEBUG>
01/24/2012 18:45:14 populate_rpm_archive|Copy cm-alarm-0.0.0.1-0.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/serviceability_callmanager|<:INFO>
01/24/2012 18:45:14 populate_rpm_archive|Located cm-alarm-0.0.0.1-0.i386.rpm in /mnt/source/Cisco/serviceability_callmanager/RPMS|<:DEBUG>
01/24/2012 18:45:14 populate_rpm_archive|Add "cp /mnt/source/Cisco/serviceability_callmanager/RPMS/cm-alarm-0.0.0.1-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/serviceability_callmanager/cm-alarm-0.0.0.1-0.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:14 populate_rpm_archive|Copy cm-rtmt-servlet-8.9.1.0-0.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/serviceability_callmanager|<:INFO>
01/24/2012 18:45:14 populate_rpm_archive|Located cm-rtmt-servlet-8.9.1.0-0.i386.rpm in /mnt/source/Cisco/serviceability_callmanager/RPMS|<:DEBUG>
01/24/2012 18:45:14 populate_rpm_archive|Add "cp /mnt/source/Cisco/serviceability_callmanager/RPMS/cm-rtmt-servlet-8.9.1.0-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/serviceability_callmanager/cm-rtmt-servlet-8.9.1.0-0.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:14 populate_rpm_archive|Copy cm-rtmt-client-plugin-8.9.1.0-0.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/serviceability_callmanager|<:INFO>
01/24/2012 18:45:14 populate_rpm_archive|Located cm-rtmt-client-plugin-8.9.1.0-0.i386.rpm in /mnt/source/Cisco/serviceability_callmanager/RPMS|<:DEBUG>
01/24/2012 18:45:14 populate_rpm_archive|Add "cp /mnt/source/Cisco/serviceability_callmanager/RPMS/cm-rtmt-client-plugin-8.9.1.0-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/serviceability_callmanager/cm-rtmt-client-plugin-8.9.1.0-0.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:14 populate_rpm_archive|Copy cm-log4jinit-servlet-0.0.0.1-0.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/serviceability_callmanager|<:INFO>
01/24/2012 18:45:14 populate_rpm_archive|Located cm-log4jinit-servlet-0.0.0.1-0.i386.rpm in /mnt/source/Cisco/serviceability_callmanager/RPMS|<:DEBUG>
01/24/2012 18:45:14 populate_rpm_archive|Add "cp /mnt/source/Cisco/serviceability_callmanager/RPMS/cm-log4jinit-servlet-0.0.0.1-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/serviceability_callmanager/cm-log4jinit-servlet-0.0.0.1-0.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:14 populate_rpm_archive|Copy cli-ucmserviceability-1.0.0.0-0.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/serviceability_callmanager|<:INFO>
01/24/2012 18:45:14 populate_rpm_archive|Located cli-ucmserviceability-1.0.0.0-0.i386.rpm in /mnt/source/Cisco/serviceability_callmanager/RPMS|<:DEBUG>
01/24/2012 18:45:14 populate_rpm_archive|Add "cp /mnt/source/Cisco/serviceability_callmanager/RPMS/cli-ucmserviceability-1.0.0.0-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/serviceability_callmanager/cli-ucmserviceability-1.0.0.0-0.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:14 populate_rpm_archive|Copy cm-soap-dpservice-0.0.0.1-0.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/serviceability_callmanager|<:INFO>
01/24/2012 18:45:14 populate_rpm_archive|Located cm-soap-dpservice-0.0.0.1-0.i386.rpm in /mnt/source/Cisco/serviceability_callmanager/RPMS|<:DEBUG>
01/24/2012 18:45:14 populate_rpm_archive|Add "cp /mnt/source/Cisco/serviceability_callmanager/RPMS/cm-soap-dpservice-0.0.0.1-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/serviceability_callmanager/cm-soap-dpservice-0.0.0.1-0.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:14 populate_rpm_archive|Copy cm-svc-web-0.0.0.1-1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/serviceability_callmanager|<:INFO>
01/24/2012 18:45:14 populate_rpm_archive|Located cm-svc-web-0.0.0.1-1.i386.rpm in /mnt/source/Cisco/serviceability_callmanager/RPMS|<:DEBUG>
01/24/2012 18:45:14 populate_rpm_archive|Add "cp /mnt/source/Cisco/serviceability_callmanager/RPMS/cm-svc-web-0.0.0.1-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/serviceability_callmanager/cm-svc-web-0.0.0.1-1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:14 populate_rpm_archive|Copy cm-soap-logcollectionservice-0.0.0.1-0.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/serviceability_callmanager|<:INFO>
01/24/2012 18:45:14 populate_rpm_archive|Located cm-soap-logcollectionservice-0.0.0.1-0.i386.rpm in /mnt/source/Cisco/serviceability_callmanager/RPMS|<:DEBUG>
01/24/2012 18:45:14 populate_rpm_archive|Add "cp /mnt/source/Cisco/serviceability_callmanager/RPMS/cm-soap-logcollectionservice-0.0.0.1-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/serviceability_callmanager/cm-soap-logcollectionservice-0.0.0.1-0.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:14 populate_rpm_archive|Copy cm-soap-realtimeservice-0.0.0.1-0.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/serviceability_callmanager|<:INFO>
01/24/2012 18:45:14 populate_rpm_archive|Located cm-soap-realtimeservice-0.0.0.1-0.i386.rpm in /mnt/source/Cisco/serviceability_callmanager/RPMS|<:DEBUG>
01/24/2012 18:45:14 populate_rpm_archive|Add "cp /mnt/source/Cisco/serviceability_callmanager/RPMS/cm-soap-realtimeservice-0.0.0.1-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/serviceability_callmanager/cm-soap-realtimeservice-0.0.0.1-0.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:14 populate_rpm_archive|Copy cm-soap-perfmonservice-0.0.0.1-0.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/serviceability_callmanager|<:INFO>
01/24/2012 18:45:14 populate_rpm_archive|Located cm-soap-perfmonservice-0.0.0.1-0.i386.rpm in /mnt/source/Cisco/serviceability_callmanager/RPMS|<:DEBUG>
01/24/2012 18:45:14 populate_rpm_archive|Add "cp /mnt/source/Cisco/serviceability_callmanager/RPMS/cm-soap-perfmonservice-0.0.0.1-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/serviceability_callmanager/cm-soap-perfmonservice-0.0.0.1-0.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:14 populate_rpm_archive|Copy cm-soap-callrecordservice-0.0.0.1-0.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/serviceability_callmanager|<:INFO>
01/24/2012 18:45:14 populate_rpm_archive|Located cm-soap-callrecordservice-0.0.0.1-0.i386.rpm in /mnt/source/Cisco/serviceability_callmanager/RPMS|<:DEBUG>
01/24/2012 18:45:14 populate_rpm_archive|Add "cp /mnt/source/Cisco/serviceability_callmanager/RPMS/cm-soap-callrecordservice-0.0.0.1-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/serviceability_callmanager/cm-soap-callrecordservice-0.0.0.1-0.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:14 populate_rpm_archive|Copy cm-auditeventresponder-0.0.0.1-1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/serviceability_callmanager|<:INFO>
01/24/2012 18:45:14 populate_rpm_archive|Located cm-auditeventresponder-0.0.0.1-1.i386.rpm in /mnt/source/Cisco/serviceability_callmanager/RPMS|<:DEBUG>
01/24/2012 18:45:14 populate_rpm_archive|Add "cp /mnt/source/Cisco/serviceability_callmanager/RPMS/cm-auditeventresponder-0.0.0.1-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/serviceability_callmanager/cm-auditeventresponder-0.0.0.1-1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:14 populate_rpm_archive|Copy cm-sch-0.0.0.1-0.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/serviceability_callmanager|<:INFO>
01/24/2012 18:45:14 populate_rpm_archive|Located cm-sch-0.0.0.1-0.i386.rpm in /mnt/source/Cisco/serviceability_callmanager/RPMS|<:DEBUG>
01/24/2012 18:45:14 populate_rpm_archive|Add "cp /mnt/source/Cisco/serviceability_callmanager/RPMS/cm-sch-0.0.0.1-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/serviceability_callmanager/cm-sch-0.0.0.1-0.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:14 populate_rpm_archive|Copy serviceability_callmanager-postinstall-8.6.2.22900-9.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/serviceability_callmanager|<:INFO>
01/24/2012 18:45:14 populate_rpm_archive|Located serviceability_callmanager-postinstall-8.6.2.22900-9.i386.rpm in /mnt/source/Cisco/serviceability_callmanager/RPMS|<:DEBUG>
01/24/2012 18:45:14 populate_rpm_archive|Add "cp /mnt/source/Cisco/serviceability_callmanager/RPMS/serviceability_callmanager-postinstall-8.6.2.22900-9.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/serviceability_callmanager/serviceability_callmanager-postinstall-8.6.2.22900-9.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:14 populate_rpm_archive|Building the command list for serviceability_callmanager is complete|<:INFO>
01/24/2012 18:45:14 populate_rpm_archive|Initialize component data, mode upgrade|<:INFO>
01/24/2012 18:45:14 populate_rpm_archive|Initialize component data, mode upgrade complete|<:INFO>
01/24/2012 18:45:14 populate_rpm_archive|Build the command list for ucapp_common|<:INFO>
01/24/2012 18:45:14 populate_rpm_archive|Read ucapp_common component for RPMs|<:DEBUG>
01/24/2012 18:45:14 populate_rpm_archive|Processing ucapp_common package element|<:DEBUG>
01/24/2012 18:45:14 populate_rpm_archive|Add RPM cm-script-5.0.1.0-1.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:14 populate_rpm_archive|Add RPM cm-ccmhelp-1.1.0.0-2.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:14 populate_rpm_archive|Add RPM cm-ccmadmin-1.1.0.0-1.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:14 populate_rpm_archive|Add RPM cm-cmplatform-1.1.0.0-1.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:15 populate_rpm_archive|Processing ucapp_common package element|<:DEBUG>
01/24/2012 18:45:15 populate_rpm_archive|Add RPM cm-encryption-1.0.0.1-0.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:15 populate_rpm_archive|Add RPM cm-authentication-1.0.0.1-0.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:15 populate_rpm_archive|Add RPM cm-app-services-0.0.0.1-0.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:15 populate_rpm_archive|Add RPM cm-changecredential-0.0.0.1-0.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:15 populate_rpm_archive|Add RPM cm-reporter-0.0.0.1-0.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:15 populate_rpm_archive|Add RPM cm-reporter-servlet-0.0.0.1-0.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:15 populate_rpm_archive|Add RPM cm-tomcatstats-0.0.0.1-0.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:15 populate_rpm_archive|Add RPM cm-scheduler-1.0.0.1-0.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:15 populate_rpm_archive|Add RPM cm-dirsync-1.0.0.1-0.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:15 populate_rpm_archive|Add RPM cm-tvs-1.0.0.0-1.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:15 populate_rpm_archive|Add RPM ucm-cucmws-1.1.0.0-1.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:15 populate_rpm_archive|Add RPM cm-cli-1.0.0.0-0.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:15 populate_rpm_archive|Processing ucapp_common phase element|<:DEBUG>
01/24/2012 18:45:16 populate_rpm_archive|Calling "mkdir -p /common/rpm-archive/8.6.2.22900-9/RPMS/ucapp_common"|<:DEBUG>
01/24/2012 18:45:16 populate_rpm_archive|Copy cm-script-5.0.1.0-1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/ucapp_common|<:INFO>
01/24/2012 18:45:16 populate_rpm_archive|Located cm-script-5.0.1.0-1.i386.rpm in /mnt/source/Cisco/ucapp_common/RPMS|<:DEBUG>
01/24/2012 18:45:16 populate_rpm_archive|Add "cp /mnt/source/Cisco/ucapp_common/RPMS/cm-script-5.0.1.0-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucapp_common/cm-script-5.0.1.0-1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:16 populate_rpm_archive|Copy cm-ccmhelp-1.1.0.0-2.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/ucapp_common|<:INFO>
01/24/2012 18:45:16 populate_rpm_archive|Located cm-ccmhelp-1.1.0.0-2.i386.rpm in /mnt/source/Cisco/ucapp_common/RPMS|<:DEBUG>
01/24/2012 18:45:16 populate_rpm_archive|Add "cp /mnt/source/Cisco/ucapp_common/RPMS/cm-ccmhelp-1.1.0.0-2.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucapp_common/cm-ccmhelp-1.1.0.0-2.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:16 populate_rpm_archive|Copy cm-ccmadmin-1.1.0.0-1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/ucapp_common|<:INFO>
01/24/2012 18:45:16 populate_rpm_archive|Located cm-ccmadmin-1.1.0.0-1.i386.rpm in /mnt/source/Cisco/ucapp_common/RPMS|<:DEBUG>
01/24/2012 18:45:16 populate_rpm_archive|Add "cp /mnt/source/Cisco/ucapp_common/RPMS/cm-ccmadmin-1.1.0.0-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucapp_common/cm-ccmadmin-1.1.0.0-1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:16 populate_rpm_archive|Copy cm-cmplatform-1.1.0.0-1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/ucapp_common|<:INFO>
01/24/2012 18:45:16 populate_rpm_archive|Located cm-cmplatform-1.1.0.0-1.i386.rpm in /mnt/source/Cisco/ucapp_common/RPMS|<:DEBUG>
01/24/2012 18:45:16 populate_rpm_archive|Add "cp /mnt/source/Cisco/ucapp_common/RPMS/cm-cmplatform-1.1.0.0-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucapp_common/cm-cmplatform-1.1.0.0-1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:16 populate_rpm_archive|Copy cm-encryption-1.0.0.1-0.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/ucapp_common|<:INFO>
01/24/2012 18:45:16 populate_rpm_archive|Located cm-encryption-1.0.0.1-0.i386.rpm in /mnt/source/Cisco/ucapp_common/RPMS|<:DEBUG>
01/24/2012 18:45:16 populate_rpm_archive|Add "cp /mnt/source/Cisco/ucapp_common/RPMS/cm-encryption-1.0.0.1-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucapp_common/cm-encryption-1.0.0.1-0.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:16 populate_rpm_archive|Copy cm-authentication-1.0.0.1-0.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/ucapp_common|<:INFO>
01/24/2012 18:45:16 populate_rpm_archive|Located cm-authentication-1.0.0.1-0.i386.rpm in /mnt/source/Cisco/ucapp_common/RPMS|<:DEBUG>
01/24/2012 18:45:16 populate_rpm_archive|Add "cp /mnt/source/Cisco/ucapp_common/RPMS/cm-authentication-1.0.0.1-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucapp_common/cm-authentication-1.0.0.1-0.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:16 populate_rpm_archive|Copy cm-app-services-0.0.0.1-0.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/ucapp_common|<:INFO>
01/24/2012 18:45:16 populate_rpm_archive|Located cm-app-services-0.0.0.1-0.i386.rpm in /mnt/source/Cisco/ucapp_common/RPMS|<:DEBUG>
01/24/2012 18:45:16 populate_rpm_archive|Add "cp /mnt/source/Cisco/ucapp_common/RPMS/cm-app-services-0.0.0.1-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucapp_common/cm-app-services-0.0.0.1-0.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:16 populate_rpm_archive|Copy cm-changecredential-0.0.0.1-0.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/ucapp_common|<:INFO>
01/24/2012 18:45:16 populate_rpm_archive|Located cm-changecredential-0.0.0.1-0.i386.rpm in /mnt/source/Cisco/ucapp_common/RPMS|<:DEBUG>
01/24/2012 18:45:16 populate_rpm_archive|Add "cp /mnt/source/Cisco/ucapp_common/RPMS/cm-changecredential-0.0.0.1-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucapp_common/cm-changecredential-0.0.0.1-0.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:16 populate_rpm_archive|Copy cm-reporter-0.0.0.1-0.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/ucapp_common|<:INFO>
01/24/2012 18:45:16 populate_rpm_archive|Located cm-reporter-0.0.0.1-0.i386.rpm in /mnt/source/Cisco/ucapp_common/RPMS|<:DEBUG>
01/24/2012 18:45:16 populate_rpm_archive|Add "cp /mnt/source/Cisco/ucapp_common/RPMS/cm-reporter-0.0.0.1-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucapp_common/cm-reporter-0.0.0.1-0.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:16 populate_rpm_archive|Copy cm-reporter-servlet-0.0.0.1-0.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/ucapp_common|<:INFO>
01/24/2012 18:45:16 populate_rpm_archive|Located cm-reporter-servlet-0.0.0.1-0.i386.rpm in /mnt/source/Cisco/ucapp_common/RPMS|<:DEBUG>
01/24/2012 18:45:16 populate_rpm_archive|Add "cp /mnt/source/Cisco/ucapp_common/RPMS/cm-reporter-servlet-0.0.0.1-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucapp_common/cm-reporter-servlet-0.0.0.1-0.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:16 populate_rpm_archive|Copy cm-tomcatstats-0.0.0.1-0.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/ucapp_common|<:INFO>
01/24/2012 18:45:16 populate_rpm_archive|Located cm-tomcatstats-0.0.0.1-0.i386.rpm in /mnt/source/Cisco/ucapp_common/RPMS|<:DEBUG>
01/24/2012 18:45:16 populate_rpm_archive|Add "cp /mnt/source/Cisco/ucapp_common/RPMS/cm-tomcatstats-0.0.0.1-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucapp_common/cm-tomcatstats-0.0.0.1-0.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:16 populate_rpm_archive|Copy cm-scheduler-1.0.0.1-0.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/ucapp_common|<:INFO>
01/24/2012 18:45:16 populate_rpm_archive|Located cm-scheduler-1.0.0.1-0.i386.rpm in /mnt/source/Cisco/ucapp_common/RPMS|<:DEBUG>
01/24/2012 18:45:16 populate_rpm_archive|Add "cp /mnt/source/Cisco/ucapp_common/RPMS/cm-scheduler-1.0.0.1-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucapp_common/cm-scheduler-1.0.0.1-0.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:16 populate_rpm_archive|Copy cm-dirsync-1.0.0.1-0.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/ucapp_common|<:INFO>
01/24/2012 18:45:16 populate_rpm_archive|Located cm-dirsync-1.0.0.1-0.i386.rpm in /mnt/source/Cisco/ucapp_common/RPMS|<:DEBUG>
01/24/2012 18:45:16 populate_rpm_archive|Add "cp /mnt/source/Cisco/ucapp_common/RPMS/cm-dirsync-1.0.0.1-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucapp_common/cm-dirsync-1.0.0.1-0.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:16 populate_rpm_archive|Copy cm-tvs-1.0.0.0-1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/ucapp_common|<:INFO>
01/24/2012 18:45:16 populate_rpm_archive|Located cm-tvs-1.0.0.0-1.i386.rpm in /mnt/source/Cisco/ucapp_common/RPMS|<:DEBUG>
01/24/2012 18:45:16 populate_rpm_archive|Add "cp /mnt/source/Cisco/ucapp_common/RPMS/cm-tvs-1.0.0.0-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucapp_common/cm-tvs-1.0.0.0-1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:16 populate_rpm_archive|Copy ucm-cucmws-1.1.0.0-1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/ucapp_common|<:INFO>
01/24/2012 18:45:16 populate_rpm_archive|Located ucm-cucmws-1.1.0.0-1.i386.rpm in /mnt/source/Cisco/ucapp_common/RPMS|<:DEBUG>
01/24/2012 18:45:16 populate_rpm_archive|Add "cp /mnt/source/Cisco/ucapp_common/RPMS/ucm-cucmws-1.1.0.0-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucapp_common/ucm-cucmws-1.1.0.0-1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:16 populate_rpm_archive|Copy cm-cli-1.0.0.0-0.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/ucapp_common|<:INFO>
01/24/2012 18:45:16 populate_rpm_archive|Located cm-cli-1.0.0.0-0.i386.rpm in /mnt/source/Cisco/ucapp_common/RPMS|<:DEBUG>
01/24/2012 18:45:16 populate_rpm_archive|Add "cp /mnt/source/Cisco/ucapp_common/RPMS/cm-cli-1.0.0.0-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucapp_common/cm-cli-1.0.0.0-0.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:16 populate_rpm_archive|Building the command list for ucapp_common is complete|<:INFO>
01/24/2012 18:45:16 populate_rpm_archive|Initialize component data, mode upgrade|<:INFO>
01/24/2012 18:45:16 populate_rpm_archive|Initialize component data, mode upgrade complete|<:INFO>
01/24/2012 18:45:16 populate_rpm_archive|Build the command list for callmanager|<:INFO>
01/24/2012 18:45:16 populate_rpm_archive|Read callmanager component for RPMs|<:DEBUG>
01/24/2012 18:45:16 populate_rpm_archive|Processing callmanager package element|<:DEBUG>
01/24/2012 18:45:16 populate_rpm_archive|Add RPM cm-ver-8.6.2.22900-9.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:16 populate_rpm_archive|Processing callmanager phase element|<:DEBUG>
01/24/2012 18:45:16 populate_rpm_archive|Add RPM cm-selinux-2.0.0.0-0.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:16 populate_rpm_archive|Add RPM cm-bps-1.1.0.0-1.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:16 populate_rpm_archive|Add RPM cm-taps-plugin-7.0.2.0-1.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:16 populate_rpm_archive|Add RPM cm-ccmmib-0.0.0.1-0.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:16 populate_rpm_archive|Add RPM cm-soap-cdrondemandservice-0.0.0.1-0.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:16 populate_rpm_archive|Add RPM cm-cef-0.0.0.1-0.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:17 populate_rpm_archive|Processing callmanager package element|<:DEBUG>
01/24/2012 18:45:17 populate_rpm_archive|Add RPM cm-car-1.0.0.0-1.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:17 populate_rpm_archive|Add RPM cm-cdrdlv-1.0.0.0-1.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:17 populate_rpm_archive|Add RPM cm-security-1.0.0.0-1.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:17 populate_rpm_archive|Add RPM cm-capf-1.0.0.0-1.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:17 populate_rpm_archive|Add RPM cm-ctlp-1.0.0.0-1.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:17 populate_rpm_archive|Add RPM cm-ccm-5.0.1.0-0.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:17 populate_rpm_archive|Add RPM cm-dna-5.0.0.2-1.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:17 populate_rpm_archive|Add RPM cm-CTIManager-1.0.0.1-0.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:17 populate_rpm_archive|Add RPM cm-tftp-1.0.0.1-0.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:17 populate_rpm_archive|Add RPM cm-locale-english_united_states-8.5.0.0-1.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:18 populate_rpm_archive|Processing callmanager package element|<:DEBUG>
01/24/2012 18:45:18 populate_rpm_archive|Add RPM cm-axlsqltoolkit-plugin-1.1.0.0-1.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:18 populate_rpm_archive|Add RPM cm-axl-1.1.0.0-1.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:18 populate_rpm_archive|Add RPM cm-uxl-1.1.0.0-1.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:18 populate_rpm_archive|Add RPM cm-pd-1.0.0.0-1.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:18 populate_rpm_archive|Add RPM cm-ccmuser-1.1.0.0-1.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:18 populate_rpm_archive|Add RPM cm-ccmcip-1.0.0.1-0.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:18 populate_rpm_archive|Add RPM cm-ipvms-8.6.0.0-1.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:18 populate_rpm_archive|Add RPM cm-ipvmsd-8.6.0.0-1.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:18 populate_rpm_archive|Add RPM cm-tsp-plugin-8.6.2.7-0.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:18 populate_rpm_archive|Add RPM cm-ctlc-plugin-6.0.0.1-1.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:18 populate_rpm_archive|Add RPM cm-em-0.0.0.1-0.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:18 populate_rpm_archive|Add RPM cm-webdialer-0.0.0.1-0.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:19 populate_rpm_archive|Processing callmanager package element|<:DEBUG>
01/24/2012 18:45:19 populate_rpm_archive|Add RPM cm-ipma-0.0.0.1-0.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:19 populate_rpm_archive|Add RPM cm-jtapi-plugin-8.6.2.10000-10.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:19 populate_rpm_archive|Add RPM cm-cmi-1.0.0.1-0.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:19 populate_rpm_archive|Add RPM cm-idp-5.0.1.0-0.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:19 populate_rpm_archive|Add RPM cm-devicepack-1.0.0.0-0.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:19 populate_rpm_archive|Add RPM cm-dhcp-1.0.0.1-0.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:19 populate_rpm_archive|Add RPM cm-srstctlclient-0.0.0.1-0.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:19 populate_rpm_archive|Add RPM cm-cfrt-0.0.0.1-0.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:19 populate_rpm_archive|Add RPM cm-cmtomcat-1.1.0.0-1.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:19 populate_rpm_archive|Add RPM cm-ccmivr-6.0.0.1-1.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:19 populate_rpm_archive|Add RPM cm-grt-1.1.0.0-1.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:20 populate_rpm_archive|Processing callmanager package element|<:DEBUG>
01/24/2012 18:45:20 populate_rpm_archive|Add RPM cm-cucreports-1.1.0.0-1.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:20 populate_rpm_archive|Processing callmanager phase element|<:DEBUG>
01/24/2012 18:45:20 populate_rpm_archive|Calling "mkdir -p /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager"|<:DEBUG>
01/24/2012 18:45:20 populate_rpm_archive|Copy cm-ver-8.6.2.22900-9.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager|<:INFO>
01/24/2012 18:45:20 populate_rpm_archive|Located cm-ver-8.6.2.22900-9.i386.rpm in /mnt/source/Cisco/callmanager/RPMS|<:DEBUG>
01/24/2012 18:45:20 populate_rpm_archive|Add "cp /mnt/source/Cisco/callmanager/RPMS/cm-ver-8.6.2.22900-9.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager/cm-ver-8.6.2.22900-9.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:20 populate_rpm_archive|Copy cm-selinux-2.0.0.0-0.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager|<:INFO>
01/24/2012 18:45:20 populate_rpm_archive|Located cm-selinux-2.0.0.0-0.i386.rpm in /mnt/source/Cisco/callmanager/RPMS|<:DEBUG>
01/24/2012 18:45:20 populate_rpm_archive|Add "cp /mnt/source/Cisco/callmanager/RPMS/cm-selinux-2.0.0.0-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager/cm-selinux-2.0.0.0-0.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:20 populate_rpm_archive|Copy cm-bps-1.1.0.0-1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager|<:INFO>
01/24/2012 18:45:20 populate_rpm_archive|Located cm-bps-1.1.0.0-1.i386.rpm in /mnt/source/Cisco/callmanager/RPMS|<:DEBUG>
01/24/2012 18:45:20 populate_rpm_archive|Add "cp /mnt/source/Cisco/callmanager/RPMS/cm-bps-1.1.0.0-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager/cm-bps-1.1.0.0-1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:20 populate_rpm_archive|Copy cm-taps-plugin-7.0.2.0-1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager|<:INFO>
01/24/2012 18:45:20 populate_rpm_archive|Located cm-taps-plugin-7.0.2.0-1.i386.rpm in /mnt/source/Cisco/callmanager/RPMS|<:DEBUG>
01/24/2012 18:45:20 populate_rpm_archive|Add "cp /mnt/source/Cisco/callmanager/RPMS/cm-taps-plugin-7.0.2.0-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager/cm-taps-plugin-7.0.2.0-1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:20 populate_rpm_archive|Copy cm-ccmmib-0.0.0.1-0.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager|<:INFO>
01/24/2012 18:45:20 populate_rpm_archive|Located cm-ccmmib-0.0.0.1-0.i386.rpm in /mnt/source/Cisco/callmanager/RPMS|<:DEBUG>
01/24/2012 18:45:20 populate_rpm_archive|Add "cp /mnt/source/Cisco/callmanager/RPMS/cm-ccmmib-0.0.0.1-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager/cm-ccmmib-0.0.0.1-0.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:20 populate_rpm_archive|Copy cm-soap-cdrondemandservice-0.0.0.1-0.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager|<:INFO>
01/24/2012 18:45:20 populate_rpm_archive|Located cm-soap-cdrondemandservice-0.0.0.1-0.i386.rpm in /mnt/source/Cisco/callmanager/RPMS|<:DEBUG>
01/24/2012 18:45:20 populate_rpm_archive|Add "cp /mnt/source/Cisco/callmanager/RPMS/cm-soap-cdrondemandservice-0.0.0.1-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager/cm-soap-cdrondemandservice-0.0.0.1-0.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:20 populate_rpm_archive|Copy cm-cef-0.0.0.1-0.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager|<:INFO>
01/24/2012 18:45:20 populate_rpm_archive|Located cm-cef-0.0.0.1-0.i386.rpm in /mnt/source/Cisco/callmanager/RPMS|<:DEBUG>
01/24/2012 18:45:20 populate_rpm_archive|Add "cp /mnt/source/Cisco/callmanager/RPMS/cm-cef-0.0.0.1-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager/cm-cef-0.0.0.1-0.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:20 populate_rpm_archive|Copy cm-car-1.0.0.0-1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager|<:INFO>
01/24/2012 18:45:20 populate_rpm_archive|Located cm-car-1.0.0.0-1.i386.rpm in /mnt/source/Cisco/callmanager/RPMS|<:DEBUG>
01/24/2012 18:45:20 populate_rpm_archive|Add "cp /mnt/source/Cisco/callmanager/RPMS/cm-car-1.0.0.0-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager/cm-car-1.0.0.0-1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:20 populate_rpm_archive|Copy cm-cdrdlv-1.0.0.0-1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager|<:INFO>
01/24/2012 18:45:20 populate_rpm_archive|Located cm-cdrdlv-1.0.0.0-1.i386.rpm in /mnt/source/Cisco/callmanager/RPMS|<:DEBUG>
01/24/2012 18:45:20 populate_rpm_archive|Add "cp /mnt/source/Cisco/callmanager/RPMS/cm-cdrdlv-1.0.0.0-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager/cm-cdrdlv-1.0.0.0-1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:20 populate_rpm_archive|Copy cm-security-1.0.0.0-1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager|<:INFO>
01/24/2012 18:45:20 populate_rpm_archive|Located cm-security-1.0.0.0-1.i386.rpm in /mnt/source/Cisco/callmanager/RPMS|<:DEBUG>
01/24/2012 18:45:20 populate_rpm_archive|Add "cp /mnt/source/Cisco/callmanager/RPMS/cm-security-1.0.0.0-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager/cm-security-1.0.0.0-1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:20 populate_rpm_archive|Copy cm-capf-1.0.0.0-1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager|<:INFO>
01/24/2012 18:45:20 populate_rpm_archive|Located cm-capf-1.0.0.0-1.i386.rpm in /mnt/source/Cisco/callmanager/RPMS|<:DEBUG>
01/24/2012 18:45:20 populate_rpm_archive|Add "cp /mnt/source/Cisco/callmanager/RPMS/cm-capf-1.0.0.0-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager/cm-capf-1.0.0.0-1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:20 populate_rpm_archive|Copy cm-ctlp-1.0.0.0-1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager|<:INFO>
01/24/2012 18:45:20 populate_rpm_archive|Located cm-ctlp-1.0.0.0-1.i386.rpm in /mnt/source/Cisco/callmanager/RPMS|<:DEBUG>
01/24/2012 18:45:20 populate_rpm_archive|Add "cp /mnt/source/Cisco/callmanager/RPMS/cm-ctlp-1.0.0.0-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager/cm-ctlp-1.0.0.0-1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:20 populate_rpm_archive|Copy cm-ccm-5.0.1.0-0.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager|<:INFO>
01/24/2012 18:45:20 populate_rpm_archive|Located cm-ccm-5.0.1.0-0.i386.rpm in /mnt/source/Cisco/callmanager/RPMS|<:DEBUG>
01/24/2012 18:45:20 populate_rpm_archive|Add "cp /mnt/source/Cisco/callmanager/RPMS/cm-ccm-5.0.1.0-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager/cm-ccm-5.0.1.0-0.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:20 populate_rpm_archive|Copy cm-dna-5.0.0.2-1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager|<:INFO>
01/24/2012 18:45:20 populate_rpm_archive|Located cm-dna-5.0.0.2-1.i386.rpm in /mnt/source/Cisco/callmanager/RPMS|<:DEBUG>
01/24/2012 18:45:20 populate_rpm_archive|Add "cp /mnt/source/Cisco/callmanager/RPMS/cm-dna-5.0.0.2-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager/cm-dna-5.0.0.2-1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:20 populate_rpm_archive|Copy cm-CTIManager-1.0.0.1-0.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager|<:INFO>
01/24/2012 18:45:20 populate_rpm_archive|Located cm-CTIManager-1.0.0.1-0.i386.rpm in /mnt/source/Cisco/callmanager/RPMS|<:DEBUG>
01/24/2012 18:45:20 populate_rpm_archive|Add "cp /mnt/source/Cisco/callmanager/RPMS/cm-CTIManager-1.0.0.1-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager/cm-CTIManager-1.0.0.1-0.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:20 populate_rpm_archive|Copy cm-tftp-1.0.0.1-0.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager|<:INFO>
01/24/2012 18:45:20 populate_rpm_archive|Located cm-tftp-1.0.0.1-0.i386.rpm in /mnt/source/Cisco/callmanager/RPMS|<:DEBUG>
01/24/2012 18:45:20 populate_rpm_archive|Add "cp /mnt/source/Cisco/callmanager/RPMS/cm-tftp-1.0.0.1-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager/cm-tftp-1.0.0.1-0.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:20 populate_rpm_archive|Copy cm-locale-english_united_states-8.5.0.0-1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager|<:INFO>
01/24/2012 18:45:20 populate_rpm_archive|Located cm-locale-english_united_states-8.5.0.0-1.i386.rpm in /mnt/source/Cisco/callmanager/RPMS|<:DEBUG>
01/24/2012 18:45:20 populate_rpm_archive|Add "cp /mnt/source/Cisco/callmanager/RPMS/cm-locale-english_united_states-8.5.0.0-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager/cm-locale-english_united_states-8.5.0.0-1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:20 populate_rpm_archive|Copy cm-axlsqltoolkit-plugin-1.1.0.0-1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager|<:INFO>
01/24/2012 18:45:20 populate_rpm_archive|Located cm-axlsqltoolkit-plugin-1.1.0.0-1.i386.rpm in /mnt/source/Cisco/callmanager/RPMS|<:DEBUG>
01/24/2012 18:45:20 populate_rpm_archive|Add "cp /mnt/source/Cisco/callmanager/RPMS/cm-axlsqltoolkit-plugin-1.1.0.0-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager/cm-axlsqltoolkit-plugin-1.1.0.0-1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:20 populate_rpm_archive|Copy cm-axl-1.1.0.0-1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager|<:INFO>
01/24/2012 18:45:20 populate_rpm_archive|Located cm-axl-1.1.0.0-1.i386.rpm in /mnt/source/Cisco/callmanager/RPMS|<:DEBUG>
01/24/2012 18:45:20 populate_rpm_archive|Add "cp /mnt/source/Cisco/callmanager/RPMS/cm-axl-1.1.0.0-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager/cm-axl-1.1.0.0-1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:20 populate_rpm_archive|Copy cm-uxl-1.1.0.0-1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager|<:INFO>
01/24/2012 18:45:20 populate_rpm_archive|Located cm-uxl-1.1.0.0-1.i386.rpm in /mnt/source/Cisco/callmanager/RPMS|<:DEBUG>
01/24/2012 18:45:20 populate_rpm_archive|Add "cp /mnt/source/Cisco/callmanager/RPMS/cm-uxl-1.1.0.0-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager/cm-uxl-1.1.0.0-1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:20 populate_rpm_archive|Copy cm-pd-1.0.0.0-1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager|<:INFO>
01/24/2012 18:45:20 populate_rpm_archive|Located cm-pd-1.0.0.0-1.i386.rpm in /mnt/source/Cisco/callmanager/RPMS|<:DEBUG>
01/24/2012 18:45:20 populate_rpm_archive|Add "cp /mnt/source/Cisco/callmanager/RPMS/cm-pd-1.0.0.0-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager/cm-pd-1.0.0.0-1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:20 populate_rpm_archive|Copy cm-ccmuser-1.1.0.0-1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager|<:INFO>
01/24/2012 18:45:20 populate_rpm_archive|Located cm-ccmuser-1.1.0.0-1.i386.rpm in /mnt/source/Cisco/callmanager/RPMS|<:DEBUG>
01/24/2012 18:45:20 populate_rpm_archive|Add "cp /mnt/source/Cisco/callmanager/RPMS/cm-ccmuser-1.1.0.0-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager/cm-ccmuser-1.1.0.0-1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:20 populate_rpm_archive|Copy cm-ccmcip-1.0.0.1-0.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager|<:INFO>
01/24/2012 18:45:20 populate_rpm_archive|Located cm-ccmcip-1.0.0.1-0.i386.rpm in /mnt/source/Cisco/callmanager/RPMS|<:DEBUG>
01/24/2012 18:45:20 populate_rpm_archive|Add "cp /mnt/source/Cisco/callmanager/RPMS/cm-ccmcip-1.0.0.1-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager/cm-ccmcip-1.0.0.1-0.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:20 populate_rpm_archive|Copy cm-ipvms-8.6.0.0-1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager|<:INFO>
01/24/2012 18:45:20 populate_rpm_archive|Located cm-ipvms-8.6.0.0-1.i386.rpm in /mnt/source/Cisco/callmanager/RPMS|<:DEBUG>
01/24/2012 18:45:20 populate_rpm_archive|Add "cp /mnt/source/Cisco/callmanager/RPMS/cm-ipvms-8.6.0.0-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager/cm-ipvms-8.6.0.0-1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:20 populate_rpm_archive|Copy cm-ipvmsd-8.6.0.0-1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager|<:INFO>
01/24/2012 18:45:20 populate_rpm_archive|Located cm-ipvmsd-8.6.0.0-1.i386.rpm in /mnt/source/Cisco/callmanager/RPMS|<:DEBUG>
01/24/2012 18:45:20 populate_rpm_archive|Add "cp /mnt/source/Cisco/callmanager/RPMS/cm-ipvmsd-8.6.0.0-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager/cm-ipvmsd-8.6.0.0-1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:20 populate_rpm_archive|Copy cm-tsp-plugin-8.6.2.7-0.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager|<:INFO>
01/24/2012 18:45:20 populate_rpm_archive|Located cm-tsp-plugin-8.6.2.7-0.i386.rpm in /mnt/source/Cisco/callmanager/RPMS|<:DEBUG>
01/24/2012 18:45:20 populate_rpm_archive|Add "cp /mnt/source/Cisco/callmanager/RPMS/cm-tsp-plugin-8.6.2.7-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager/cm-tsp-plugin-8.6.2.7-0.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:20 populate_rpm_archive|Copy cm-ctlc-plugin-6.0.0.1-1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager|<:INFO>
01/24/2012 18:45:20 populate_rpm_archive|Located cm-ctlc-plugin-6.0.0.1-1.i386.rpm in /mnt/source/Cisco/callmanager/RPMS|<:DEBUG>
01/24/2012 18:45:20 populate_rpm_archive|Add "cp /mnt/source/Cisco/callmanager/RPMS/cm-ctlc-plugin-6.0.0.1-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager/cm-ctlc-plugin-6.0.0.1-1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:20 populate_rpm_archive|Copy cm-em-0.0.0.1-0.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager|<:INFO>
01/24/2012 18:45:20 populate_rpm_archive|Located cm-em-0.0.0.1-0.i386.rpm in /mnt/source/Cisco/callmanager/RPMS|<:DEBUG>
01/24/2012 18:45:20 populate_rpm_archive|Add "cp /mnt/source/Cisco/callmanager/RPMS/cm-em-0.0.0.1-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager/cm-em-0.0.0.1-0.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:20 populate_rpm_archive|Copy cm-webdialer-0.0.0.1-0.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager|<:INFO>
01/24/2012 18:45:20 populate_rpm_archive|Located cm-webdialer-0.0.0.1-0.i386.rpm in /mnt/source/Cisco/callmanager/RPMS|<:DEBUG>
01/24/2012 18:45:20 populate_rpm_archive|Add "cp /mnt/source/Cisco/callmanager/RPMS/cm-webdialer-0.0.0.1-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager/cm-webdialer-0.0.0.1-0.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:20 populate_rpm_archive|Copy cm-ipma-0.0.0.1-0.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager|<:INFO>
01/24/2012 18:45:20 populate_rpm_archive|Located cm-ipma-0.0.0.1-0.i386.rpm in /mnt/source/Cisco/callmanager/RPMS|<:DEBUG>
01/24/2012 18:45:20 populate_rpm_archive|Add "cp /mnt/source/Cisco/callmanager/RPMS/cm-ipma-0.0.0.1-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager/cm-ipma-0.0.0.1-0.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:20 populate_rpm_archive|Copy cm-jtapi-plugin-8.6.2.10000-10.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager|<:INFO>
01/24/2012 18:45:20 populate_rpm_archive|Located cm-jtapi-plugin-8.6.2.10000-10.i386.rpm in /mnt/source/Cisco/callmanager/RPMS|<:DEBUG>
01/24/2012 18:45:20 populate_rpm_archive|Add "cp /mnt/source/Cisco/callmanager/RPMS/cm-jtapi-plugin-8.6.2.10000-10.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager/cm-jtapi-plugin-8.6.2.10000-10.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:20 populate_rpm_archive|Copy cm-cmi-1.0.0.1-0.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager|<:INFO>
01/24/2012 18:45:20 populate_rpm_archive|Located cm-cmi-1.0.0.1-0.i386.rpm in /mnt/source/Cisco/callmanager/RPMS|<:DEBUG>
01/24/2012 18:45:20 populate_rpm_archive|Add "cp /mnt/source/Cisco/callmanager/RPMS/cm-cmi-1.0.0.1-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager/cm-cmi-1.0.0.1-0.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:20 populate_rpm_archive|Copy cm-idp-5.0.1.0-0.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager|<:INFO>
01/24/2012 18:45:20 populate_rpm_archive|Located cm-idp-5.0.1.0-0.i386.rpm in /mnt/source/Cisco/callmanager/RPMS|<:DEBUG>
01/24/2012 18:45:20 populate_rpm_archive|Add "cp /mnt/source/Cisco/callmanager/RPMS/cm-idp-5.0.1.0-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager/cm-idp-5.0.1.0-0.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:20 populate_rpm_archive|Copy cm-devicepack-1.0.0.0-0.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager|<:INFO>
01/24/2012 18:45:20 populate_rpm_archive|Located cm-devicepack-1.0.0.0-0.i386.rpm in /mnt/source/Cisco/callmanager/RPMS|<:DEBUG>
01/24/2012 18:45:20 populate_rpm_archive|Add "cp /mnt/source/Cisco/callmanager/RPMS/cm-devicepack-1.0.0.0-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager/cm-devicepack-1.0.0.0-0.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:20 populate_rpm_archive|Copy cm-dhcp-1.0.0.1-0.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager|<:INFO>
01/24/2012 18:45:20 populate_rpm_archive|Located cm-dhcp-1.0.0.1-0.i386.rpm in /mnt/source/Cisco/callmanager/RPMS|<:DEBUG>
01/24/2012 18:45:20 populate_rpm_archive|Add "cp /mnt/source/Cisco/callmanager/RPMS/cm-dhcp-1.0.0.1-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager/cm-dhcp-1.0.0.1-0.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:20 populate_rpm_archive|Copy cm-srstctlclient-0.0.0.1-0.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager|<:INFO>
01/24/2012 18:45:20 populate_rpm_archive|Located cm-srstctlclient-0.0.0.1-0.i386.rpm in /mnt/source/Cisco/callmanager/RPMS|<:DEBUG>
01/24/2012 18:45:20 populate_rpm_archive|Add "cp /mnt/source/Cisco/callmanager/RPMS/cm-srstctlclient-0.0.0.1-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager/cm-srstctlclient-0.0.0.1-0.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:20 populate_rpm_archive|Copy cm-cfrt-0.0.0.1-0.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager|<:INFO>
01/24/2012 18:45:20 populate_rpm_archive|Located cm-cfrt-0.0.0.1-0.i386.rpm in /mnt/source/Cisco/callmanager/RPMS|<:DEBUG>
01/24/2012 18:45:20 populate_rpm_archive|Add "cp /mnt/source/Cisco/callmanager/RPMS/cm-cfrt-0.0.0.1-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager/cm-cfrt-0.0.0.1-0.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:20 populate_rpm_archive|Copy cm-cmtomcat-1.1.0.0-1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager|<:INFO>
01/24/2012 18:45:20 populate_rpm_archive|Located cm-cmtomcat-1.1.0.0-1.i386.rpm in /mnt/source/Cisco/callmanager/RPMS|<:DEBUG>
01/24/2012 18:45:20 populate_rpm_archive|Add "cp /mnt/source/Cisco/callmanager/RPMS/cm-cmtomcat-1.1.0.0-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager/cm-cmtomcat-1.1.0.0-1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:20 populate_rpm_archive|Copy cm-ccmivr-6.0.0.1-1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager|<:INFO>
01/24/2012 18:45:20 populate_rpm_archive|Located cm-ccmivr-6.0.0.1-1.i386.rpm in /mnt/source/Cisco/callmanager/RPMS|<:DEBUG>
01/24/2012 18:45:20 populate_rpm_archive|Add "cp /mnt/source/Cisco/callmanager/RPMS/cm-ccmivr-6.0.0.1-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager/cm-ccmivr-6.0.0.1-1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:20 populate_rpm_archive|Copy cm-grt-1.1.0.0-1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager|<:INFO>
01/24/2012 18:45:20 populate_rpm_archive|Located cm-grt-1.1.0.0-1.i386.rpm in /mnt/source/Cisco/callmanager/RPMS|<:DEBUG>
01/24/2012 18:45:20 populate_rpm_archive|Add "cp /mnt/source/Cisco/callmanager/RPMS/cm-grt-1.1.0.0-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager/cm-grt-1.1.0.0-1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:20 populate_rpm_archive|Copy cm-cucreports-1.1.0.0-1.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager|<:INFO>
01/24/2012 18:45:20 populate_rpm_archive|Located cm-cucreports-1.1.0.0-1.i386.rpm in /mnt/source/Cisco/callmanager/RPMS|<:DEBUG>
01/24/2012 18:45:20 populate_rpm_archive|Add "cp /mnt/source/Cisco/callmanager/RPMS/cm-cucreports-1.1.0.0-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager/cm-cucreports-1.1.0.0-1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:20 populate_rpm_archive|Building the command list for callmanager is complete|<:INFO>
01/24/2012 18:45:20 populate_rpm_archive|Initialize component data, mode upgrade|<:INFO>
01/24/2012 18:45:20 populate_rpm_archive|Initialize component data, mode upgrade complete|<:INFO>
01/24/2012 18:45:20 populate_rpm_archive|Build the command list for cm_licensing|<:INFO>
01/24/2012 18:45:20 populate_rpm_archive|Read cm_licensing component for RPMs|<:DEBUG>
01/24/2012 18:45:20 populate_rpm_archive|Processing cm_licensing package element|<:DEBUG>
01/24/2012 18:45:20 populate_rpm_archive|Add RPM cm-licensing-2.0.0.0-0.i386.rpm to the list|<:DEBUG>
01/24/2012 18:45:20 populate_rpm_archive|Processing cm_licensing phase element|<:DEBUG>
01/24/2012 18:45:20 populate_rpm_archive|Calling "mkdir -p /common/rpm-archive/8.6.2.22900-9/RPMS/cm_licensing"|<:DEBUG>
01/24/2012 18:45:21 populate_rpm_archive|Copy cm-licensing-2.0.0.0-0.i386.rpm to /common/rpm-archive/8.6.2.22900-9/RPMS/cm_licensing|<:INFO>
01/24/2012 18:45:21 populate_rpm_archive|Located cm-licensing-2.0.0.0-0.i386.rpm in /mnt/source/Cisco/cm_licensing/RPMS|<:DEBUG>
01/24/2012 18:45:21 populate_rpm_archive|Add "cp /mnt/source/Cisco/cm_licensing/RPMS/cm-licensing-2.0.0.0-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/cm_licensing/cm-licensing-2.0.0.0-0.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:45:21 populate_rpm_archive|Building the command list for cm_licensing is complete|<:INFO>
01/24/2012 18:45:21 populate_rpm_archive|Execute commands in the command list|<:INFO>
01/24/2012 18:45:21 populate_rpm_archive|Calling "cp /mnt/source/Cisco/ucos/RPMS/master-8.6.2.22900-9.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucos/master-8.6.2.22900-9.i386.rpm"|<:DEBUG>
01/24/2012 18:45:21 populate_rpm_archive|Calling "cp /mnt/source/Cisco/ucos/RPMS/ucfips-openssl-2.0.0.1-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucos/ucfips-openssl-2.0.0.1-1.i386.rpm"|<:DEBUG>
01/24/2012 18:45:21 populate_rpm_archive|Calling "cp /mnt/source/Cisco/ucos/RPMS/openssh-5.1p1-3.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucos/openssh-5.1p1-3.i386.rpm"|<:DEBUG>
01/24/2012 18:45:21 populate_rpm_archive|Calling "cp /mnt/source/Cisco/ucos/RPMS/openssh-clients-5.1p1-3.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucos/openssh-clients-5.1p1-3.i386.rpm"|<:DEBUG>
01/24/2012 18:45:21 populate_rpm_archive|Calling "cp /mnt/source/Cisco/ucos/RPMS/openssh-server-5.1p1-3.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucos/openssh-server-5.1p1-3.i386.rpm"|<:DEBUG>
01/24/2012 18:45:21 populate_rpm_archive|Calling "cp /mnt/source/Cisco/ucos/RPMS/ipv6-kmod-update-2-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucos/ipv6-kmod-update-2-1.i386.rpm"|<:DEBUG>
01/24/2012 18:45:21 populate_rpm_archive|Calling "cp /mnt/source/Cisco/ucplatform/RPMS/platform-libs-1.0.0.0-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-libs-1.0.0.0-1.i386.rpm"|<:DEBUG>
01/24/2012 18:45:21 populate_rpm_archive|Calling "cp /mnt/source/Cisco/ucplatform/RPMS/platform-preferences-1.0.1-8.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-preferences-1.0.1-8.i386.rpm"|<:DEBUG>
01/24/2012 18:45:21 populate_rpm_archive|Calling "cp /mnt/source/Cisco/ucplatform/RPMS/platform-adminsftp-1.0.0.0-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-adminsftp-1.0.0.0-1.i386.rpm"|<:DEBUG>
01/24/2012 18:45:21 populate_rpm_archive|Calling "cp /mnt/source/Cisco/ucplatform/RPMS/platform-ver-2.0.0.1-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-ver-2.0.0.1-1.i386.rpm"|<:DEBUG>
01/24/2012 18:45:21 populate_rpm_archive|Calling "cp /mnt/source/Cisco/ucplatform/RPMS/platform-selinux-2.0.0.0-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-selinux-2.0.0.0-1.i386.rpm"|<:DEBUG>
01/24/2012 18:45:21 populate_rpm_archive|Calling "cp /mnt/source/Cisco/ucplatform/RPMS/platform-ui-2.0.0.1-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-ui-2.0.0.1-1.i386.rpm"|<:DEBUG>
01/24/2012 18:45:21 populate_rpm_archive|Calling "cp /mnt/source/Cisco/ucplatform/RPMS/platform-licensing-2.0.0.0-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-licensing-2.0.0.0-1.i386.rpm"|<:DEBUG>
01/24/2012 18:45:21 populate_rpm_archive|Calling "cp /mnt/source/Cisco/ucplatform/RPMS/platform-drf-2.0.0.2-2.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-drf-2.0.0.2-2.i386.rpm"|<:DEBUG>
01/24/2012 18:45:22 populate_rpm_archive|Calling "cp /mnt/source/Cisco/ucplatform/RPMS/platform-remotesupport-2.0.0.1-3.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-remotesupport-2.0.0.1-3.i386.rpm"|<:DEBUG>
01/24/2012 18:45:22 populate_rpm_archive|Calling "cp /mnt/source/Cisco/ucplatform/RPMS/platform-servM-2.0.0.1-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-servM-2.0.0.1-1.i386.rpm"|<:DEBUG>
01/24/2012 18:45:22 populate_rpm_archive|Calling "cp /mnt/source/Cisco/ucplatform/RPMS/service-registration-2.0.0.1-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/service-registration-2.0.0.1-1.i386.rpm"|<:DEBUG>
01/24/2012 18:45:22 populate_rpm_archive|Calling "cp /mnt/source/Cisco/ucplatform/RPMS/platform-sec-2.0.0.1-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-sec-2.0.0.1-1.i386.rpm"|<:DEBUG>
01/24/2012 18:45:22 populate_rpm_archive|Calling "cp /mnt/source/Cisco/ucplatform/RPMS/platform-cm-2.0.0.0-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-cm-2.0.0.0-1.i386.rpm"|<:DEBUG>
01/24/2012 18:45:22 populate_rpm_archive|Calling "cp /mnt/source/Cisco/ucplatform/RPMS/platform-api-3.0.0.0-6.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-api-3.0.0.0-6.i386.rpm"|<:DEBUG>
01/24/2012 18:45:22 populate_rpm_archive|Calling "cp /mnt/source/Cisco/ucplatform/RPMS/platform-util-2.0.0.1-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-util-2.0.0.1-1.i386.rpm"|<:DEBUG>
01/24/2012 18:45:22 populate_rpm_archive|Calling "cp /mnt/source/Cisco/ucplatform/RPMS/os-services-1.2-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/os-services-1.2-1.i386.rpm"|<:DEBUG>
01/24/2012 18:45:22 populate_rpm_archive|Calling "cp /mnt/source/Cisco/ucplatform/RPMS/fiostats-0.99.2-4.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/fiostats-0.99.2-4.i386.rpm"|<:DEBUG>
01/24/2012 18:45:22 populate_rpm_archive|Calling "cp /mnt/source/Cisco/ucplatform/RPMS/fior-0.99.1-3.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/fior-0.99.1-3.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:45:22 populate_rpm_archive|Calling "cp /mnt/source/Cisco/ucplatform/RPMS/platform-dbcfs-0.3-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-dbcfs-0.3-1.i386.rpm"|<:DEBUG>
01/24/2012 18:45:22 populate_rpm_archive|Calling "cp /mnt/source/Cisco/ucplatform/RPMS/platform-tomcat-1.0.0.0-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-tomcat-1.0.0.0-1.i386.rpm"|<:DEBUG>
01/24/2012 18:45:22 populate_rpm_archive|Calling "cp /mnt/source/Cisco/ucplatform/RPMS/ucfips-selftest-1.0.0.0-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/ucfips-selftest-1.0.0.0-1.i386.rpm"|<:DEBUG>
01/24/2012 18:45:22 populate_rpm_archive|Calling "cp /mnt/source/Cisco/ucplatform/RPMS/platform-fipsutil-1.0.0.0-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-fipsutil-1.0.0.0-1.i386.rpm"|<:DEBUG>
01/24/2012 18:45:22 populate_rpm_archive|Calling "cp /mnt/source/Cisco/ucplatform/RPMS/platform-snmp-1.0.0.0-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-snmp-1.0.0.0-0.i386.rpm"|<:DEBUG>
01/24/2012 18:45:22 populate_rpm_archive|Calling "cp /mnt/source/Cisco/ucplatform/RPMS/platform-tzdata-2012c-1.el5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-tzdata-2012c-1.el5.i386.rpm"|<:DEBUG>
01/24/2012 18:45:22 populate_rpm_archive|Calling "cp /mnt/source/Cisco/ucplatform/RPMS/platform-ipsec-1.0.0.0-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-ipsec-1.0.0.0-1.i386.rpm"|<:DEBUG>
01/24/2012 18:45:22 populate_rpm_archive|Calling "cp /mnt/source/Cisco/ucplatform_cluster/RPMS/platform-clm-2.0.0.1-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform_cluster/platform-clm-2.0.0.1-1.i386.rpm"|<:DEBUG>
01/24/2012 18:45:23 populate_rpm_archive|Calling "cp /mnt/source/Cisco/ucplatform_cluster/RPMS/platform-sso-2.0.0.0-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform_cluster/platform-sso-2.0.0.0-1.i386.rpm"|<:DEBUG>
01/24/2012 18:45:23 populate_rpm_archive|Calling "cp /mnt/source/Cisco/thirdparty/RPMS/cm-lib-1.0.0.0-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/thirdparty/cm-lib-1.0.0.0-1.i386.rpm"|<:DEBUG>
01/24/2012 18:45:23 populate_rpm_archive|Calling "cp /mnt/source/Cisco/serviceability_core/RPMS/cm-pi-0.0.0.1-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/serviceability_core/cm-pi-0.0.0.1-0.i386.rpm"|<:DEBUG>
01/24/2012 18:45:23 populate_rpm_archive|Calling "cp /mnt/source/Cisco/database/RPMS/cm-dbms-1.0.0.0-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/database/cm-dbms-1.0.0.0-1.i386.rpm"|<:DEBUG>
01/24/2012 18:45:29 populate_rpm_archive|Calling "cp /mnt/source/Cisco/database/RPMS/cm-dbl-1.0.0.0-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/database/cm-dbl-1.0.0.0-1.i386.rpm"|<:DEBUG>
01/24/2012 18:45:30 populate_rpm_archive|Calling "cp /mnt/source/Cisco/serviceability_common/RPMS/snmp-mon-0.0.0.21-5.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/serviceability_common/snmp-mon-0.0.0.21-5.i386.rpm"|<:DEBUG>
01/24/2012 18:45:30 populate_rpm_archive|Calling "cp /mnt/source/Cisco/serviceability_common/RPMS/cm-cdp-0.0.0.1-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/serviceability_common/cm-cdp-0.0.0.1-0.i386.rpm"|<:DEBUG>
01/24/2012 18:45:30 populate_rpm_archive|Calling "cp /mnt/source/Cisco/serviceability_common/RPMS/cm-sysapp-1.0.0.0-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/serviceability_common/cm-sysapp-1.0.0.0-1.i386.rpm"|<:DEBUG>
01/24/2012 18:45:30 populate_rpm_archive|Calling "cp /mnt/source/Cisco/serviceability_common/RPMS/cm-amc-0.0.0.1-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/serviceability_common/cm-amc-0.0.0.1-0.i386.rpm"|<:DEBUG>
01/24/2012 18:45:30 populate_rpm_archive|Calling "cp /mnt/source/Cisco/serviceability_common/RPMS/cm-tct-svc-0.0.0.1-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/serviceability_common/cm-tct-svc-0.0.0.1-1.i386.rpm"|<:DEBUG>
01/24/2012 18:45:30 populate_rpm_archive|Calling "cp /mnt/source/Cisco/serviceability_common/RPMS/cm-lpm-0.0.0.1-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/serviceability_common/cm-lpm-0.0.0.1-0.i386.rpm"|<:DEBUG>
01/24/2012 18:45:30 populate_rpm_archive|Calling "cp /mnt/source/Cisco/serviceability_common/RPMS/cm-syslog-0.0.0.1-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/serviceability_common/cm-syslog-0.0.0.1-0.i386.rpm"|<:DEBUG>
01/24/2012 18:45:31 populate_rpm_archive|Calling "cp /mnt/source/Cisco/serviceability_common/RPMS/cm-RIS-0.0.0.1-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/serviceability_common/cm-RIS-0.0.0.1-0.i386.rpm"|<:DEBUG>
01/24/2012 18:45:31 populate_rpm_archive|Calling "cp /mnt/source/Cisco/serviceability_common/RPMS/cm-auditlogd-0.0.0.1-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/serviceability_common/cm-auditlogd-0.0.0.1-0.i386.rpm"|<:DEBUG>
01/24/2012 18:45:31 populate_rpm_archive|Calling "cp /mnt/source/Cisco/serviceability_common/RPMS/serviceability_common-migration-8.6.2.22900-9.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/serviceability_common/serviceability_common-migration-8.6.2.22900-9.i386.rpm"|<:DEBUG>
01/24/2012 18:45:31 populate_rpm_archive|Calling "cp /mnt/source/Cisco/serviceability_common/RPMS/serviceability_common-postinstall-8.6.2.22900-9.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/serviceability_common/serviceability_common-postinstall-8.6.2.22900-9.i386.rpm"|<:DEBUG>
01/24/2012 18:45:31 populate_rpm_archive|Calling "cp /mnt/source/Cisco/serviceability_common/RPMS/serviceability_common-final-8.6.2.22900-9.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/serviceability_common/serviceability_common-final-8.6.2.22900-9.i386.rpm"|<:DEBUG>
01/24/2012 18:45:31 populate_rpm_archive|Calling "cp /mnt/source/Cisco/serviceability_callmanager/RPMS/cm-alarm-0.0.0.1-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/serviceability_callmanager/cm-alarm-0.0.0.1-0.i386.rpm"|<:DEBUG>
01/24/2012 18:45:31 populate_rpm_archive|Calling "cp /mnt/source/Cisco/serviceability_callmanager/RPMS/cm-rtmt-servlet-8.9.1.0-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/serviceability_callmanager/cm-rtmt-servlet-8.9.1.0-0.i386.rpm"|<:DEBUG>
01/24/2012 18:45:31 populate_rpm_archive|Calling "cp /mnt/source/Cisco/serviceability_callmanager/RPMS/cm-rtmt-client-plugin-8.9.1.0-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/serviceability_callmanager/cm-rtmt-client-plugin-8.9.1.0-0.i386.rpm"|<:DEBUG>
01/24/2012 18:45:33 populate_rpm_archive|Calling "cp /mnt/source/Cisco/serviceability_callmanager/RPMS/cm-log4jinit-servlet-0.0.0.1-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/serviceability_callmanager/cm-log4jinit-servlet-0.0.0.1-0.i386.rpm"|<:DEBUG>
01/24/2012 18:45:33 populate_rpm_archive|Calling "cp /mnt/source/Cisco/serviceability_callmanager/RPMS/cli-ucmserviceability-1.0.0.0-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/serviceability_callmanager/cli-ucmserviceability-1.0.0.0-0.i386.rpm"|<:DEBUG>
01/24/2012 18:45:33 populate_rpm_archive|Calling "cp /mnt/source/Cisco/serviceability_callmanager/RPMS/cm-soap-dpservice-0.0.0.1-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/serviceability_callmanager/cm-soap-dpservice-0.0.0.1-0.i386.rpm"|<:DEBUG>
01/24/2012 18:45:33 populate_rpm_archive|Calling "cp /mnt/source/Cisco/serviceability_callmanager/RPMS/cm-svc-web-0.0.0.1-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/serviceability_callmanager/cm-svc-web-0.0.0.1-1.i386.rpm"|<:DEBUG>
01/24/2012 18:45:33 populate_rpm_archive|Calling "cp /mnt/source/Cisco/serviceability_callmanager/RPMS/cm-soap-logcollectionservice-0.0.0.1-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/serviceability_callmanager/cm-soap-logcollectionservice-0.0.0.1-0.i386.rpm"|<:DEBUG>
01/24/2012 18:45:33 populate_rpm_archive|Calling "cp /mnt/source/Cisco/serviceability_callmanager/RPMS/cm-soap-realtimeservice-0.0.0.1-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/serviceability_callmanager/cm-soap-realtimeservice-0.0.0.1-0.i386.rpm"|<:DEBUG>
01/24/2012 18:45:33 populate_rpm_archive|Calling "cp /mnt/source/Cisco/serviceability_callmanager/RPMS/cm-soap-perfmonservice-0.0.0.1-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/serviceability_callmanager/cm-soap-perfmonservice-0.0.0.1-0.i386.rpm"|<:DEBUG>
01/24/2012 18:45:33 populate_rpm_archive|Calling "cp /mnt/source/Cisco/serviceability_callmanager/RPMS/cm-soap-callrecordservice-0.0.0.1-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/serviceability_callmanager/cm-soap-callrecordservice-0.0.0.1-0.i386.rpm"|<:DEBUG>
01/24/2012 18:45:33 populate_rpm_archive|Calling "cp /mnt/source/Cisco/serviceability_callmanager/RPMS/cm-auditeventresponder-0.0.0.1-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/serviceability_callmanager/cm-auditeventresponder-0.0.0.1-1.i386.rpm"|<:DEBUG>
01/24/2012 18:45:33 populate_rpm_archive|Calling "cp /mnt/source/Cisco/serviceability_callmanager/RPMS/cm-sch-0.0.0.1-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/serviceability_callmanager/cm-sch-0.0.0.1-0.i386.rpm"|<:DEBUG>
01/24/2012 18:45:33 populate_rpm_archive|Calling "cp /mnt/source/Cisco/serviceability_callmanager/RPMS/serviceability_callmanager-postinstall-8.6.2.22900-9.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/serviceability_callmanager/serviceability_callmanager-postinstall-8.6.2.22900-9.i386.rpm"|<:DEBUG>
01/24/2012 18:45:33 populate_rpm_archive|Calling "cp /mnt/source/Cisco/ucapp_common/RPMS/cm-script-5.0.1.0-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucapp_common/cm-script-5.0.1.0-1.i386.rpm"|<:DEBUG>
01/24/2012 18:45:33 populate_rpm_archive|Calling "cp /mnt/source/Cisco/ucapp_common/RPMS/cm-ccmhelp-1.1.0.0-2.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucapp_common/cm-ccmhelp-1.1.0.0-2.i386.rpm"|<:DEBUG>
01/24/2012 18:45:37 populate_rpm_archive|Calling "cp /mnt/source/Cisco/ucapp_common/RPMS/cm-ccmadmin-1.1.0.0-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucapp_common/cm-ccmadmin-1.1.0.0-1.i386.rpm"|<:DEBUG>
01/24/2012 18:45:38 populate_rpm_archive|Calling "cp /mnt/source/Cisco/ucapp_common/RPMS/cm-cmplatform-1.1.0.0-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucapp_common/cm-cmplatform-1.1.0.0-1.i386.rpm"|<:DEBUG>
01/24/2012 18:45:38 populate_rpm_archive|Calling "cp /mnt/source/Cisco/ucapp_common/RPMS/cm-encryption-1.0.0.1-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucapp_common/cm-encryption-1.0.0.1-0.i386.rpm"|<:DEBUG>
01/24/2012 18:45:38 populate_rpm_archive|Calling "cp /mnt/source/Cisco/ucapp_common/RPMS/cm-authentication-1.0.0.1-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucapp_common/cm-authentication-1.0.0.1-0.i386.rpm"|<:DEBUG>
01/24/2012 18:45:38 populate_rpm_archive|Calling "cp /mnt/source/Cisco/ucapp_common/RPMS/cm-app-services-0.0.0.1-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucapp_common/cm-app-services-0.0.0.1-0.i386.rpm"|<:DEBUG>
01/24/2012 18:45:38 populate_rpm_archive|Calling "cp /mnt/source/Cisco/ucapp_common/RPMS/cm-changecredential-0.0.0.1-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucapp_common/cm-changecredential-0.0.0.1-0.i386.rpm"|<:DEBUG>
01/24/2012 18:45:38 populate_rpm_archive|Calling "cp /mnt/source/Cisco/ucapp_common/RPMS/cm-reporter-0.0.0.1-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucapp_common/cm-reporter-0.0.0.1-0.i386.rpm"|<:DEBUG>
01/24/2012 18:45:38 populate_rpm_archive|Calling "cp /mnt/source/Cisco/ucapp_common/RPMS/cm-reporter-servlet-0.0.0.1-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucapp_common/cm-reporter-servlet-0.0.0.1-0.i386.rpm"|<:DEBUG>
01/24/2012 18:45:38 populate_rpm_archive|Calling "cp /mnt/source/Cisco/ucapp_common/RPMS/cm-tomcatstats-0.0.0.1-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucapp_common/cm-tomcatstats-0.0.0.1-0.i386.rpm"|<:DEBUG>
01/24/2012 18:45:38 populate_rpm_archive|Calling "cp /mnt/source/Cisco/ucapp_common/RPMS/cm-scheduler-1.0.0.1-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucapp_common/cm-scheduler-1.0.0.1-0.i386.rpm"|<:DEBUG>
01/24/2012 18:45:38 populate_rpm_archive|Calling "cp /mnt/source/Cisco/ucapp_common/RPMS/cm-dirsync-1.0.0.1-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucapp_common/cm-dirsync-1.0.0.1-0.i386.rpm"|<:DEBUG>
01/24/2012 18:45:38 populate_rpm_archive|Calling "cp /mnt/source/Cisco/ucapp_common/RPMS/cm-tvs-1.0.0.0-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucapp_common/cm-tvs-1.0.0.0-1.i386.rpm"|<:DEBUG>
01/24/2012 18:45:38 populate_rpm_archive|Calling "cp /mnt/source/Cisco/ucapp_common/RPMS/ucm-cucmws-1.1.0.0-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucapp_common/ucm-cucmws-1.1.0.0-1.i386.rpm"|<:DEBUG>
01/24/2012 18:45:39 populate_rpm_archive|Calling "cp /mnt/source/Cisco/ucapp_common/RPMS/cm-cli-1.0.0.0-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/ucapp_common/cm-cli-1.0.0.0-0.i386.rpm"|<:DEBUG>
01/24/2012 18:45:39 populate_rpm_archive|Calling "cp /mnt/source/Cisco/callmanager/RPMS/cm-ver-8.6.2.22900-9.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager/cm-ver-8.6.2.22900-9.i386.rpm"|<:DEBUG>
01/24/2012 18:45:39 populate_rpm_archive|Calling "cp /mnt/source/Cisco/callmanager/RPMS/cm-selinux-2.0.0.0-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager/cm-selinux-2.0.0.0-0.i386.rpm"|<:DEBUG>
01/24/2012 18:45:39 populate_rpm_archive|Calling "cp /mnt/source/Cisco/callmanager/RPMS/cm-bps-1.1.0.0-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager/cm-bps-1.1.0.0-1.i386.rpm"|<:DEBUG>
01/24/2012 18:45:39 populate_rpm_archive|Calling "cp /mnt/source/Cisco/callmanager/RPMS/cm-taps-plugin-7.0.2.0-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager/cm-taps-plugin-7.0.2.0-1.i386.rpm"|<:DEBUG>
01/24/2012 18:45:39 populate_rpm_archive|Calling "cp /mnt/source/Cisco/callmanager/RPMS/cm-ccmmib-0.0.0.1-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager/cm-ccmmib-0.0.0.1-0.i386.rpm"|<:DEBUG>
01/24/2012 18:45:39 populate_rpm_archive|Calling "cp /mnt/source/Cisco/callmanager/RPMS/cm-soap-cdrondemandservice-0.0.0.1-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager/cm-soap-cdrondemandservice-0.0.0.1-0.i386.rpm"|<:DEBUG>
01/24/2012 18:45:39 populate_rpm_archive|Calling "cp /mnt/source/Cisco/callmanager/RPMS/cm-cef-0.0.0.1-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager/cm-cef-0.0.0.1-0.i386.rpm"|<:DEBUG>
01/24/2012 18:45:39 populate_rpm_archive|Calling "cp /mnt/source/Cisco/callmanager/RPMS/cm-car-1.0.0.0-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager/cm-car-1.0.0.0-1.i386.rpm"|<:DEBUG>
01/24/2012 18:45:40 populate_rpm_archive|Calling "cp /mnt/source/Cisco/callmanager/RPMS/cm-cdrdlv-1.0.0.0-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager/cm-cdrdlv-1.0.0.0-1.i386.rpm"|<:DEBUG>
01/24/2012 18:45:40 populate_rpm_archive|Calling "cp /mnt/source/Cisco/callmanager/RPMS/cm-security-1.0.0.0-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager/cm-security-1.0.0.0-1.i386.rpm"|<:DEBUG>
01/24/2012 18:45:40 populate_rpm_archive|Calling "cp /mnt/source/Cisco/callmanager/RPMS/cm-capf-1.0.0.0-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager/cm-capf-1.0.0.0-1.i386.rpm"|<:DEBUG>
01/24/2012 18:45:40 populate_rpm_archive|Calling "cp /mnt/source/Cisco/callmanager/RPMS/cm-ctlp-1.0.0.0-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager/cm-ctlp-1.0.0.0-1.i386.rpm"|<:DEBUG>
01/24/2012 18:45:40 populate_rpm_archive|Calling "cp /mnt/source/Cisco/callmanager/RPMS/cm-ccm-5.0.1.0-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager/cm-ccm-5.0.1.0-0.i386.rpm"|<:DEBUG>
01/24/2012 18:45:46 populate_rpm_archive|Calling "cp /mnt/source/Cisco/callmanager/RPMS/cm-dna-5.0.0.2-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager/cm-dna-5.0.0.2-1.i386.rpm"|<:DEBUG>
01/24/2012 18:45:46 populate_rpm_archive|Calling "cp /mnt/source/Cisco/callmanager/RPMS/cm-CTIManager-1.0.0.1-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager/cm-CTIManager-1.0.0.1-0.i386.rpm"|<:DEBUG>
01/24/2012 18:45:46 populate_rpm_archive|Calling "cp /mnt/source/Cisco/callmanager/RPMS/cm-tftp-1.0.0.1-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager/cm-tftp-1.0.0.1-0.i386.rpm"|<:DEBUG>
01/24/2012 18:45:46 populate_rpm_archive|Calling "cp /mnt/source/Cisco/callmanager/RPMS/cm-locale-english_united_states-8.5.0.0-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager/cm-locale-english_united_states-8.5.0.0-1.i386.rpm"|<:DEBUG>
01/24/2012 18:45:47 populate_rpm_archive|Calling "cp /mnt/source/Cisco/callmanager/RPMS/cm-axlsqltoolkit-plugin-1.1.0.0-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager/cm-axlsqltoolkit-plugin-1.1.0.0-1.i386.rpm"|<:DEBUG>
01/24/2012 18:45:47 populate_rpm_archive|Calling "cp /mnt/source/Cisco/callmanager/RPMS/cm-axl-1.1.0.0-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager/cm-axl-1.1.0.0-1.i386.rpm"|<:DEBUG>
01/24/2012 18:45:48 populate_rpm_archive|Calling "cp /mnt/source/Cisco/callmanager/RPMS/cm-uxl-1.1.0.0-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager/cm-uxl-1.1.0.0-1.i386.rpm"|<:DEBUG>
01/24/2012 18:45:48 populate_rpm_archive|Calling "cp /mnt/source/Cisco/callmanager/RPMS/cm-pd-1.0.0.0-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager/cm-pd-1.0.0.0-1.i386.rpm"|<:DEBUG>
01/24/2012 18:45:48 populate_rpm_archive|Calling "cp /mnt/source/Cisco/callmanager/RPMS/cm-ccmuser-1.1.0.0-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager/cm-ccmuser-1.1.0.0-1.i386.rpm"|<:DEBUG>
01/24/2012 18:45:49 populate_rpm_archive|Calling "cp /mnt/source/Cisco/callmanager/RPMS/cm-ccmcip-1.0.0.1-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager/cm-ccmcip-1.0.0.1-0.i386.rpm"|<:DEBUG>
01/24/2012 18:45:49 populate_rpm_archive|Calling "cp /mnt/source/Cisco/callmanager/RPMS/cm-ipvms-8.6.0.0-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager/cm-ipvms-8.6.0.0-1.i386.rpm"|<:DEBUG>
01/24/2012 18:45:49 populate_rpm_archive|Calling "cp /mnt/source/Cisco/callmanager/RPMS/cm-ipvmsd-8.6.0.0-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager/cm-ipvmsd-8.6.0.0-1.i386.rpm"|<:DEBUG>
01/24/2012 18:45:50 populate_rpm_archive|Calling "cp /mnt/source/Cisco/callmanager/RPMS/cm-tsp-plugin-8.6.2.7-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager/cm-tsp-plugin-8.6.2.7-0.i386.rpm"|<:DEBUG>
01/24/2012 18:45:50 populate_rpm_archive|Calling "cp /mnt/source/Cisco/callmanager/RPMS/cm-ctlc-plugin-6.0.0.1-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager/cm-ctlc-plugin-6.0.0.1-1.i386.rpm"|<:DEBUG>
01/24/2012 18:45:52 populate_rpm_archive|Calling "cp /mnt/source/Cisco/callmanager/RPMS/cm-em-0.0.0.1-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager/cm-em-0.0.0.1-0.i386.rpm"|<:DEBUG>
01/24/2012 18:45:52 populate_rpm_archive|Calling "cp /mnt/source/Cisco/callmanager/RPMS/cm-webdialer-0.0.0.1-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager/cm-webdialer-0.0.0.1-0.i386.rpm"|<:DEBUG>
01/24/2012 18:45:52 populate_rpm_archive|Calling "cp /mnt/source/Cisco/callmanager/RPMS/cm-ipma-0.0.0.1-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager/cm-ipma-0.0.0.1-0.i386.rpm"|<:DEBUG>
01/24/2012 18:45:55 populate_rpm_archive|Calling "cp /mnt/source/Cisco/callmanager/RPMS/cm-jtapi-plugin-8.6.2.10000-10.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager/cm-jtapi-plugin-8.6.2.10000-10.i386.rpm"|<:DEBUG>
01/24/2012 18:45:59 populate_rpm_archive|Calling "cp /mnt/source/Cisco/callmanager/RPMS/cm-cmi-1.0.0.1-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager/cm-cmi-1.0.0.1-0.i386.rpm"|<:DEBUG>
01/24/2012 18:45:59 populate_rpm_archive|Calling "cp /mnt/source/Cisco/callmanager/RPMS/cm-idp-5.0.1.0-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager/cm-idp-5.0.1.0-0.i386.rpm"|<:DEBUG>
01/24/2012 18:45:59 populate_rpm_archive|Calling "cp /mnt/source/Cisco/callmanager/RPMS/cm-devicepack-1.0.0.0-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager/cm-devicepack-1.0.0.0-0.i386.rpm"|<:DEBUG>
01/24/2012 18:46:19 populate_rpm_archive|Calling "cp /mnt/source/Cisco/callmanager/RPMS/cm-dhcp-1.0.0.1-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager/cm-dhcp-1.0.0.1-0.i386.rpm"|<:DEBUG>
01/24/2012 18:46:19 populate_rpm_archive|Calling "cp /mnt/source/Cisco/callmanager/RPMS/cm-srstctlclient-0.0.0.1-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager/cm-srstctlclient-0.0.0.1-0.i386.rpm"|<:DEBUG>
01/24/2012 18:46:19 populate_rpm_archive|Calling "cp /mnt/source/Cisco/callmanager/RPMS/cm-cfrt-0.0.0.1-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager/cm-cfrt-0.0.0.1-0.i386.rpm"|<:DEBUG>
01/24/2012 18:46:20 populate_rpm_archive|Calling "cp /mnt/source/Cisco/callmanager/RPMS/cm-cmtomcat-1.1.0.0-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager/cm-cmtomcat-1.1.0.0-1.i386.rpm"|<:DEBUG>
01/24/2012 18:46:20 populate_rpm_archive|Calling "cp /mnt/source/Cisco/callmanager/RPMS/cm-ccmivr-6.0.0.1-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager/cm-ccmivr-6.0.0.1-1.i386.rpm"|<:DEBUG>
01/24/2012 18:46:20 populate_rpm_archive|Calling "cp /mnt/source/Cisco/callmanager/RPMS/cm-grt-1.1.0.0-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager/cm-grt-1.1.0.0-1.i386.rpm"|<:DEBUG>
01/24/2012 18:46:20 populate_rpm_archive|Calling "cp /mnt/source/Cisco/callmanager/RPMS/cm-cucreports-1.1.0.0-1.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/callmanager/cm-cucreports-1.1.0.0-1.i386.rpm"|<:DEBUG>
01/24/2012 18:46:20 populate_rpm_archive|Calling "cp /mnt/source/Cisco/cm_licensing/RPMS/cm-licensing-2.0.0.0-0.i386.rpm /common/rpm-archive/8.6.2.22900-9/RPMS/cm_licensing/cm-licensing-2.0.0.0-0.i386.rpm"|<:DEBUG>
01/24/2012 18:46:20 populate_rpm_archive|Command execution is complete|<:INFO>
01/24/2012 18:46:20 populate_rpm_archive|Populate RPM archive for deployment type complete|<:INFO>
01/24/2012 18:46:20 populate_rpm_archive|Populate RPM archive for deployment type RTMTFinish|<:NOTICE>
01/24/2012 18:46:20 upgrade_manager.sh|Install platform on inactive partition|<:INFO>
01/24/2012 18:46:20 upgrade_manager.sh|Prepare inactive partition|<:INFO>
01/24/2012 18:46:20 upgrade_manager.sh|Calling /common/download/8.6.2.22900-9/Cisco/bin/platform_pre_install src_dir=/mnt/source base_dir=/common/download/8.6.2.22900-9 mode=upgrade rpm_archive=/common/rpm-archive/8.6.2.22900-9|<:DEBUG>
01/24/2012 18:46:20 platform_pre_install|Initialize setup functions|<:INFO>
01/24/2012 18:46:20 platform_pre_install|Calling "source /common/cisco/install/setup/utils.sh"|<:DEBUG>
01/24/2012 18:46:20 platform_pre_install|Initialize setup functions complete|<:INFO>
01/24/2012 18:46:20 platform_pre_install|Parse argument src_dir=/mnt/source|<:DEBUG>
01/24/2012 18:46:20 platform_pre_install|Parse argument base_dir=/common/download/8.6.2.22900-9|<:DEBUG>
01/24/2012 18:46:20 platform_pre_install|Parse argument mode=upgrade|<:DEBUG>
01/24/2012 18:46:20 platform_pre_install|Parse argument rpm_archive=/common/rpm-archive/8.6.2.22900-9|<:DEBUG>
01/24/2012 18:46:20 platform_pre_install|Initialize global data|<:INFO>
01/24/2012 18:46:20 platform_pre_install|Initialize RPM repository variables|<:INFO>
01/24/2012 18:46:21 platform_pre_install|Initialize global data complete|<:INFO>
01/24/2012 18:46:21 platform_pre_install|Copy /mnt/source/Cisco/base_scripts/format_partition.py to /common/cisco/bin|<:INFO>
01/24/2012 18:46:21 platform_pre_install|Calling "cp /mnt/source/Cisco/base_scripts/format_partition.py /common/cisco/bin"|<:DEBUG>
01/24/2012 18:46:21 platform_pre_install|Start Platform Pre-install RTMTStart|<:NOTICE>
01/24/2012 18:46:21 platform_pre_install|Platform Pre-install starting|<:INFO>
01/24/2012 18:46:21 platform_pre_install|Remove inactive partition from boot loader|<:INFO>
01/24/2012 18:46:21 platform_pre_install|Calling /common/cisco/bin/prepare_grub --phase L2 --action create --basepath /mnt/source/Cisco --logfile /common/log/install/capture.txt|<:DEBUG>
01/24/2012 18:46:21 platform_pre_install|(CAPTURE) prepare_grub: Called with args: --phase L2 --action create --basepath /mnt/source/Cisco --logfile /common/log/install/capture.txt|<:DEBUG>
01/24/2012 18:46:21 platform_pre_install|(CAPTURE) ln: creating symbolic link `//boot/grub/menu.lst' to `//boot/grub/grub.conf': File exists|<:DEBUG>
01/24/2012 18:46:21 platform_pre_install|(CAPTURE) e_grub: Setting up GRUB for l2 for create action|<:DEBUG>
01/24/2012 18:46:21 platform_pre_install|(CAPTURE) [12/01/24_18:46:21] prepare_grub: Created a new /grub/boot/grub/grub.conf with entries from /tmp/active_grub_entry & |<:DEBUG>
01/24/2012 18:46:21 platform_pre_install|Remove inactive partition from boot loader complete|<:INFO>
01/24/2012 18:46:21 platform_pre_install|Format inactive partition|<:INFO>
01/24/2012 18:46:21 platform_pre_install|Find a partition label for the inactive partition|<:INFO>
01/24/2012 18:46:21 platform_pre_install|Root label is /|<:DEBUG>
01/24/2012 18:46:21 platform_pre_install|Returning inactive partition label "/partB"|<:DEBUG>
01/24/2012 18:46:21 platform_pre_install|Find a device for mount point /partB|<:INFO>
01/24/2012 18:46:21 platform_pre_install|Calling /sbin/findfs LABEL=/partB|<:DEBUG>
01/24/2012 18:46:22 platform_pre_install|Returning device "/dev/sda2" for mount point "/partB"|<:DEBUG>
01/24/2012 18:46:22 platform_pre_install|Calling "/common/cisco/bin/format_partition.py part=/partB label=/partB device=/dev/sda2 pidf=/tmp/format_partition_pid resultf=/tmp/format_partition_results"|<:DEBUG>
01/24/2012 18:46:22 format_partition|Argument part=/partB|<:DEBUG>
01/24/2012 18:46:22 format_partition|Argument label=/partB|<:DEBUG>
01/24/2012 18:46:22 format_partition|Argument device=/dev/sda2|<:DEBUG>
01/24/2012 18:46:22 format_partition|Argument pidf=/tmp/format_partition_pid|<:DEBUG>
01/24/2012 18:46:22 format_partition|Argument resultf=/tmp/format_partition_results|<:DEBUG>
01/24/2012 18:46:22 format_partition|Generate the pid file, /tmp/format_partition_pid|<:DEBUG>
01/24/2012 18:46:22 format_partition|Open file /tmp/tmp_file_9559|<:DEBUG>
01/24/2012 18:46:22 format_partition|Writing 9559 to /tmp/tmp_file_9559|<:DEBUG>
01/24/2012 18:46:22 format_partition|Renaming /tmp/tmp_file_9559 to /tmp/format_partition_pid|<:DEBUG>
01/24/2012 18:46:22 format_partition|Unmount partition /partB|<:INFO>
01/24/2012 18:46:22 format_partition|Unmount any mounted items on "/partB" mount points|<:DEBUG>
01/24/2012 18:46:22 format_partition|Checking mount point /|<:DEBUG>
01/24/2012 18:46:22 format_partition|Checking mount point /dev|<:DEBUG>
01/24/2012 18:46:22 format_partition|Checking mount point /proc|<:DEBUG>
01/24/2012 18:46:22 format_partition|Checking mount point /sys|<:DEBUG>
01/24/2012 18:46:22 format_partition|Checking mount point /selinux|<:DEBUG>
01/24/2012 18:46:22 format_partition|Checking mount point /proc/bus/usb|<:DEBUG>
01/24/2012 18:46:22 format_partition|Checking mount point /dev/pts|<:DEBUG>
01/24/2012 18:46:22 format_partition|Checking mount point /grub|<:DEBUG>
01/24/2012 18:46:22 format_partition|Checking mount point /common|<:DEBUG>
01/24/2012 18:46:22 format_partition|Checking mount point /dev/shm|<:DEBUG>
01/24/2012 18:46:22 format_partition|Checking mount point /proc/sys/fs/binfmt_misc|<:DEBUG>
01/24/2012 18:46:22 format_partition|Checking mount point /var/log/ramfs/cm/trace/ccm/sdi|<:DEBUG>
01/24/2012 18:46:22 format_partition|Checking mount point /var/log/ramfs/cm/trace/ccm/sdl|<:DEBUG>
01/24/2012 18:46:22 format_partition|Checking mount point /var/log/ramfs/cm/trace/ccm/calllogs|<:DEBUG>
01/24/2012 18:46:22 format_partition|Checking mount point /var/log/ramfs/cm/trace/ccm/dntrace|<:DEBUG>
01/24/2012 18:46:22 format_partition|Checking mount point /var/log/ramfs/cm/trace/cti/sdi|<:DEBUG>
01/24/2012 18:46:22 format_partition|Checking mount point /var/log/ramfs/cm/trace/cti/sdl|<:DEBUG>
01/24/2012 18:46:22 format_partition|Checking mount point /partB|<:DEBUG>
01/24/2012 18:46:22 format_partition|Checking mount point /partB/proc/sys/fs/binfmt_misc|<:DEBUG>
01/24/2012 18:46:22 format_partition|Calling "fuser /partB/proc/sys/fs/binfmt_misc > /common/log/install/capture.txt 2>&1"|<:DEBUG>
01/24/2012 18:46:22 platform_pre_install|Waiting for pid file, /tmp/format_partition_pid|<:DEBUG>
01/24/2012 18:46:22 platform_pre_install|Waiting for "format_partition.py" (9559) to complete|<:DEBUG>
01/24/2012 18:46:22 format_partition|Calling "umount -l /partB/proc/sys/fs/binfmt_misc > /common/log/install/capture.txt 2>&1"|<:DEBUG>
01/24/2012 18:46:22 format_partition|Checking mount point /partB/partB|<:DEBUG>
01/24/2012 18:46:22 format_partition|Calling "fuser /partB/partB > /common/log/install/capture.txt 2>&1"|<:DEBUG>
01/24/2012 18:46:22 format_partition|Calling "umount -l /partB/partB > /common/log/install/capture.txt 2>&1"|<:DEBUG>
01/24/2012 18:46:22 format_partition|Checking mount point /partB/grub|<:DEBUG>
01/24/2012 18:46:22 format_partition|Calling "fuser /partB/grub > /common/log/install/capture.txt 2>&1"|<:DEBUG>
01/24/2012 18:46:22 format_partition|Calling "umount -l /partB/grub > /common/log/install/capture.txt 2>&1"|<:DEBUG>
01/24/2012 18:46:22 format_partition|Checking mount point /partB/common|<:DEBUG>
01/24/2012 18:46:22 format_partition|Calling "fuser /partB/common > /common/log/install/capture.txt 2>&1"|<:DEBUG>
01/24/2012 18:46:22 format_partition|Calling "umount -l /partB/common > /common/log/install/capture.txt 2>&1"|<:DEBUG>
01/24/2012 18:46:22 format_partition|Checking mount point /partB/proc|<:DEBUG>
01/24/2012 18:46:22 format_partition|Calling "fuser /partB/proc > /common/log/install/capture.txt 2>&1"|<:DEBUG>
01/24/2012 18:46:22 format_partition|Calling "umount -l /partB/proc > /common/log/install/capture.txt 2>&1"|<:DEBUG>
01/24/2012 18:46:22 format_partition|Checking mount point /partB/dev|<:DEBUG>
01/24/2012 18:46:22 format_partition|Calling "fuser /partB/dev > /common/log/install/capture.txt 2>&1"|<:DEBUG>
01/24/2012 18:46:22 format_partition|Calling "umount -l /partB/dev > /common/log/install/capture.txt 2>&1"|<:DEBUG>
01/24/2012 18:46:22 format_partition|Checking mount point /partB/sys|<:DEBUG>
01/24/2012 18:46:22 format_partition|Calling "fuser /partB/sys > /common/log/install/capture.txt 2>&1"|<:DEBUG>
01/24/2012 18:46:22 format_partition|Calling "umount -l /partB/sys > /common/log/install/capture.txt 2>&1"|<:DEBUG>
01/24/2012 18:46:22 format_partition|Checking mount point /partB/selinux|<:DEBUG>
01/24/2012 18:46:22 format_partition|Calling "fuser /partB/selinux > /common/log/install/capture.txt 2>&1"|<:DEBUG>
01/24/2012 18:46:22 format_partition|Calling "umount -l /partB/selinux > /common/log/install/capture.txt 2>&1"|<:DEBUG>
01/24/2012 18:46:22 format_partition|Checking mount point /partB/dev/pts|<:DEBUG>
01/24/2012 18:46:22 format_partition|Calling "fuser /partB/dev/pts > /common/log/install/capture.txt 2>&1"|<:DEBUG>
01/24/2012 18:46:22 format_partition|Calling "umount -l /partB/dev/pts > /common/log/install/capture.txt 2>&1"|<:DEBUG>
01/24/2012 18:46:22 format_partition|Checking mount point /mnt/source|<:DEBUG>
01/24/2012 18:46:22 format_partition|Unmount "/partB"|<:DEBUG>
01/24/2012 18:46:22 format_partition|Calling "fuser -k /partB > /common/log/install/capture.txt 2>&1"|<:DEBUG>
01/24/2012 18:46:22 format_partition|Calling "umount -l /partB > /common/log/install/capture.txt 2>&1"|<:DEBUG>
01/24/2012 18:46:22 format_partition|Unmount partition /partB complete|<:INFO>
01/24/2012 18:46:22 format_partition|Format partition /partB|<:INFO>
01/24/2012 18:46:22 format_partition|Calling "mkfs -t ext3 -L /partB /dev/sda2 > /common/log/install/capture.txt 2>&1"|<:DEBUG>
01/24/2012 18:46:22 format_partition|Open file /tmp/mkfs_cmd_9559|<:DEBUG>
01/24/2012 18:46:22 format_partition|Create mkfs script /tmp/mkfs_cmd_9559|<:DEBUG>
01/24/2012 18:46:22 format_partition|Make /tmp/mkfs_cmd_9559 executable|<:DEBUG>
01/24/2012 18:46:22 format_partition|Execute /tmp/mkfs_cmd_9559|<:DEBUG>
01/24/2012 18:46:23 format_partition|Remove /tmp/mkfs_cmd_9559|<:DEBUG>
01/24/2012 18:46:23 format_partition|Calling "tune2fs -m 1 -C 0 -i 0 -O dir_index /dev/sda2 > /common/log/install/capture.txt 2>&1"|<:DEBUG>
01/24/2012 18:46:23 format_partition|(CAPTURE) tune2fs 1.39 (29-May-2006)|<:DEBUG>
01/24/2012 18:46:23 format_partition|(CAPTURE) Setting current mount count to 0|<:DEBUG>
01/24/2012 18:46:23 format_partition|(CAPTURE) Setting interval between checks to 0 seconds|<:DEBUG>
01/24/2012 18:46:23 format_partition|(CAPTURE) Setting reserved blocks percentage to 1% (37191 blocks)|<:DEBUG>
01/24/2012 18:46:23 format_partition|Format partition /partB complete|<:INFO>
01/24/2012 18:46:23 format_partition|Remount partition /partB|<:INFO>
01/24/2012 18:46:23 format_partition|Calling "mount -l /partB > /common/log/install/capture.txt 2>&1"|<:DEBUG>
01/24/2012 18:46:23 format_partition|Remount partition /partB complete|<:INFO>
01/24/2012 18:46:23 format_partition|Generate the result file, /tmp/format_partition_results, and exit|<:DEBUG>
01/24/2012 18:46:23 format_partition|Open file /tmp/tmp_file_9559|<:DEBUG>
01/24/2012 18:46:23 format_partition|Writing 0 to /tmp/tmp_file_9559|<:DEBUG>
01/24/2012 18:46:23 format_partition|Renaming /tmp/tmp_file_9559 to /tmp/format_partition_results|<:DEBUG>
01/24/2012 18:46:24 platform_pre_install|"format_partition.py" (9559) is complete (0)|<:DEBUG>
01/24/2012 18:46:24 platform_pre_install|Format inactive partition complete|<:INFO>
01/24/2012 18:46:24 platform_pre_install|Clean up inactive partition log areas|<:INFO>
01/24/2012 18:46:24 platform_pre_install|Remove files from /var/log/inactive|<:DEBUG>
01/24/2012 18:46:27 platform_pre_install|Remove directories from /var/log/inactive|<:DEBUG>
01/24/2012 18:46:27 platform_pre_install|(CAPTURE) find: /var/log/inactive/audit: No such file or directory|<:DEBUG>
01/24/2012 18:46:27 platform_pre_install|(CAPTURE) find: /var/log/inactive/ccm_db: No such file or directory|<:DEBUG>
01/24/2012 18:46:27 platform_pre_install|(CAPTURE) find: /var/log/inactive/cm: No such file or directory|<:DEBUG>
01/24/2012 18:46:27 platform_pre_install|(CAPTURE) find: /var/log/inactive/core: No such file or directory|<:DEBUG>
01/24/2012 18:46:27 platform_pre_install|(CAPTURE) find: /var/log/inactive/dp_db: No such file or directory|<:DEBUG>
01/24/2012 18:46:27 platform_pre_install|(CAPTURE) find: /var/log/inactive/mgetty: No such file or directory|<:DEBUG>
01/24/2012 18:46:27 platform_pre_install|(CAPTURE) find: /var/log/inactive/patches: No such file or directory|<:DEBUG>
01/24/2012 18:46:27 platform_pre_install|(CAPTURE) find: /var/log/inactive/platform: No such file or directory|<:DEBUG>
01/24/2012 18:46:27 platform_pre_install|(CAPTURE) find: /var/log/inactive/sso: No such file or directory|<:DEBUG>
01/24/2012 18:46:27 platform_pre_install|(CAPTURE) find: /var/log/inactive/syslog: No such file or directory|<:DEBUG>
01/24/2012 18:46:27 platform_pre_install|(CAPTURE) find: /var/log/inactive/tomcat: No such file or directory|<:DEBUG>
01/24/2012 18:46:27 platform_pre_install|Clean up rpm_archive area|<:INFO>
01/24/2012 18:46:27 platform_pre_install|Examine /common/rpm-archive/8.6.2.22900-9 for removal|<:DEBUG>
01/24/2012 18:46:27 platform_pre_install|/common/rpm-archive/RPMS, /common/rpm-archive/8.6.2.20000-2, /common/rpm-archive/8.6.2.22900-9|<:DEBUG>
01/24/2012 18:46:27 platform_pre_install|Platform Pre-install RTMTFinish|<:NOTICE>
01/24/2012 18:46:27 platform_pre_install|Platform Pre-install successful|<:INFO>
01/24/2012 18:46:27 upgrade_manager.sh|Preparation of inactive partition complete|<:INFO>
01/24/2012 18:46:27 upgrade_manager.sh|Install the OS on inactive partition|<:INFO>
01/24/2012 18:46:27 upgrade_manager.sh|Calling /common/download/8.6.2.22900-9/Cisco/bin/install_os src_dir=/mnt/source base_dir=/common/download/8.6.2.22900-9 mode=upgrade rpm_archive=/common/rpm-archive/8.6.2.22900-9|<:DEBUG>
01/24/2012 18:46:27 install_os|Parse argument src_dir=/mnt/source|<:DEBUG>
01/24/2012 18:46:27 install_os|Parse argument base_dir=/common/download/8.6.2.22900-9|<:DEBUG>
01/24/2012 18:46:27 install_os|Parse argument mode=upgrade|<:DEBUG>
01/24/2012 18:46:27 install_os|Parse argument rpm_archive=/common/rpm-archive/8.6.2.22900-9|<:DEBUG>
01/24/2012 18:46:27 install_os|Initialize global data|<:INFO>
01/24/2012 18:46:27 install_os|Initialize chroot variables|<:DEBUG>
01/24/2012 18:46:27 install_os|Initialize RPM repository variables|<:DEBUG>
01/24/2012 18:46:27 install_os|Initialize global data complete|<:INFO>
01/24/2012 18:46:27 install_os|Calling "source /common/cisco/install/setup/utils.sh"|<:DEBUG>
01/24/2012 18:46:27 install_os|Copy /mnt/source/Cisco/install/os_rpm_list to /common/cisco/install|<:INFO>
01/24/2012 18:46:27 install_os|Calling "cp /mnt/source/Cisco/install/os_rpm_list /common/cisco/install"|<:DEBUG>
01/24/2012 18:46:28 install_os|Copy /mnt/source/Cisco/install/bin/install_rpms to /common/cisco/bin|<:INFO>
01/24/2012 18:46:28 install_os|Upgrade OS RTMTStart|<:NOTICE>
01/24/2012 18:46:28 install_os|Upgrade OS starting|<:INFO>
01/24/2012 18:46:28 install_os|Installing the OS on the inactive partition|<:INFO>
01/24/2012 18:46:28 install_os|Generate RAM disk items for the OS install|<:INFO>
01/24/2012 18:46:28 install_os|Calling "mkdir -p /partB/dev"|<:DEBUG>
01/24/2012 18:46:28 install_os|Calling "mknod /partB/dev/null c 1 3"|<:DEBUG>
01/24/2012 18:46:28 install_os|Calling "mkdir -p /partB/etc"|<:DEBUG>
01/24/2012 18:46:28 install_os|Copy /etc/fstab to /partB/etc/fstab|<:INFO>
01/24/2012 18:46:28 install_os|Calling "cp /etc/fstab /partB/etc/fstab"|<:DEBUG>
01/24/2012 18:46:28 install_os|Install the OS RPMS|<:INFO>
01/24/2012 18:46:28 install_rpms|Parse argument list=/common/cisco/install/os_rpm_list|<:DEBUG>
01/24/2012 18:46:28 install_rpms|Parse argument repo=/common/rpm-archive/8.6.2.22900-9/RPMS|<:DEBUG>
01/24/2012 18:46:28 install_rpms|Parse argument dir=/partB|<:DEBUG>
01/24/2012 18:46:28 install_rpms|Parse argument initdb|<:DEBUG>
01/24/2012 18:46:28 install_rpms|Process RPMs from /common/cisco/install/os_rpm_list|<:INFO>
01/24/2012 18:46:28 install_rpms|Get RPMs to install for group base|<:DEBUG>
01/24/2012 18:46:28 install_rpms|No packages found for group base.  Continue.|<:DEBUG>
01/24/2012 18:46:28 install_rpms|Get RPMs to install for group core|<:DEBUG>
01/24/2012 18:46:28 install_rpms|Installing 151 RPMs for group core|<:INFO>
01/24/2012 18:46:28 install_rpms|Calling nice -n 19 rpm --root /partB -i (suppressing output)|<:DEBUG>
01/24/2012 18:46:29 install_rpms|Calling nice -n 19 rpm --root /partB -i --nodeps (suppressing output)|<:DEBUG>
01/24/2012 18:47:17 install_rpms|Install RPMs for group core -  complete|<:INFO>
01/24/2012 18:47:17 install_rpms|Get RPMs to install for group cucos-application|<:DEBUG>
01/24/2012 18:47:17 install_rpms|Installing 24 RPMs for group cucos-application|<:INFO>
01/24/2012 18:47:17 install_rpms|Calling nice -n 19 rpm --root /partB -i (suppressing output)|<:DEBUG>
01/24/2012 18:47:18 install_rpms|Calling nice -n 19 rpm --root /partB -i --nodeps (suppressing output)|<:DEBUG>
01/24/2012 18:47:21 install_rpms|Install RPMs for group cucos-application -  complete|<:INFO>
01/24/2012 18:47:21 install_rpms|Get RPMs to install for group cucos-base|<:DEBUG>
01/24/2012 18:47:21 install_rpms|Installing 61 RPMs for group cucos-base|<:INFO>
01/24/2012 18:47:21 install_rpms|Calling nice -n 19 rpm --root /partB -i (suppressing output)|<:DEBUG>
01/24/2012 18:47:22 install_rpms|Calling nice -n 19 rpm --root /partB -i --nodeps (suppressing output)|<:DEBUG>
01/24/2012 18:47:27 install_rpms|Install RPMs for group cucos-base -  complete|<:INFO>
01/24/2012 18:47:27 install_rpms|Get RPMs to install for group cucos-platform|<:DEBUG>
01/24/2012 18:47:27 install_rpms|Installing 15 RPMs for group cucos-platform|<:INFO>
01/24/2012 18:47:27 install_rpms|Calling nice -n 19 rpm --root /partB -i (suppressing output)|<:DEBUG>
01/24/2012 18:47:41 install_rpms|Install RPMs for group cucos-platform -  complete|<:INFO>
01/24/2012 18:47:41 install_rpms|RPM Process complete|<:INFO>
01/24/2012 18:47:41 install_os|Generating /etc/modprobe.conf|<:INFO>
01/24/2012 18:47:41 install_os|Creating /partB/etc/modprobe.conf from /etc/modprobe.conf|<:DEBUG>
01/24/2012 18:47:41 install_os|Generate fstab for the inactive partition|<:INFO>
01/24/2012 18:47:41 install_os|Swapping / and /partB in /partB/etc/fstab|<:DEBUG>
01/24/2012 18:47:41 install_os|Calling "cp /tmp/fstab /partB/etc/fstab"|<:DEBUG>
01/24/2012 18:47:41 install_os|Make the initrd image for the new OS on the inactive partition|<:INFO>
01/24/2012 18:47:41 install_os|HWModel = VMware|<:INFO>
01/24/2012 18:47:41 install_os|chroot /partB mkinitrd -v /boot/initrd-2.6.18-194.26.1.el5PAE.img 2.6.18-194.26.1.el5PAE|<:DEBUG>
01/24/2012 18:47:43 install_os|(CAPTURE) warning: /common/rpm-archive/8.6.2.22900-9/RPMS/kernel-PAE-2.6.18-194.26.1.eCreating initramfs|<:DEBUG>
01/24/2012 18:47:43 install_os|(CAPTURE) Looking for deps of module ehci-hcd|<:DEBUG>
01/24/2012 18:47:43 install_os|(CAPTURE) Looking for deps of module ohci-hcd|<:DEBUG>
01/24/2012 18:47:43 install_os|(CAPTURE) Looking for deps of module uhci-hcd|<:DEBUG>
01/24/2012 18:47:43 install_os|(CAPTURE) Looking for deps of module ext3: jbd |<:DEBUG>
01/24/2012 18:47:43 install_os|(CAPTURE) Looking for deps of module jbd|<:DEBUG>
01/24/2012 18:47:43 install_os|(CAPTURE) Looking for driver for device LABEL=/partB|<:DEBUG>
01/24/2012 18:47:43 install_os|(CAPTURE) Looking for deps of module mptbase|<:DEBUG>
01/24/2012 18:47:43 install_os|(CAPTURE) Looking for deps of module mptspi: scsi_mod scsi_transport_spi mptbase mptscsih |<:DEBUG>
01/24/2012 18:47:43 install_os|(CAPTURE) Looking for deps of module scsi_mod|<:DEBUG>
01/24/2012 18:47:43 install_os|(CAPTURE) Looking for deps of module sd_mod: scsi_mod |<:DEBUG>
01/24/2012 18:47:43 install_os|(CAPTURE) Looking for deps of module scsi_transport_spi: scsi_mod |<:DEBUG>
01/24/2012 18:47:43 install_os|(CAPTURE) Looking for deps of module mptscsih: scsi_mod mptbase |<:DEBUG>
01/24/2012 18:47:43 install_os|(CAPTURE) Looking for deps of module ata_piix: scsi_mod libata |<:DEBUG>
01/24/2012 18:47:43 install_os|(CAPTURE) Looking for deps of module libata: scsi_mod |<:DEBUG>
01/24/2012 18:47:43 install_os|(CAPTURE) Looking for deps of module ide-disk|<:DEBUG>
01/24/2012 18:47:43 install_os|(CAPTURE) Looking for deps of module dm-mem-cache|<:DEBUG>
01/24/2012 18:47:43 install_os|(CAPTURE) Looking for deps of module dm-region_hash: dm-mod dm-log |<:DEBUG>
01/24/2012 18:47:43 install_os|(CAPTURE) Looking for deps of module dm-mod|<:DEBUG>
01/24/2012 18:47:43 install_os|(CAPTURE) Looking for deps of module dm-log: dm-mod |<:DEBUG>
01/24/2012 18:47:43 install_os|(CAPTURE) Looking for deps of module dm-message|<:DEBUG>
01/24/2012 18:47:43 install_os|(CAPTURE) Looking for deps of module dm-raid45: dm-message dm-mod dm-mem-cache dm-log dm-region_hash |<:DEBUG>
01/24/2012 18:47:43 install_os|(CAPTURE) Using modules:  /lib/modules/2.6.18-194.26.1.el5PAE/kernel/drivers/usb/host/ehci-hcd.ko /lib/modules/2.6.18-194.26.1.el5PAE/kernel/drivers/usb/host/ohci-hcd.ko /lib/modules/2.6.18-194.26.1.el5PAE/kernel/drivers/usb/host/uhci-hcd.ko /lib/modules/2.6.18-194.26.1.el5PAE/kernel/fs/jbd/jbd.ko /lib/modules/2.6.18-194.26.1.el5PAE/kernel/fs/ext3/ext3.ko /lib/modules/2.6.18-194.26.1.el5PAE/kernel/drivers/message/fusion/mptbase.ko /lib/modules/2.6.18-194.26.1.el5PAE/kernel/drivers/scsi/scsi_mod.ko /lib/modules/2.6.18-194.26.1.el5PAE/kernel/drivers/scsi/sd_mod.ko /lib/modules/2.6.18-194.26.1.el5PAE/kernel/drivers/scsi/scsi_transport_spi.ko /lib/modules/2.6.18-194.26.1.el5PAE/kernel/drivers/message/fusion/mptscsih.ko /lib/modules/2.6.18-194.26.1.el5PAE/kernel/drivers/message/fusion/mptspi.ko /lib/modules/2.6.18-194.26.1.el5PAE/kernel/drivers/ata/libata.ko /lib/modules/2.6.18-194.26.1.el5PAE/kernel/drivers/ata/ata_piix.ko /lib/modules/2.6.18-194.26.1.el5PAE/kernel/drivers/md/dm-mem-cache.ko /lib/modules/2.6.18|<:DEBUG>
01/24/2012 18:47:43 install_os|(CAPTURE) /sbin/nash -> /tmp/initrd.m11986/bin/nash|<:DEBUG>
01/24/2012 18:47:43 install_os|(CAPTURE) /sbin/insmod.static -> /tmp/initrd.m11986/bin/insmod|<:DEBUG>
01/24/2012 18:47:43 install_os|(CAPTURE) copy from `/lib/modules/2.6.18-194.26.1.el5PAE/kernel/drivers/usb/host/ehci-hcd.ko' [elf32-i386] to `/tmp/initrd.m11986/lib/ehci-hcd.ko' [elf32-i386]|<:DEBUG>
01/24/2012 18:47:43 install_os|(CAPTURE) copy from `/lib/modules/2.6.18-194.26.1.el5PAE/kernel/drivers/usb/host/ohci-hcd.ko' [elf32-i386] to `/tmp/initrd.m11986/lib/ohci-hcd.ko' [elf32-i386]|<:DEBUG>
01/24/2012 18:47:43 install_os|(CAPTURE) copy from `/lib/modules/2.6.18-194.26.1.el5PAE/kernel/drivers/usb/host/uhci-hcd.ko' [elf32-i386] to `/tmp/initrd.m11986/lib/uhci-hcd.ko' [elf32-i386]|<:DEBUG>
01/24/2012 18:47:43 install_os|(CAPTURE) copy from `/lib/modules/2.6.18-194.26.1.el5PAE/kernel/fs/jbd/jbd.ko' [elf32-i386] to `/tmp/initrd.m11986/lib/jbd.ko' [elf32-i386]|<:DEBUG>
01/24/2012 18:47:43 install_os|(CAPTURE) copy from `/lib/modules/2.6.18-194.26.1.el5PAE/kernel/fs/ext3/ext3.ko' [elf32-i386] to `/tmp/initrd.m11986/lib/ext3.ko' [elf32-i386]|<:DEBUG>
01/24/2012 18:47:43 install_os|(CAPTURE) copy from `/lib/modules/2.6.18-194.26.1.el5PAE/kernel/drivers/message/fusion/mptbase.ko' [elf32-i386] to `/tmp/initrd.m11986/lib/mptbase.ko' [elf32-i386]|<:DEBUG>
01/24/2012 18:47:43 install_os|(CAPTURE) copy from `/lib/modules/2.6.18-194.26.1.el5PAE/kernel/drivers/scsi/scsi_mod.ko' [elf32-i386] to `/tmp/initrd.m11986/lib/scsi_mod.ko' [elf32-i386]|<:DEBUG>
01/24/2012 18:47:43 install_os|(CAPTURE) copy from `/lib/modules/2.6.18-194.26.1.el5PAE/kernel/drivers/scsi/sd_mod.ko' [elf32-i386] to `/tmp/initrd.m11986/lib/sd_mod.ko' [elf32-i386]|<:DEBUG>
01/24/2012 18:47:43 install_os|(CAPTURE) copy from `/lib/modules/2.6.18-194.26.1.el5PAE/kernel/drivers/scsi/scsi_transport_spi.ko' [elf32-i386] to `/tmp/initrd.m11986/lib/scsi_transport_spi.ko' [elf32-i386]|<:DEBUG>
01/24/2012 18:47:43 install_os|(CAPTURE) copy from `/lib/modules/2.6.18-194.26.1.el5PAE/kernel/drivers/message/fusion/mptscsih.ko' [elf32-i386] to `/tmp/initrd.m11986/lib/mptscsih.ko' [elf32-i386]|<:DEBUG>
01/24/2012 18:47:43 install_os|(CAPTURE) copy from `/lib/modules/2.6.18-194.26.1.el5PAE/kernel/drivers/message/fusion/mptspi.ko' [elf32-i386] to `/tmp/initrd.m11986/lib/mptspi.ko' [elf32-i386]|<:DEBUG>
01/24/2012 18:47:43 install_os|(CAPTURE) copy from `/lib/modules/2.6.18-194.26.1.el5PAE/kernel/drivers/ata/libata.ko' [elf32-i386] to `/tmp/initrd.m11986/lib/libata.ko' [elf32-i386]|<:DEBUG>
01/24/2012 18:47:43 install_os|(CAPTURE) copy from `/lib/modules/2.6.18-194.26.1.el5PAE/kernel/drivers/ata/ata_piix.ko' [elf32-i386] to `/tmp/initrd.m11986/lib/ata_piix.ko' [elf32-i386]|<:DEBUG>
01/24/2012 18:47:43 install_os|(CAPTURE) copy from `/lib/modules/2.6.18-194.26.1.el5PAE/kernel/drivers/md/dm-mem-cache.ko' [elf32-i386] to `/tmp/initrd.m11986/lib/dm-mem-cache.ko' [elf32-i386]|<:DEBUG>
01/24/2012 18:47:43 install_os|(CAPTURE) copy from `/lib/modules/2.6.18-194.26.1.el5PAE/kernel/drivers/md/dm-mod.ko' [elf32-i386] to `/tmp/initrd.m11986/lib/dm-mod.ko' [elf32-i386]|<:DEBUG>
01/24/2012 18:47:43 install_os|(CAPTURE) copy from `/lib/modules/2.6.18-194.26.1.el5PAE/kernel/drivers/md/dm-log.ko' [elf32-i386] to `/tmp/initrd.m11986/lib/dm-log.ko' [elf32-i386]|<:DEBUG>
01/24/2012 18:47:43 install_os|(CAPTURE) copy from `/lib/modules/2.6.18-194.26.1.el5PAE/kernel/drivers/md/dm-region_hash.ko' [elf32-i386] to `/tmp/initrd.m11986/lib/dm-region_hash.ko' [elf32-i386]|<:DEBUG>
01/24/2012 18:47:43 install_os|(CAPTURE) copy from `/lib/modules/2.6.18-194.26.1.el5PAE/kernel/drivers/md/dm-message.ko' [elf32-i386] to `/tmp/initrd.m11986/lib/dm-message.ko' [elf32-i386]|<:DEBUG>
01/24/2012 18:47:43 install_os|(CAPTURE) copy from `/lib/modules/2.6.18-194.26.1.el5PAE/kernel/drivers/md/dm-raid45.ko' [elf32-i386] to `/tmp/initrd.m11986/lib/dm-raid45.ko' [elf32-i386]|<:DEBUG>
01/24/2012 18:47:43 install_os|(CAPTURE) /sbin/dmraid.static -> /tmp/initrd.m11986/bin/dmraid|<:DEBUG>
01/24/2012 18:47:43 install_os|(CAPTURE) /sbin/kpartx.static -> /tmp/initrd.m11986/bin/kpartx|<:DEBUG>
01/24/2012 18:47:43 install_os|(CAPTURE) Adding module ehci-hcd|<:DEBUG>
01/24/2012 18:47:43 install_os|(CAPTURE) Adding module ohci-hcd|<:DEBUG>
01/24/2012 18:47:43 install_os|(CAPTURE) Adding module uhci-hcd|<:DEBUG>
01/24/2012 18:47:43 install_os|(CAPTURE) Adding module jbd|<:DEBUG>
01/24/2012 18:47:43 install_os|(CAPTURE) Adding module ext3|<:DEBUG>
01/24/2012 18:47:43 install_os|(CAPTURE) Adding module mptbase|<:DEBUG>
01/24/2012 18:47:43 install_os|(CAPTURE) Adding module scsi_mod|<:DEBUG>
01/24/2012 18:47:43 install_os|(CAPTURE) Adding module sd_mod|<:DEBUG>
01/24/2012 18:47:43 install_os|(CAPTURE) Adding module scsi_transport_spi|<:DEBUG>
01/24/2012 18:47:43 install_os|(CAPTURE) Adding module mptscsih|<:DEBUG>
01/24/2012 18:47:43 install_os|(CAPTURE) Adding module mptspi|<:DEBUG>
01/24/2012 18:47:43 install_os|(CAPTURE) Adding module libata|<:DEBUG>
01/24/2012 18:47:43 install_os|(CAPTURE) Adding module ata_piix|<:DEBUG>
01/24/2012 18:47:43 install_os|(CAPTURE) Adding module dm-mem-cache|<:DEBUG>
01/24/2012 18:47:43 install_os|(CAPTURE) Adding module dm-mod|<:DEBUG>
01/24/2012 18:47:43 install_os|(CAPTURE) Adding module dm-log|<:DEBUG>
01/24/2012 18:47:43 install_os|(CAPTURE) Adding module dm-region_hash|<:DEBUG>
01/24/2012 18:47:43 install_os|(CAPTURE) Adding module dm-message|<:DEBUG>
01/24/2012 18:47:43 install_os|(CAPTURE) Adding module dm-raid45|<:DEBUG>
01/24/2012 18:47:43 install_os|Generating needed devices on the inactive partition|<:INFO>
01/24/2012 18:47:43 install_os|Installing OS complete.|<:INFO>
01/24/2012 18:47:43 install_os|Upgrade OS RTMTFinish|<:NOTICE>
01/24/2012 18:47:43 install_os|Upgrade OS successful|<:INFO>
01/24/2012 18:47:43 upgrade_manager.sh|OS install on inactive partition complete|<:INFO>
01/24/2012 18:47:43 upgrade_manager.sh|Perform post-processing nochroot|<:INFO>
01/24/2012 18:47:43 upgrade_manager.sh|Calling /common/download/8.6.2.22900-9/Cisco/bin/platform_post_install_nochroot src_dir=/mnt/source base_dir=/common/download/8.6.2.22900-9 mode=upgrade rpm_archive=/common/rpm-archive/8.6.2.22900-9|<:DEBUG>
01/24/2012 18:47:43 upgrade_manager.sh|PATH=/common/download/8.6.2.22900-9/Cisco/bin:/usr/kerberos/sbin:/usr/kerberos/bin:/usr/local/sbin:/sbin:/usr/sbin:/bin:/usr/bin:/sbin:/home/sftpuser:/root/.security|<:DEBUG>
01/24/2012 18:47:43 platform_post_install_nochroot|Initialize setup functions|<:INFO>
01/24/2012 18:47:43 platform_post_install_nochroot|Calling "source /common/cisco/install/setup/utils.sh"|<:DEBUG>
01/24/2012 18:47:43 platform_post_install_nochroot|Calling "source /common/cisco/install/setup/create_old_style_config_files.sh"|<:DEBUG>
01/24/2012 18:47:43 platform_post_install_nochroot|Initialize setup functions complete|<:INFO>
01/24/2012 18:47:43 platform_post_install_nochroot|Parse argument src_dir=/mnt/source|<:DEBUG>
01/24/2012 18:47:43 platform_post_install_nochroot|Parse argument base_dir=/common/download/8.6.2.22900-9|<:DEBUG>
01/24/2012 18:47:43 platform_post_install_nochroot|Parse argument mode=upgrade|<:DEBUG>
01/24/2012 18:47:43 platform_post_install_nochroot|Parse argument rpm_archive=/common/rpm-archive/8.6.2.22900-9|<:DEBUG>
01/24/2012 18:47:43 platform_post_install_nochroot|Creation/Copy of libraries/directories RTMTStart|<:NOTICE>
01/24/2012 18:47:43 platform_post_install_nochroot|Create directories on inactive partition|<:INFO>
01/24/2012 18:47:43 platform_post_install_nochroot|Calling "mkdir -p -m755 /partB/partB"|<:DEBUG>
01/24/2012 18:47:43 platform_post_install_nochroot|Calling "mkdir -p -m755 /partB/grub"|<:DEBUG>
01/24/2012 18:47:43 platform_post_install_nochroot|Calling "mkdir -p -m755 /partB/common"|<:DEBUG>
01/24/2012 18:47:43 platform_post_install_nochroot|Calling "mkdir -p -m755 /partB/sys"|<:DEBUG>
01/24/2012 18:47:43 platform_post_install_nochroot|Calling "mkdir -p -m777 /partB/opt/cisco/install"|<:DEBUG>
01/24/2012 18:47:43 platform_post_install_nochroot|Calling "mkdir -p /partB/usr/local/thirdparty"|<:DEBUG>
01/24/2012 18:47:43 platform_post_install_nochroot|Calling "mkdir -p /partB/usr/local/thirdparty/java"|<:DEBUG>
01/24/2012 18:47:43 platform_post_install_nochroot|Calling "mkdir -p -m777 /partB/usr/local/platform/conf"|<:DEBUG>
01/24/2012 18:47:43 platform_post_install_nochroot|Calling "mkdir -p /partB/mnt/source"|<:DEBUG>
01/24/2012 18:47:43 platform_post_install_nochroot|Remounting  to /partB/mnt/source|<:DEBUG>
01/24/2012 18:47:43 platform_post_install_nochroot|Calling "/partB/bin/mount --bind /mnt/source /partB/mnt/source"|<:DEBUG>
01/24/2012 18:47:43 platform_post_install_nochroot|Mounting common partitions on inactive partition|<:INFO>
01/24/2012 18:47:43 platform_post_install_nochroot|Calling "/partB/bin/mount --bind / /partB/partB"|<:DEBUG>
01/24/2012 18:47:43 platform_post_install_nochroot|Calling "/partB/bin/mount --bind /grub /partB/grub"|<:DEBUG>
01/24/2012 18:47:43 platform_post_install_nochroot|Calling "/partB/bin/mount --bind /common /partB/common"|<:DEBUG>
01/24/2012 18:47:43 platform_post_install_nochroot|Calling "/partB/bin/mount --bind /proc /partB/proc"|<:DEBUG>
01/24/2012 18:47:43 platform_post_install_nochroot|Calling "/partB/bin/mount --bind /dev /partB/dev"|<:DEBUG>
01/24/2012 18:47:43 platform_post_install_nochroot|Calling "/partB/bin/mount --bind /sys /partB/sys"|<:DEBUG>
01/24/2012 18:47:44 platform_post_install_nochroot|Transfer files to the inactive partition|<:INFO>
01/24/2012 18:47:44 platform_post_install_nochroot|Copying contents of /common/cisco/bin to /partB/opt/cisco/install|<:DEBUG>
01/24/2012 18:47:44 platform_post_install_nochroot|Copy /common/cisco/bin to /partB/opt/cisco/install|<:INFO>
01/24/2012 18:47:44 platform_post_install_nochroot|Calling "mkdir -p /partB/opt/cisco/install/bin"|<:DEBUG>
01/24/2012 18:47:44 platform_post_install_nochroot|Calling "cp /common/cisco/bin/platform_pre_install /partB/opt/cisco/install/bin"|<:DEBUG>
01/24/2012 18:47:44 platform_post_install_nochroot|Calling "cp /common/cisco/bin/xmlfoo /partB/opt/cisco/install/bin"|<:DEBUG>
01/24/2012 18:47:44 platform_post_install_nochroot|Calling "cp /common/cisco/bin/progmeter /partB/opt/cisco/install/bin"|<:DEBUG>
01/24/2012 18:47:44 platform_post_install_nochroot|Calling "cp /common/cisco/bin/fsck /partB/opt/cisco/install/bin"|<:DEBUG>
01/24/2012 18:47:44 platform_post_install_nochroot|Calling "cp /common/cisco/bin/product_extensions /partB/opt/cisco/install/bin"|<:DEBUG>
01/24/2012 18:47:44 platform_post_install_nochroot|Calling "cp /common/cisco/bin/ks_pre.sh /partB/opt/cisco/install/bin"|<:DEBUG>
01/24/2012 18:47:44 platform_post_install_nochroot|Calling "cp /common/cisco/bin/iaccount.sh /partB/opt/cisco/install/bin"|<:DEBUG>
01/24/2012 18:47:44 platform_post_install_nochroot|Calling "cp /common/cisco/bin/skip_mediacheck /partB/opt/cisco/install/bin"|<:DEBUG>
01/24/2012 18:47:44 platform_post_install_nochroot|Calling "cp /common/cisco/bin/usb_key_detect /partB/opt/cisco/install/bin"|<:DEBUG>
01/24/2012 18:47:44 platform_post_install_nochroot|Calling "cp /common/cisco/bin/date /partB/opt/cisco/install/bin"|<:DEBUG>
01/24/2012 18:47:44 platform_post_install_nochroot|Calling "cp /common/cisco/bin/diff /partB/opt/cisco/install/bin"|<:DEBUG>
01/24/2012 18:47:44 platform_post_install_nochroot|Calling "cp /common/cisco/bin/format_partition.py /partB/opt/cisco/install/bin"|<:DEBUG>
01/24/2012 18:47:44 platform_post_install_nochroot|Calling "cp /common/cisco/bin/xcomponent.sh /partB/opt/cisco/install/bin"|<:DEBUG>
01/24/2012 18:47:44 platform_post_install_nochroot|Calling "cp /common/cisco/bin/InstallWizard /partB/opt/cisco/install/bin"|<:DEBUG>
01/24/2012 18:47:44 platform_post_install_nochroot|Calling "cp /common/cisco/bin/ilog_impl /partB/opt/cisco/install/bin"|<:DEBUG>
01/24/2012 18:47:44 platform_post_install_nochroot|Calling "cp /common/cisco/bin/ihistory.sh /partB/opt/cisco/install/bin"|<:DEBUG>
01/24/2012 18:47:44 platform_post_install_nochroot|Calling "cp /common/cisco/bin/populate_rpm_archive /partB/opt/cisco/install/bin"|<:DEBUG>
01/24/2012 18:47:44 platform_post_install_nochroot|Calling "cp /common/cisco/bin/prepare_grub /partB/opt/cisco/install/bin"|<:DEBUG>
01/24/2012 18:47:44 platform_post_install_nochroot|Calling "cp /common/cisco/bin/strace /partB/opt/cisco/install/bin"|<:DEBUG>
01/24/2012 18:47:44 platform_post_install_nochroot|Calling "cp /common/cisco/bin/install_rpms /partB/opt/cisco/install/bin"|<:DEBUG>
01/24/2012 18:47:44 platform_post_install_nochroot|Calling "cp /common/cisco/bin/ideployment.sh /partB/opt/cisco/install/bin"|<:DEBUG>
01/24/2012 18:47:44 platform_post_install_nochroot|Calling "cp /common/cisco/bin/awk /partB/opt/cisco/install/bin"|<:DEBUG>
01/24/2012 18:47:44 platform_post_install_nochroot|Calling "cp /common/cisco/bin/iproduct_impl /partB/opt/cisco/install/bin"|<:DEBUG>
01/24/2012 18:47:44 platform_post_install_nochroot|Calling "cp /common/cisco/bin/install_emailer /partB/opt/cisco/install/bin"|<:DEBUG>
01/24/2012 18:47:44 platform_post_install_nochroot|Calling "cp /common/cisco/bin/cpio /partB/opt/cisco/install/bin"|<:DEBUG>
01/24/2012 18:47:44 platform_post_install_nochroot|Calling "cp /common/cisco/bin/eject /partB/opt/cisco/install/bin"|<:DEBUG>
01/24/2012 18:47:44 platform_post_install_nochroot|Calling "cp /common/cisco/bin/component_install /partB/opt/cisco/install/bin"|<:DEBUG>
01/24/2012 18:47:44 platform_post_install_nochroot|Calling "cp /common/cisco/bin/sort /partB/opt/cisco/install/bin"|<:DEBUG>
01/24/2012 18:47:44 platform_post_install_nochroot|Calling "cp /common/cisco/bin/ilog.sh /partB/opt/cisco/install/bin"|<:DEBUG>
01/24/2012 18:47:44 platform_post_install_nochroot|Calling "cp /common/cisco/bin/xplatformconfig.sh /partB/opt/cisco/install/bin"|<:DEBUG>
01/24/2012 18:47:44 platform_post_install_nochroot|Calling "cp /common/cisco/bin/ks_post.sh /partB/opt/cisco/install/bin"|<:DEBUG>
01/24/2012 18:47:44 platform_post_install_nochroot|Calling "cp /common/cisco/bin/ihistory_impl /partB/opt/cisco/install/bin"|<:DEBUG>
01/24/2012 18:47:44 platform_post_install_nochroot|Calling "cp /common/cisco/bin/platform_post_install /partB/opt/cisco/install/bin"|<:DEBUG>
01/24/2012 18:47:44 platform_post_install_nochroot|Calling "cp /common/cisco/bin/pmNormalizeGeneric /partB/opt/cisco/install/bin"|<:DEBUG>
01/24/2012 18:47:44 platform_post_install_nochroot|Calling "cp /common/cisco/bin/lsusb /partB/opt/cisco/install/bin"|<:DEBUG>
01/24/2012 18:47:44 platform_post_install_nochroot|Calling "cp /common/cisco/bin/bc /partB/opt/cisco/install/bin"|<:DEBUG>
01/24/2012 18:47:44 platform_post_install_nochroot|Calling "cp /common/cisco/bin/iaccount_impl /partB/opt/cisco/install/bin"|<:DEBUG>
01/24/2012 18:47:44 platform_post_install_nochroot|Calling "cp /common/cisco/bin/emailer /partB/opt/cisco/install/bin"|<:DEBUG>
01/24/2012 18:47:44 platform_post_install_nochroot|Calling "cp /common/cisco/bin/xplatformconfig_impl /partB/opt/cisco/install/bin"|<:DEBUG>
01/24/2012 18:47:44 platform_post_install_nochroot|Calling "cp /common/cisco/bin/icluster_impl /partB/opt/cisco/install/bin"|<:DEBUG>
01/24/2012 18:47:44 platform_post_install_nochroot|Calling "cp /common/cisco/bin/icertificate_impl /partB/opt/cisco/install/bin"|<:DEBUG>
01/24/2012 18:47:44 platform_post_install_nochroot|Calling "cp /common/cisco/bin/xproduct.sh /partB/opt/cisco/install/bin"|<:DEBUG>
01/24/2012 18:47:44 platform_post_install_nochroot|Calling "cp /common/cisco/bin/install_os /partB/opt/cisco/install/bin"|<:DEBUG>
01/24/2012 18:47:44 platform_post_install_nochroot|Calling "cp /common/cisco/bin/ks_post_nochroot.sh /partB/opt/cisco/install/bin"|<:DEBUG>
01/24/2012 18:47:44 platform_post_install_nochroot|Calling "cp /common/cisco/bin/ihardware_impl /partB/opt/cisco/install/bin"|<:DEBUG>
01/24/2012 18:47:44 platform_post_install_nochroot|Calling "cp /common/cisco/bin/anaconda /partB/opt/cisco/install/bin"|<:DEBUG>
01/24/2012 18:47:44 platform_post_install_nochroot|Calling "cp /common/cisco/bin/icluster.sh /partB/opt/cisco/install/bin"|<:DEBUG>
01/24/2012 18:47:44 platform_post_install_nochroot|Calling "cp /common/cisco/bin/iproduct.sh /partB/opt/cisco/install/bin"|<:DEBUG>
01/24/2012 18:47:44 platform_post_install_nochroot|Calling "cp /common/cisco/bin/icertificate.sh /partB/opt/cisco/install/bin"|<:DEBUG>
01/24/2012 18:47:44 platform_post_install_nochroot|Calling "cp /common/cisco/bin/PlatformXmlUpg /partB/opt/cisco/install/bin"|<:DEBUG>
01/24/2012 18:47:44 platform_post_install_nochroot|Calling "cp /common/cisco/bin/icluster_data_sync_list /partB/opt/cisco/install/bin"|<:DEBUG>
01/24/2012 18:47:44 platform_post_install_nochroot|Calling "cp /common/cisco/bin/platform_post_install_nochroot /partB/opt/cisco/install/bin"|<:DEBUG>
01/24/2012 18:47:44 platform_post_install_nochroot|Calling "cp /common/cisco/bin/display_screen /partB/opt/cisco/install/bin"|<:DEBUG>
01/24/2012 18:47:44 platform_post_install_nochroot|Calling "cp /common/cisco/bin/ihardware.sh /partB/opt/cisco/install/bin"|<:DEBUG>
01/24/2012 18:47:44 platform_post_install_nochroot|Calling "cp /common/cisco/bin/lsscsi /partB/opt/cisco/install/bin"|<:DEBUG>
01/24/2012 18:47:44 platform_post_install_nochroot|Calling "cp /common/cisco/bin/dump_diagnostic_functions.sh /partB/opt/cisco/install/bin"|<:DEBUG>
01/24/2012 18:47:44 platform_post_install_nochroot|Calling "cp /common/cisco/bin/mcheck /partB/opt/cisco/install/bin"|<:DEBUG>
01/24/2012 18:47:44 platform_post_install_nochroot|Calling "cp /common/cisco/bin/ilog2.sh /partB/opt/cisco/install/bin"|<:DEBUG>
01/24/2012 18:47:44 platform_post_install_nochroot|Calling "cp /common/cisco/bin/xml /partB/opt/cisco/install/bin"|<:DEBUG>
01/24/2012 18:47:44 platform_post_install_nochroot|Copying platformConfig.xml file to /partB/usr/local/platform/conf|<:DEBUG>
01/24/2012 18:47:44 platform_post_install_nochroot|Copy /common/cisco/platformConfig.xml to /partB/usr/local/platform/conf|<:INFO>
01/24/2012 18:47:44 platform_post_install_nochroot|Calling "cp /common/cisco/platformConfig.xml /partB/usr/local/platform/conf"|<:DEBUG>
01/24/2012 18:47:44 platform_post_install_nochroot|Copying contents of /common/cisco/lib to /partB/opt/cisco/install|<:DEBUG>
01/24/2012 18:47:44 platform_post_install_nochroot|Copy /common/cisco/lib to /partB/opt/cisco/install|<:INFO>
01/24/2012 18:47:44 platform_post_install_nochroot|Calling "mkdir -p /partB/opt/cisco/install/lib"|<:DEBUG>
01/24/2012 18:47:44 platform_post_install_nochroot|Calling "cp /common/cisco/lib/cracklib_dict.pwi /partB/opt/cisco/install/lib"|<:DEBUG>
01/24/2012 18:47:44 platform_post_install_nochroot|Calling "cp /common/cisco/lib/cracklib_dict.pwd /partB/opt/cisco/install/lib"|<:DEBUG>
01/24/2012 18:47:44 platform_post_install_nochroot|Calling "cp /common/cisco/lib/cracklib_dict.hwm /partB/opt/cisco/install/lib"|<:DEBUG>
01/24/2012 18:47:44 platform_post_install_nochroot|Calling "cp /common/cisco/lib/libstdc++.so.6.0.3 /partB/opt/cisco/install/lib"|<:DEBUG>
01/24/2012 18:47:44 platform_post_install_nochroot|Calling "cp /common/cisco/lib/libstdc++.so.6 /partB/opt/cisco/install/lib"|<:DEBUG>
01/24/2012 18:47:44 platform_post_install_nochroot|Calling "cp /common/cisco/lib/libpcre.so.0 /partB/opt/cisco/install/lib"|<:DEBUG>
01/24/2012 18:47:44 platform_post_install_nochroot|Calling "cp /common/cisco/lib/libstdc++-libc6.2-2.so.3 /partB/opt/cisco/install/lib"|<:DEBUG>
01/24/2012 18:47:44 platform_post_install_nochroot|Calling "cp /common/cisco/lib/libstlport.so.5.1 /partB/opt/cisco/install/lib"|<:DEBUG>
01/24/2012 18:47:44 platform_post_install_nochroot|Calling "cp /common/cisco/lib/libstdc++.so.5 /partB/opt/cisco/install/lib"|<:DEBUG>
01/24/2012 18:47:44 platform_post_install_nochroot|Calling "cp /common/cisco/lib/libcrack.so.2.8.0 /partB/opt/cisco/install/lib"|<:DEBUG>
01/24/2012 18:47:44 platform_post_install_nochroot|Calling "cp /common/cisco/lib/libusb-0.1.so.4 /partB/opt/cisco/install/lib"|<:DEBUG>
01/24/2012 18:47:44 platform_post_install_nochroot|Calling "cp /common/cisco/lib/libxerces-c.so.27 /partB/opt/cisco/install/lib"|<:DEBUG>
01/24/2012 18:47:44 platform_post_install_nochroot|Calling "mkdir -p /partB/etc/opt/cisco"|<:DEBUG>
01/24/2012 18:47:44 platform_post_install_nochroot|Copying contents of /common/cisco/install to /partB/etc/opt/cisco|<:INFO>
01/24/2012 18:47:44 platform_post_install_nochroot|Copy /common/cisco/install to /partB/etc/opt/cisco|<:INFO>
01/24/2012 18:47:44 platform_post_install_nochroot|Calling "mkdir -p /partB/etc/opt/cisco/install"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/preflight-messages.properties /partB/etc/opt/cisco/install"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/install-confirm-content_L2.jsp /partB/etc/opt/cisco/install"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/dynamicConfig_L2.xml /partB/etc/opt/cisco/install"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/dynamic_H3.jsp /partB/etc/opt/cisco/install"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/install-confirm-content_H3.jsp /partB/etc/opt/cisco/install"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/install-confirm-content_RU.jsp /partB/etc/opt/cisco/install"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/dynamic_RU_UC.jsp /partB/etc/opt/cisco/install"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/Iaccount.jar /partB/etc/opt/cisco/install"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/Iproduct.jar /partB/etc/opt/cisco/install"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/Ihistory.jar /partB/etc/opt/cisco/install"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/dynamicConfig_RU.xml /partB/etc/opt/cisco/install"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/Ihardware.jar /partB/etc/opt/cisco/install"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "mkdir -p /partB/etc/opt/cisco/install/conf"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/conf/callmanager_product.conf /partB/etc/opt/cisco/install/conf"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/conf/connection_component.conf /partB/etc/opt/cisco/install/conf"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "mkdir -p /partB/etc/opt/cisco/install/conf/hssi_errors"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/conf/hssi_errors/7835I3_error_message /partB/etc/opt/cisco/install/conf/hssi_errors"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/conf/hssi_errors/7828I4_error_message /partB/etc/opt/cisco/install/conf/hssi_errors"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/conf/hssi_errors/7825I4_error_message /partB/etc/opt/cisco/install/conf/hssi_errors"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/conf/hssi_errors/7835H3_error_message /partB/etc/opt/cisco/install/conf/hssi_errors"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/conf/hssi_errors/7816I4_error_message /partB/etc/opt/cisco/install/conf/hssi_errors"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/conf/hssi_errors/7890C1_error_message /partB/etc/opt/cisco/install/conf/hssi_errors"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/conf/hssi_errors/7845I3_error_message /partB/etc/opt/cisco/install/conf/hssi_errors"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/conf/hssi_errors/7828H4_error_message /partB/etc/opt/cisco/install/conf/hssi_errors"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/conf/hssi_errors/7825I5_error_message /partB/etc/opt/cisco/install/conf/hssi_errors"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/conf/hssi_errors/7835H2_error_message /partB/etc/opt/cisco/install/conf/hssi_errors"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/conf/hssi_errors/7825H4_error_message /partB/etc/opt/cisco/install/conf/hssi_errors"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/conf/hssi_errors/7845H3PLUS_error_message /partB/etc/opt/cisco/install/conf/hssi_errors"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/conf/hssi_errors/7845H2_error_message /partB/etc/opt/cisco/install/conf/hssi_errors"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/conf/hssi_errors/7816I5_error_message /partB/etc/opt/cisco/install/conf/hssi_errors"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/conf/hssi_errors/7845I3PLUS_error_message /partB/etc/opt/cisco/install/conf/hssi_errors"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/conf/hssi_errors/7845H3_error_message /partB/etc/opt/cisco/install/conf/hssi_errors"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/conf/hssi_errors/7828I5_error_message /partB/etc/opt/cisco/install/conf/hssi_errors"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/conf/ucos_component.conf /partB/etc/opt/cisco/install/conf"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/conf/ucplatform_cluster_component.conf /partB/etc/opt/cisco/install/conf"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/conf/cuba_component.conf /partB/etc/opt/cisco/install/conf"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/conf/ucapp_common_component.conf /partB/etc/opt/cisco/install/conf"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/conf/ucplatform_component.conf /partB/etc/opt/cisco/install/conf"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/conf/serviceability_callmanager_component.conf /partB/etc/opt/cisco/install/conf"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/conf/ucplatform_nocluster_component.conf /partB/etc/opt/cisco/install/conf"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/conf/serviceability_core_component.conf /partB/etc/opt/cisco/install/conf"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/conf/database_component.conf /partB/etc/opt/cisco/install/conf"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/conf/cm_licensing_component.conf /partB/etc/opt/cisco/install/conf"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/conf/serviceability_common_component.conf /partB/etc/opt/cisco/install/conf"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/conf/callmanager_component.conf /partB/etc/opt/cisco/install/conf"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/conf/thirdparty_component.conf /partB/etc/opt/cisco/install/conf"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/conf/TRANS.TBL /partB/etc/opt/cisco/install/conf"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/dynamicConfig_RU_UC.xml /partB/etc/opt/cisco/install"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "mkdir -p /partB/etc/opt/cisco/install/bin"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/bin/timestamp_log_files /partB/etc/opt/cisco/install/bin"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/bin/tempDynamic.preflight /partB/etc/opt/cisco/install/bin"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/bin/install_emailer /partB/etc/opt/cisco/install/bin"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/bin/gen_hw_cache /partB/etc/opt/cisco/install/bin"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/bin/preflight_cancel /partB/etc/opt/cisco/install/bin"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/bin/emailer /partB/etc/opt/cisco/install/bin"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/bin/refresh_upgrade /partB/etc/opt/cisco/install/bin"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/bin/detach_from_parent /partB/etc/opt/cisco/install/bin"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/bin/install_func /partB/etc/opt/cisco/install/bin"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/bin/refresh_upgrade_shutdown /partB/etc/opt/cisco/install/bin"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/bin/preflight /partB/etc/opt/cisco/install/bin"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/bin/TRANS.TBL /partB/etc/opt/cisco/install/bin"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/dynamicConfig_H3_UC.xml /partB/etc/opt/cisco/install"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/Icluster.jar /partB/etc/opt/cisco/install"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/dynamic_RU.jsp /partB/etc/opt/cisco/install"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/upgrade-messages.properties /partB/etc/opt/cisco/install"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/os_rpm_list /partB/etc/opt/cisco/install"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/install-confirm-content_H3_UC.jsp /partB/etc/opt/cisco/install"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/filter_pattern_rules /partB/etc/opt/cisco/install"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "mkdir -p /partB/etc/opt/cisco/install/setup"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/setup/install_chkpatch.sh /partB/etc/opt/cisco/install/setup"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/setup/TEMPLATE.sh /partB/etc/opt/cisco/install/setup"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/setup/dell_init.sh /partB/etc/opt/cisco/install/setup"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/setup/install_master_rpm.sh /partB/etc/opt/cisco/install/setup"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/setup/relocate_java.sh /partB/etc/opt/cisco/install/setup"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/setup/configure_core_and_syslogd.sh /partB/etc/opt/cisco/install/setup"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/setup/fix_issue.sh /partB/etc/opt/cisco/install/setup"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/setup/prepare_log_area.sh /partB/etc/opt/cisco/install/setup"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/setup/setup_serial_console.sh /partB/etc/opt/cisco/install/setup"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/setup/update_iptables.sh /partB/etc/opt/cisco/install/setup"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/setup/product_info.sh /partB/etc/opt/cisco/install/setup"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/setup/update_rc_sysinit.sh /partB/etc/opt/cisco/install/setup"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/setup/setup_ntp_watchdog.sh /partB/etc/opt/cisco/install/setup"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/setup/utils.sh /partB/etc/opt/cisco/install/setup"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/setup/setup_java_api.sh /partB/etc/opt/cisco/install/setup"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/setup/update_tmpwatch.sh /partB/etc/opt/cisco/install/setup"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/setup/net-snmp_service.sh /partB/etc/opt/cisco/install/setup"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/setup/setup_kdump.sh /partB/etc/opt/cisco/install/setup"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/setup/setup_handle_modprobe_blacklist_file.sh /partB/etc/opt/cisco/install/setup"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/setup/initialize_logging.sh /partB/etc/opt/cisco/install/setup"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/setup/temp_workaround.sh /partB/etc/opt/cisco/install/setup"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/setup/populate_archive.sh /partB/etc/opt/cisco/install/setup"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/setup/update_install_conf_unrst.sh /partB/etc/opt/cisco/install/setup"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/setup/disable_services.sh /partB/etc/opt/cisco/install/setup"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/setup/disable_ntp_from_dhcp.sh /partB/etc/opt/cisco/install/setup"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/setup/setup_ntp.sh /partB/etc/opt/cisco/install/setup"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/setup/smartd_service.sh /partB/etc/opt/cisco/install/setup"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/setup/setup_root_access.sh /partB/etc/opt/cisco/install/setup"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/setup/configure_writecache.sh /partB/etc/opt/cisco/install/setup"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/setup/create_jdk_links.sh /partB/etc/opt/cisco/install/setup"|<:DEBUG>
01/24/2012 18:47:45 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/setup/check_root_cron_job.sh /partB/etc/opt/cisco/install/setup"|<:DEBUG>
01/24/2012 18:47:46 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/setup/update_etc_profile.sh /partB/etc/opt/cisco/install/setup"|<:DEBUG>
01/24/2012 18:47:46 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/setup/apply_tzupdater.sh /partB/etc/opt/cisco/install/setup"|<:DEBUG>
01/24/2012 18:47:46 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/setup/update_fstab.sh /partB/etc/opt/cisco/install/setup"|<:DEBUG>
01/24/2012 18:47:46 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/setup/install_platform_prefs.sh /partB/etc/opt/cisco/install/setup"|<:DEBUG>
01/24/2012 18:47:46 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/setup/swap_nic_if.sh /partB/etc/opt/cisco/install/setup"|<:DEBUG>
01/24/2012 18:47:46 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/setup/setup_cli_access.sh /partB/etc/opt/cisco/install/setup"|<:DEBUG>
01/24/2012 18:47:46 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/setup/create_old_style_config_files.sh /partB/etc/opt/cisco/install/setup"|<:DEBUG>
01/24/2012 18:47:46 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/setup/ipmi_service.sh /partB/etc/opt/cisco/install/setup"|<:DEBUG>
01/24/2012 18:47:46 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/setup/TRANS.TBL /partB/etc/opt/cisco/install/setup"|<:DEBUG>
01/24/2012 18:47:46 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/dynamic_L2.jsp /partB/etc/opt/cisco/install"|<:DEBUG>
01/24/2012 18:47:46 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/upgrade-messages.xml /partB/etc/opt/cisco/install"|<:DEBUG>
01/24/2012 18:47:46 platform_post_install_nochroot|Calling "mkdir -p /partB/etc/opt/cisco/install/lib"|<:DEBUG>
01/24/2012 18:47:46 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/lib/check_upgrade_space.sh /partB/etc/opt/cisco/install/lib"|<:DEBUG>
01/24/2012 18:47:46 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/lib/TRANS.TBL /partB/etc/opt/cisco/install/lib"|<:DEBUG>
01/24/2012 18:47:46 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/hw_rpm_map.txt /partB/etc/opt/cisco/install"|<:DEBUG>
01/24/2012 18:47:46 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/dynamicConfig_H3.xml /partB/etc/opt/cisco/install"|<:DEBUG>
01/24/2012 18:47:46 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/copfile_rules /partB/etc/opt/cisco/install"|<:DEBUG>
01/24/2012 18:47:46 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/dynamic_H3_UC.jsp /partB/etc/opt/cisco/install"|<:DEBUG>
01/24/2012 18:47:46 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/Ideployment.jar /partB/etc/opt/cisco/install"|<:DEBUG>
01/24/2012 18:47:46 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/Icertificate.jar /partB/etc/opt/cisco/install"|<:DEBUG>
01/24/2012 18:47:46 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/preflight.xml /partB/etc/opt/cisco/install"|<:DEBUG>
01/24/2012 18:47:46 platform_post_install_nochroot|Calling "cp -r /common/cisco/install/TRANS.TBL /partB/etc/opt/cisco/install"|<:DEBUG>
01/24/2012 18:47:46 platform_post_install_nochroot|Copying component scripts to /partB/opt/cisco/install|<:DEBUG>
01/24/2012 18:47:46 platform_post_install_nochroot|Calling "mkdir -p /partB/opt/cisco/install/callmanager/scripts"|<:DEBUG>
01/24/2012 18:47:46 platform_post_install_nochroot|Copy /mnt/source/Cisco/callmanager/scripts/* to /partB/opt/cisco/install/callmanager/scripts|<:INFO>
01/24/2012 18:47:46 platform_post_install_nochroot|Calling "cp /mnt/source/Cisco/callmanager/scripts/cm_bps_migration.sh /partB/opt/cisco/install/callmanager/scripts"|<:DEBUG>
01/24/2012 18:47:46 platform_post_install_nochroot|Calling "cp /mnt/source/Cisco/callmanager/scripts/cm_capf_post.sh /partB/opt/cisco/install/callmanager/scripts"|<:DEBUG>
01/24/2012 18:47:46 platform_post_install_nochroot|Calling "cp /mnt/source/Cisco/callmanager/scripts/cm_msa_post.sh /partB/opt/cisco/install/callmanager/scripts"|<:DEBUG>
01/24/2012 18:47:46 platform_post_install_nochroot|Calling "cp /mnt/source/Cisco/callmanager/scripts/cm_tftp_post.sh /partB/opt/cisco/install/callmanager/scripts"|<:DEBUG>
01/24/2012 18:47:46 platform_post_install_nochroot|Calling "cp /mnt/source/Cisco/callmanager/scripts/data.sql /partB/opt/cisco/install/callmanager/scripts"|<:DEBUG>
01/24/2012 18:47:46 platform_post_install_nochroot|Calling "cp /mnt/source/Cisco/callmanager/scripts/datatype.sql /partB/opt/cisco/install/callmanager/scripts"|<:DEBUG>
01/24/2012 18:47:46 platform_post_install_nochroot|Calling "cp /mnt/source/Cisco/callmanager/scripts/dialplan_files_migrate /partB/opt/cisco/install/callmanager/scripts"|<:DEBUG>
01/24/2012 18:47:46 platform_post_install_nochroot|Calling "cp /mnt/source/Cisco/callmanager/scripts/exportcardb.py /partB/opt/cisco/install/callmanager/scripts"|<:DEBUG>
01/24/2012 18:47:46 platform_post_install_nochroot|Calling "cp /mnt/source/Cisco/callmanager/scripts/header.sql /partB/opt/cisco/install/callmanager/scripts"|<:DEBUG>
01/24/2012 18:47:46 platform_post_install_nochroot|Calling "cp /mnt/source/Cisco/callmanager/scripts/importcardb.py /partB/opt/cisco/install/callmanager/scripts"|<:DEBUG>
01/24/2012 18:47:46 platform_post_install_nochroot|Calling "cp /mnt/source/Cisco/callmanager/scripts/TableNames.sql /partB/opt/cisco/install/callmanager/scripts"|<:DEBUG>
01/24/2012 18:47:46 platform_post_install_nochroot|Calling "cp /mnt/source/Cisco/callmanager/scripts/TRANS.TBL /partB/opt/cisco/install/callmanager/scripts"|<:DEBUG>
01/24/2012 18:47:46 platform_post_install_nochroot|Calling "mkdir -p /partB/opt/cisco/install/cm_licensing/scripts"|<:DEBUG>
01/24/2012 18:47:46 platform_post_install_nochroot|Copy /mnt/source/Cisco/cm_licensing/scripts/* to /partB/opt/cisco/install/cm_licensing/scripts|<:INFO>
01/24/2012 18:47:46 platform_post_install_nochroot|Calling "cp /mnt/source/Cisco/cm_licensing/scripts/cm_lic_post.sh /partB/opt/cisco/install/cm_licensing/scripts"|<:DEBUG>
01/24/2012 18:47:46 platform_post_install_nochroot|Calling "cp /mnt/source/Cisco/cm_licensing/scripts/TRANS.TBL /partB/opt/cisco/install/cm_licensing/scripts"|<:DEBUG>
01/24/2012 18:47:46 platform_post_install_nochroot|Calling "mkdir -p /partB/opt/cisco/install/connection/scripts"|<:DEBUG>
01/24/2012 18:47:46 platform_post_install_nochroot|Copy /mnt/source/Cisco/connection/scripts/* to /partB/opt/cisco/install/connection/scripts|<:INFO>
01/24/2012 18:47:46 platform_post_install_nochroot|Calling "cp /mnt/source/Cisco/connection/scripts/cuc-export /partB/opt/cisco/install/connection/scripts"|<:DEBUG>
01/24/2012 18:47:46 platform_post_install_nochroot|Calling "cp /mnt/source/Cisco/connection/scripts/cuc-export.py /partB/opt/cisco/install/connection/scripts"|<:DEBUG>
01/24/2012 18:47:46 platform_post_install_nochroot|Calling "cp /mnt/source/Cisco/connection/scripts/cuc-preinstall /partB/opt/cisco/install/connection/scripts"|<:DEBUG>
01/24/2012 18:47:46 platform_post_install_nochroot|Calling "cp /mnt/source/Cisco/connection/scripts/TRANS.TBL /partB/opt/cisco/install/connection/scripts"|<:DEBUG>
01/24/2012 18:47:46 platform_post_install_nochroot|Calling "mkdir -p /partB/opt/cisco/install/database/scripts"|<:DEBUG>
01/24/2012 18:47:46 platform_post_install_nochroot|Copy /mnt/source/Cisco/database/scripts/* to /partB/opt/cisco/install/database/scripts|<:INFO>
01/24/2012 18:47:46 platform_post_install_nochroot|Calling "cp /mnt/source/Cisco/database/scripts/exportcucm.py /partB/opt/cisco/install/database/scripts"|<:DEBUG>
01/24/2012 18:47:46 platform_post_install_nochroot|Calling "cp /mnt/source/Cisco/database/scripts/TRANS.TBL /partB/opt/cisco/install/database/scripts"|<:DEBUG>
01/24/2012 18:47:46 platform_post_install_nochroot|Calling "mkdir -p /partB/opt/cisco/install/serviceability_common/scripts"|<:DEBUG>
01/24/2012 18:47:46 platform_post_install_nochroot|Copy /mnt/source/Cisco/serviceability_common/scripts/* to /partB/opt/cisco/install/serviceability_common/scripts|<:INFO>
01/24/2012 18:47:46 platform_post_install_nochroot|Calling "cp /mnt/source/Cisco/serviceability_common/scripts/cm_cdp_migration.sh /partB/opt/cisco/install/serviceability_common/scripts"|<:DEBUG>
01/24/2012 18:47:46 platform_post_install_nochroot|Calling "cp /mnt/source/Cisco/serviceability_common/scripts/cm_syslog_migration.sh /partB/opt/cisco/install/serviceability_common/scripts"|<:DEBUG>
01/24/2012 18:47:46 platform_post_install_nochroot|Calling "cp /mnt/source/Cisco/serviceability_common/scripts/TRANS.TBL /partB/opt/cisco/install/serviceability_common/scripts"|<:DEBUG>
01/24/2012 18:47:46 platform_post_install_nochroot|Calling "mkdir -p /partB/opt/cisco/install/ucapp_common/scripts"|<:DEBUG>
01/24/2012 18:47:46 platform_post_install_nochroot|Copy /mnt/source/Cisco/ucapp_common/scripts/* to /partB/opt/cisco/install/ucapp_common/scripts|<:INFO>
01/24/2012 18:47:46 platform_post_install_nochroot|Calling "cp /mnt/source/Cisco/ucapp_common/scripts/ccmservice_migration.sh /partB/opt/cisco/install/ucapp_common/scripts"|<:DEBUG>
01/24/2012 18:47:46 platform_post_install_nochroot|Calling "cp /mnt/source/Cisco/ucapp_common/scripts/cm_reporter_migration.sh /partB/opt/cisco/install/ucapp_common/scripts"|<:DEBUG>
01/24/2012 18:47:46 platform_post_install_nochroot|Calling "cp /mnt/source/Cisco/ucapp_common/scripts/TRANS.TBL /partB/opt/cisco/install/ucapp_common/scripts"|<:DEBUG>
01/24/2012 18:47:46 platform_post_install_nochroot|Calling "mkdir -p /partB/opt/cisco/install/ucplatform_cluster/scripts"|<:DEBUG>
01/24/2012 18:47:46 platform_post_install_nochroot|Copy /mnt/source/Cisco/ucplatform_cluster/scripts/* to /partB/opt/cisco/install/ucplatform_cluster/scripts|<:INFO>
01/24/2012 18:47:46 platform_post_install_nochroot|Calling "cp /mnt/source/Cisco/ucplatform_cluster/scripts/platform_sso_migrate /partB/opt/cisco/install/ucplatform_cluster/scripts"|<:DEBUG>
01/24/2012 18:47:46 platform_post_install_nochroot|Calling "cp /mnt/source/Cisco/ucplatform_cluster/scripts/TRANS.TBL /partB/opt/cisco/install/ucplatform_cluster/scripts"|<:DEBUG>
01/24/2012 18:47:46 platform_post_install_nochroot|Copy /mnt/source/Cisco/ucplatform/scripts/* to /partB/opt/cisco/install/ucplatform/scripts|<:INFO>
01/24/2012 18:47:46 platform_post_install_nochroot|Calling "cp /mnt/source/Cisco/ucplatform/scripts/drf_migrate /partB/opt/cisco/install/ucplatform/scripts"|<:DEBUG>
01/24/2012 18:47:46 platform_post_install_nochroot|Calling "cp /mnt/source/Cisco/ucplatform/scripts/installed_options_migrate /partB/opt/cisco/install/ucplatform/scripts"|<:DEBUG>
01/24/2012 18:47:46 platform_post_install_nochroot|Calling "cp /mnt/source/Cisco/ucplatform/scripts/install_log_migrate /partB/opt/cisco/install/ucplatform/scripts"|<:DEBUG>
01/24/2012 18:47:46 platform_post_install_nochroot|Calling "cp /mnt/source/Cisco/ucplatform/scripts/migrate_cli_configuration /partB/opt/cisco/install/ucplatform/scripts"|<:DEBUG>
01/24/2012 18:47:46 platform_post_install_nochroot|Calling "cp /mnt/source/Cisco/ucplatform/scripts/network_files_migrate /partB/opt/cisco/install/ucplatform/scripts"|<:DEBUG>
01/24/2012 18:47:46 platform_post_install_nochroot|Calling "cp /mnt/source/Cisco/ucplatform/scripts/password_migrate /partB/opt/cisco/install/ucplatform/scripts"|<:DEBUG>
01/24/2012 18:47:46 platform_post_install_nochroot|Calling "cp /mnt/source/Cisco/ucplatform/scripts/platform_admin_acct_final /partB/opt/cisco/install/ucplatform/scripts"|<:DEBUG>
01/24/2012 18:47:47 platform_post_install_nochroot|Calling "cp /mnt/source/Cisco/ucplatform/scripts/platform_certs_migrate /partB/opt/cisco/install/ucplatform/scripts"|<:DEBUG>
01/24/2012 18:47:47 platform_post_install_nochroot|Calling "cp /mnt/source/Cisco/ucplatform/scripts/product_postinstall /partB/opt/cisco/install/ucplatform/scripts"|<:DEBUG>
01/24/2012 18:47:47 platform_post_install_nochroot|Calling "cp /mnt/source/Cisco/ucplatform/scripts/product_prepare /partB/opt/cisco/install/ucplatform/scripts"|<:DEBUG>
01/24/2012 18:47:47 platform_post_install_nochroot|Calling "cp /mnt/source/Cisco/ucplatform/scripts/security_final /partB/opt/cisco/install/ucplatform/scripts"|<:DEBUG>
01/24/2012 18:47:47 platform_post_install_nochroot|Calling "cp /mnt/source/Cisco/ucplatform/scripts/security_postinstall /partB/opt/cisco/install/ucplatform/scripts"|<:DEBUG>
01/24/2012 18:47:47 platform_post_install_nochroot|Calling "cp /mnt/source/Cisco/ucplatform/scripts/security_prepare /partB/opt/cisco/install/ucplatform/scripts"|<:DEBUG>
01/24/2012 18:47:47 platform_post_install_nochroot|Calling "cp /mnt/source/Cisco/ucplatform/scripts/servm_export /partB/opt/cisco/install/ucplatform/scripts"|<:DEBUG>
01/24/2012 18:47:47 platform_post_install_nochroot|Calling "cp /mnt/source/Cisco/ucplatform/scripts/ssh_keys_migrate /partB/opt/cisco/install/ucplatform/scripts"|<:DEBUG>
01/24/2012 18:47:47 platform_post_install_nochroot|Calling "cp /mnt/source/Cisco/ucplatform/scripts/tomcat_prepare /partB/opt/cisco/install/ucplatform/scripts"|<:DEBUG>
01/24/2012 18:47:47 platform_post_install_nochroot|Calling "cp /mnt/source/Cisco/ucplatform/scripts/TRANS.TBL /partB/opt/cisco/install/ucplatform/scripts"|<:DEBUG>
01/24/2012 18:47:47 platform_post_install_nochroot|Calling "mkdir -p -m755 /partB/usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 18:47:47 platform_post_install_nochroot|Creating old style config files|<:INFO>
01/24/2012 18:47:47 platform_post_install_nochroot|Setup APIs for Python support|<:INFO>
01/24/2012 18:47:47 platform_post_install_nochroot|Copy /common/cisco/python/iaccount.so to /partB/usr/lib/python2.4|<:INFO>
01/24/2012 18:47:47 platform_post_install_nochroot|Calling "cp /common/cisco/python/iaccount.so /partB/usr/lib/python2.4"|<:DEBUG>
01/24/2012 18:47:47 platform_post_install_nochroot|Copy /common/cisco/python/icertificate.so to /partB/usr/lib/python2.4|<:INFO>
01/24/2012 18:47:47 platform_post_install_nochroot|Calling "cp /common/cisco/python/icertificate.so /partB/usr/lib/python2.4"|<:DEBUG>
01/24/2012 18:47:47 platform_post_install_nochroot|Copy /common/cisco/python/icluster.so to /partB/usr/lib/python2.4|<:INFO>
01/24/2012 18:47:47 platform_post_install_nochroot|Calling "cp /common/cisco/python/icluster.so /partB/usr/lib/python2.4"|<:DEBUG>
01/24/2012 18:47:47 platform_post_install_nochroot|Copy /common/cisco/python/ihardware.so to /partB/usr/lib/python2.4|<:INFO>
01/24/2012 18:47:47 platform_post_install_nochroot|Calling "cp /common/cisco/python/ihardware.so /partB/usr/lib/python2.4"|<:DEBUG>
01/24/2012 18:47:47 platform_post_install_nochroot|Copy /common/cisco/python/ilog.so to /partB/usr/lib/python2.4|<:INFO>
01/24/2012 18:47:47 platform_post_install_nochroot|Calling "cp /common/cisco/python/ilog.so /partB/usr/lib/python2.4"|<:DEBUG>
01/24/2012 18:47:47 platform_post_install_nochroot|Copy /common/cisco/python/iproduct.so to /partB/usr/lib/python2.4|<:INFO>
01/24/2012 18:47:47 platform_post_install_nochroot|Calling "cp /common/cisco/python/iproduct.so /partB/usr/lib/python2.4"|<:DEBUG>
01/24/2012 18:47:47 platform_post_install_nochroot|Creation/Copy of libraries/directories RTMTFinish|<:NOTICE>
01/24/2012 18:47:47 platform_post_install_nochroot|platform_post_install_nochroot complete. Result: success|<:INFO>
01/24/2012 18:47:47 upgrade_manager.sh|Post-processing complete|<:INFO>
01/24/2012 18:47:47 upgrade_manager.sh|Perform post-processing chroot'd to /partB|<:INFO>
01/24/2012 18:47:47 upgrade_manager.sh|Calling chroot /partB /common/download/8.6.2.22900-9/Cisco/bin/platform_post_install src_dir=/mnt/source base_dir=/common/download/8.6.2.22900-9 mode=upgrade rpm_archive=/common/rpm-archive/8.6.2.22900-9|<:DEBUG>
01/24/2012 13:47:47 platform_post_install|Initialize product API|<:DEBUG>
01/24/2012 13:47:48 platform_post_install|Initialize hardware API|<:DEBUG>
01/24/2012 13:47:48 ServerApiManager|INITIALIZE: sam_legacy_mode_init=1|<:DEBUG>
01/24/2012 13:47:59 ServerApiManager|INITIALIZE: sam_hssi_mode_init=0|<:DEBUG>
01/24/2012 13:47:59 platform_post_install|Initialize APIs complete|<:INFO>
01/24/2012 13:47:59 platform_post_install|Initialize setup functions|<:INFO>
01/24/2012 13:47:59 platform_post_install|Calling "source /etc/opt/cisco/install/setup/apply_tzupdater.sh"|<:DEBUG>
01/24/2012 13:47:59 platform_post_install|Calling "source /etc/opt/cisco/install/setup/check_root_cron_job.sh"|<:DEBUG>
01/24/2012 13:47:59 platform_post_install|Calling "source /etc/opt/cisco/install/setup/configure_core_and_syslogd.sh"|<:DEBUG>
01/24/2012 13:47:59 platform_post_install|Calling "source /etc/opt/cisco/install/setup/configure_writecache.sh"|<:DEBUG>
01/24/2012 13:47:59 platform_post_install|Calling "source /etc/opt/cisco/install/setup/create_jdk_links.sh"|<:DEBUG>
01/24/2012 13:47:59 platform_post_install|Calling "source /etc/opt/cisco/install/setup/create_old_style_config_files.sh"|<:DEBUG>
01/24/2012 13:47:59 platform_post_install|Calling "source /etc/opt/cisco/install/setup/dell_init.sh"|<:DEBUG>
01/24/2012 13:47:59 platform_post_install|Calling "source /etc/opt/cisco/install/setup/disable_ntp_from_dhcp.sh"|<:DEBUG>
01/24/2012 13:47:59 platform_post_install|Calling "source /etc/opt/cisco/install/setup/disable_services.sh"|<:DEBUG>
01/24/2012 13:47:59 platform_post_install|Calling "source /etc/opt/cisco/install/setup/fix_issue.sh"|<:DEBUG>
01/24/2012 13:47:59 platform_post_install|Calling "source /etc/opt/cisco/install/setup/initialize_logging.sh"|<:DEBUG>
01/24/2012 13:47:59 platform_post_install|Calling "source /etc/opt/cisco/install/setup/install_chkpatch.sh"|<:DEBUG>
01/24/2012 13:47:59 platform_post_install|Calling "source /etc/opt/cisco/install/setup/install_master_rpm.sh"|<:DEBUG>
01/24/2012 13:47:59 platform_post_install|Calling "source /etc/opt/cisco/install/setup/install_platform_prefs.sh"|<:DEBUG>
01/24/2012 13:47:59 platform_post_install|Calling "source /etc/opt/cisco/install/setup/ipmi_service.sh"|<:DEBUG>
01/24/2012 13:47:59 platform_post_install|Calling "source /etc/opt/cisco/install/setup/net-snmp_service.sh"|<:DEBUG>
01/24/2012 13:47:59 platform_post_install|Calling "source /etc/opt/cisco/install/setup/populate_archive.sh"|<:DEBUG>
01/24/2012 13:47:59 platform_post_install|Calling "source /etc/opt/cisco/install/setup/prepare_log_area.sh"|<:DEBUG>
01/24/2012 13:47:59 platform_post_install|Calling "source /etc/opt/cisco/install/setup/product_info.sh"|<:DEBUG>
01/24/2012 13:47:59 platform_post_install|Calling "source /etc/opt/cisco/install/setup/relocate_java.sh"|<:DEBUG>
01/24/2012 13:47:59 platform_post_install|Calling "source /etc/opt/cisco/install/setup/setup_cli_access.sh"|<:DEBUG>
01/24/2012 13:47:59 platform_post_install|Calling "source /etc/opt/cisco/install/setup/setup_handle_modprobe_blacklist_file.sh"|<:DEBUG>
01/24/2012 13:47:59 platform_post_install|Calling "source /etc/opt/cisco/install/setup/setup_java_api.sh"|<:DEBUG>
01/24/2012 13:47:59 platform_post_install|Calling "source /etc/opt/cisco/install/setup/setup_kdump.sh"|<:DEBUG>
01/24/2012 13:47:59 platform_post_install|Calling "source /etc/opt/cisco/install/setup/setup_ntp.sh"|<:DEBUG>
01/24/2012 13:47:59 platform_post_install|Calling "source /etc/opt/cisco/install/setup/setup_ntp_watchdog.sh"|<:DEBUG>
01/24/2012 13:47:59 platform_post_install|Calling "source /etc/opt/cisco/install/setup/setup_root_access.sh"|<:DEBUG>
01/24/2012 13:47:59 platform_post_install|Calling "source /etc/opt/cisco/install/setup/setup_serial_console.sh"|<:DEBUG>
01/24/2012 13:47:59 platform_post_install|Calling "source /etc/opt/cisco/install/setup/smartd_service.sh"|<:DEBUG>
01/24/2012 13:47:59 platform_post_install|Calling "source /etc/opt/cisco/install/setup/swap_nic_if.sh"|<:DEBUG>
01/24/2012 13:47:59 platform_post_install|Calling "source /etc/opt/cisco/install/setup/TEMPLATE.sh"|<:DEBUG>
01/24/2012 13:47:59 platform_post_install|Calling "source /etc/opt/cisco/install/setup/temp_workaround.sh"|<:DEBUG>
01/24/2012 13:47:59 platform_post_install|Calling "source /etc/opt/cisco/install/setup/update_etc_profile.sh"|<:DEBUG>
01/24/2012 13:47:59 platform_post_install|Calling "source /etc/opt/cisco/install/setup/update_fstab.sh"|<:DEBUG>
01/24/2012 13:47:59 platform_post_install|Calling "source /etc/opt/cisco/install/setup/update_install_conf_unrst.sh"|<:DEBUG>
01/24/2012 13:47:59 platform_post_install|Calling "source /etc/opt/cisco/install/setup/update_iptables.sh"|<:DEBUG>
01/24/2012 13:47:59 platform_post_install|Calling "source /etc/opt/cisco/install/setup/update_rc_sysinit.sh"|<:DEBUG>
01/24/2012 13:47:59 platform_post_install|Calling "source /etc/opt/cisco/install/setup/update_tmpwatch.sh"|<:DEBUG>
01/24/2012 13:47:59 platform_post_install|Calling "source /etc/opt/cisco/install/setup/utils.sh"|<:DEBUG>
01/24/2012 13:47:59 platform_post_install|Initialize setup functions complete|<:INFO>
01/24/2012 13:47:59 platform_post_install|Parse argument src_dir=/mnt/source|<:DEBUG>
01/24/2012 13:47:59 platform_post_install|Parse argument base_dir=/common/download/8.6.2.22900-9|<:DEBUG>
01/24/2012 13:47:59 platform_post_install|Parse argument mode=upgrade|<:DEBUG>
01/24/2012 13:47:59 platform_post_install|Parse argument rpm_archive=/common/rpm-archive/8.6.2.22900-9|<:DEBUG>
01/24/2012 13:47:59 platform_post_install|Initialize global variables|<:INFO>
01/24/2012 13:47:59 platform_post_install|Initialize chroot variables|<:DEBUG>
01/24/2012 13:47:59 platform_post_install|Initialize RPM repository variables|<:DEBUG>
01/24/2012 13:47:59 platform_post_install|VERSION=8.6.2.22900-9|<:DEBUG>
01/24/2012 13:48:00 platform_post_install|HWMODEL=VMware, CPUSPEED=2500, VENDOR= VMware, Inc.|<:DEBUG>
01/24/2012 13:48:00 platform_post_install|Initialize global variables complete|<:INFO>
01/24/2012 13:48:00 platform_post_install|Start Platform Post-upgrade RTMTStart|<:NOTICE>
01/24/2012 13:48:00 platform_post_install|Platform Post-upgrade starting|<:INFO>
01/24/2012 13:48:00 platform_post_install|Post-install processing|<:INFO>
01/24/2012 13:48:00 platform_post_install|Setup APIs for Java support|<:INFO>
01/24/2012 13:48:00 platform_post_install|Calling "mkdir -p /usr/local/platform/jar"|<:DEBUG>
01/24/2012 13:48:00 platform_post_install|Calling "mkdir -p /usr/local/thirdparty/jakarta-tomcat/lib"|<:DEBUG>
01/24/2012 13:48:00 platform_post_install|Copy /mnt/source/Cisco/install/Iaccount.jar to /usr/local/platform/jar/Iaccount.jar|<:INFO>
01/24/2012 13:48:00 platform_post_install|Calling "cp -r /mnt/source/Cisco/install/Iaccount.jar /usr/local/platform/jar/Iaccount.jar"|<:DEBUG>
01/24/2012 13:48:00 platform_post_install|Calling "ln -s /usr/local/platform/jar/Iaccount.jar /usr/local/thirdparty/jakarta-tomcat/lib/Iaccount.jar"|<:DEBUG>
01/24/2012 13:48:00 platform_post_install|Copy /mnt/source/Cisco/install/Icertificate.jar to /usr/local/platform/jar/Icertificate.jar|<:INFO>
01/24/2012 13:48:00 platform_post_install|Calling "cp -r /mnt/source/Cisco/install/Icertificate.jar /usr/local/platform/jar/Icertificate.jar"|<:DEBUG>
01/24/2012 13:48:00 platform_post_install|Calling "ln -s /usr/local/platform/jar/Icertificate.jar /usr/local/thirdparty/jakarta-tomcat/lib/Icertificate.jar"|<:DEBUG>
01/24/2012 13:48:00 platform_post_install|Copy /mnt/source/Cisco/install/Icluster.jar to /usr/local/platform/jar/Icluster.jar|<:INFO>
01/24/2012 13:48:00 platform_post_install|Calling "cp -r /mnt/source/Cisco/install/Icluster.jar /usr/local/platform/jar/Icluster.jar"|<:DEBUG>
01/24/2012 13:48:00 platform_post_install|Calling "ln -s /usr/local/platform/jar/Icluster.jar /usr/local/thirdparty/jakarta-tomcat/lib/Icluster.jar"|<:DEBUG>
01/24/2012 13:48:00 platform_post_install|Copy /mnt/source/Cisco/install/Ideployment.jar to /usr/local/platform/jar/Ideployment.jar|<:INFO>
01/24/2012 13:48:00 platform_post_install|Calling "cp -r /mnt/source/Cisco/install/Ideployment.jar /usr/local/platform/jar/Ideployment.jar"|<:DEBUG>
01/24/2012 13:48:00 platform_post_install|Calling "ln -s /usr/local/platform/jar/Ideployment.jar /usr/local/thirdparty/jakarta-tomcat/lib/Ideployment.jar"|<:DEBUG>
01/24/2012 13:48:00 platform_post_install|Copy /mnt/source/Cisco/install/Ihardware.jar to /usr/local/platform/jar/Ihardware.jar|<:INFO>
01/24/2012 13:48:00 platform_post_install|Calling "cp -r /mnt/source/Cisco/install/Ihardware.jar /usr/local/platform/jar/Ihardware.jar"|<:DEBUG>
01/24/2012 13:48:00 platform_post_install|Calling "ln -s /usr/local/platform/jar/Ihardware.jar /usr/local/thirdparty/jakarta-tomcat/lib/Ihardware.jar"|<:DEBUG>
01/24/2012 13:48:00 platform_post_install|Copy /mnt/source/Cisco/install/Ihistory.jar to /usr/local/platform/jar/Ihistory.jar|<:INFO>
01/24/2012 13:48:00 platform_post_install|Calling "cp -r /mnt/source/Cisco/install/Ihistory.jar /usr/local/platform/jar/Ihistory.jar"|<:DEBUG>
01/24/2012 13:48:00 platform_post_install|Calling "ln -s /usr/local/platform/jar/Ihistory.jar /usr/local/thirdparty/jakarta-tomcat/lib/Ihistory.jar"|<:DEBUG>
01/24/2012 13:48:00 platform_post_install|Copy /mnt/source/Cisco/install/Iproduct.jar to /usr/local/platform/jar/Iproduct.jar|<:INFO>
01/24/2012 13:48:00 platform_post_install|Calling "cp -r /mnt/source/Cisco/install/Iproduct.jar /usr/local/platform/jar/Iproduct.jar"|<:DEBUG>
01/24/2012 13:48:00 platform_post_install|Calling "ln -s /usr/local/platform/jar/Iproduct.jar /usr/local/thirdparty/jakarta-tomcat/lib/Iproduct.jar"|<:DEBUG>
01/24/2012 13:48:00 platform_post_install|/etc/fstab update completed|<:INFO>
01/24/2012 13:48:00 platform_post_install|update_tmpwatch for /etc/cron.daily/tmpwatch completed|<:INFO>
01/24/2012 13:48:00 platform_post_install|Setting up soft links for the log directories|<:INFO>
01/24/2012 13:48:00 platform_post_install|Creating /var/log/install link|<:DEBUG>
01/24/2012 13:48:00 platform_post_install|Calling "ln -s /common/log/install /var/log/install"|<:DEBUG>
01/24/2012 13:48:00 platform_post_install|Creating /var/log/active and /var/log/inactive links|<:DEBUG>
01/24/2012 13:48:00 platform_post_install|Calling "ln -s /common/log/taos-log-b /var/log/active"|<:DEBUG>
01/24/2012 13:48:00 platform_post_install|Calling "ln -s /common/log/taos-log-a /var/log/inactive"|<:DEBUG>
01/24/2012 13:48:00 platform_post_install|Mount pts device|<:INFO>
01/24/2012 13:48:00 platform_post_install|Calling "mkdir -p /dev/pts"|<:DEBUG>
01/24/2012 13:48:00 platform_post_install|Migrate password information|<:INFO>
01/24/2012 13:48:00 platform_post_install|Copy /partB/etc/shadow to /etc/shadow|<:INFO>
01/24/2012 13:48:00 platform_post_install|Calling "cp /partB/etc/shadow /etc/shadow"|<:DEBUG>
01/24/2012 13:48:00 platform_post_install|Copy /partB/etc/gshadow to /etc/gshadow|<:INFO>
01/24/2012 13:48:00 platform_post_install|Calling "cp /partB/etc/gshadow /etc/gshadow"|<:DEBUG>
01/24/2012 13:48:00 platform_post_install|Copy /partB/etc/pam.d/system-auth-ac to /etc/pam.d/system-auth-ac|<:INFO>
01/24/2012 13:48:00 platform_post_install|Calling "cp /partB/etc/pam.d/system-auth-ac /etc/pam.d/system-auth-ac"|<:DEBUG>
01/24/2012 13:48:00 platform_post_install|Calling "pwconv"|<:DEBUG>
01/24/2012 13:48:00 platform_post_install|Disabling root access|<:INFO>
01/24/2012 13:48:00 platform_post_install|Copying over progress meter|<:INFO>
01/24/2012 13:48:00 platform_post_install|Copy /mnt/source/Cisco/base_scripts/progmeter to /opt/cisco/install/bin|<:INFO>
01/24/2012 13:48:00 platform_post_install|Calling "cp -f /mnt/source/Cisco/base_scripts/progmeter /opt/cisco/install/bin"|<:DEBUG>
01/24/2012 13:48:00 platform_post_install|Copy /mnt/source/Cisco/base_scripts/pmNormalizeGeneric to /opt/cisco/install/bin|<:INFO>
01/24/2012 13:48:00 platform_post_install|Calling "cp -f /mnt/source/Cisco/base_scripts/pmNormalizeGeneric /opt/cisco/install/bin"|<:DEBUG>
01/24/2012 13:48:00 platform_post_install|Copy all scripts to the inactive partition|<:INFO>
01/24/2012 13:48:00 ServerApiManager|SRCVENDORDIR called|<:DEBUG>
01/24/2012 13:48:00 ServerApiManager|SRCVENDORDIR=/mnt/source/Cisco/hssi|<:DEBUG>
01/24/2012 13:48:00 ServerApiManager|DESTVENDORDIR called|<:DEBUG>
01/24/2012 13:48:00 ServerApiManager|DESTVENDORDIR = /usr/local/bin/hssi|<:DEBUG>
01/24/2012 13:48:00 platform_post_install|src_vendor_dir=/mnt/source/Cisco/hssi dst_vendor_dir=/usr/local/bin/hssi|<:DEBUG>
01/24/2012 13:48:00 platform_post_install|Calling "mkdir -p /usr/local/bin"|<:DEBUG>
01/24/2012 13:48:00 platform_post_install|Calling "mkdir -p /root"|<:DEBUG>
01/24/2012 13:48:00 platform_post_install|Copy /mnt/source/Cisco/base_scripts to /common/rpm-archive/8.6.2.22900-9|<:INFO>
01/24/2012 13:48:00 platform_post_install|Calling "mkdir -p /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/adminAccountsWrap.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/align.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/AppInstall /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/appmanager.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/auditd.conf.source /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/auditd_func /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/audit.rules.source /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/authenticateFile /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/callmanager_mid_install.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/cancel_download.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/cancel_upgrade.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/ccm-trace-spacers.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/check_comp.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/check_file_fragmentation.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/check_process.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/check_size.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/chkpatch /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/cleanup_misc.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/copfile_syslog.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/copy_and_authenticate.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/coresident_switch.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/cpulimit_script.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/create_ntp_watchdog_cron_job.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/csa.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/detach_from_parent /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/display_screen /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/dscp-markings /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/dump_diagnostic_functions.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/dump_diagnostic_information.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/encryptCCMPin.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/encryptCCMPassword.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/env.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/exclude_file /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/filefrag /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/file_list.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/file_test.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/firewall.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/forcedatasyncsub.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/ftp_list.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/ftp_load.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/ftp_sftp_errval /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/gen_checksum_file /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/get_active_version.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/get_ccm_version.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/get_cuc_version.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/get_inactive_version.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/get_parent_procs_IDs.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/get_primary_interface_name.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/get-reg-value.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/get_timezone_list.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/get_user_data /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/grub_swap_impl.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/grub_add.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/grub_del.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/grub_swap.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/hardware_check.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/hosts.allow.source /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/hosts.deny.source /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/hosts_mgr.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/hwcheck /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/hw_based_install.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/hw_functions.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/hw_settings.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/hw_validation /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/iaccount_impl /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/iaccount.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/iaccount.so /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/IBMjtzu.zip /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/icertificate_impl /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/icertificate.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/icertificate.so /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/icluster_data_sync_list /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/icluster_impl /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/icluster.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/icluster.so /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/ideployment.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/iftp /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/ihardware.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/ihardware_impl /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/ihardware_legacy.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/ihardware.so /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/ihistory_impl /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/ihistory.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/ilog.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/ilog.so /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/ilog2.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/ilog_impl /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/import_config.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/init_net_snmpd_conf.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/install_notification_registration.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/INSTALLATION_FAILED /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/InstallWizard /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/install_rpm.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/iowait_monitor /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/iowait_monitor.conf /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/io_monitor_controller.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/ip6tables /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/ipp2ipt /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/ipprefs /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/ipprefs_bulk.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/iproduct_impl /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/iproduct.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/iproduct.so /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/iptables /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/isClusterNodeValid.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:01 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/isftp /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/isHardwareParameterOutOfThreshold /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/itar /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/izip /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/joinxml.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/kDump.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/kDumpServer.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/kdump_vmcores.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/kernel_tunables.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/legacy_hw_settings.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/LicenseMac.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/linux_sw_raid_setup.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/list_cluster.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/locale_install.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/local_list.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/local_load.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/logrotate_wrapper /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/mfginstall.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/netDump.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/networkDiagnostic.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/networkFaultTolerance.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/nic_reverse /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/ntpRunningStatus.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/ntpUtilities.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/ntp_check_sub_configuration.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/ntp_check_stratum.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/ntp_check_servers_reachability.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/ntp_check_drift.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/ntp_one_shot.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/ntp_reachability.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/ntp_start.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/ntp_stop.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/ntp_validate_servers.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/ntp_verify_stratum.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/parse_upgrade_log /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/platform_blockssh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/pmNormalizeFtp /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/pmNormalizeGeneric /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/post_rpm_upgrade.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/prepare_tape.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/primNodeVerify.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/process_monitor.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/procNodeVerify.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/prodInterface.xml /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/product_blockssh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/product_sudoers /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/product_profile /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/profile /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/progmeter /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/rclocalmgr.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/rcsysinit.source /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/reboot.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/record_result /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/regenerate_all_certs.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/reggetval /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/regparse /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/removeCliAccess.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/removeRootAccess.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/restorecon_call.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/restore_ethernet_interface.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/rm_rpm_archive.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/rtmt_logger.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/runsubsql.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/sam_hw_settings.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/sd_auto_mirror.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/sd_cancelInstall.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/sd_dnssetup /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/sd_domainname /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/sd_gethostbyname /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/sd_hostname /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/sd_hostsetup /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/sd_hostupdate /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/sd_hwdetect /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/sd_ifconfig /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/sd_installprefs /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/sd_iptables /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/sd_killInstall.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/sd_killPartitionB_PIDs.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/sd_language /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/sd_ntp /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/sd_ntpdate /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/sd_ntpkey /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/sd_prefs /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/sd_raidconfig /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/sd_set_clock.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/sd_zoneinfo /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/server_api_manager.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/server_specific_install.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/set_dev_permissions /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/sftp_connect_wrapper.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/sftp_get_file.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/sftp_list.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/sftp_load.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/show_ipv6_settings.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/show_no_login_console.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/SIGNED_FILTER /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/size_update.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/skip_mediacheck /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/smtp_test /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/snmpHWInfo.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/snmpUpgrade.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/spin.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/ssh_keygen.exp /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/ssh_server_details.exp /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/ssh_server.exp /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/stages /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/sysctlconf.source /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/systemcmd.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/terminal_io /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/tftp_upload_security.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/TRANS.TBL /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/tzupdater.jar /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/upgrade_install.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/upgrade_validate_file.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/upgrade_get_file.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/upgrade_manager.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/upgradeMonitor.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/upgrade_monitor /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/upgrade_platform_certs.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/usb_key_detect /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/validate_install.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/validateDHCP.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/validate_ipv6_address.py /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/validateNetworking.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/verifyNetwork /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/verify_rpm_checksum.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/verify_web_connection.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/xmlfoo /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:02 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/xml_writer.sh /common/rpm-archive/8.6.2.22900-9/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Copy /mnt/source/Cisco/base_scripts to /usr/local/bin|<:INFO>
01/24/2012 13:48:03 platform_post_install|Calling "mkdir -p /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/adminAccountsWrap.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/align.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/AppInstall /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/appmanager.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/auditd.conf.source /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/auditd_func /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/audit.rules.source /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/authenticateFile /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/callmanager_mid_install.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/cancel_download.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/cancel_upgrade.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/ccm-trace-spacers.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/check_comp.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/check_file_fragmentation.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/check_process.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/check_size.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/chkpatch /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/cleanup_misc.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/copfile_syslog.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/copy_and_authenticate.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/coresident_switch.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/cpulimit_script.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/create_ntp_watchdog_cron_job.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/csa.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/detach_from_parent /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/display_screen /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/dscp-markings /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/dump_diagnostic_functions.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/dump_diagnostic_information.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/encryptCCMPin.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/encryptCCMPassword.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/env.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/exclude_file /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/filefrag /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/file_list.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/file_test.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/firewall.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/forcedatasyncsub.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/format_partition.py /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/ftp_list.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/ftp_load.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/ftp_sftp_errval /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/gen_checksum_file /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/get_active_version.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/get_ccm_version.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/get_cuc_version.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/get_inactive_version.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/get_parent_procs_IDs.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/get_primary_interface_name.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/get-reg-value.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/get_timezone_list.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/get_user_data /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/grub_swap_impl.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/grub_add.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/grub_del.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/grub_swap.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/hardware_check.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/hosts.allow.source /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/hosts.deny.source /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/hosts_mgr.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/hwcheck /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/hw_based_install.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/hw_functions.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/hw_settings.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/hw_validation /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/iaccount_impl /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/iaccount.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/iaccount.so /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/IBMjtzu.zip /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/icertificate_impl /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/icertificate.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/icertificate.so /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/icluster_data_sync_list /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/icluster_impl /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/icluster.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/icluster.so /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/ideployment.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/iftp /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/ihardware.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/ihardware_impl /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/ihardware_legacy.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/ihardware.so /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/ihistory_impl /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/ihistory.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/ilog.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/ilog.so /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/ilog2.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/ilog_impl /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/import_config.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/init_net_snmpd_conf.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/install_notification_registration.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/INSTALLATION_FAILED /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/InstallWizard /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/install_rpm.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/iowait_monitor /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/iowait_monitor.conf /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/io_monitor_controller.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/ip6tables /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/ipp2ipt /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/ipprefs /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/ipprefs_bulk.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/iproduct_impl /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:03 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/iproduct.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/iproduct.so /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/iptables /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/isClusterNodeValid.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/isftp /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/isHardwareParameterOutOfThreshold /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/itar /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/izip /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/joinxml.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/kDump.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/kDumpServer.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/kdump_vmcores.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/kernel_tunables.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/legacy_hw_settings.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/LicenseMac.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/linux_sw_raid_setup.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/list_cluster.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/locale_install.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/local_list.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/local_load.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/logrotate_wrapper /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/mfginstall.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/netDump.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/networkDiagnostic.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/networkFaultTolerance.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/nic_reverse /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/ntpRunningStatus.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/ntpUtilities.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/ntp_check_sub_configuration.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/ntp_check_stratum.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/ntp_check_servers_reachability.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/ntp_check_drift.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/ntp_one_shot.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/ntp_reachability.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/ntp_start.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/ntp_stop.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/ntp_validate_servers.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/ntp_verify_stratum.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/parse_upgrade_log /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/platform_blockssh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/pmNormalizeFtp /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/pmNormalizeGeneric /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/post_rpm_upgrade.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/prepare_tape.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/primNodeVerify.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/process_monitor.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/procNodeVerify.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/prodInterface.xml /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/product_blockssh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/product_sudoers /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/product_profile /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/profile /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/progmeter /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/rclocalmgr.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/rcsysinit.source /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/reboot.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/record_result /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/regenerate_all_certs.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/reggetval /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/regparse /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/removeCliAccess.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/removeRootAccess.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/restorecon_call.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/restore_ethernet_interface.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/rm_rpm_archive.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/rtmt_logger.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/runsubsql.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/sam_hw_settings.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/sd_auto_mirror.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/sd_cancelInstall.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/sd_dnssetup /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/sd_domainname /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/sd_gethostbyname /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/sd_hostname /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/sd_hostsetup /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/sd_hostupdate /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/sd_hwdetect /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/sd_ifconfig /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/sd_installprefs /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/sd_iptables /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/sd_killInstall.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/sd_killPartitionB_PIDs.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/sd_language /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/sd_ntp /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/sd_ntpdate /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/sd_ntpkey /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/sd_prefs /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/sd_raidconfig /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/sd_set_clock.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/sd_zoneinfo /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/server_api_manager.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/server_specific_install.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/set_dev_permissions /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/sftp_connect_wrapper.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/sftp_get_file.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/sftp_list.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/sftp_load.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/show_ipv6_settings.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/show_no_login_console.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/SIGNED_FILTER /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/size_update.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/skip_mediacheck /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/smtp_test /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:04 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/snmpHWInfo.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:05 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/snmpUpgrade.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:05 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/spin.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:05 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/ssh_keygen.exp /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:05 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/ssh_server_details.exp /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:05 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/ssh_server.exp /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:05 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/stages /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:05 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/sysctlconf.source /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:05 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/systemcmd.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:05 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/terminal_io /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:05 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/tftp_upload_security.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:05 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/TRANS.TBL /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:05 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/tzupdater.jar /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:05 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/upgrade_install.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:05 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/upgrade_validate_file.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:05 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/upgrade_get_file.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:05 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/upgrade_manager.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:05 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/upgradeMonitor.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:05 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/upgrade_monitor /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:05 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/upgrade_platform_certs.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:05 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/usb_key_detect /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:05 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/validate_install.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:05 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/validateDHCP.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:05 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/validate_ipv6_address.py /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:05 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/validateNetworking.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:05 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/verifyNetwork /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:05 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/verify_rpm_checksum.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:05 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/verify_web_connection.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:05 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/xmlfoo /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:05 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_scripts/xml_writer.sh /usr/local/bin/base_scripts"|<:DEBUG>
01/24/2012 13:48:05 platform_post_install|Copy /mnt/source/Cisco/base_bin to /usr/local/bin|<:INFO>
01/24/2012 13:48:05 platform_post_install|Calling "mkdir -p /usr/local/bin/base_bin"|<:DEBUG>
01/24/2012 13:48:05 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_bin/PlatformXmlUpg /usr/local/bin/base_bin"|<:DEBUG>
01/24/2012 13:48:05 platform_post_install|Calling "cp -r /mnt/source/Cisco/base_bin/TRANS.TBL /usr/local/bin/base_bin"|<:DEBUG>
01/24/2012 13:48:05 platform_post_install|Calling "mkdir -p /usr/local/bin/hssi/shared/bin"|<:DEBUG>
01/24/2012 13:48:05 platform_post_install|Copy /mnt/source/Cisco/hssi/shared/bin/get_pid.sh to /usr/local/bin/hssi/shared/bin|<:INFO>
01/24/2012 13:48:05 platform_post_install|Calling "cp -rd /mnt/source/Cisco/hssi/shared/bin/get_pid.sh /usr/local/bin/hssi/shared/bin"|<:DEBUG>
01/24/2012 13:48:05 platform_post_install|Copy /mnt/source/Cisco/hssi/shared/bin/hssi_api.sh to /usr/local/bin/hssi/shared/bin|<:INFO>
01/24/2012 13:48:05 platform_post_install|Calling "cp -rd /mnt/source/Cisco/hssi/shared/bin/hssi_api.sh /usr/local/bin/hssi/shared/bin"|<:DEBUG>
01/24/2012 13:48:05 platform_post_install|Copy /mnt/source/Cisco/hssi/shared/bin/hssi_defines.sh to /usr/local/bin/hssi/shared/bin|<:INFO>
01/24/2012 13:48:05 platform_post_install|Calling "cp -rd /mnt/source/Cisco/hssi/shared/bin/hssi_defines.sh /usr/local/bin/hssi/shared/bin"|<:DEBUG>
01/24/2012 13:48:06 platform_post_install|Copy /mnt/source/Cisco/hssi/shared/bin/hssi_hcf_defines.sh to /usr/local/bin/hssi/shared/bin|<:INFO>
01/24/2012 13:48:06 platform_post_install|Calling "cp -rd /mnt/source/Cisco/hssi/shared/bin/hssi_hcf_defines.sh /usr/local/bin/hssi/shared/bin"|<:DEBUG>
01/24/2012 13:48:06 platform_post_install|Copy /mnt/source/Cisco/hssi/shared/bin/hssi_server_defines.sh to /usr/local/bin/hssi/shared/bin|<:INFO>
01/24/2012 13:48:06 platform_post_install|Calling "cp -rd /mnt/source/Cisco/hssi/shared/bin/hssi_server_defines.sh /usr/local/bin/hssi/shared/bin"|<:DEBUG>
01/24/2012 13:48:06 platform_post_install|Copy /mnt/source/Cisco/hssi/shared/bin/hssi_warn.sh to /usr/local/bin/hssi/shared/bin|<:INFO>
01/24/2012 13:48:06 platform_post_install|Calling "cp -rd /mnt/source/Cisco/hssi/shared/bin/hssi_warn.sh /usr/local/bin/hssi/shared/bin"|<:DEBUG>
01/24/2012 13:48:06 platform_post_install|Copy /mnt/source/Cisco/hssi/shared/bin/README.TXT to /usr/local/bin/hssi/shared/bin|<:INFO>
01/24/2012 13:48:06 platform_post_install|Calling "cp -rd /mnt/source/Cisco/hssi/shared/bin/README.TXT /usr/local/bin/hssi/shared/bin"|<:DEBUG>
01/24/2012 13:48:06 platform_post_install|Copy /mnt/source/Cisco/hssi/shared/bin/shared_implementation.sh to /usr/local/bin/hssi/shared/bin|<:INFO>
01/24/2012 13:48:06 platform_post_install|Calling "cp -rd /mnt/source/Cisco/hssi/shared/bin/shared_implementation.sh /usr/local/bin/hssi/shared/bin"|<:DEBUG>
01/24/2012 13:48:06 platform_post_install|Calling "mkdir -p /usr/local/bin/hssi/shared/hcf"|<:DEBUG>
01/24/2012 13:48:06 platform_post_install|Copy /mnt/source/Cisco/hssi/shared/hcf/README.TXT to /usr/local/bin/hssi/shared/hcf|<:INFO>
01/24/2012 13:48:06 platform_post_install|Calling "cp -rd /mnt/source/Cisco/hssi/shared/hcf/README.TXT /usr/local/bin/hssi/shared/hcf"|<:DEBUG>
01/24/2012 13:48:06 platform_post_install|Copy /mnt/source/Cisco/hssi/shared/README.TXT to /usr/local/bin/hssi/shared|<:INFO>
01/24/2012 13:48:06 platform_post_install|Calling "cp -rd /mnt/source/Cisco/hssi/shared/README.TXT /usr/local/bin/hssi/shared"|<:DEBUG>
01/24/2012 13:48:06 platform_post_install|Calling "mkdir -p /usr/local/bin/hssi/server_implementation/VMWARE/supported/shared/bin"|<:DEBUG>
01/24/2012 13:48:06 platform_post_install|Copy /mnt/source/Cisco/hssi/server_implementation/VMWARE/supported/shared/bin/api_implementation.sh to /usr/local/bin/hssi/server_implementation/VMWARE/supported/shared/bin|<:INFO>
01/24/2012 13:48:06 platform_post_install|Calling "cp -rd /mnt/source/Cisco/hssi/server_implementation/VMWARE/supported/shared/bin/api_implementation.sh /usr/local/bin/hssi/server_implementation/VMWARE/supported/shared/bin"|<:DEBUG>
01/24/2012 13:48:06 platform_post_install|Copy /mnt/source/Cisco/hssi/server_implementation/VMWARE/supported/shared/bin/README.TXT to /usr/local/bin/hssi/server_implementation/VMWARE/supported/shared/bin|<:INFO>
01/24/2012 13:48:06 platform_post_install|Calling "cp -rd /mnt/source/Cisco/hssi/server_implementation/VMWARE/supported/shared/bin/README.TXT /usr/local/bin/hssi/server_implementation/VMWARE/supported/shared/bin"|<:DEBUG>
01/24/2012 13:48:06 platform_post_install|Copy /mnt/source/Cisco/hssi/server_implementation/VMWARE/supported/shared/bin/supported.data to /usr/local/bin/hssi/server_implementation/VMWARE/supported/shared/bin|<:INFO>
01/24/2012 13:48:06 platform_post_install|Calling "cp -rd /mnt/source/Cisco/hssi/server_implementation/VMWARE/supported/shared/bin/supported.data /usr/local/bin/hssi/server_implementation/VMWARE/supported/shared/bin"|<:DEBUG>
01/24/2012 13:48:06 platform_post_install|Copy /mnt/source/Cisco/hssi/server_implementation/VMWARE/supported/shared/README.TXT to /usr/local/bin/hssi/server_implementation/VMWARE/supported/shared|<:INFO>
01/24/2012 13:48:06 platform_post_install|Calling "cp -rd /mnt/source/Cisco/hssi/server_implementation/VMWARE/supported/shared/README.TXT /usr/local/bin/hssi/server_implementation/VMWARE/supported/shared"|<:DEBUG>
01/24/2012 13:48:06 platform_post_install|Calling "mkdir -p /usr/local/bin/hssi/server_implementation/VMWARE/shared/bin"|<:DEBUG>
01/24/2012 13:48:06 platform_post_install|Copy /mnt/source/Cisco/hssi/server_implementation/VMWARE/shared/bin/install_pool.meta to /usr/local/bin/hssi/server_implementation/VMWARE/shared/bin|<:INFO>
01/24/2012 13:48:06 platform_post_install|Calling "cp -rd /mnt/source/Cisco/hssi/server_implementation/VMWARE/shared/bin/install_pool.meta /usr/local/bin/hssi/server_implementation/VMWARE/shared/bin"|<:DEBUG>
01/24/2012 13:48:06 platform_post_install|Copy /mnt/source/Cisco/hssi/server_implementation/VMWARE/shared/bin/shared_implementation.sh to /usr/local/bin/hssi/server_implementation/VMWARE/shared/bin|<:INFO>
01/24/2012 13:48:06 platform_post_install|Calling "cp -rd /mnt/source/Cisco/hssi/server_implementation/VMWARE/shared/bin/shared_implementation.sh /usr/local/bin/hssi/server_implementation/VMWARE/shared/bin"|<:DEBUG>
01/24/2012 13:48:06 platform_post_install|Copy /mnt/source/Cisco/hssi/server_implementation/VMWARE/shared/bin/VMWARE.data to /usr/local/bin/hssi/server_implementation/VMWARE/shared/bin|<:INFO>
01/24/2012 13:48:06 platform_post_install|Calling "cp -rd /mnt/source/Cisco/hssi/server_implementation/VMWARE/shared/bin/VMWARE.data /usr/local/bin/hssi/server_implementation/VMWARE/shared/bin"|<:DEBUG>
01/24/2012 13:48:06 platform_post_install|Calling "mkdir -p /usr/local/bin/hssi/server_implementation/VMWARE/shared/hcf"|<:DEBUG>
01/24/2012 13:48:06 platform_post_install|Copy /mnt/source/Cisco/hssi/server_implementation/VMWARE/shared/hcf/VMwareTools-4.0.0-208167.tar.gz to /usr/local/bin/hssi/server_implementation/VMWARE/shared/hcf|<:INFO>
01/24/2012 13:48:06 platform_post_install|Calling "cp -rd /mnt/source/Cisco/hssi/server_implementation/VMWARE/shared/hcf/VMwareTools-4.0.0-208167.tar.gz /usr/local/bin/hssi/server_implementation/VMWARE/shared/hcf"|<:DEBUG>
01/24/2012 13:48:06 platform_post_install|Calling "mkdir -p /usr/local/bin/hssi/server_implementation/shared/bin"|<:DEBUG>
01/24/2012 13:48:06 platform_post_install|Copy /mnt/source/Cisco/hssi/server_implementation/shared/bin/get_internal_USBkey.sh to /usr/local/bin/hssi/server_implementation/shared/bin|<:INFO>
01/24/2012 13:48:06 platform_post_install|Calling "cp -rd /mnt/source/Cisco/hssi/server_implementation/shared/bin/get_internal_USBkey.sh /usr/local/bin/hssi/server_implementation/shared/bin"|<:DEBUG>
01/24/2012 13:48:06 platform_post_install|Copy /mnt/source/Cisco/hssi/server_implementation/shared/bin/install_pool.meta to /usr/local/bin/hssi/server_implementation/shared/bin|<:INFO>
01/24/2012 13:48:06 platform_post_install|Calling "cp -rd /mnt/source/Cisco/hssi/server_implementation/shared/bin/install_pool.meta /usr/local/bin/hssi/server_implementation/shared/bin"|<:DEBUG>
01/24/2012 13:48:06 platform_post_install|Copy /mnt/source/Cisco/hssi/server_implementation/shared/bin/README.TXT to /usr/local/bin/hssi/server_implementation/shared/bin|<:INFO>
01/24/2012 13:48:06 platform_post_install|Calling "cp -rd /mnt/source/Cisco/hssi/server_implementation/shared/bin/README.TXT /usr/local/bin/hssi/server_implementation/shared/bin"|<:DEBUG>
01/24/2012 13:48:06 platform_post_install|Copy /mnt/source/Cisco/hssi/server_implementation/shared/bin/shared_implementation.sh to /usr/local/bin/hssi/server_implementation/shared/bin|<:INFO>
01/24/2012 13:48:06 platform_post_install|Calling "cp -rd /mnt/source/Cisco/hssi/server_implementation/shared/bin/shared_implementation.sh /usr/local/bin/hssi/server_implementation/shared/bin"|<:DEBUG>
01/24/2012 13:48:06 platform_post_install|Calling "mkdir -p /usr/local/bin/hssi/server_implementation/shared/hcf"|<:DEBUG>
01/24/2012 13:48:06 platform_post_install|Copy /mnt/source/Cisco/hssi/server_implementation/shared/hcf/hcf_bios_setup.sh to /usr/local/bin/hssi/server_implementation/shared/hcf|<:INFO>
01/24/2012 13:48:06 platform_post_install|Calling "cp -rd /mnt/source/Cisco/hssi/server_implementation/shared/hcf/hcf_bios_setup.sh /usr/local/bin/hssi/server_implementation/shared/hcf"|<:DEBUG>
01/24/2012 13:48:06 platform_post_install|Copy /mnt/source/Cisco/hssi/server_implementation/shared/hcf/hcf_modules_preload.sh to /usr/local/bin/hssi/server_implementation/shared/hcf|<:INFO>
01/24/2012 13:48:06 platform_post_install|Calling "cp -rd /mnt/source/Cisco/hssi/server_implementation/shared/hcf/hcf_modules_preload.sh /usr/local/bin/hssi/server_implementation/shared/hcf"|<:DEBUG>
01/24/2012 13:48:06 platform_post_install|Copy /mnt/source/Cisco/hssi/server_implementation/shared/hcf/hcf_update.sh to /usr/local/bin/hssi/server_implementation/shared/hcf|<:INFO>
01/24/2012 13:48:06 platform_post_install|Calling "cp -rd /mnt/source/Cisco/hssi/server_implementation/shared/hcf/hcf_update.sh /usr/local/bin/hssi/server_implementation/shared/hcf"|<:DEBUG>
01/24/2012 13:48:06 platform_post_install|Copy /mnt/source/Cisco/hssi/server_implementation/shared/hcf/README.TXT to /usr/local/bin/hssi/server_implementation/shared/hcf|<:INFO>
01/24/2012 13:48:06 platform_post_install|Calling "cp -rd /mnt/source/Cisco/hssi/server_implementation/shared/hcf/README.TXT /usr/local/bin/hssi/server_implementation/shared/hcf"|<:DEBUG>
01/24/2012 13:48:06 platform_post_install|Copy /mnt/source/Cisco/hssi/server_implementation/shared/README.TXT to /usr/local/bin/hssi/server_implementation/shared|<:INFO>
01/24/2012 13:48:06 platform_post_install|Calling "cp -rd /mnt/source/Cisco/hssi/server_implementation/shared/README.TXT /usr/local/bin/hssi/server_implementation/shared"|<:DEBUG>
01/24/2012 13:48:06 platform_post_install|Calling "mkdir -p /usr/local/bin/hssi/install_pool"|<:DEBUG>
01/24/2012 13:48:06 platform_post_install|Copy /mnt/source/Cisco/hssi/install_pool/migrateVMwareTools.sh to /usr/local/bin/hssi/install_pool|<:INFO>
01/24/2012 13:48:07 platform_post_install|Calling "cp -rd /mnt/source/Cisco/hssi/install_pool/migrateVMwareTools.sh /usr/local/bin/hssi/install_pool"|<:DEBUG>
01/24/2012 13:48:07 platform_post_install|Copy /mnt/source/Cisco/hssi/install_pool/net-snmp-libs-5.3.2.2-9.el5_5.1.i386.rpm to /usr/local/bin/hssi/install_pool|<:INFO>
01/24/2012 13:48:07 platform_post_install|Calling "cp -rd /mnt/source/Cisco/hssi/install_pool/net-snmp-libs-5.3.2.2-9.el5_5.1.i386.rpm /usr/local/bin/hssi/install_pool"|<:DEBUG>
01/24/2012 13:48:07 platform_post_install|Copy /mnt/source/Cisco/hssi/install_pool/net-snmp-5.3.2.2-9.el5_5.1.i386.rpm to /usr/local/bin/hssi/install_pool|<:INFO>
01/24/2012 13:48:07 platform_post_install|Calling "cp -rd /mnt/source/Cisco/hssi/install_pool/net-snmp-5.3.2.2-9.el5_5.1.i386.rpm /usr/local/bin/hssi/install_pool"|<:DEBUG>
01/24/2012 13:48:07 platform_post_install|Copy /mnt/source/Cisco/hssi/install_pool/net-snmp-utils-5.3.2.2-9.el5_5.1.i386.rpm to /usr/local/bin/hssi/install_pool|<:INFO>
01/24/2012 13:48:07 platform_post_install|Calling "cp -rd /mnt/source/Cisco/hssi/install_pool/net-snmp-utils-5.3.2.2-9.el5_5.1.i386.rpm /usr/local/bin/hssi/install_pool"|<:DEBUG>
01/24/2012 13:48:07 platform_post_install|Copy /mnt/source/Cisco/hssi/install_pool/init_wrapper.sh to /usr/local/bin/hssi/install_pool|<:INFO>
01/24/2012 13:48:07 platform_post_install|Calling "cp -rd /mnt/source/Cisco/hssi/install_pool/init_wrapper.sh /usr/local/bin/hssi/install_pool"|<:DEBUG>
01/24/2012 13:48:07 platform_post_install|Copy /mnt/source/Cisco/hssi/install_pool/apcupsd-3.14.8-1.el5.i386.rpm to /usr/local/bin/hssi/install_pool|<:INFO>
01/24/2012 13:48:07 platform_post_install|Calling "cp -rd /mnt/source/Cisco/hssi/install_pool/apcupsd-3.14.8-1.el5.i386.rpm /usr/local/bin/hssi/install_pool"|<:DEBUG>
01/24/2012 13:48:07 platform_post_install|Copy /mnt/source/Cisco/.security to /root|<:INFO>
01/24/2012 13:48:07 platform_post_install|Calling "mkdir -p /root/.security"|<:DEBUG>
01/24/2012 13:48:07 platform_post_install|Calling "mkdir -p /root/.security/accounts/ccm/conf"|<:DEBUG>
01/24/2012 13:48:07 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/accounts/ccm/conf/ccm_add_grp_members.cnf /root/.security/accounts/ccm/conf"|<:DEBUG>
01/24/2012 13:48:07 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/accounts/ccm/conf/ccm_create_user_accnt.cnf /root/.security/accounts/ccm/conf"|<:DEBUG>
01/24/2012 13:48:07 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/accounts/ccm/conf/TRANS.TBL /root/.security/accounts/ccm/conf"|<:DEBUG>
01/24/2012 13:48:07 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/accounts/ccm/create_ccm_accounts.sh /root/.security/accounts/ccm"|<:DEBUG>
01/24/2012 13:48:07 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/accounts/ccm/TRANS.TBL /root/.security/accounts/ccm"|<:DEBUG>
01/24/2012 13:48:07 platform_post_install|Calling "mkdir -p /root/.security/accounts/conf"|<:DEBUG>
01/24/2012 13:48:07 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/accounts/conf/add_grp_members.cnf /root/.security/accounts/conf"|<:DEBUG>
01/24/2012 13:48:07 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/accounts/conf/change_world_perms.cnf /root/.security/accounts/conf"|<:DEBUG>
01/24/2012 13:48:07 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/accounts/conf/create_user_accnt.cnf /root/.security/accounts/conf"|<:DEBUG>
01/24/2012 13:48:07 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/accounts/conf/TRANS.TBL /root/.security/accounts/conf"|<:DEBUG>
01/24/2012 13:48:07 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/accounts/create_special_accounts.sh /root/.security/accounts"|<:DEBUG>
01/24/2012 13:48:07 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/accounts/create_usergrp_accnt.sh /root/.security/accounts"|<:DEBUG>
01/24/2012 13:48:07 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/accounts/TRANS.TBL /root/.security/accounts"|<:DEBUG>
01/24/2012 13:48:07 platform_post_install|Calling "mkdir -p /root/.security/admin"|<:DEBUG>
01/24/2012 13:48:07 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/admin/adminAccounts.sh /root/.security/admin"|<:DEBUG>
01/24/2012 13:48:07 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/admin/adminAddSudo.sh /root/.security/admin"|<:DEBUG>
01/24/2012 13:48:07 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/admin/adminRmSudo.sh /root/.security/admin"|<:DEBUG>
01/24/2012 13:48:07 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/admin/sudoers.sh /root/.security/admin"|<:DEBUG>
01/24/2012 13:48:07 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/admin/TRANS.TBL /root/.security/admin"|<:DEBUG>
01/24/2012 13:48:07 platform_post_install|Calling "mkdir -p /root/.security/ccm"|<:DEBUG>
01/24/2012 13:48:07 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/ccm/firstnode_init.sh /root/.security/ccm"|<:DEBUG>
01/24/2012 13:48:07 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/ccm/setccmservicedetails.sh /root/.security/ccm"|<:DEBUG>
01/24/2012 13:48:07 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/ccm/subsequentnode_init.sh /root/.security/ccm"|<:DEBUG>
01/24/2012 13:48:07 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/ccm/sudoers.sh /root/.security/ccm"|<:DEBUG>
01/24/2012 13:48:07 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/ccm/TRANS.TBL /root/.security/ccm"|<:DEBUG>
01/24/2012 13:48:07 platform_post_install|Calling "mkdir -p /root/.security/cert"|<:DEBUG>
01/24/2012 13:48:07 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/cert/ExportPrivClassPath /root/.security/cert"|<:DEBUG>
01/24/2012 13:48:07 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/cert/ExportPriv.class /root/.security/cert"|<:DEBUG>
01/24/2012 13:48:07 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/cert/generate_selfsigned_cert_pem.sh /root/.security/cert"|<:DEBUG>
01/24/2012 13:48:07 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/cert/generate_selfsigned_cert.sh /root/.security/cert"|<:DEBUG>
01/24/2012 13:48:07 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/cert/gen_keystore_pwd.sh /root/.security/cert"|<:DEBUG>
01/24/2012 13:48:07 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/cert/locateCertDirs.sh /root/.security/cert"|<:DEBUG>
01/24/2012 13:48:07 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/cert/locateX509Details.sh /root/.security/cert"|<:DEBUG>
01/24/2012 13:48:07 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/cert/merge_cert_conf_files.sh /root/.security/cert"|<:DEBUG>
01/24/2012 13:48:07 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/cert/perform_cert.sh /root/.security/cert"|<:DEBUG>
01/24/2012 13:48:07 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/cert/TRANS.TBL /root/.security/cert"|<:DEBUG>
01/24/2012 13:48:07 platform_post_install|Calling "mkdir -p /root/.security/clm"|<:DEBUG>
01/24/2012 13:48:07 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/clm/sudoers.sh /root/.security/clm"|<:DEBUG>
01/24/2012 13:48:07 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/clm/TRANS.TBL /root/.security/clm"|<:DEBUG>
01/24/2012 13:48:07 platform_post_install|Calling "mkdir -p /root/.security/drf"|<:DEBUG>
01/24/2012 13:48:07 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/drf/drfkeys_shell.sh /root/.security/drf"|<:DEBUG>
01/24/2012 13:48:07 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/drf/enable_drf_clusternode.sh /root/.security/drf"|<:DEBUG>
01/24/2012 13:48:07 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/drf/setdrfdetails.sh /root/.security/drf"|<:DEBUG>
01/24/2012 13:48:07 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/drf/sudoers.sh /root/.security/drf"|<:DEBUG>
01/24/2012 13:48:07 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/drf/tardd.sh /root/.security/drf"|<:DEBUG>
01/24/2012 13:48:07 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/drf/TRANS.TBL /root/.security/drf"|<:DEBUG>
01/24/2012 13:48:07 platform_post_install|Calling "mkdir -p /root/.security/dscp/automation"|<:DEBUG>
01/24/2012 13:48:07 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/dscp/automation/dscp_test.sh /root/.security/dscp/automation"|<:DEBUG>
01/24/2012 13:48:07 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/dscp/automation/TRANS.TBL /root/.security/dscp/automation"|<:DEBUG>
01/24/2012 13:48:07 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/dscp/dscp_auto_test.sh /root/.security/dscp"|<:DEBUG>
01/24/2012 13:48:07 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/dscp/dscp-markings /root/.security/dscp"|<:DEBUG>
01/24/2012 13:48:07 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/dscp/dscp-markings.cpp /root/.security/dscp"|<:DEBUG>
01/24/2012 13:48:07 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/dscp/dscp_options.hpp /root/.security/dscp"|<:DEBUG>
01/24/2012 13:48:07 platform_post_install|Calling "mkdir -p /root/.security/dscp/linux/i386"|<:DEBUG>
01/24/2012 13:48:07 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/dscp/linux/i386/dscp-markings.o /root/.security/dscp/linux/i386"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/dscp/linux/i386/TRANS.TBL /root/.security/dscp/linux/i386"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/dscp/linux/TRANS.TBL /root/.security/dscp/linux"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/dscp/Makefile /root/.security/dscp"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/dscp/TRANS.TBL /root/.security/dscp"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "mkdir -p /root/.security/install_file_signing"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/install_file_signing/TRANS.TBL /root/.security/install_file_signing"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "mkdir -p /root/.security/install_file_signing/xml_public_keys"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/install_file_signing/xml_public_keys/3951_cop2_dev.xml /root/.security/install_file_signing/xml_public_keys"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/install_file_signing/xml_public_keys/3951_cop_dev.xml /root/.security/install_file_signing/xml_public_keys"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/install_file_signing/xml_public_keys/3rdPartyPhone_cop2_dev.xml /root/.security/install_file_signing/xml_public_keys"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/install_file_signing/xml_public_keys/3rdPartyPhone_cop_dev.xml /root/.security/install_file_signing/xml_public_keys"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/install_file_signing/xml_public_keys/6600_cop2_dev.xml /root/.security/install_file_signing/xml_public_keys"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/install_file_signing/xml_public_keys/6600_cop_dev.xml /root/.security/install_file_signing/xml_public_keys"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/install_file_signing/xml_public_keys/7902_cop2_dev.xml /root/.security/install_file_signing/xml_public_keys"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/install_file_signing/xml_public_keys/7902_cop_dev.xml /root/.security/install_file_signing/xml_public_keys"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/install_file_signing/xml_public_keys/7905_cop2_dev.xml /root/.security/install_file_signing/xml_public_keys"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/install_file_signing/xml_public_keys/7905_cop_dev.xml /root/.security/install_file_signing/xml_public_keys"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/install_file_signing/xml_public_keys/7910_cop2_dev.xml /root/.security/install_file_signing/xml_public_keys"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/install_file_signing/xml_public_keys/7910_cop_dev.xml /root/.security/install_file_signing/xml_public_keys"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/install_file_signing/xml_public_keys/7911_cop2_dev.xml /root/.security/install_file_signing/xml_public_keys"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/install_file_signing/xml_public_keys/7911_cop_dev.xml /root/.security/install_file_signing/xml_public_keys"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/install_file_signing/xml_public_keys/7912_cop2_dev.xml /root/.security/install_file_signing/xml_public_keys"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/install_file_signing/xml_public_keys/7912_cop_dev.xml /root/.security/install_file_signing/xml_public_keys"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/install_file_signing/xml_public_keys/7920_cop2_dev.xml /root/.security/install_file_signing/xml_public_keys"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/install_file_signing/xml_public_keys/7920_cop_dev.xml /root/.security/install_file_signing/xml_public_keys"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/install_file_signing/xml_public_keys/7921_cop2_dev.xml /root/.security/install_file_signing/xml_public_keys"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/install_file_signing/xml_public_keys/7921_cop_dev.xml /root/.security/install_file_signing/xml_public_keys"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/install_file_signing/xml_public_keys/7926_cop2_dev.xml /root/.security/install_file_signing/xml_public_keys"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/install_file_signing/xml_public_keys/7931_cop2_dev.xml /root/.security/install_file_signing/xml_public_keys"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/install_file_signing/xml_public_keys/7931_cop_dev.xml /root/.security/install_file_signing/xml_public_keys"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/install_file_signing/xml_public_keys/7935_cop2_dev.xml /root/.security/install_file_signing/xml_public_keys"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/install_file_signing/xml_public_keys/7935_cop_dev.xml /root/.security/install_file_signing/xml_public_keys"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/install_file_signing/xml_public_keys/7936_cop2_dev.xml /root/.security/install_file_signing/xml_public_keys"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/install_file_signing/xml_public_keys/7936_cop_dev.xml /root/.security/install_file_signing/xml_public_keys"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/install_file_signing/xml_public_keys/7937_cop2_dev.xml /root/.security/install_file_signing/xml_public_keys"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/install_file_signing/xml_public_keys/7941_cop2_dev.xml /root/.security/install_file_signing/xml_public_keys"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/install_file_signing/xml_public_keys/7941_cop_dev.xml /root/.security/install_file_signing/xml_public_keys"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/install_file_signing/xml_public_keys/7942_cop2_dev.xml /root/.security/install_file_signing/xml_public_keys"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/install_file_signing/xml_public_keys/7942_cop_dev.xml /root/.security/install_file_signing/xml_public_keys"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/install_file_signing/xml_public_keys/7945_cop2_dev.xml /root/.security/install_file_signing/xml_public_keys"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/install_file_signing/xml_public_keys/7945_cop_dev.xml /root/.security/install_file_signing/xml_public_keys"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/install_file_signing/xml_public_keys/7960_cop2_dev.xml /root/.security/install_file_signing/xml_public_keys"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/install_file_signing/xml_public_keys/7960_cop_dev.xml /root/.security/install_file_signing/xml_public_keys"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/install_file_signing/xml_public_keys/7970_cop2_dev.xml /root/.security/install_file_signing/xml_public_keys"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/install_file_signing/xml_public_keys/7970_cop_dev.xml /root/.security/install_file_signing/xml_public_keys"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/install_file_signing/xml_public_keys/7975_cop2_dev.xml /root/.security/install_file_signing/xml_public_keys"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/install_file_signing/xml_public_keys/7975_cop_dev.xml /root/.security/install_file_signing/xml_public_keys"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/install_file_signing/xml_public_keys/7985_cop2_dev.xml /root/.security/install_file_signing/xml_public_keys"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/install_file_signing/xml_public_keys/7985_cop_dev.xml /root/.security/install_file_signing/xml_public_keys"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/install_file_signing/xml_public_keys/9971_cop2_dev.xml /root/.security/install_file_signing/xml_public_keys"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/install_file_signing/xml_public_keys/ata_cop2_dev.xml /root/.security/install_file_signing/xml_public_keys"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/install_file_signing/xml_public_keys/ata_cop_dev.xml /root/.security/install_file_signing/xml_public_keys"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/install_file_signing/xml_public_keys/CCBU_dev_cop_dev.xml /root/.security/install_file_signing/xml_public_keys"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/install_file_signing/xml_public_keys/ccmPatch_cop2_dev.xml /root/.security/install_file_signing/xml_public_keys"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/install_file_signing/xml_public_keys/ccmPatch_cop_dev.xml /root/.security/install_file_signing/xml_public_keys"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/install_file_signing/xml_public_keys/CM_sec_patch_release.xml /root/.security/install_file_signing/xml_public_keys"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/install_file_signing/xml_public_keys/CM_sec_patch_dev.xml /root/.security/install_file_signing/xml_public_keys"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/install_file_signing/xml_public_keys/CM_sec_patch2_dev.xml /root/.security/install_file_signing/xml_public_keys"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/install_file_signing/xml_public_keys/devicePack_cop2_dev.xml /root/.security/install_file_signing/xml_public_keys"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/install_file_signing/xml_public_keys/devicePack_cop_dev.xml /root/.security/install_file_signing/xml_public_keys"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/install_file_signing/xml_public_keys/DST_cop_dev.xml /root/.security/install_file_signing/xml_public_keys"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/install_file_signing/xml_public_keys/intDialplan_cop2_dev.xml /root/.security/install_file_signing/xml_public_keys"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/install_file_signing/xml_public_keys/intDialplan_cop_dev.xml /root/.security/install_file_signing/xml_public_keys"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/install_file_signing/xml_public_keys/IPCom_cop2_dev.xml /root/.security/install_file_signing/xml_public_keys"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/install_file_signing/xml_public_keys/IPCom_cop_dev.xml /root/.security/install_file_signing/xml_public_keys"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/install_file_signing/xml_public_keys/IPPhoneCommonCode_cop2_dev.xml /root/.security/install_file_signing/xml_public_keys"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/install_file_signing/xml_public_keys/IPPhoneCommonCode_cop_dev.xml /root/.security/install_file_signing/xml_public_keys"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/install_file_signing/xml_public_keys/locale_cop2_dev.xml /root/.security/install_file_signing/xml_public_keys"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/install_file_signing/xml_public_keys/locale_cop_dev.xml /root/.security/install_file_signing/xml_public_keys"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/install_file_signing/xml_public_keys/selinux_cop2_dev.xml /root/.security/install_file_signing/xml_public_keys"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/install_file_signing/xml_public_keys/telepres_sip_cop2_dev.xml /root/.security/install_file_signing/xml_public_keys"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/install_file_signing/xml_public_keys/telepres_sip_cop_dev.xml /root/.security/install_file_signing/xml_public_keys"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/install_file_signing/xml_public_keys/TRANS.TBL /root/.security/install_file_signing/xml_public_keys"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/install_file_signing/xml_public_keys/TSBU_INFRA_cop_dev.xml /root/.security/install_file_signing/xml_public_keys"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/install_file_signing/xml_public_keys/UnityConnectionLocale_cop2_dev.xml /root/.security/install_file_signing/xml_public_keys"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/install_file_signing/xml_public_keys/UnityConnectionLocale_cop_dev.xml /root/.security/install_file_signing/xml_public_keys"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/install_file_signing/xml_public_keys/UnityConnectionFriendly_cop2_dev.xml /root/.security/install_file_signing/xml_public_keys"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/install_file_signing/xml_public_keys/UnityConnectionFriendly_cop_dev.xml /root/.security/install_file_signing/xml_public_keys"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "mkdir -p /root/.security/ipsec"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/ipsec/create_ipsecuser.sh /root/.security/ipsec"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/ipsec/dblping_ipsec.sh /root/.security/ipsec"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/ipsec/disable_ipsec.sh /root/.security/ipsec"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/ipsec/enable_ipsec_clusternode.sh /root/.security/ipsec"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/ipsec/enable_ipsec.sh /root/.security/ipsec"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/ipsec/gen_ipsec_selfsigned.sh /root/.security/ipsec"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/ipsec/handshake_ipsec.sh /root/.security/ipsec"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/ipsec/initialize_ipsec_nonfips.sh /root/.security/ipsec"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/ipsec/initialize_ipsec_fips.sh /root/.security/ipsec"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/ipsec/initialize_ipsec.sh /root/.security/ipsec"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/ipsec/ipsec_initd_fips /root/.security/ipsec"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/ipsec/ipsec_validate_nonfips.sh /root/.security/ipsec"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/ipsec/ipsec_validate_fips.sh /root/.security/ipsec"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/ipsec/ipsecuser_shell.sh /root/.security/ipsec"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/ipsec/ipsec-config.txt /root/.security/ipsec"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/ipsec/ipsec_initd /root/.security/ipsec"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/ipsec/ipsec_init_unmonitored.sh /root/.security/ipsec"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/ipsec/ipsec_migrate_policies /root/.security/ipsec"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/ipsec/ipsec_update_NSS /root/.security/ipsec"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/ipsec/ipsec_validate.sh /root/.security/ipsec"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/ipsec/iptable_ipsec.sh /root/.security/ipsec"|<:DEBUG>
01/24/2012 13:48:08 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/ipsec/perform_ipsec_cert.sh /root/.security/ipsec"|<:DEBUG>
01/24/2012 13:48:09 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/ipsec/setup_policies_fips /root/.security/ipsec"|<:DEBUG>
01/24/2012 13:48:09 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/ipsec/setup_policies.sh /root/.security/ipsec"|<:DEBUG>
01/24/2012 13:48:09 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/ipsec/set_ipsecuser_pwd.exp /root/.security/ipsec"|<:DEBUG>
01/24/2012 13:48:09 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/ipsec/start_ipsec.sh /root/.security/ipsec"|<:DEBUG>
01/24/2012 13:48:09 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/ipsec/start_racoon.sh /root/.security/ipsec"|<:DEBUG>
01/24/2012 13:48:09 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/ipsec/stop_racoon.sh /root/.security/ipsec"|<:DEBUG>
01/24/2012 13:48:09 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/ipsec/TRANS.TBL /root/.security/ipsec"|<:DEBUG>
01/24/2012 13:48:09 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/post_appinstall.sh /root/.security"|<:DEBUG>
01/24/2012 13:48:09 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/product_sd_upgrade.sh /root/.security"|<:DEBUG>
01/24/2012 13:48:09 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/product_sd_postinstall.sh /root/.security"|<:DEBUG>
01/24/2012 13:48:09 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/product_sd_install.sh /root/.security"|<:DEBUG>
01/24/2012 13:48:09 platform_post_install|Calling "mkdir -p /root/.security/pwrecovery"|<:DEBUG>
01/24/2012 13:48:09 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/pwrecovery/dummy /root/.security/pwrecovery"|<:DEBUG>
01/24/2012 13:48:09 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/pwrecovery/sudoers.sh /root/.security/pwrecovery"|<:DEBUG>
01/24/2012 13:48:09 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/pwrecovery/TRANS.TBL /root/.security/pwrecovery"|<:DEBUG>
01/24/2012 13:48:09 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/secure_sd_upgrade.sh /root/.security"|<:DEBUG>
01/24/2012 13:48:09 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/secure_sd_postinstall.sh /root/.security"|<:DEBUG>
01/24/2012 13:48:09 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/secure_sd_install.sh /root/.security"|<:DEBUG>
01/24/2012 13:48:09 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/setkeysdetails.sh /root/.security"|<:DEBUG>
01/24/2012 13:48:09 platform_post_install|Calling "mkdir -p /root/.security/sftp"|<:DEBUG>
01/24/2012 13:48:09 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/sftp/download_windows.sh /root/.security/sftp"|<:DEBUG>
01/24/2012 13:48:09 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/sftp/generate_ssh_keys.sh /root/.security/sftp"|<:DEBUG>
01/24/2012 13:48:09 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/sftp/set_sftp_pwd.exp /root/.security/sftp"|<:DEBUG>
01/24/2012 13:48:09 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/sftp/sftp_config /root/.security/sftp"|<:DEBUG>
01/24/2012 13:48:09 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/sftp/sftp_connect.sh /root/.security/sftp"|<:DEBUG>
01/24/2012 13:48:09 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/sftp/sftp_knownhosts.exp /root/.security/sftp"|<:DEBUG>
01/24/2012 13:48:09 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/sftp/sftp_password.exp /root/.security/sftp"|<:DEBUG>
01/24/2012 13:48:09 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/sftp/ssh_PK_setup.sh /root/.security/sftp"|<:DEBUG>
01/24/2012 13:48:09 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/sftp/TRANS.TBL /root/.security/sftp"|<:DEBUG>
01/24/2012 13:48:09 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/sftp/update_sftpuser_pwd.sh /root/.security/sftp"|<:DEBUG>
01/24/2012 13:48:09 platform_post_install|Calling "mkdir -p /root/.security/system"|<:DEBUG>
01/24/2012 13:48:09 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/system/cleanup_files.sh /root/.security/system"|<:DEBUG>
01/24/2012 13:48:09 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/system/harden.sh /root/.security/system"|<:DEBUG>
01/24/2012 13:48:09 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/system/immunize.sh /root/.security/system"|<:DEBUG>
01/24/2012 13:48:09 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/system/ip6tables /root/.security/system"|<:DEBUG>
01/24/2012 13:48:09 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/system/ipprefs.conf /root/.security/system"|<:DEBUG>
01/24/2012 13:48:09 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/system/iptables /root/.security/system"|<:DEBUG>
01/24/2012 13:48:09 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/system/logrotate_mgetty.source /root/.security/system"|<:DEBUG>
01/24/2012 13:48:09 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/system/logrotate_syslog.source /root/.security/system"|<:DEBUG>
01/24/2012 13:48:09 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/system/secure_files_permission.sh /root/.security/system"|<:DEBUG>
01/24/2012 13:48:09 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/system/stop_services.sh /root/.security/system"|<:DEBUG>
01/24/2012 13:48:09 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/system/TRANS.TBL /root/.security/system"|<:DEBUG>
01/24/2012 13:48:09 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/system/unimmunize.sh /root/.security/system"|<:DEBUG>
01/24/2012 13:48:09 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/system/update_profile.sh /root/.security/system"|<:DEBUG>
01/24/2012 13:48:09 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/system/update_syslog_details.sh /root/.security/system"|<:DEBUG>
01/24/2012 13:48:09 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/tomcat_sd_upgrade.sh /root/.security"|<:DEBUG>
01/24/2012 13:48:09 platform_post_install|Calling "mkdir -p /root/.security/tomcat"|<:DEBUG>
01/24/2012 13:48:09 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/tomcat/catalina.sh.source /root/.security/tomcat"|<:DEBUG>
01/24/2012 13:48:09 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/tomcat/catalina.policy.source /root/.security/tomcat"|<:DEBUG>
01/24/2012 13:48:09 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/tomcat/context.xml.source /root/.security/tomcat"|<:DEBUG>
01/24/2012 13:48:09 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/tomcat/display_tomcat_cert.sh /root/.security/tomcat"|<:DEBUG>
01/24/2012 13:48:09 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/tomcat/favicon.ico /root/.security/tomcat"|<:DEBUG>
01/24/2012 13:48:09 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/tomcat/gen_tomcat_shutdown.sh /root/.security/tomcat"|<:DEBUG>
01/24/2012 13:48:09 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/tomcat/gen_tomcat_users.sh /root/.security/tomcat"|<:DEBUG>
01/24/2012 13:48:09 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/tomcat/gen_tomcatkeystore_pwd.sh /root/.security/tomcat"|<:DEBUG>
01/24/2012 13:48:09 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/tomcat/gen_tomcat_selfsigned.sh /root/.security/tomcat"|<:DEBUG>
01/24/2012 13:48:09 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/tomcat/logging.properties.source /root/.security/tomcat"|<:DEBUG>
01/24/2012 13:48:09 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/tomcat/manager.xml.source /root/.security/tomcat"|<:DEBUG>
01/24/2012 13:48:09 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/tomcat/robots.txt /root/.security/tomcat"|<:DEBUG>
01/24/2012 13:48:09 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/tomcat/server.xml.source /root/.security/tomcat"|<:DEBUG>
01/24/2012 13:48:09 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/tomcat/sudoers.sh /root/.security/tomcat"|<:DEBUG>
01/24/2012 13:48:09 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/tomcat/tomcat_security_startup.sh /root/.security/tomcat"|<:DEBUG>
01/24/2012 13:48:09 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/tomcat/tomcat /root/.security/tomcat"|<:DEBUG>
01/24/2012 13:48:09 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/tomcat/tomcatJlauncherConfig.xml /root/.security/tomcat"|<:DEBUG>
01/24/2012 13:48:09 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/tomcat/tomcat_diagnostics.sh /root/.security/tomcat"|<:DEBUG>
01/24/2012 13:48:09 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/tomcat/tomcat_oninit.sh /root/.security/tomcat"|<:DEBUG>
01/24/2012 13:48:09 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/tomcat/tomcat_startup.sh /root/.security/tomcat"|<:DEBUG>
01/24/2012 13:48:09 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/tomcat/TRANS.TBL /root/.security/tomcat"|<:DEBUG>
01/24/2012 13:48:09 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/tomcat/update_catalina_policy.sh /root/.security/tomcat"|<:DEBUG>
01/24/2012 13:48:09 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/tomcat/update_logging.sh /root/.security/tomcat"|<:DEBUG>
01/24/2012 13:48:09 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/tomcat/update_startup.sh /root/.security/tomcat"|<:DEBUG>
01/24/2012 13:48:09 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/tomcat/web.xml.source /root/.security/tomcat"|<:DEBUG>
01/24/2012 13:48:09 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/tomcat_sd_install.sh /root/.security"|<:DEBUG>
01/24/2012 13:48:09 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/TRANS.TBL /root/.security"|<:DEBUG>
01/24/2012 13:48:09 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/update_user_pwd.exp /root/.security"|<:DEBUG>
01/24/2012 13:48:09 platform_post_install|Calling "cp -r /mnt/source/Cisco/.security/update_usr_pmd.sh /root/.security"|<:DEBUG>
01/24/2012 13:48:09 platform_post_install|copyVendorLinks /mnt/source/Cisco/hssi /usr/local/bin/hssi|<:DEBUG>
01/24/2012 13:48:10 component_install|Initializing xproduct.sh API|<:DEBUG>
01/24/2012 13:48:10 component_install|Initializing xcomponent.sh API|<:DEBUG>
01/24/2012 13:48:10 component_install|Initializing xplatformconfig.sh API|<:DEBUG>
01/24/2012 13:48:10 component_install|Parse argument type=system|<:DEBUG>
01/24/2012 13:48:10 component_install|Parse argument mode=upgrade|<:DEBUG>
01/24/2012 13:48:10 component_install|Install system component, mode upgrade|<:INFO>
01/24/2012 13:48:10 component_install|Initialize product data, mode upgrade|<:INFO>
01/24/2012 13:48:10 component_install|Initialize "to" side product version|<:INFO>
01/24/2012 13:48:10 component_install|Access "to" side API|<:DEBUG>
01/24/2012 13:48:10 component_install|Got version 8.6.2.22900-9|<:DEBUG>
01/24/2012 13:48:10 component_install|Initialize "to" side product version complete|<:INFO>
01/24/2012 13:48:10 component_install|Initialize "from" side product version|<:INFO>
01/24/2012 13:48:10 component_install|Access "from" side API|<:DEBUG>
01/24/2012 13:48:10 component_install|Got version 8.6.2.20000-2|<:DEBUG>
01/24/2012 13:48:10 component_install|Initialize "from" side product version complete|<:INFO>
01/24/2012 13:48:10 component_install|Initialize product data complete|<:INFO>
01/24/2012 13:48:10 component_install|Initialize component data, mode upgrade|<:INFO>
01/24/2012 13:48:10 component_install|Initialize ucos "to" side version|<:INFO>
01/24/2012 13:48:10 component_install|Initialize ucos "to" side version complete|<:INFO>
01/24/2012 13:48:10 component_install|Initialize ucos "from" side version|<:INFO>
01/24/2012 13:48:10 component_install|Component ucos available on active side|<:DEBUG>
01/24/2012 13:48:10 component_install|Initialize ucos "from" side version complete|<:INFO>
01/24/2012 13:48:10 component_install|Initialize global data complete|<:INFO>
01/24/2012 13:48:10 component_install|Build the command list for ucos|<:INFO>
01/24/2012 13:48:10 component_install|Initialize command list|<:DEBUG>
01/24/2012 13:48:10 component_install|Build ucos install phase commands|<:DEBUG>
01/24/2012 13:48:10 component_install|Processing ucos install element|<:DEBUG>
01/24/2012 13:48:10 component_install|Processing ucos package element|<:DEBUG>
01/24/2012 13:48:10 component_install|Checking if RPM /common/rpm-archive/8.6.2.22900-9/RPMS/ucos/master-8.6.2.22900-9.i386.rpm exists|<:DEBUG>
01/24/2012 13:48:10 component_install|Add "rpm  -iv --replacefiles /common/rpm-archive/8.6.2.22900-9/RPMS/ucos/master-8.6.2.22900-9.i386.rpm" to command list|<:DEBUG>
01/24/2012 13:48:10 component_install|Checking if RPM /common/rpm-archive/8.6.2.22900-9/RPMS/ucos/ucfips-openssl-2.0.0.1-1.i386.rpm exists|<:DEBUG>
01/24/2012 13:48:10 component_install|Add "rpm  -iv --replacefiles /common/rpm-archive/8.6.2.22900-9/RPMS/ucos/ucfips-openssl-2.0.0.1-1.i386.rpm" to command list|<:DEBUG>
01/24/2012 13:48:10 component_install|Checking if RPM /common/rpm-archive/8.6.2.22900-9/RPMS/ucos/openssh-5.1p1-3.i386.rpm exists|<:DEBUG>
01/24/2012 13:48:10 component_install|Add "rpm  -iv --replacefiles /common/rpm-archive/8.6.2.22900-9/RPMS/ucos/openssh-5.1p1-3.i386.rpm" to command list|<:DEBUG>
01/24/2012 13:48:10 component_install|Checking if RPM /common/rpm-archive/8.6.2.22900-9/RPMS/ucos/openssh-clients-5.1p1-3.i386.rpm exists|<:DEBUG>
01/24/2012 13:48:10 component_install|Add "rpm  -iv --replacefiles /common/rpm-archive/8.6.2.22900-9/RPMS/ucos/openssh-clients-5.1p1-3.i386.rpm" to command list|<:DEBUG>
01/24/2012 13:48:10 component_install|Checking if RPM /common/rpm-archive/8.6.2.22900-9/RPMS/ucos/openssh-server-5.1p1-3.i386.rpm exists|<:DEBUG>
01/24/2012 13:48:10 component_install|Add "rpm  -iv --replacefiles /common/rpm-archive/8.6.2.22900-9/RPMS/ucos/openssh-server-5.1p1-3.i386.rpm" to command list|<:DEBUG>
01/24/2012 13:48:10 component_install|Checking if RPM /common/rpm-archive/8.6.2.22900-9/RPMS/ucos/ipv6-kmod-update-2-1.i386.rpm exists|<:DEBUG>
01/24/2012 13:48:10 component_install|Add "rpm  -iv --replacefiles /common/rpm-archive/8.6.2.22900-9/RPMS/ucos/ipv6-kmod-update-2-1.i386.rpm" to command list|<:DEBUG>
01/24/2012 13:48:11 component_install|Building the command list for ucos is complete|<:INFO>
01/24/2012 13:48:11 component_install|Command execution for ucos component RTMTStart|<:NOTICE>
01/24/2012 13:48:11 component_install|Execute commands in the command list for ucos component|<:INFO>
01/24/2012 13:48:11 component_install|Execute "rpm  -iv --replacefiles /common/rpm-archive/8.6.2.22900-9/RPMS/ucos/master-8.6.2.22900-9.i386.rpm"|<:DEBUG>
01/24/2012 13:48:11 component_install|Execute "rpm  -iv --replacefiles /common/rpm-archive/8.6.2.22900-9/RPMS/ucos/ucfips-openssl-2.0.0.1-1.i386.rpm"|<:DEBUG>
01/24/2012 13:48:11 component_install|Execute "rpm  -iv --replacefiles /common/rpm-archive/8.6.2.22900-9/RPMS/ucos/openssh-5.1p1-3.i386.rpm"|<:DEBUG>
01/24/2012 13:48:11 component_install|Execute "rpm  -iv --replacefiles /common/rpm-archive/8.6.2.22900-9/RPMS/ucos/openssh-clients-5.1p1-3.i386.rpm"|<:DEBUG>
01/24/2012 13:48:11 component_install|Execute "rpm  -iv --replacefiles /common/rpm-archive/8.6.2.22900-9/RPMS/ucos/openssh-server-5.1p1-3.i386.rpm"|<:DEBUG>
01/24/2012 13:48:11 component_install|Execute "rpm  -iv --replacefiles /common/rpm-archive/8.6.2.22900-9/RPMS/ucos/ipv6-kmod-update-2-1.i386.rpm"|<:DEBUG>
01/24/2012 13:48:12 component_install|Command execution for ucos component is complete|<:INFO>
01/24/2012 13:48:12 component_install|Command execution for ucos component RTMTFinish|<:NOTICE>
01/24/2012 13:48:12 component_install|Installation of system component complete|<:INFO>
01/24/2012 13:48:12 platform_post_install|Installing chkpatch service|<:INFO>
01/24/2012 13:48:12 platform_post_install|Calling "mkdir -p /usr/local/os-services/patches/scripts"|<:DEBUG>
01/24/2012 13:48:12 platform_post_install|Calling "mkdir -p /var/log/active/patches"|<:DEBUG>
01/24/2012 13:48:12 platform_post_install|Copy /usr/local/bin/base_scripts/chkpatch to /etc/rc.d/init.d|<:INFO>
01/24/2012 13:48:12 platform_post_install|Calling "cp /usr/local/bin/base_scripts/chkpatch /etc/rc.d/init.d"|<:DEBUG>
01/24/2012 13:48:12 platform_post_install|Calling "chkconfig --add chkpatch"|<:DEBUG>
01/24/2012 13:48:12 platform_post_install|Calling "chkconfig --level 345 chkpatch on"|<:DEBUG>
01/24/2012 13:48:12 platform_post_install|Setup Java in /usr/local/thirdparty/java|<:INFO>
01/24/2012 13:48:12 platform_post_install|Calling "ln -s /usr/java/latest"|<:DEBUG>
01/24/2012 13:48:12 platform_post_install|Calling "ln -s /usr/java/jdk1.6.0_31"|<:DEBUG>
01/24/2012 13:48:12 platform_post_install|Calling "ln -s /usr/java/default"|<:DEBUG>
01/24/2012 13:48:12 platform_post_install|Create java jdk links|<:INFO>
01/24/2012 13:48:12 platform_post_install|Determine jdk RPM version|<:DEBUG>
01/24/2012 13:48:12 platform_post_install|jdk RPM version is jdk1.6.0_31|<:DEBUG>
01/24/2012 13:48:12 platform_post_install|Create legacy j2sdk link to jdk1.6.0_31|<:DEBUG>
01/24/2012 13:48:12 platform_post_install|Calling "ln -s jdk1.6.0_31 j2sdk"|<:DEBUG>
01/24/2012 13:48:12 platform_post_install|Create jdk link to jdk1.6.0_31|<:DEBUG>
01/24/2012 13:48:12 platform_post_install|Calling "ln -s jdk1.6.0_31 jdk"|<:DEBUG>
01/24/2012 13:48:13 platform_post_install|Applying tzupdater|<:INFO>
01/24/2012 13:48:13 platform_post_install|Updating JRE TZ version|<:INFO>
01/24/2012 13:48:13 platform_post_install|(CAPTURE) java.home: /usr/java/jdk1.6.0_31/jre|<:DEBUG>
01/24/2012 13:48:13 platform_post_install|(CAPTURE) java.vendor: Sun Microsystems Inc.|<:DEBUG>
01/24/2012 13:48:13 platform_post_install|(CAPTURE) java.version: 1.6.0_31|<:DEBUG>
01/24/2012 13:48:13 platform_post_install|(CAPTURE) JRE time zone data version: tzdata2011l|<:DEBUG>
01/24/2012 13:48:13 platform_post_install|(CAPTURE) Embedded time zone data version: tzdata2012c|<:DEBUG>
01/24/2012 13:48:13 platform_post_install|(CAPTURE) Extracting files... done.|<:DEBUG>
01/24/2012 13:48:13 platform_post_install|(CAPTURE) Renaming directories... done.|<:DEBUG>
01/24/2012 13:48:13 platform_post_install|(CAPTURE) Validating the new time zone data... done.|<:DEBUG>
01/24/2012 13:48:13 platform_post_install|(CAPTURE) Time zone data update is complete.|<:DEBUG>
01/24/2012 13:48:13 platform_post_install|JRE TZ version updated successfully|<:INFO>
01/24/2012 13:48:13 platform_post_install|Configuring for core files|<:INFO>
01/24/2012 13:48:13 platform_post_install|Configuring syslogd|<:INFO>
01/24/2012 13:48:13 platform_post_install|Copy /tmp/syslog.tmp to /etc/sysconfig/syslog|<:INFO>
01/24/2012 13:48:13 platform_post_install|Calling "cp -f /tmp/syslog.tmp /etc/sysconfig/syslog"|<:DEBUG>
01/24/2012 13:48:13 platform_post_install|Migrating ssh keys|<:INFO>
01/24/2012 13:48:13 platform_post_install|Copy /partB/etc/ssh/ssh_host_rsa_key.pub to /etc/ssh/.|<:INFO>
01/24/2012 13:48:13 platform_post_install|Calling "cp -f /partB/etc/ssh/ssh_host_dsa_key /partB/etc/ssh/ssh_host_dsa_key.pub /partB/etc/ssh/ssh_host_key /partB/etc/ssh/ssh_host_key.pub /partB/etc/ssh/ssh_host_rsa_key /partB/etc/ssh/ssh_host_rsa_key.pub /etc/ssh/."|<:DEBUG>
01/24/2012 13:48:13 platform_post_install|Migrating clock configuration|<:INFO>
01/24/2012 13:48:13 platform_post_install|Copy /partB/etc/sysconfig/clock to /etc/sysconfig/clock|<:INFO>
01/24/2012 13:48:13 platform_post_install|Calling "cp -f /partB/etc/sysconfig/clock /etc/sysconfig/clock"|<:DEBUG>
01/24/2012 13:48:13 platform_post_install|Migrating language configuration|<:INFO>
01/24/2012 13:48:13 platform_post_install|Copy /partB/etc/sysconfig/i18n to /etc/sysconfig/i18n|<:INFO>
01/24/2012 13:48:13 platform_post_install|Calling "cp -f /partB/etc/sysconfig/i18n /etc/sysconfig/i18n"|<:DEBUG>
01/24/2012 13:48:13 platform_post_install|Updating etc profile information|<:INFO>
01/24/2012 13:48:13 platform_post_install|Setting up the timezone|<:INFO>
01/24/2012 13:48:13 platform_post_install|Setting up environment profile|<:INFO>
01/24/2012 13:48:13 platform_post_install|Set up the environment variables in cli_product_hw.conf|<:INFO>
01/24/2012 13:48:13 platform_post_install|Configure write cache for IDE based servers|<:INFO>
01/24/2012 13:48:13 platform_post_install|Set up the serial console|<:INFO>
01/24/2012 13:48:14 platform_post_install|Move disk config file to platform config directory|<:INFO>
01/24/2012 13:48:14 platform_post_install|Copy /partB/usr/local/platform/conf/disk_config.txt to /usr/local/platform/conf|<:INFO>
01/24/2012 13:48:14 platform_post_install|Calling "cp /partB/usr/local/platform/conf/disk_config.txt /usr/local/platform/conf"|<:DEBUG>
01/24/2012 13:48:14 platform_post_install|Update /etc/rc.d/rc.sysinit|<:INFO>
01/24/2012 13:48:14 platform_post_install|Replacing /etc/rc.d/rc.sysinit|<:DEBUG>
01/24/2012 13:48:14 platform_post_install|Check hardware for nic_reverse service support|<:INFO>
01/24/2012 13:48:14 platform_post_install|Fix any IBM director agent issues|<:INFO>
01/24/2012 13:48:14 ServerApiManager|SAM_UPGRADE_HW_RPMS_AND_DEVS being called with [pre-reboot]|<:DEBUG>
01/24/2012 13:48:15 component_install|Initializing xproduct.sh API|<:DEBUG>
01/24/2012 13:48:15 component_install|Initializing xcomponent.sh API|<:DEBUG>
01/24/2012 13:48:15 component_install|Initializing xplatformconfig.sh API|<:DEBUG>
01/24/2012 13:48:15 component_install|Parse argument type=infrastructure|<:DEBUG>
01/24/2012 13:48:15 component_install|Parse argument mode=upgrade|<:DEBUG>
01/24/2012 13:48:15 component_install|Install infrastructure component, mode upgrade|<:INFO>
01/24/2012 13:48:15 component_install|Initialize product data, mode upgrade|<:INFO>
01/24/2012 13:48:15 component_install|Initialize "to" side product version|<:INFO>
01/24/2012 13:48:15 component_install|Access "to" side API|<:DEBUG>
01/24/2012 13:48:15 component_install|Got version 8.6.2.22900-9|<:DEBUG>
01/24/2012 13:48:15 component_install|Initialize "to" side product version complete|<:INFO>
01/24/2012 13:48:15 component_install|Initialize "from" side product version|<:INFO>
01/24/2012 13:48:15 component_install|Access "from" side API|<:DEBUG>
01/24/2012 13:48:15 component_install|Got version 8.6.2.20000-2|<:DEBUG>
01/24/2012 13:48:15 component_install|Initialize "from" side product version complete|<:INFO>
01/24/2012 13:48:15 component_install|Initialize product data complete|<:INFO>
01/24/2012 13:48:15 component_install|Initialize component data, mode upgrade|<:INFO>
01/24/2012 13:48:15 component_install|Initialize ucplatform "to" side version|<:INFO>
01/24/2012 13:48:15 component_install|Initialize ucplatform "to" side version complete|<:INFO>
01/24/2012 13:48:15 component_install|Initialize ucplatform "from" side version|<:INFO>
01/24/2012 13:48:15 component_install|Component ucplatform available on active side|<:DEBUG>
01/24/2012 13:48:15 component_install|Initialize ucplatform "from" side version complete|<:INFO>
01/24/2012 13:48:15 component_install|Initialize global data complete|<:INFO>
01/24/2012 13:48:15 component_install|Build the command list for ucplatform|<:INFO>
01/24/2012 13:48:15 component_install|Initialize command list|<:DEBUG>
01/24/2012 13:48:15 component_install|Build ucplatform install phase commands|<:DEBUG>
01/24/2012 13:48:15 component_install|Processing ucplatform install element|<:DEBUG>
01/24/2012 13:48:15 component_install|Processing ucplatform phase element|<:DEBUG>
01/24/2012 13:48:15 component_install|Processing ucplatform preinstall element|<:DEBUG>
01/24/2012 13:48:15 component_install|Processing ucplatform script element|<:DEBUG>
01/24/2012 13:48:15 component_install|Add "security_prepare L2 PreInstall 8.6.2.22900-9 8.6.2.20000-2 /usr/local/cm/ /partB/usr/local/cm/ /common/log/install/capture.txt" to command list|<:DEBUG>
01/24/2012 13:48:15 component_install|Add "product_prepare L2 PreInstall 8.6.2.22900-9 8.6.2.20000-2 /usr/local/cm/ /partB/usr/local/cm/ /common/log/install/capture.txt" to command list|<:DEBUG>
01/24/2012 13:48:15 component_install|Add "tomcat_prepare L2 PreInstall 8.6.2.22900-9 8.6.2.20000-2 /usr/local/cm/ /partB/usr/local/cm/ /common/log/install/capture.txt" to command list|<:DEBUG>
01/24/2012 13:48:16 component_install|Processing ucplatform package element|<:DEBUG>
01/24/2012 13:48:16 component_install|Checking if RPM /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-libs-1.0.0.0-1.i386.rpm exists|<:DEBUG>
01/24/2012 13:48:16 component_install|Add "rpm  -iv --replacefiles /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-libs-1.0.0.0-1.i386.rpm" to command list|<:DEBUG>
01/24/2012 13:48:16 component_install|Checking if RPM /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-preferences-1.0.1-8.i386.rpm exists|<:DEBUG>
01/24/2012 13:48:16 component_install|Add "rpm  -iv --replacefiles /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-preferences-1.0.1-8.i386.rpm" to command list|<:DEBUG>
01/24/2012 13:48:16 component_install|Checking if RPM /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-adminsftp-1.0.0.0-1.i386.rpm exists|<:DEBUG>
01/24/2012 13:48:16 component_install|Add "rpm  -iv --replacefiles /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-adminsftp-1.0.0.0-1.i386.rpm" to command list|<:DEBUG>
01/24/2012 13:48:16 component_install|Checking if RPM /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-ver-2.0.0.1-1.i386.rpm exists|<:DEBUG>
01/24/2012 13:48:16 component_install|Add "rpm  -iv --replacefiles /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-ver-2.0.0.1-1.i386.rpm" to command list|<:DEBUG>
01/24/2012 13:48:16 component_install|Checking if RPM /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-selinux-2.0.0.0-1.i386.rpm exists|<:DEBUG>
01/24/2012 13:48:16 component_install|Add "rpm  -iv --replacefiles /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-selinux-2.0.0.0-1.i386.rpm" to command list|<:DEBUG>
01/24/2012 13:48:16 component_install|Checking if RPM /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-ui-2.0.0.1-1.i386.rpm exists|<:DEBUG>
01/24/2012 13:48:16 component_install|Add "rpm  -iv --replacefiles /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-ui-2.0.0.1-1.i386.rpm" to command list|<:DEBUG>
01/24/2012 13:48:16 component_install|Checking if RPM /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-licensing-2.0.0.0-1.i386.rpm exists|<:DEBUG>
01/24/2012 13:48:16 component_install|Add "rpm  -iv --replacefiles /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-licensing-2.0.0.0-1.i386.rpm" to command list|<:DEBUG>
01/24/2012 13:48:16 component_install|Checking if RPM /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-drf-2.0.0.2-2.i386.rpm exists|<:DEBUG>
01/24/2012 13:48:16 component_install|Add "rpm  -iv --replacefiles /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-drf-2.0.0.2-2.i386.rpm" to command list|<:DEBUG>
01/24/2012 13:48:16 component_install|Checking if RPM /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-remotesupport-2.0.0.1-3.i386.rpm exists|<:DEBUG>
01/24/2012 13:48:17 component_install|Add "rpm  -iv --replacefiles /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-remotesupport-2.0.0.1-3.i386.rpm" to command list|<:DEBUG>
01/24/2012 13:48:17 component_install|Processing ucplatform package element|<:DEBUG>
01/24/2012 13:48:17 component_install|Checking if RPM /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-servM-2.0.0.1-1.i386.rpm exists|<:DEBUG>
01/24/2012 13:48:17 component_install|Add "rpm  -iv --replacefiles /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-servM-2.0.0.1-1.i386.rpm" to command list|<:DEBUG>
01/24/2012 13:48:17 component_install|Checking if RPM /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/service-registration-2.0.0.1-1.i386.rpm exists|<:DEBUG>
01/24/2012 13:48:17 component_install|Add "rpm  -iv --replacefiles /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/service-registration-2.0.0.1-1.i386.rpm" to command list|<:DEBUG>
01/24/2012 13:48:17 component_install|Checking if RPM /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-sec-2.0.0.1-1.i386.rpm exists|<:DEBUG>
01/24/2012 13:48:17 component_install|Add "rpm  -iv --replacefiles /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-sec-2.0.0.1-1.i386.rpm" to command list|<:DEBUG>
01/24/2012 13:48:17 component_install|Checking if RPM /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-cm-2.0.0.0-1.i386.rpm exists|<:DEBUG>
01/24/2012 13:48:17 component_install|Add "rpm  -iv --replacefiles /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-cm-2.0.0.0-1.i386.rpm" to command list|<:DEBUG>
01/24/2012 13:48:17 component_install|Checking if RPM /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-api-3.0.0.0-6.i386.rpm exists|<:DEBUG>
01/24/2012 13:48:17 component_install|Add "rpm  -iv --replacefiles /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-api-3.0.0.0-6.i386.rpm" to command list|<:DEBUG>
01/24/2012 13:48:17 component_install|Checking if RPM /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-util-2.0.0.1-1.i386.rpm exists|<:DEBUG>
01/24/2012 13:48:17 component_install|Add "rpm  -iv --replacefiles /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-util-2.0.0.1-1.i386.rpm" to command list|<:DEBUG>
01/24/2012 13:48:17 component_install|Checking if RPM /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/os-services-1.2-1.i386.rpm exists|<:DEBUG>
01/24/2012 13:48:17 component_install|Add "rpm  -iv --replacefiles /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/os-services-1.2-1.i386.rpm" to command list|<:DEBUG>
01/24/2012 13:48:18 component_install|Processing ucplatform package element|<:DEBUG>
01/24/2012 13:48:18 component_install|Checking if RPM /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/fiostats-0.99.2-4.i386.rpm exists|<:DEBUG>
01/24/2012 13:48:18 component_install|Add "rpm  -iv --replacefiles /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/fiostats-0.99.2-4.i386.rpm" to command list|<:DEBUG>
01/24/2012 13:48:18 component_install|Checking if RPM /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/fior-0.99.1-3.el5.i386.rpm exists|<:DEBUG>
01/24/2012 13:48:18 component_install|Add "rpm  -iv --replacefiles /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/fior-0.99.1-3.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 13:48:18 component_install|Checking if RPM /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-dbcfs-0.3-1.i386.rpm exists|<:DEBUG>
01/24/2012 13:48:18 component_install|Add "rpm  -iv --replacefiles /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-dbcfs-0.3-1.i386.rpm" to command list|<:DEBUG>
01/24/2012 13:48:18 component_install|Checking if RPM /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-tomcat-1.0.0.0-1.i386.rpm exists|<:DEBUG>
01/24/2012 13:48:18 component_install|Add "rpm  -iv --replacefiles /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-tomcat-1.0.0.0-1.i386.rpm" to command list|<:DEBUG>
01/24/2012 13:48:18 component_install|Checking if RPM /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/ucfips-selftest-1.0.0.0-1.i386.rpm exists|<:DEBUG>
01/24/2012 13:48:18 component_install|Add "rpm  -iv --replacefiles /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/ucfips-selftest-1.0.0.0-1.i386.rpm" to command list|<:DEBUG>
01/24/2012 13:48:18 component_install|Checking if RPM /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-fipsutil-1.0.0.0-1.i386.rpm exists|<:DEBUG>
01/24/2012 13:48:18 component_install|Add "rpm  -iv --replacefiles /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-fipsutil-1.0.0.0-1.i386.rpm" to command list|<:DEBUG>
01/24/2012 13:48:18 component_install|Checking if RPM /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-snmp-1.0.0.0-0.i386.rpm exists|<:DEBUG>
01/24/2012 13:48:18 component_install|Add "rpm  -iv --replacefiles /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-snmp-1.0.0.0-0.i386.rpm" to command list|<:DEBUG>
01/24/2012 13:48:18 component_install|Checking if RPM /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-tzdata-2012c-1.el5.i386.rpm exists|<:DEBUG>
01/24/2012 13:48:18 component_install|Add "rpm  -iv --replacefiles /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-tzdata-2012c-1.el5.i386.rpm" to command list|<:DEBUG>
01/24/2012 13:48:18 component_install|Checking if RPM /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-ipsec-1.0.0.0-1.i386.rpm exists|<:DEBUG>
01/24/2012 13:48:18 component_install|Add "rpm  -iv --replacefiles /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-ipsec-1.0.0.0-1.i386.rpm" to command list|<:DEBUG>
01/24/2012 13:48:18 component_install|Processing ucplatform phase element|<:DEBUG>
01/24/2012 13:48:18 component_install|Processing ucplatform migration element|<:DEBUG>
01/24/2012 13:48:19 component_install|Processing ucplatform script element|<:DEBUG>
01/24/2012 13:48:19 component_install|Add "security_prepare L2 Migration 8.6.2.22900-9 8.6.2.20000-2 /usr/local/cm/ /partB/usr/local/cm/ /common/log/install/capture.txt" to command list|<:DEBUG>
01/24/2012 13:48:19 component_install|Add "drf_migrate L2 Migration 8.6.2.22900-9 8.6.2.20000-2 /usr/local/cm/ /partB/usr/local/cm/ /common/log/install/capture.txt" to command list|<:DEBUG>
01/24/2012 13:48:19 component_install|Add "migrate_cli_configuration L2 Migration 8.6.2.22900-9 8.6.2.20000-2 /usr/local/cm/ /partB/usr/local/cm/ /common/log/install/capture.txt" to command list|<:DEBUG>
01/24/2012 13:48:19 component_install|Processing ucplatform phase element|<:DEBUG>
01/24/2012 13:48:19 component_install|Processing ucplatform import element|<:DEBUG>
01/24/2012 13:48:19 component_install|Processing ucplatform postinstall element|<:DEBUG>
01/24/2012 13:48:19 component_install|Add "security_postinstall L2 PostInstall 8.6.2.22900-9 8.6.2.20000-2 /usr/local/cm/ /partB/usr/local/cm/ /common/log/install/capture.txt" to command list|<:DEBUG>
01/24/2012 13:48:19 component_install|Add "/usr/local/bin/base_scripts/init_net_snmpd_conf.sh L2 PostInstall 8.6.2.22900-9 8.6.2.20000-2 /usr/local/cm/ /partB/usr/local/cm/ /common/log/install/capture.txt" to command list|<:DEBUG>
01/24/2012 13:48:19 component_install|Building the command list for ucplatform is complete|<:INFO>
01/24/2012 13:48:19 component_install|Command execution for ucplatform component RTMTStart|<:NOTICE>
01/24/2012 13:48:19 component_install|Execute commands in the command list for ucplatform component|<:INFO>
01/24/2012 13:48:19 component_install|Search path is /opt/cisco/install/ucplatform/scripts:/usr/local/cm/script|<:DEBUG>
01/24/2012 13:48:19 component_install|Checking command /opt/cisco/install/ucplatform/scripts/security_prepare|<:DEBUG>
01/24/2012 13:48:19 component_install|Execute "/opt/cisco/install/ucplatform/scripts/security_prepare L2 PreInstall 8.6.2.22900-9 8.6.2.20000-2 /usr/local/cm/ /partB/usr/local/cm/ /common/log/install/capture.txt"|<:DEBUG>
01/24/2012 18:48:20 security_prepare|Parse arguments|<:DEBUG>
01/24/2012 18:48:20 security_prepare|Validate arguments|<:DEBUG>
01/24/2012 18:48:20 security_prepare|Initialize global variables|<:DEBUG>
01/24/2012 18:48:20 security_prepare|Handle Security Information|<:DEBUG>
01/24/2012 18:48:20 security_prepare|Install security information|<:DEBUG>
01/24/2012 18:48:20 security_prepare|Create special directories|<:DEBUG>
01/24/2012 18:48:20 security_prepare|Create common links|<:DEBUG>
01/24/2012 18:48:20 security_prepare|Create special accounts|<:DEBUG>
01/24/2012 18:48:20 create_special_accounts.sh|Creating important user accounts/groups RTMTStart|<:NOTICE>
01/24/2012 18:48:20 create_special_accounts.sh|Create sftpuser group and account|<:INFO>
01/24/2012 18:48:20 create_special_accounts.sh|Successfully created sftpuser group|<:INFO>
01/24/2012 18:48:20 create_special_accounts.sh|Successfully created sftpuser account|<:INFO>
01/24/2012 18:48:20 create_special_accounts.sh|Create .ssh and the config file|<:INFO>
01/24/2012 18:48:20 create_special_accounts.sh|Create platform group and account|<:INFO>
01/24/2012 18:48:20 create_special_accounts.sh|Successfully created platform group|<:INFO>
01/24/2012 18:48:20 create_special_accounts.sh|Successfully created platform account|<:INFO>
01/24/2012 18:48:20 create_special_accounts.sh|Create tomcat group and account|<:INFO>
01/24/2012 18:48:20 create_special_accounts.sh|Successfully created tomcat group|<:INFO>
01/24/2012 18:48:20 create_special_accounts.sh|Successfully created tomcat account|<:INFO>
01/24/2012 18:48:20 create_special_accounts.sh|Create administrator group|<:INFO>
01/24/2012 18:48:20 create_special_accounts.sh|Successfully created administrator group|<:INFO>
01/24/2012 18:48:20 create_special_accounts.sh|Create drfkeys group|<:INFO>
01/24/2012 18:48:20 create_special_accounts.sh|Successfully created drfkeys group|<:INFO>
01/24/2012 18:48:20 create_special_accounts.sh|Create pwrecovery account|<:INFO>
01/24/2012 18:48:20 create_special_accounts.sh|Successfully created pwrecovery account|<:INFO>
01/24/2012 18:48:20 create_special_accounts.sh|Successfully updated sudoers file for pwrecovery|<:INFO>
01/24/2012 18:48:20 create_special_accounts.sh|Create servmgr account|<:INFO>
01/24/2012 18:48:20 create_special_accounts.sh|Successfully created servmgr account|<:INFO>
01/24/2012 18:48:20 create_special_accounts.sh|Create clm account  UID set to 590|<:INFO>
01/24/2012 18:48:20 create_special_accounts.sh|Successfully created clm account|<:INFO>
01/24/2012 18:48:20 create_special_accounts.sh|Create drf account|<:INFO>
01/24/2012 18:48:20 create_special_accounts.sh|Successfully created drf account|<:INFO>
01/24/2012 18:48:20 create_special_accounts.sh|Create licmgr account|<:INFO>
01/24/2012 18:48:20 create_special_accounts.sh|Successfully created licmgr account|<:INFO>
01/24/2012 18:48:20 create_special_accounts.sh|Create enotify account|<:INFO>
01/24/2012 18:48:20 create_special_accounts.sh|Successfully created enotify account|<:INFO>
01/24/2012 18:48:20 create_special_accounts.sh|Create certmgr account|<:INFO>
01/24/2012 18:48:20 create_special_accounts.sh|Successfully created certmgr account|<:INFO>
01/24/2012 18:48:20 create_special_accounts.sh|Create ipsecmgr account|<:INFO>
01/24/2012 18:48:20 create_special_accounts.sh|Successfully created ipsecmgr account|<:INFO>
01/24/2012 18:48:20 create_special_accounts.sh|Create drfuser account|<:INFO>
01/24/2012 18:48:20 create_special_accounts.sh|Successfully created drfuser account|<:INFO>
01/24/2012 18:48:20 create_special_accounts.sh|Create drfkeys account|<:INFO>
01/24/2012 18:48:20 create_special_accounts.sh|Successfully created drfkeys account|<:INFO>
01/24/2012 18:48:20 create_special_accounts.sh|Creating important user accounts/groups RTMTFinish|<:NOTICE>
01/24/2012 18:48:20 create_special_accounts.sh|Create ccmbase group and account|<:INFO>
01/24/2012 18:48:20 create_special_accounts.sh|Successfully created ccmbase group|<:INFO>
01/24/2012 18:48:20 create_special_accounts.sh|Successfully created ccmservice account|<:INFO>
01/24/2012 18:48:20 security_prepare|Add component sudoers|<:DEBUG>
01/24/2012 18:48:20 security_prepare|Create /etc/sudoers|<:DEBUG>
01/24/2012 18:48:20 security_prepare|Successfully updated sudoers file for pwrecovery|<:INFO>
01/24/2012 18:48:20 sudoers.sh|Add tomcat SFTP script execution to /etc/sudoers|<:DEBUG>
01/24/2012 18:48:20 sudoers.sh|Tomcat config setup RTMTStart|<:NOTICE>
01/24/2012 18:48:20 sudoers.sh|Add tomcat password change script execution to /etc/sudoers|<:DEBUG>
01/24/2012 18:48:20 sudoers.sh|Add tomcat Upgrade script execution to /etc/sudoers|<:DEBUG>
01/24/2012 18:48:20 sudoers.sh|Add tomcat admin script execution to /etc/sudoers|<:DEBUG>
01/24/2012 18:48:20 sudoers.sh|Add tomcat certificate management script execution to /etc/sudoers|<:DEBUG>
01/24/2012 18:48:20 sudoers.sh|Add tomcat IPsec management script execution to /etc/sudoers|<:DEBUG>
01/24/2012 18:48:20 sudoers.sh|Tomcat config setup RTMTFinish|<:NOTICE>
01/24/2012 18:48:20 sudoers.sh|Add tomcat console banner script execution to /etc/sudoers|<:DEBUG>
01/24/2012 18:48:20 security_prepare|Successfully updated sudoers file for tomcat|<:INFO>
01/24/2012 18:48:20 security_prepare|Successfully updated sudoers file for drf|<:INFO>
01/24/2012 18:48:20 security_prepare|Successfully updated sudoers file for ccmservice|<:INFO>
01/24/2012 18:48:20 security_prepare|Successfully updated sudoers file for clm|<:INFO>
01/24/2012 18:48:20 security_prepare|Add tomcat install settings|<:DEBUG>
01/24/2012 18:48:20 security_prepare|Perform general hardening|<:DEBUG>
01/24/2012 18:48:20 harden.sh|Disabling various keys/functions RTMTStart|<:NOTICE>
01/24/2012 18:48:20 harden.sh|Disabled CTRL-ALT-DELETE|<:INFO>
01/24/2012 18:48:20 harden.sh|The following line added in /etc/ssh/sshd_config|<:DEBUG>
01/24/2012 18:48:20 harden.sh|MACs hmac-sha1|<:DEBUG>
01/24/2012 18:48:20 harden.sh|/etc/ssh/sshd_config has a line for X11Forwarding|<:DEBUG>
01/24/2012 18:48:20 harden.sh|AllowTcpForwarding no|<:DEBUG>
01/24/2012 18:48:20 harden.sh|The following line was added in /etc/ssh/sshd_config|<:DEBUG>
01/24/2012 18:48:20 harden.sh|DenyUsers pwrecovery informix|<:DEBUG>
01/24/2012 18:48:20 harden.sh|The following lines was added in /etc/ssh/sshd_config|<:DEBUG>
01/24/2012 18:48:20 harden.sh|Match group administrator\n\tForceCommand /usr/local/platform/bin/cliscript.sh|<:DEBUG>
01/24/2012 18:48:20 harden.sh|Restricted single terminal for root|<:INFO>
01/24/2012 18:48:20 harden.sh|Disallow su to root|<:INFO>
01/24/2012 18:48:20 harden.sh|/etc/login.defs exists in the active partition. Copying the PASS_MIN_LEN to maintain password complexity over upgrades|<:INFO>
01/24/2012 18:48:20 harden.sh|Acquired the required value from the active side: -6-|<:INFO>
01/24/2012 18:48:20 harden.sh|Changed minimum password length to 6|<:INFO>
01/24/2012 18:48:20 harden.sh|Changed maximum password days to 99999|<:INFO>
01/24/2012 18:48:20 harden.sh|/etc/security/opasswd exists in the active partition. Copying the file to maintain password remembered over upgrades|<:INFO>
01/24/2012 18:48:20 harden.sh|/etc/pam.d/system-auth exists in the active partition. Not touching it as it will be copied by upgrade os to maintain data over upgrades|<:INFO>
01/24/2012 18:48:20 harden.sh|Modified LoginGraceTime to be LoginGraceTime 600|<:DEBUG>
01/24/2012 18:48:20 harden.sh|/etc/ssh/sshd_config has access rights of -rw-r--r--|<:DEBUG>
01/24/2012 18:48:20 harden.sh|/etc/pam.d/system-auth file exists|<:DEBUG>
01/24/2012 18:48:20 harden.sh|Removed try_first_pass from /etc/pam.d/system-auth|<:DEBUG>
01/24/2012 18:48:20 harden.sh|VIM_CONF_FILE file exists|<:DEBUG>
01/24/2012 18:48:20 harden.sh|Removed the tmpid entry from from /etc/profile.d/vim.sh|<:DEBUG>
01/24/2012 18:48:20 harden.sh|Disabling various keys/functions RTMTFinish|<:NOTICE>
01/24/2012 18:48:20 security_prepare|Successfully performed general hardening|<:INFO>
01/24/2012 18:48:20 security_prepare|Add IP table rules|<:DEBUG>
01/24/2012 18:48:21 security_prepare|Generate SFTP Keys|<:DEBUG>
01/24/2012 18:48:21 security_prepare|Execute upgrade product extensions|<:DEBUG>
01/24/2012 18:48:23 product_extensions|No ucm extensions found for security_sd_upgrade.sh.  Continuing normally.|<:INFO>
01/24/2012 18:48:23 security_prepare|security information prepare successful|<:INFO>
01/24/2012 13:48:23 component_install|Search path is /opt/cisco/install/ucplatform/scripts:/usr/local/cm/script|<:DEBUG>
01/24/2012 13:48:23 component_install|Checking command /opt/cisco/install/ucplatform/scripts/product_prepare|<:DEBUG>
01/24/2012 13:48:23 component_install|Execute "/opt/cisco/install/ucplatform/scripts/product_prepare L2 PreInstall 8.6.2.22900-9 8.6.2.20000-2 /usr/local/cm/ /partB/usr/local/cm/ /common/log/install/capture.txt"|<:DEBUG>
01/24/2012 18:48:24 product_prepare|Parse arguments|<:DEBUG>
01/24/2012 18:48:24 product_prepare|Validate arguments|<:DEBUG>
01/24/2012 18:48:24 product_prepare|Operation Mode: upgrade|<:DEBUG>
01/24/2012 18:48:24 product_prepare|Create CCM accounts|<:DEBUG>
01/24/2012 18:48:24 create_ccm_accounts.sh|CCM Account creation RTMTStart|<:NOTICE>
01/24/2012 18:48:24 create_ccm_accounts.sh|Create CCM account and group information|<:INFO>
01/24/2012 18:48:24 create_usergrp_accnt.sh|Create other CCM accounts RTMTStart|<:NOTICE>
01/24/2012 18:48:24 create_usergrp_accnt.sh|Create application accounts.|<:INFO>
01/24/2012 18:48:24 create_usergrp_accnt.sh|*******************************************************|<:INFO>
01/24/2012 18:48:24 create_usergrp_accnt.sh||<:INFO>
01/24/2012 18:48:24 create_usergrp_accnt.sh|Group platform already exists|<:INFO>
01/24/2012 18:48:24 create_usergrp_accnt.sh|Account directory set to /dev/null|<:INFO>
01/24/2012 18:48:24 create_usergrp_accnt.sh|Account already exists for : servmgr|<:INFO>
01/24/2012 18:48:24 create_usergrp_accnt.sh|Successfully added servmgr to group sftpuser|<:INFO>
01/24/2012 18:48:24 create_usergrp_accnt.sh|Successfully added sftpuser to group platform|<:INFO>
01/24/2012 18:48:24 create_usergrp_accnt.sh|User servmgr added to /etc/sudoers User_Alias SFTPUSER list|<:INFO>
01/24/2012 18:48:24 create_usergrp_accnt.sh|Account already exists for : drf|<:INFO>
01/24/2012 18:48:24 create_usergrp_accnt.sh|Successfully added drf to group sftpuser|<:INFO>
01/24/2012 18:48:24 create_usergrp_accnt.sh|User drf added to /etc/sudoers User_Alias SFTPUSER list|<:INFO>
01/24/2012 18:48:24 create_usergrp_accnt.sh|Group ccmbase already exists|<:INFO>
01/24/2012 18:48:24 create_usergrp_accnt.sh|Create account : ccmbase|<:INFO>
01/24/2012 18:48:24 create_usergrp_accnt.sh|Created account: ccmbase|<:INFO>
01/24/2012 18:48:24 create_usergrp_accnt.sh|Successfully added ccmbase to group sftpuser|<:INFO>
01/24/2012 18:48:24 create_usergrp_accnt.sh|Successfully added sftpuser to group ccmbase|<:INFO>
01/24/2012 18:48:24 create_usergrp_accnt.sh|User ccmbase added to /etc/sudoers User_Alias SFTPUSER list|<:INFO>
01/24/2012 18:48:24 create_usergrp_accnt.sh|Create account : cdp|<:INFO>
01/24/2012 18:48:24 create_usergrp_accnt.sh|Created account: cdp|<:INFO>
01/24/2012 18:48:24 create_usergrp_accnt.sh|Successfully added cdp to group sftpuser|<:INFO>
01/24/2012 18:48:24 create_usergrp_accnt.sh|User cdp added to /etc/sudoers User_Alias SFTPUSER list|<:INFO>
01/24/2012 18:48:24 create_usergrp_accnt.sh|Create account : database|<:INFO>
01/24/2012 18:48:24 create_usergrp_accnt.sh|Created account: database|<:INFO>
01/24/2012 18:48:24 create_usergrp_accnt.sh|Successfully added database to group sftpuser|<:INFO>
01/24/2012 18:48:24 create_usergrp_accnt.sh|User database added to /etc/sudoers User_Alias SFTPUSER list|<:INFO>
01/24/2012 18:48:24 create_usergrp_accnt.sh|Create account : certbase|<:INFO>
01/24/2012 18:48:24 create_usergrp_accnt.sh|Created account: certbase|<:INFO>
01/24/2012 18:48:24 create_usergrp_accnt.sh|Successfully added certbase to group sftpuser|<:INFO>
01/24/2012 18:48:24 create_usergrp_accnt.sh|User certbase added to /etc/sudoers User_Alias SFTPUSER list|<:INFO>
01/24/2012 18:48:24 create_usergrp_accnt.sh|Create account : ctftp|<:INFO>
01/24/2012 18:48:24 create_usergrp_accnt.sh|Created account: ctftp|<:INFO>
01/24/2012 18:48:24 create_usergrp_accnt.sh|Successfully added ctftp to group sftpuser|<:INFO>
01/24/2012 18:48:24 create_usergrp_accnt.sh|User ctftp added to /etc/sudoers User_Alias SFTPUSER list|<:INFO>
01/24/2012 18:48:24 create_usergrp_accnt.sh|Create account : lpm|<:INFO>
01/24/2012 18:48:24 create_usergrp_accnt.sh|Created account: lpm|<:INFO>
01/24/2012 18:48:24 create_usergrp_accnt.sh|Successfully added lpm to group sftpuser|<:INFO>
01/24/2012 18:48:25 create_usergrp_accnt.sh|User lpm added to /etc/sudoers User_Alias SFTPUSER list|<:INFO>
01/24/2012 18:48:25 create_usergrp_accnt.sh|*******************************************************|<:INFO>
01/24/2012 18:48:25 create_usergrp_accnt.sh||<:INFO>
01/24/2012 18:48:25 create_usergrp_accnt.sh|Created group: certuser|<:INFO>
01/24/2012 18:48:25 create_usergrp_accnt.sh|Account directory set to /dev/null|<:INFO>
01/24/2012 18:48:25 create_usergrp_accnt.sh|Create account : certuser|<:INFO>
01/24/2012 18:48:25 create_usergrp_accnt.sh|Created account: certuser|<:INFO>
01/24/2012 18:48:25 create_usergrp_accnt.sh|Created group: tomcatmgr|<:INFO>
01/24/2012 18:48:25 create_usergrp_accnt.sh|Create account : tomcatmgr|<:INFO>
01/24/2012 18:48:25 create_usergrp_accnt.sh|Created account: tomcatmgr|<:INFO>
01/24/2012 18:48:25 create_usergrp_accnt.sh|Created group: ccmsyslog|<:INFO>
01/24/2012 18:48:25 create_usergrp_accnt.sh|Create account : ccmsyslog|<:INFO>
01/24/2012 18:48:25 create_usergrp_accnt.sh|Created account: ccmsyslog|<:INFO>
01/24/2012 18:48:25 create_usergrp_accnt.sh|Created group: dbuser|<:INFO>
01/24/2012 18:48:25 create_usergrp_accnt.sh|Create account : dbuser|<:INFO>
01/24/2012 18:48:25 create_usergrp_accnt.sh|Created account: dbuser|<:INFO>
01/24/2012 18:48:25 create_usergrp_accnt.sh|Created group: dbccm|<:INFO>
01/24/2012 18:48:25 create_usergrp_accnt.sh|Create account : dbccm|<:INFO>
01/24/2012 18:48:25 create_usergrp_accnt.sh|Created account: dbccm|<:INFO>
01/24/2012 18:48:25 create_usergrp_accnt.sh|Created group: dbtftp|<:INFO>
01/24/2012 18:48:25 create_usergrp_accnt.sh|Create account : dbtftp|<:INFO>
01/24/2012 18:48:25 create_usergrp_accnt.sh|Created account: dbtftp|<:INFO>
01/24/2012 18:48:25 create_usergrp_accnt.sh|Created group: dbcmi|<:INFO>
01/24/2012 18:48:25 create_usergrp_accnt.sh|Create account : dbcmi|<:INFO>
01/24/2012 18:48:25 create_usergrp_accnt.sh|Created account: dbcmi|<:INFO>
01/24/2012 18:48:25 create_usergrp_accnt.sh|Created group: dbipvms|<:INFO>
01/24/2012 18:48:25 create_usergrp_accnt.sh|Create account : dbipvms|<:INFO>
01/24/2012 18:48:25 create_usergrp_accnt.sh|Created account: dbipvms|<:INFO>
01/24/2012 18:48:25 create_usergrp_accnt.sh|Created group: dbacserver|<:INFO>
01/24/2012 18:48:25 create_usergrp_accnt.sh|Create account : dbacserver|<:INFO>
01/24/2012 18:48:25 create_usergrp_accnt.sh|Created account: dbacserver|<:INFO>
01/24/2012 18:48:25 create_usergrp_accnt.sh|Created group: dbmon|<:INFO>
01/24/2012 18:48:25 create_usergrp_accnt.sh|Create account : dbmon|<:INFO>
01/24/2012 18:48:25 create_usergrp_accnt.sh|Created account: dbmon|<:INFO>
01/24/2012 18:48:25 create_usergrp_accnt.sh|Created group: dbent|<:INFO>
01/24/2012 18:48:25 create_usergrp_accnt.sh|Create account : dbent|<:INFO>
01/24/2012 18:48:25 create_usergrp_accnt.sh|Created account: dbent|<:INFO>
01/24/2012 18:48:25 create_usergrp_accnt.sh|Created group: dbcti|<:INFO>
01/24/2012 18:48:25 create_usergrp_accnt.sh|Create account : dbcti|<:INFO>
01/24/2012 18:48:25 create_usergrp_accnt.sh|Created account: dbcti|<:INFO>
01/24/2012 18:48:25 create_usergrp_accnt.sh|Created group: dbris|<:INFO>
01/24/2012 18:48:25 create_usergrp_accnt.sh|Create account : dbris|<:INFO>
01/24/2012 18:48:25 create_usergrp_accnt.sh|Created account: dbris|<:INFO>
01/24/2012 18:48:26 create_usergrp_accnt.sh|*******************************************************|<:INFO>
01/24/2012 18:48:26 create_usergrp_accnt.sh||<:INFO>
01/24/2012 18:48:26 create_usergrp_accnt.sh|Created group: dbcapf|<:INFO>
01/24/2012 18:48:26 create_usergrp_accnt.sh|Account directory set to /dev/null|<:INFO>
01/24/2012 18:48:26 create_usergrp_accnt.sh|Create account : dbcapf|<:INFO>
01/24/2012 18:48:26 create_usergrp_accnt.sh|Created account: dbcapf|<:INFO>
01/24/2012 18:48:26 create_usergrp_accnt.sh|Created group: dblpm|<:INFO>
01/24/2012 18:48:26 create_usergrp_accnt.sh|Create account : dblpm|<:INFO>
01/24/2012 18:48:26 create_usergrp_accnt.sh|Created account: dblpm|<:INFO>
01/24/2012 18:48:26 create_usergrp_accnt.sh|Created group: dbmibagt|<:INFO>
01/24/2012 18:48:26 create_usergrp_accnt.sh|Create account : dbmibagt|<:INFO>
01/24/2012 18:48:26 create_usergrp_accnt.sh|Created account: dbmibagt|<:INFO>
01/24/2012 18:48:26 create_usergrp_accnt.sh|Created group: dbipma|<:INFO>
01/24/2012 18:48:26 create_usergrp_accnt.sh|Create account : dbipma|<:INFO>
01/24/2012 18:48:26 create_usergrp_accnt.sh|Created account: dbipma|<:INFO>
01/24/2012 18:48:26 create_usergrp_accnt.sh|Created group: dbcef|<:INFO>
01/24/2012 18:48:26 create_usergrp_accnt.sh|Create account : dbcef|<:INFO>
01/24/2012 18:48:26 create_usergrp_accnt.sh|Created account: dbcef|<:INFO>
01/24/2012 18:48:26 create_usergrp_accnt.sh|Created group: dbbps|<:INFO>
01/24/2012 18:48:26 create_usergrp_accnt.sh|Create account : dbbps|<:INFO>
01/24/2012 18:48:26 create_usergrp_accnt.sh|Created account: dbbps|<:INFO>
01/24/2012 18:48:26 create_usergrp_accnt.sh|Created group: dbamc|<:INFO>
01/24/2012 18:48:26 create_usergrp_accnt.sh|Create account : dbamc|<:INFO>
01/24/2012 18:48:26 create_usergrp_accnt.sh|Created account: dbamc|<:INFO>
01/24/2012 18:48:26 create_usergrp_accnt.sh|Created group: dbemweb|<:INFO>
01/24/2012 18:48:26 create_usergrp_accnt.sh|Create account : dbemweb|<:INFO>
01/24/2012 18:48:26 create_usergrp_accnt.sh|Created account: dbemweb|<:INFO>
01/24/2012 18:48:26 create_usergrp_accnt.sh|Created group: dbcarsch|<:INFO>
01/24/2012 18:48:26 create_usergrp_accnt.sh|Create account : dbcarsch|<:INFO>
01/24/2012 18:48:26 create_usergrp_accnt.sh|Created account: dbcarsch|<:INFO>
01/24/2012 18:48:26 create_usergrp_accnt.sh|Created group: dbadminweb|<:INFO>
01/24/2012 18:48:26 create_usergrp_accnt.sh|Create account : dbadminweb|<:INFO>
01/24/2012 18:48:26 create_usergrp_accnt.sh|Created account: dbadminweb|<:INFO>
01/24/2012 18:48:26 create_usergrp_accnt.sh|Created group: dbaxlweb|<:INFO>
01/24/2012 18:48:26 create_usergrp_accnt.sh|Create account : dbaxlweb|<:INFO>
01/24/2012 18:48:26 create_usergrp_accnt.sh|Created account: dbaxlweb|<:INFO>
01/24/2012 18:48:26 create_usergrp_accnt.sh|Created group: dbcarweb|<:INFO>
01/24/2012 18:48:26 create_usergrp_accnt.sh|Create account : dbcarweb|<:INFO>
01/24/2012 18:48:26 create_usergrp_accnt.sh|Created account: dbcarweb|<:INFO>
01/24/2012 18:48:26 create_usergrp_accnt.sh|Created group: dbdblweb|<:INFO>
01/24/2012 18:48:26 create_usergrp_accnt.sh|Create account : dbdblweb|<:INFO>
01/24/2012 18:48:26 create_usergrp_accnt.sh|Created account: dbdblweb|<:INFO>
01/24/2012 18:48:26 create_usergrp_accnt.sh|Created group: dbserviceweb|<:INFO>
01/24/2012 18:48:26 create_usergrp_accnt.sh|Create account : dbserviceweb|<:INFO>
01/24/2012 18:48:26 create_usergrp_accnt.sh|Created account: dbserviceweb|<:INFO>
01/24/2012 18:48:26 create_usergrp_accnt.sh|Created group: dbncsweb|<:INFO>
01/24/2012 18:48:26 create_usergrp_accnt.sh|Create account : dbncsweb|<:INFO>
01/24/2012 18:48:26 create_usergrp_accnt.sh|Created account: dbncsweb|<:INFO>
01/24/2012 18:48:27 create_usergrp_accnt.sh|Created group: dbpdweb|<:INFO>
01/24/2012 18:48:27 create_usergrp_accnt.sh|Account directory set to /dev/null|<:INFO>
01/24/2012 18:48:27 create_usergrp_accnt.sh|Create account : dbpdweb|<:INFO>
01/24/2012 18:48:27 create_usergrp_accnt.sh|Created account: dbpdweb|<:INFO>
01/24/2012 18:48:27 create_usergrp_accnt.sh|*******************************************************|<:INFO>
01/24/2012 18:48:27 create_usergrp_accnt.sh||<:INFO>
01/24/2012 18:48:27 create_usergrp_accnt.sh|Created group: dbrolesecurity|<:INFO>
01/24/2012 18:48:27 create_usergrp_accnt.sh|Create account : dbrolesecurity|<:INFO>
01/24/2012 18:48:27 create_usergrp_accnt.sh|Created account: dbrolesecurity|<:INFO>
01/24/2012 18:48:27 create_usergrp_accnt.sh|Created group: dbrealmweb|<:INFO>
01/24/2012 18:48:27 create_usergrp_accnt.sh|Create account : dbrealmweb|<:INFO>
01/24/2012 18:48:27 create_usergrp_accnt.sh|Created account: dbrealmweb|<:INFO>
01/24/2012 18:48:27 create_usergrp_accnt.sh|Created group: dbrtmtweb|<:INFO>
01/24/2012 18:48:27 create_usergrp_accnt.sh|Create account : dbrtmtweb|<:INFO>
01/24/2012 18:48:27 create_usergrp_accnt.sh|Created account: dbrtmtweb|<:INFO>
01/24/2012 18:48:27 create_usergrp_accnt.sh|Created group: dbwebdialerweb|<:INFO>
01/24/2012 18:48:27 create_usergrp_accnt.sh|Create account : dbwebdialerweb|<:INFO>
01/24/2012 18:48:27 create_usergrp_accnt.sh|Created account: dbwebdialerweb|<:INFO>
01/24/2012 18:48:27 create_usergrp_accnt.sh|Created group: dbsoapweb|<:INFO>
01/24/2012 18:48:27 create_usergrp_accnt.sh|Create account : dbsoapweb|<:INFO>
01/24/2012 18:48:27 create_usergrp_accnt.sh|Created account: dbsoapweb|<:INFO>
01/24/2012 18:48:27 create_usergrp_accnt.sh|Created group: dbcdrondemand|<:INFO>
01/24/2012 18:48:27 create_usergrp_accnt.sh|Create account : dbcdrondemand|<:INFO>
01/24/2012 18:48:27 create_usergrp_accnt.sh|Created account: dbcdrondemand|<:INFO>
01/24/2012 18:48:27 create_usergrp_accnt.sh|Created group: dbcdragent|<:INFO>
01/24/2012 18:48:27 create_usergrp_accnt.sh|Create account : dbcdragent|<:INFO>
01/24/2012 18:48:27 create_usergrp_accnt.sh|Created account: dbcdragent|<:INFO>
01/24/2012 18:48:27 create_usergrp_accnt.sh|Created group: dbcdrrep|<:INFO>
01/24/2012 18:48:27 create_usergrp_accnt.sh|Create account : dbcdrrep|<:INFO>
01/24/2012 18:48:27 create_usergrp_accnt.sh|Created account: dbcdrrep|<:INFO>
01/24/2012 18:48:27 create_usergrp_accnt.sh|Created group: dbctlprovider|<:INFO>
01/24/2012 18:48:27 create_usergrp_accnt.sh|Create account : dbctlprovider|<:INFO>
01/24/2012 18:48:27 create_usergrp_accnt.sh|Created account: dbctlprovider|<:INFO>
01/24/2012 18:48:27 create_usergrp_accnt.sh|Created group: dbcsa|<:INFO>
01/24/2012 18:48:27 create_usergrp_accnt.sh|Create account : dbcsa|<:INFO>
01/24/2012 18:48:27 create_usergrp_accnt.sh|Created account: dbcsa|<:INFO>
01/24/2012 18:48:27 create_usergrp_accnt.sh|Created group: dbtomcat|<:INFO>
01/24/2012 18:48:27 create_usergrp_accnt.sh|Create account : dbtomcat|<:INFO>
01/24/2012 18:48:28 create_usergrp_accnt.sh|Created account: dbtomcat|<:INFO>
01/24/2012 18:48:28 create_usergrp_accnt.sh|*******************************************************|<:INFO>
01/24/2012 18:48:28 create_usergrp_accnt.sh||<:INFO>
01/24/2012 18:48:28 create_usergrp_accnt.sh|Created group: dbdhcp|<:INFO>
01/24/2012 18:48:28 create_usergrp_accnt.sh|Account directory set to /dev/null|<:INFO>
01/24/2012 18:48:28 create_usergrp_accnt.sh|Create account : dbdhcp|<:INFO>
01/24/2012 18:48:28 create_usergrp_accnt.sh|Created account: dbdhcp|<:INFO>
01/24/2012 18:48:28 create_usergrp_accnt.sh|Created group: dbdna|<:INFO>
01/24/2012 18:48:28 create_usergrp_accnt.sh|Create account : dbdna|<:INFO>
01/24/2012 18:48:28 create_usergrp_accnt.sh|Created account: dbdna|<:INFO>
01/24/2012 18:48:28 create_usergrp_accnt.sh|Created group: dbdirsync|<:INFO>
01/24/2012 18:48:28 create_usergrp_accnt.sh|Create account : dbdirsync|<:INFO>
01/24/2012 18:48:28 create_usergrp_accnt.sh|Created account: dbdirsync|<:INFO>
01/24/2012 18:48:28 create_usergrp_accnt.sh|Created group: dbdrfmaster|<:INFO>
01/24/2012 18:48:28 create_usergrp_accnt.sh|Create account : dbdrfmaster|<:INFO>
01/24/2012 18:48:28 create_usergrp_accnt.sh|Created account: dbdrfmaster|<:INFO>
01/24/2012 18:48:28 create_usergrp_accnt.sh|Created group: dbdrflocal|<:INFO>
01/24/2012 18:48:28 create_usergrp_accnt.sh|Create account : dbdrflocal|<:INFO>
01/24/2012 18:48:28 create_usergrp_accnt.sh|Created account: dbdrflocal|<:INFO>
01/24/2012 18:48:28 create_usergrp_accnt.sh|Created group: dbemapp|<:INFO>
01/24/2012 18:48:28 create_usergrp_accnt.sh|Create account : dbemapp|<:INFO>
01/24/2012 18:48:28 create_usergrp_accnt.sh|Created account: dbemapp|<:INFO>
01/24/2012 18:48:28 create_usergrp_accnt.sh|Created group: dblicense|<:INFO>
01/24/2012 18:48:28 create_usergrp_accnt.sh|Create account : dblicense|<:INFO>
01/24/2012 18:48:28 create_usergrp_accnt.sh|Created account: dblicense|<:INFO>
01/24/2012 18:48:28 create_usergrp_accnt.sh|Created group: dbrtmt|<:INFO>
01/24/2012 18:48:28 create_usergrp_accnt.sh|Create account : dbrtmt|<:INFO>
01/24/2012 18:48:28 create_usergrp_accnt.sh|Created account: dbrtmt|<:INFO>
01/24/2012 18:48:28 create_usergrp_accnt.sh|Created group: dbtaps|<:INFO>
01/24/2012 18:48:28 create_usergrp_accnt.sh|Create account : dbtaps|<:INFO>
01/24/2012 18:48:28 create_usergrp_accnt.sh|Created account: dbtaps|<:INFO>
01/24/2012 18:48:28 create_usergrp_accnt.sh|Created group: dbtracecoll|<:INFO>
01/24/2012 18:48:28 create_usergrp_accnt.sh|Create account : dbtracecoll|<:INFO>
01/24/2012 18:48:28 create_usergrp_accnt.sh|Created account: dbtracecoll|<:INFO>
01/24/2012 18:48:28 create_usergrp_accnt.sh|Created group: dbipphone|<:INFO>
01/24/2012 18:48:28 create_usergrp_accnt.sh|Create account : dbipphone|<:INFO>
01/24/2012 18:48:28 create_usergrp_accnt.sh|Created account: dbipphone|<:INFO>
01/24/2012 18:48:28 create_usergrp_accnt.sh|Created group: dbcli|<:INFO>
01/24/2012 18:48:28 create_usergrp_accnt.sh|Create account : dbcli|<:INFO>
01/24/2012 18:48:28 create_usergrp_accnt.sh|Created account: dbcli|<:INFO>
01/24/2012 18:48:28 create_usergrp_accnt.sh|Created group: dbims|<:INFO>
01/24/2012 18:48:28 create_usergrp_accnt.sh|Create account : dbims|<:INFO>
01/24/2012 18:48:28 create_usergrp_accnt.sh|Created account: dbims|<:INFO>
01/24/2012 18:48:28 create_usergrp_accnt.sh|Created group: dbuserweb|<:INFO>
01/24/2012 18:48:28 create_usergrp_accnt.sh|Create account : dbuserweb|<:INFO>
01/24/2012 18:48:28 create_usergrp_accnt.sh|Created account: dbuserweb|<:INFO>
01/24/2012 18:48:28 create_usergrp_accnt.sh|Created group: dblog4j|<:INFO>
01/24/2012 18:48:29 create_usergrp_accnt.sh|Account directory set to /dev/null|<:INFO>
01/24/2012 18:48:29 create_usergrp_accnt.sh|Create account : dblog4j|<:INFO>
01/24/2012 18:48:29 create_usergrp_accnt.sh|Created account: dblog4j|<:INFO>
01/24/2012 18:48:29 create_usergrp_accnt.sh|*******************************************************|<:INFO>
01/24/2012 18:48:29 create_usergrp_accnt.sh||<:INFO>
01/24/2012 18:48:29 create_usergrp_accnt.sh|Created group: dbcuc|<:INFO>
01/24/2012 18:48:29 create_usergrp_accnt.sh|Create account : dbcuc|<:INFO>
01/24/2012 18:48:29 create_usergrp_accnt.sh|Created account: dbcuc|<:INFO>
01/24/2012 18:48:29 create_usergrp_accnt.sh|Created group: dbsyslog|<:INFO>
01/24/2012 18:48:29 create_usergrp_accnt.sh|Create account : dbsyslog|<:INFO>
01/24/2012 18:48:29 create_usergrp_accnt.sh|Created account: dbsyslog|<:INFO>
01/24/2012 18:48:29 create_usergrp_accnt.sh|Created group: dbccmivr|<:INFO>
01/24/2012 18:48:29 create_usergrp_accnt.sh|Create account : dbccmivr|<:INFO>
01/24/2012 18:48:29 create_usergrp_accnt.sh|Created account: dbccmivr|<:INFO>
01/24/2012 18:48:29 create_usergrp_accnt.sh|Created group: dbdbl|<:INFO>
01/24/2012 18:48:29 create_usergrp_accnt.sh|Create account : dbdbl|<:INFO>
01/24/2012 18:48:29 create_usergrp_accnt.sh|Created account: dbdbl|<:INFO>
01/24/2012 18:48:29 create_usergrp_accnt.sh|Created group: dbidp|<:INFO>
01/24/2012 18:48:29 create_usergrp_accnt.sh|Create account : dbidp|<:INFO>
01/24/2012 18:48:29 create_usergrp_accnt.sh|Created account: dbidp|<:INFO>
01/24/2012 18:48:29 create_usergrp_accnt.sh|Created group: dbcipc|<:INFO>
01/24/2012 18:48:29 create_usergrp_accnt.sh|Create account : dbcipc|<:INFO>
01/24/2012 18:48:29 create_usergrp_accnt.sh|Created account: dbcipc|<:INFO>
01/24/2012 18:48:29 create_usergrp_accnt.sh|Created group: dbauditlog|<:INFO>
01/24/2012 18:48:29 create_usergrp_accnt.sh|Create account : dbauditlog|<:INFO>
01/24/2012 18:48:29 create_usergrp_accnt.sh|Created account: dbauditlog|<:INFO>
01/24/2012 18:48:29 create_usergrp_accnt.sh|Created group: dbtvs|<:INFO>
01/24/2012 18:48:29 create_usergrp_accnt.sh|Create account : dbtvs|<:INFO>
01/24/2012 18:48:29 create_usergrp_accnt.sh|Created account: dbtvs|<:INFO>
01/24/2012 18:48:29 create_usergrp_accnt.sh|Created group: dbcertmgr|<:INFO>
01/24/2012 18:48:29 create_usergrp_accnt.sh|Create account : dbcertmgr|<:INFO>
01/24/2012 18:48:29 create_usergrp_accnt.sh|Created account: dbcertmgr|<:INFO>
01/24/2012 18:48:29 create_usergrp_accnt.sh|Created group: dbdptemplate|<:INFO>
01/24/2012 18:48:29 create_usergrp_accnt.sh|Create account : dbdptemplate|<:INFO>
01/24/2012 18:48:29 create_usergrp_accnt.sh|Created account: dbdptemplate|<:INFO>
01/24/2012 18:48:29 create_usergrp_accnt.sh|******************************************|<:INFO>
01/24/2012 18:48:29 create_usergrp_accnt.sh|Successfully created application accounts.|<:INFO>
01/24/2012 18:48:29 create_usergrp_accnt.sh|Adding group members.|<:INFO>
01/24/2012 18:48:29 create_usergrp_accnt.sh|****************************************************|<:INFO>
01/24/2012 18:48:29 create_usergrp_accnt.sh|Adding Members: tomcat to group: ccmbase|<:INFO>
01/24/2012 18:48:29 create_usergrp_accnt.sh|Adding tomcat to group ccmbase|<:INFO>
01/24/2012 18:48:29 create_usergrp_accnt.sh|Creating directory /var/log/active/cm, if not already present|<:INFO>
01/24/2012 18:48:29 create_usergrp_accnt.sh|Setting group permissions to 777 on /var/log/active/cm|<:INFO>
01/24/2012 18:48:29 create_usergrp_accnt.sh|SFTP IN is SET :appending WX to group permissions|<:INFO>
01/24/2012 18:48:29 create_usergrp_accnt.sh|SFTP OUT is SET :appending RX to group permissions|<:INFO>
01/24/2012 18:48:29 create_usergrp_accnt.sh|Adding sftpuser to group ccmbase|<:INFO>
01/24/2012 18:48:29 create_usergrp_accnt.sh|Unsetting OTHER RWX permissions on /var/log/active/cm|<:INFO>
01/24/2012 18:48:29 create_usergrp_accnt.sh|Creating directory /var/log/active/platform/log, if not already present|<:INFO>
01/24/2012 18:48:29 create_usergrp_accnt.sh|Setting group permissions to 777 on /var/log/active/platform/log|<:INFO>
01/24/2012 18:48:29 create_usergrp_accnt.sh|Unsetting OTHER RWX permissions on /var/log/active/platform/log|<:INFO>
01/24/2012 18:48:29 create_usergrp_accnt.sh|Creating directory /var/log/active/cm/trace, if not already present|<:INFO>
01/24/2012 18:48:29 create_usergrp_accnt.sh|Setting group permissions to 770 on /var/log/active/cm/trace|<:INFO>
01/24/2012 18:48:29 create_usergrp_accnt.sh|Unsetting OTHER RWX permissions on /var/log/active/cm/trace|<:INFO>
01/24/2012 18:48:29 create_usergrp_accnt.sh|Creating directory /var/log/active/cm/log, if not already present|<:INFO>
01/24/2012 18:48:29 create_usergrp_accnt.sh|Setting group permissions to 770 on /var/log/active/cm/log|<:INFO>
01/24/2012 18:48:29 create_usergrp_accnt.sh|Unsetting OTHER RWX permissions on /var/log/active/cm/log|<:INFO>
01/24/2012 18:48:29 create_usergrp_accnt.sh|Creating directory /var/log/active/cm/report, if not already present|<:INFO>
01/24/2012 18:48:29 create_usergrp_accnt.sh|Setting group permissions to 770 on /var/log/active/cm/report|<:INFO>
01/24/2012 18:48:29 create_usergrp_accnt.sh|Unsetting OTHER RWX permissions on /var/log/active/cm/report|<:INFO>
01/24/2012 18:48:29 create_usergrp_accnt.sh|Creating directory /usr/local/cm, if not already present|<:INFO>
01/24/2012 18:48:29 create_usergrp_accnt.sh|Setting group permissions to 775 on /usr/local/cm|<:INFO>
01/24/2012 18:48:30 create_usergrp_accnt.sh|Unsetting OTHER RWX permissions on /usr/local/cm|<:INFO>
01/24/2012 18:48:30 create_usergrp_accnt.sh||<:INFO>
01/24/2012 18:48:30 create_usergrp_accnt.sh|Creating directory /usr/local/cm/bin, if not already present|<:INFO>
01/24/2012 18:48:30 create_usergrp_accnt.sh|Setting group permissions to 775 on /usr/local/cm/bin|<:INFO>
01/24/2012 18:48:30 create_usergrp_accnt.sh|Unsetting OTHER RWX permissions on /usr/local/cm/bin|<:INFO>
01/24/2012 18:48:30 create_usergrp_accnt.sh|Creating directory /usr/local/cm/conf, if not already present|<:INFO>
01/24/2012 18:48:30 create_usergrp_accnt.sh|Setting group permissions to 777 on /usr/local/cm/conf|<:INFO>
01/24/2012 18:48:30 create_usergrp_accnt.sh|Unsetting OTHER RWX permissions on /usr/local/cm/conf|<:INFO>
01/24/2012 18:48:30 create_usergrp_accnt.sh|****************************************************|<:INFO>
01/24/2012 18:48:30 create_usergrp_accnt.sh|Adding Members: ctftp to group: ccmbase|<:INFO>
01/24/2012 18:48:30 create_usergrp_accnt.sh|Adding ctftp to group ccmbase|<:INFO>
01/24/2012 18:48:30 create_usergrp_accnt.sh|Creating directory /var/log/active/cm/tftpdata, if not already present|<:INFO>
01/24/2012 18:48:30 create_usergrp_accnt.sh|Setting group permissions to 644 on /var/log/active/cm/tftpdata|<:INFO>
01/24/2012 18:48:30 create_usergrp_accnt.sh|Unsetting OTHER RWX permissions on /var/log/active/cm/tftpdata|<:INFO>
01/24/2012 18:48:30 create_usergrp_accnt.sh|Adding Members: ccmbase,cdp,servmgr,ccmservice, database, informix, certbase, ctftp, lpm, drf, licmgr, certmgr to group: tomcat|<:INFO>
01/24/2012 18:48:30 create_usergrp_accnt.sh|Adding ccmbase to group tomcat|<:INFO>
01/24/2012 18:48:30 create_usergrp_accnt.sh|Adding cdp to group tomcat|<:INFO>
01/24/2012 18:48:30 create_usergrp_accnt.sh|Adding servmgr to group tomcat|<:INFO>
01/24/2012 18:48:30 create_usergrp_accnt.sh|Adding ccmservice to group tomcat|<:INFO>
01/24/2012 18:48:30 create_usergrp_accnt.sh|Adding database to group tomcat|<:INFO>
01/24/2012 18:48:30 create_usergrp_accnt.sh|Adding informix to group tomcat|<:INFO>
01/24/2012 18:48:30 create_usergrp_accnt.sh|Adding certbase to group tomcat|<:INFO>
01/24/2012 18:48:30 create_usergrp_accnt.sh|Adding ctftp to group tomcat|<:INFO>
01/24/2012 18:48:30 create_usergrp_accnt.sh|Adding lpm to group tomcat|<:INFO>
01/24/2012 18:48:30 create_usergrp_accnt.sh|Adding drf to group tomcat|<:INFO>
01/24/2012 18:48:30 create_usergrp_accnt.sh|Adding licmgr to group tomcat|<:INFO>
01/24/2012 18:48:30 create_usergrp_accnt.sh|Adding certmgr to group tomcat|<:INFO>
01/24/2012 18:48:30 create_usergrp_accnt.sh|Creating directory /usr/local/thirdparty/jakarta-tomcat, if not already present|<:INFO>
01/24/2012 18:48:30 create_usergrp_accnt.sh|Setting group permissions to 777 on /usr/local/thirdparty/jakarta-tomcat|<:INFO>
01/24/2012 18:48:30 create_usergrp_accnt.sh|SFTP IN is SET :appending WX to group permissions|<:INFO>
01/24/2012 18:48:30 create_usergrp_accnt.sh|SFTP OUT is SET :appending RX to group permissions|<:INFO>
01/24/2012 18:48:30 create_usergrp_accnt.sh|Adding sftpuser to group tomcat|<:INFO>
01/24/2012 18:48:30 create_usergrp_accnt.sh|Unsetting OTHER RWX permissions on /usr/local/thirdparty/jakarta-tomcat|<:INFO>
01/24/2012 18:48:30 create_usergrp_accnt.sh|Adding Members: informix,dbuser,dbccm,dbtftp,dbcmi,dbipvms,dbacserver, dbmon,dbent, dbcti, dbris, dbcapf, dblpm,dbmibagt,dbipma,dbcef,dbbps, dbamc, dbemweb, dbcarsch,dbadminweb, dbaxlweb,dbcarweb,dbdblweb,dbserviceweb,dbncsweb,dbpdweb, dbrolesecurity,dbrealmweb,dbrtmtweb,dbwebdialerweb,dbsoapweb,dbcdrondemand,dbcdragent,dbcdrrep, dbctlprovider,dbcsa,dbtomcat, dbdhcp,dbdna,dbdirsync,dbdrfmaster,dbdrflocal,dbemapp, dblicense, dbrtmt,dbtaps,dbtracecoll,dbipphone,dbcli,dbims,dbuserweb,dblog4j,dbcuc,dbsyslog,dbccmivr,dbdbl,dbidp,dbcipc,dbauditlog,dbtvs,dbcertmgr,dbdptemplate to group: ccmbase|<:INFO>
01/24/2012 18:48:30 create_usergrp_accnt.sh|Adding informix to group ccmbase|<:INFO>
01/24/2012 18:48:30 create_usergrp_accnt.sh|Adding dbuser to group ccmbase|<:INFO>
01/24/2012 18:48:30 create_usergrp_accnt.sh|Adding dbccm to group ccmbase|<:INFO>
01/24/2012 18:48:30 create_usergrp_accnt.sh|Adding dbtftp to group ccmbase|<:INFO>
01/24/2012 18:48:30 create_usergrp_accnt.sh|Adding dbcmi to group ccmbase|<:INFO>
01/24/2012 18:48:30 create_usergrp_accnt.sh|Adding dbipvms to group ccmbase|<:INFO>
01/24/2012 18:48:30 create_usergrp_accnt.sh|Adding dbacserver to group ccmbase|<:INFO>
01/24/2012 18:48:30 create_usergrp_accnt.sh|Adding dbmon to group ccmbase|<:INFO>
01/24/2012 18:48:30 create_usergrp_accnt.sh|Adding dbent to group ccmbase|<:INFO>
01/24/2012 18:48:30 create_usergrp_accnt.sh|Adding dbcti to group ccmbase|<:INFO>
01/24/2012 18:48:30 create_usergrp_accnt.sh|Adding dbris to group ccmbase|<:INFO>
01/24/2012 18:48:30 create_usergrp_accnt.sh|Adding dbcapf to group ccmbase|<:INFO>
01/24/2012 18:48:31 create_usergrp_accnt.sh|Adding dblpm to group ccmbase|<:INFO>
01/24/2012 18:48:31 create_usergrp_accnt.sh|Adding dbmibagt to group ccmbase|<:INFO>
01/24/2012 18:48:31 create_usergrp_accnt.sh|Adding dbipma to group ccmbase|<:INFO>
01/24/2012 18:48:31 create_usergrp_accnt.sh|Adding dbcef to group ccmbase|<:INFO>
01/24/2012 18:48:31 create_usergrp_accnt.sh|Adding dbbps to group ccmbase|<:INFO>
01/24/2012 18:48:31 create_usergrp_accnt.sh|Adding dbamc to group ccmbase|<:INFO>
01/24/2012 18:48:31 create_usergrp_accnt.sh|Adding dbemweb to group ccmbase|<:INFO>
01/24/2012 18:48:31 create_usergrp_accnt.sh|Adding dbcarsch to group ccmbase|<:INFO>
01/24/2012 18:48:31 create_usergrp_accnt.sh|Adding dbadminweb to group ccmbase|<:INFO>
01/24/2012 18:48:31 create_usergrp_accnt.sh|Adding dbaxlweb to group ccmbase|<:INFO>
01/24/2012 18:48:31 create_usergrp_accnt.sh|Adding dbcarweb to group ccmbase|<:INFO>
01/24/2012 18:48:31 create_usergrp_accnt.sh|Adding dbdblweb to group ccmbase|<:INFO>
01/24/2012 18:48:31 create_usergrp_accnt.sh|Adding dbserviceweb to group ccmbase|<:INFO>
01/24/2012 18:48:31 create_usergrp_accnt.sh|Adding dbncsweb to group ccmbase|<:INFO>
01/24/2012 18:48:31 create_usergrp_accnt.sh|Adding dbpdweb to group ccmbase|<:INFO>
01/24/2012 18:48:31 create_usergrp_accnt.sh|Adding dbrolesecurity to group ccmbase|<:INFO>
01/24/2012 18:48:31 create_usergrp_accnt.sh|Adding dbrealmweb to group ccmbase|<:INFO>
01/24/2012 18:48:31 create_usergrp_accnt.sh|Adding dbrtmtweb to group ccmbase|<:INFO>
01/24/2012 18:48:31 create_usergrp_accnt.sh|Adding dbwebdialerweb to group ccmbase|<:INFO>
01/24/2012 18:48:31 create_usergrp_accnt.sh|Adding dbsoapweb to group ccmbase|<:INFO>
01/24/2012 18:48:31 create_usergrp_accnt.sh|Adding dbcdrondemand to group ccmbase|<:INFO>
01/24/2012 18:48:31 create_usergrp_accnt.sh|Adding dbcdragent to group ccmbase|<:INFO>
01/24/2012 18:48:31 create_usergrp_accnt.sh|Adding dbcdrrep to group ccmbase|<:INFO>
01/24/2012 18:48:31 create_usergrp_accnt.sh|Adding dbctlprovider to group ccmbase|<:INFO>
01/24/2012 18:48:31 create_usergrp_accnt.sh|Adding dbcsa to group ccmbase|<:INFO>
01/24/2012 18:48:31 create_usergrp_accnt.sh|Adding dbtomcat to group ccmbase|<:INFO>
01/24/2012 18:48:31 create_usergrp_accnt.sh|Adding dbdhcp to group ccmbase|<:INFO>
01/24/2012 18:48:31 create_usergrp_accnt.sh|Adding dbdna to group ccmbase|<:INFO>
01/24/2012 18:48:31 create_usergrp_accnt.sh|Adding dbdirsync to group ccmbase|<:INFO>
01/24/2012 18:48:31 create_usergrp_accnt.sh|Adding dbdrfmaster to group ccmbase|<:INFO>
01/24/2012 18:48:31 create_usergrp_accnt.sh|Adding dbdrflocal to group ccmbase|<:INFO>
01/24/2012 18:48:31 create_usergrp_accnt.sh|Adding dbemapp to group ccmbase|<:INFO>
01/24/2012 18:48:31 create_usergrp_accnt.sh|Adding dblicense to group ccmbase|<:INFO>
01/24/2012 18:48:31 create_usergrp_accnt.sh|Adding dbrtmt to group ccmbase|<:INFO>
01/24/2012 18:48:31 create_usergrp_accnt.sh|Adding dbtaps to group ccmbase|<:INFO>
01/24/2012 18:48:31 create_usergrp_accnt.sh|Adding dbtracecoll to group ccmbase|<:INFO>
01/24/2012 18:48:31 create_usergrp_accnt.sh|Adding dbipphone to group ccmbase|<:INFO>
01/24/2012 18:48:31 create_usergrp_accnt.sh|Adding dbcli to group ccmbase|<:INFO>
01/24/2012 18:48:31 create_usergrp_accnt.sh|Adding dbims to group ccmbase|<:INFO>
01/24/2012 18:48:31 create_usergrp_accnt.sh|Adding web to group ccmbase|<:INFO>
01/24/2012 18:48:32 create_usergrp_accnt.sh|Adding dblog4j to group ccmbase|<:INFO>
01/24/2012 18:48:32 create_usergrp_accnt.sh|Adding dbcuc to group ccmbase|<:INFO>
01/24/2012 18:48:32 create_usergrp_accnt.sh|Adding dbsyslog to group ccmbase|<:INFO>
01/24/2012 18:48:32 create_usergrp_accnt.sh|Adding ivr to group ccmbase|<:INFO>
01/24/2012 18:48:32 create_usergrp_accnt.sh|Adding dbdbl to group ccmbase|<:INFO>
01/24/2012 18:48:32 create_usergrp_accnt.sh|Adding dbidp to group ccmbase|<:INFO>
01/24/2012 18:48:32 create_usergrp_accnt.sh|Adding dbcipc to group ccmbase|<:INFO>
01/24/2012 18:48:32 create_usergrp_accnt.sh|Adding dbauditlog to group ccmbase|<:INFO>
01/24/2012 18:48:32 create_usergrp_accnt.sh|Adding dbtvs to group ccmbase|<:INFO>
01/24/2012 18:48:32 create_usergrp_accnt.sh|Adding dbcertmgr to group ccmbase|<:INFO>
01/24/2012 18:48:32 create_usergrp_accnt.sh|Adding dbdptemplate to group ccmbase|<:INFO>
01/24/2012 18:48:32 create_usergrp_accnt.sh||<:INFO>
01/24/2012 18:48:32 create_usergrp_accnt.sh|Creating directory /usr/local/cm, if not already present|<:INFO>
01/24/2012 18:48:32 create_usergrp_accnt.sh|Setting group permissions to 775 on /usr/local/cm|<:INFO>
01/24/2012 18:48:32 create_usergrp_accnt.sh|SFTP IN is SET :appending WX to group permissions|<:INFO>
01/24/2012 18:48:32 create_usergrp_accnt.sh|SFTP OUT is SET :appending RX to group permissions|<:INFO>
01/24/2012 18:48:32 create_usergrp_accnt.sh|Adding sftpuser to group ccmbase|<:INFO>
01/24/2012 18:48:32 create_usergrp_accnt.sh|Unsetting OTHER RWX permissions on /usr/local/cm|<:INFO>
01/24/2012 18:48:32 create_usergrp_accnt.sh|****************************************************|<:INFO>
01/24/2012 18:48:32 create_usergrp_accnt.sh|Adding Members: servmgr,drf, licmgr, enotify, certmgr to group: ccmbase|<:INFO>
01/24/2012 18:48:32 create_usergrp_accnt.sh|Adding servmgr to group ccmbase|<:INFO>
01/24/2012 18:48:32 create_usergrp_accnt.sh|Adding drf to group ccmbase|<:INFO>
01/24/2012 18:48:32 create_usergrp_accnt.sh|Adding licmgr to group ccmbase|<:INFO>
01/24/2012 18:48:32 create_usergrp_accnt.sh|Adding enotify to group ccmbase|<:INFO>
01/24/2012 18:48:32 create_usergrp_accnt.sh|Adding certmgr to group ccmbase|<:INFO>
01/24/2012 18:48:32 create_usergrp_accnt.sh|Adding Members: certbase,ccmbase to group: certuser|<:INFO>
01/24/2012 18:48:32 create_usergrp_accnt.sh|Adding certbase to group certuser|<:INFO>
01/24/2012 18:48:32 create_usergrp_accnt.sh|Adding ccmbase to group certuser|<:INFO>
01/24/2012 18:48:32 create_usergrp_accnt.sh|Creating directory /usr/local/cm/.security/certs, if not already present|<:INFO>
01/24/2012 18:48:32 create_usergrp_accnt.sh|Setting group permissions to 770 on /usr/local/cm/.security/certs|<:INFO>
01/24/2012 18:48:32 create_usergrp_accnt.sh|Unsetting OTHER RWX permissions on /usr/local/cm/.security/certs|<:INFO>
01/24/2012 18:48:32 create_usergrp_accnt.sh|Creating directory /usr/local/cm/.security/keys, if not already present|<:INFO>
01/24/2012 18:48:32 create_usergrp_accnt.sh|Setting group permissions to 770 on /usr/local/cm/.security/keys|<:INFO>
01/24/2012 18:48:32 create_usergrp_accnt.sh|Unsetting OTHER RWX permissions on /usr/local/cm/.security/keys|<:INFO>
01/24/2012 18:48:32 create_usergrp_accnt.sh|Adding Members: servmgr to group: tomcatmgr|<:INFO>
01/24/2012 18:48:32 create_usergrp_accnt.sh|Adding servmgr to group tomcatmgr|<:INFO>
01/24/2012 18:48:32 create_usergrp_accnt.sh|Adding Members: lpm,tomcat,drf,licmgr, ccmservice,sftpuser,ccmbase to group: ccmsyslog|<:INFO>
01/24/2012 18:48:32 create_usergrp_accnt.sh|Adding lpm to group ccmsyslog|<:INFO>
01/24/2012 18:48:32 create_usergrp_accnt.sh|Adding tomcat to group ccmsyslog|<:INFO>
01/24/2012 18:48:32 create_usergrp_accnt.sh|Adding drf to group ccmsyslog|<:INFO>
01/24/2012 18:48:32 create_usergrp_accnt.sh|Adding licmgr to group ccmsyslog|<:INFO>
01/24/2012 18:48:32 create_usergrp_accnt.sh|Adding ccmservice to group ccmsyslog|<:INFO>
01/24/2012 18:48:32 create_usergrp_accnt.sh|Adding sftpuser to group ccmsyslog|<:INFO>
01/24/2012 18:48:32 create_usergrp_accnt.sh|Adding ccmbase to group ccmsyslog|<:INFO>
01/24/2012 18:48:32 create_usergrp_accnt.sh|Creating directory /var/log/active/syslog, if not already present|<:INFO>
01/24/2012 18:48:32 create_usergrp_accnt.sh|Setting group permissions to 770 on /var/log/active/syslog|<:INFO>
01/24/2012 18:48:32 create_usergrp_accnt.sh|Unsetting OTHER RWX permissions on /var/log/active/syslog|<:INFO>
01/24/2012 18:48:32 create_usergrp_accnt.sh|Adding Members: ccmbase,cdp,ccmservice,database,certbase,ctftp,lpm,informix to group: platform|<:INFO>
01/24/2012 18:48:32 create_usergrp_accnt.sh|Adding ccmbase to group platform|<:INFO>
01/24/2012 18:48:32 create_usergrp_accnt.sh|Adding cdp to group platform|<:INFO>
01/24/2012 18:48:32 create_usergrp_accnt.sh|Adding ccmservice to group platform|<:INFO>
01/24/2012 18:48:32 create_usergrp_accnt.sh|Adding database to group platform|<:INFO>
01/24/2012 18:48:32 create_usergrp_accnt.sh|Adding certbase to group platform|<:INFO>
01/24/2012 18:48:33 create_usergrp_accnt.sh|Adding ctftp to group platform|<:INFO>
01/24/2012 18:48:33 create_usergrp_accnt.sh|Adding lpm to group platform|<:INFO>
01/24/2012 18:48:33 create_usergrp_accnt.sh|Adding informix to group platform|<:INFO>
01/24/2012 18:48:33 create_usergrp_accnt.sh|****************************************************|<:INFO>
01/24/2012 18:48:33 create_usergrp_accnt.sh|Adding Members: licmgr to group: sftpuser|<:INFO>
01/24/2012 18:48:33 create_usergrp_accnt.sh||<:INFO>
01/24/2012 18:48:33 create_usergrp_accnt.sh|Adding licmgr to group sftpuser|<:INFO>
01/24/2012 18:48:33 create_usergrp_accnt.sh|Adding Members: licmgr to group: administrator|<:INFO>
01/24/2012 18:48:33 create_usergrp_accnt.sh|Adding licmgr to group administrator|<:INFO>
01/24/2012 18:48:33 create_usergrp_accnt.sh|Adding Members: lpm,tomcat,ccmservice,sftpuser to group: informix|<:INFO>
01/24/2012 18:48:33 create_usergrp_accnt.sh|Adding lpm to group informix|<:INFO>
01/24/2012 18:48:33 create_usergrp_accnt.sh|Adding tomcat to group informix|<:INFO>
01/24/2012 18:48:33 create_usergrp_accnt.sh|Adding ccmservice to group informix|<:INFO>
01/24/2012 18:48:33 create_usergrp_accnt.sh|Adding sftpuser to group informix|<:INFO>
01/24/2012 18:48:33 create_usergrp_accnt.sh|*********************************************|<:INFO>
01/24/2012 18:48:33 create_usergrp_accnt.sh|Successfully added group members|<:INFO>
01/24/2012 18:48:33 create_usergrp_accnt.sh|Changing world permissions on directories|<:INFO>
01/24/2012 18:48:33 create_ccm_accounts.sh|Successfully created CCM account and group information|<:INFO>
01/24/2012 18:48:33 create_ccm_accounts.sh|CCM Account creation RTMTFinish|<:NOTICE>
01/24/2012 18:48:33 product_prepare|Setup tomcat support|<:DEBUG>
01/24/2012 18:48:33 product_prepare|Copy /root/.security/tomcat/catalina.policy.source to /usr/local/thirdparty/jakarta-tomcat/conf/catalina.policy|<:DEBUG>
01/24/2012 18:48:33 product_prepare|Copy /root/.security/tomcat/catalina.sh.source to /usr/local/thirdparty/jakarta-tomcat/bin/catalina.sh|<:DEBUG>
01/24/2012 18:48:33 product_prepare|Copy /root/.security/tomcat/tomcat_security_startup.sh to /home/tomcat|<:DEBUG>
01/24/2012 18:48:33 product_prepare|Copy /root/.security/tomcat/tomcat_diagnostics.sh to /home/tomcat|<:DEBUG>
01/24/2012 18:48:33 product_prepare|Update syslog info|<:DEBUG>
01/24/2012 18:48:33 product_prepare|mkdir -p /var/log/active/syslog|<:DEBUG>
01/24/2012 18:48:33 product_prepare|chmod 770 /var/log/active/syslog|<:DEBUG>
01/24/2012 18:48:33 product_prepare|touch /var/log/active/syslog/boot.log|<:DEBUG>
01/24/2012 18:48:33 product_prepare|touch /var/log/active/syslog/CallManager|<:DEBUG>
01/24/2012 18:48:33 product_prepare|touch /var/log/active/syslog/cron|<:DEBUG>
01/24/2012 18:48:33 product_prepare|touch /var/log/active/syslog/maillog|<:DEBUG>
01/24/2012 18:48:33 product_prepare|touch /var/log/active/syslog/messages|<:DEBUG>
01/24/2012 18:48:33 product_prepare|touch /var/log/active/syslog/secure|<:DEBUG>
01/24/2012 18:48:33 product_prepare|touch /var/log/active/syslog/spooler|<:DEBUG>
01/24/2012 18:48:33 product_prepare|touch /var/log/active/syslog/.|<:DEBUG>
01/24/2012 18:48:33 product_prepare|touch /var/log/active/syslog/..|<:DEBUG>
01/24/2012 18:48:33 product_prepare|chown -R root:ccmsyslog /var/log/active/syslog|<:DEBUG>
01/24/2012 18:48:33 product_prepare|total 32
drwxrwxrwx 6 ccmbase ccmbase   4096 Jan 24 18:48 cm
drwxr-xr-x 2 root    root      4096 Jan 24 18:48 patches
drwxr-xr-x 3 root    root      4096 Jan 24 18:48 platform
drwxrwx--- 2 root    ccmsyslog 4096 Jan 24 18:48 syslog
total 44
drwxrwx--- 2 root ccmsyslog 4096 Jan 24 18:48 .
drwxrwxrwt 6 root root      4096 Jan 24 18:48 ..
-rw-r--r-- 1 root ccmsyslog    0 Jan 24 18:48 boot.log
-rw-r--r-- 1 root ccmsyslog    0 Jan 24 18:48 CallManager
-rw-r--r-- 1 root ccmsyslog    0 Jan 24 18:48 cron
-rw-r--r-- 1 root ccmsyslog    0 Jan 24 18:48 maillog
-rw-r--r-- 1 root ccmsyslog    0 Jan 24 18:48 messages
-rw-r--r-- 1 root ccmsyslog    0 Jan 24 18:48 secure
-rw-r--r-- 1 root ccmsyslog    0 Jan 24 18:48 spooler|<:DEBUG>
01/24/2012 18:48:33 product_prepare|Calling /root/.security/system/upgrade_syslog_details.sh|<:DEBUG>
01/24/2012 18:48:33 product_prepare|Updating logrotate information for syslog files|<:DEBUG>
01/24/2012 18:48:33 product_prepare|Updating logrotate information for mgetty files|<:DEBUG>
01/24/2012 18:48:33 product_prepare|Modified Log Level to be debug 2|<:DEBUG>
01/24/2012 18:48:33 product_prepare|Adding logrotate_wrapper to /etc/cron.hourly|<:DEBUG>
01/24/2012 18:48:33 product_prepare|Update syslog.conf for /var/log/active/platform/log/authenticateFile.log log file|<:DEBUG>
01/24/2012 18:48:33 product_prepare|Redirect core files|<:DEBUG>
01/24/2012 18:48:33 product_prepare|Update cm permissions and ownerships|<:DEBUG>
01/24/2012 18:48:33 set_dev_permissions|device=ttyS*|<:DEBUG>
01/24/2012 18:48:33 set_dev_permissions|group=ccmbase|<:DEBUG>
01/24/2012 18:48:33 set_dev_permissions|perms=0660|<:DEBUG>
01/24/2012 18:48:33 set_dev_permissions|Updating /etc/udev/rules.d/75-cisco.rules for ttyS*|<:DEBUG>
01/24/2012 18:48:33 set_dev_permissions|device=ttyUSB*|<:DEBUG>
01/24/2012 18:48:33 set_dev_permissions|Updating /etc/udev/rules.d/75-cisco.rules for ttyUSB*|<:DEBUG>
01/24/2012 18:48:33 product_prepare|Update sudoers with product sudoers|<:DEBUG>
01/24/2012 18:48:33 product_prepare|Create /etc/sysctl.conf|<:DEBUG>
01/24/2012 18:48:33 product_prepare|Setting kernel tunables|<:INFO>
01/24/2012 18:48:33 product_prepare|Change ipconntrack_max from (131072) to (131072)|<:DEBUG>
01/24/2012 18:48:33 product_prepare|Setup product profiel for servm|<:DEBUG>
01/24/2012 18:48:34 product_prepare|Setting up auditd|<:INFO>
01/24/2012 18:48:34 product_prepare|Creating vos audit directory|<:INFO>
01/24/2012 18:48:34 product_prepare|Activating setgid on auditd|<:INFO>
01/24/2012 18:48:34 product_prepare|Copying auditd configuation to /etc/audit|<:INFO>
01/24/2012 18:48:34 product_prepare|Copying hosts.allow and hosts.deny to /etc during auditd setup|<:INFO>
01/24/2012 18:48:34 product_prepare|Modify sudoers environment for correct sudo behaviour|<:INFO>
01/24/2012 18:48:34 product_prepare|Modify sudoers environment complete|<:INFO>
01/24/2012 18:48:36 product_extensions|No ucm extensions found for product_sd_install.sh.  Continuing normally.|<:INFO>
01/24/2012 13:48:36 component_install|Search path is /opt/cisco/install/ucplatform/scripts:/usr/local/cm/script|<:DEBUG>
01/24/2012 13:48:36 component_install|Checking command /opt/cisco/install/ucplatform/scripts/tomcat_prepare|<:DEBUG>
01/24/2012 13:48:36 component_install|Execute "/opt/cisco/install/ucplatform/scripts/tomcat_prepare L2 PreInstall 8.6.2.22900-9 8.6.2.20000-2 /usr/local/cm/ /partB/usr/local/cm/ /common/log/install/capture.txt"|<:DEBUG>
01/24/2012 18:48:36 tomcat_prepare|Parse arguments|<:DEBUG>
01/24/2012 18:48:36 tomcat_prepare|Validate arguments|<:DEBUG>
01/24/2012 18:48:36 tomcat_prepare|Operation Mode: upgrade|<:DEBUG>
01/24/2012 18:48:36 tomcat_prepare|Reset tomcat log directory|<:DEBUG>
01/24/2012 18:48:36 tomcat_prepare|Set tomcat permissions and ownerships|<:DEBUG>
01/24/2012 18:48:36 tomcat_prepare|Set permissions /var/log/active/tomcat/logs during install|<:DEBUG>
01/24/2012 18:48:36 tomcat_prepare|BEGIN Setting permissions tomcat directory and files during install|<:DEBUG>
01/24/2012 18:48:36 tomcat_prepare|END Setting permissions tomcat directory and files during install|<:DEBUG>
01/24/2012 18:48:36 tomcat_prepare|Setup Cisco ICON|<:DEBUG>
01/24/2012 18:48:36 tomcat_prepare|Setup robots.txt file|<:DEBUG>
01/24/2012 18:48:36 tomcat_prepare|Setup accessible tomcat symbolic links|<:DEBUG>
01/24/2012 18:48:36 tomcat_prepare|Remove unnecessary webapps|<:DEBUG>
01/24/2012 18:48:36 tomcat_prepare|Hardening permission of tomcat config files|<:INFO>
01/24/2012 13:48:36 component_install|Execute "rpm  -iv --replacefiles /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-libs-1.0.0.0-1.i386.rpm"|<:DEBUG>
01/24/2012 13:48:36 component_install|Execute "rpm  -iv --replacefiles /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-preferences-1.0.1-8.i386.rpm"|<:DEBUG>
01/24/2012 13:48:37 component_install|Execute "rpm  -iv --replacefiles /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-adminsftp-1.0.0.0-1.i386.rpm"|<:DEBUG>
01/24/2012 13:48:37 component_install|Execute "rpm  -iv --replacefiles /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-ver-2.0.0.1-1.i386.rpm"|<:DEBUG>
01/24/2012 13:48:37 component_install|Execute "rpm  -iv --replacefiles /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-selinux-2.0.0.0-1.i386.rpm"|<:DEBUG>
01/24/2012 13:48:37 component_install|Execute "rpm  -iv --replacefiles /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-ui-2.0.0.1-1.i386.rpm"|<:DEBUG>
01/24/2012 13:48:38 component_install|Execute "rpm  -iv --replacefiles /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-licensing-2.0.0.0-1.i386.rpm"|<:DEBUG>
01/24/2012 13:48:38 component_install|Execute "rpm  -iv --replacefiles /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-drf-2.0.0.2-2.i386.rpm"|<:DEBUG>
01/24/2012 13:48:39 component_install|Execute "rpm  -iv --replacefiles /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-remotesupport-2.0.0.1-3.i386.rpm"|<:DEBUG>
01/24/2012 13:48:39 component_install|Execute "rpm  -iv --replacefiles /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-servM-2.0.0.1-1.i386.rpm"|<:DEBUG>
01/24/2012 13:48:39 component_install|Execute "rpm  -iv --replacefiles /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/service-registration-2.0.0.1-1.i386.rpm"|<:DEBUG>
01/24/2012 13:48:40 component_install|Execute "rpm  -iv --replacefiles /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-sec-2.0.0.1-1.i386.rpm"|<:DEBUG>
01/24/2012 13:48:40 GEN003080|Successfully changed the permission of /etc/cron.d/sysstat|<:DEBUG>
01/24/2012 13:48:40 GEN003080|Successfully changed the permission of /etc/crontab|<:DEBUG>
01/24/2012 13:48:40 GEN003080|Successfully changed the permission of /etc/cron.deny|<:DEBUG>
01/24/2012 13:48:40 GEN003080|Permissions for /etc/cron.hourly/logrotate_wrapper already set to 700|<:INFO>
01/24/2012 13:48:40 GEN003080|Successfully changed the permission of /etc/cron.hourly/remotesupport.cron|<:DEBUG>
01/24/2012 13:48:40 GEN003080|Permissions for /etc/cron.daily/adminsftpwatch already set to 700|<:INFO>
01/24/2012 13:48:40 GEN003080|Permissions for /etc/cron.daily/ia_cron_daily already set to 700|<:INFO>
01/24/2012 13:48:40 GEN003080|Successfully changed the permission of /etc/cron.daily/logrotate|<:DEBUG>
01/24/2012 13:48:40 GEN003080|Successfully changed the permission of /etc/cron.daily/rpm|<:DEBUG>
01/24/2012 13:48:40 GEN003080|Successfully changed the permission of /etc/cron.daily/tmpwatch|<:DEBUG>
01/24/2012 13:48:40 GEN003520| /var/crash is already owned by root|<:INFO>
01/24/2012 13:48:40 GEN003520| /var/crash is already owned by group root|<:INFO>
01/24/2012 13:48:40 GEN003520|/var/crash is more permissive than 700.|<:INFO>
01/24/2012 13:48:40 GEN004000|Executing GEN004000|<:INFO>
01/24/2012 13:48:40 GEN004000|Successfully change permission for /bin/traceroute|<:DEBUG>
01/24/2012 13:48:40 GEN004820|Executing GEN004820|<:INFO>
01/24/2012 13:48:40 GEN004820|Removing user ftp|<:DEBUG>
01/24/2012 13:48:40 GEN004820|Successfully deleted user ftp|<:INFO>
01/24/2012 13:48:40 GEN004820|Removing user operator|<:DEBUG>
01/24/2012 13:48:41 GEN004820|Successfully deleted user operator|<:INFO>
01/24/2012 13:48:41 GEN004820|Removing user mail|<:DEBUG>
01/24/2012 13:48:41 GEN004820|Successfully deleted user mail|<:INFO>
01/24/2012 13:48:41 GEN004820|Removing user lp|<:DEBUG>
01/24/2012 13:48:41 GEN004820|Successfully deleted user lp|<:INFO>
01/24/2012 13:48:41 GEN004820|NO ACTION - user anonymous does not exist|<:INFO>
01/24/2012 13:48:41 GEN005540|Executing GEN005540|<:INFO>
01/24/2012 13:48:41 GEN005540|/etc/ssh/sshd_config does not have a warning banner configured.|<:INFO>
01/24/2012 13:48:41 GEN005540|Added Banner line to /etc/ssh/sshd_config|<:INFO>
01/24/2012 13:48:41 LNX00320|Executing LNX00320|<:INFO>
01/24/2012 13:48:41 LNX00320|Removing  - user halt|<:INFO>
01/24/2012 13:48:41 LNX00320|Successfully removed user halt|<:INFO>
01/24/2012 13:48:41 LNX00320|Removing  - user shutdown|<:INFO>
01/24/2012 13:48:41 LNX00320|Successfully removed user shutdown|<:INFO>
01/24/2012 13:48:41 LNX00320|NO ACTION - user reboot does not exist|<:INFO>
01/24/2012 13:48:41 LNX00320|NO ACTION - user who does not exist|<:INFO>
01/24/2012 13:48:41 LNX00340|Executing LNX00340|<:INFO>
01/24/2012 13:48:42 LNX00340|Successfully removed user games|<:INFO>
01/24/2012 13:48:42 LNX00340|Successfully removed user news|<:INFO>
01/24/2012 13:48:42 LNX00340|warning  Unable to remove group news|<:INFO>
01/24/2012 13:48:42 LNX00340|Successfully removed user gopher|<:INFO>
01/24/2012 13:48:42 GEN000020|Addressing GEN000020|<:INFO>
01/24/2012 13:48:42 GEN000020|add line: ~~:S:wait:/sbin/sulogin to /etc/inittab|<:INFO>
01/24/2012 13:48:42 GEN000480|Executing GEN000480|<:INFO>
01/24/2012 13:48:42 GEN000480|FAIL_DELAY is not set in /etc/login.defs|<:NOTICE>
01/24/2012 13:48:42 GEN000920|Addressing GEN000920|<:INFO>
01/24/2012 13:48:42 GEN000920|Changed /root permissions to 0700|<:INFO>
01/24/2012 13:48:42 GEN004640|Executing GEN004640|<:INFO>
01/24/2012 13:48:42 GEN004640|Commenting out decode line in /etc/aliases|<:INFO>
01/24/2012 13:48:42 component_install|Execute "rpm  -iv --replacefiles /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-cm-2.0.0.0-1.i386.rpm"|<:DEBUG>
01/24/2012 13:48:42 component_install|Execute "rpm  -iv --replacefiles /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-api-3.0.0.0-6.i386.rpm"|<:DEBUG>
01/24/2012 13:48:43 component_install|Execute "rpm  -iv --replacefiles /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-util-2.0.0.1-1.i386.rpm"|<:DEBUG>
01/24/2012 13:48:43 component_install|Execute "rpm  -iv --replacefiles /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/os-services-1.2-1.i386.rpm"|<:DEBUG>
01/24/2012 13:48:43 component_install|Execute "rpm  -iv --replacefiles /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/fiostats-0.99.2-4.i386.rpm"|<:DEBUG>
01/24/2012 13:48:43 component_install|Execute "rpm  -iv --replacefiles /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/fior-0.99.1-3.el5.i386.rpm"|<:DEBUG>
01/24/2012 13:48:43 component_install|Execute "rpm  -iv --replacefiles /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-dbcfs-0.3-1.i386.rpm"|<:DEBUG>
01/24/2012 13:48:44 component_install|Execute "rpm  -iv --replacefiles /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-tomcat-1.0.0.0-1.i386.rpm"|<:DEBUG>
01/24/2012 18:48:44 |migrate_tomcat_settings.sh: web.xml migration|<:INFO>
01/24/2012 18:48:44 |migrate_tomcat_settings.sh: /partB//usr/local/thirdparty/jakarta-tomcat/conf/web.xml session-timeout is 30 and context-param session-timeout is 30|<:INFO>
01/24/2012 18:48:44 |migrate_tomcat_settings.sh: migrating session timeout values from /partB|<:INFO>
01/24/2012 18:48:44 |migrate_tomcat_settings.sh: /usr/local/thirdparty/jakarta-tomcat/conf/web.xml session timeout and context param session-timeout updated|<:INFO>
01/24/2012 18:48:44 |migrate_tomcat_settings.sh: migration complete|<:INFO>
01/24/2012 13:48:44 component_install|Execute "rpm  -iv --replacefiles /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/ucfips-selftest-1.0.0.0-1.i386.rpm"|<:DEBUG>
01/24/2012 13:48:44 component_install|Execute "rpm  -iv --replacefiles /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-fipsutil-1.0.0.0-1.i386.rpm"|<:DEBUG>
01/24/2012 13:48:44 component_install|Execute "rpm  -iv --replacefiles /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-snmp-1.0.0.0-0.i386.rpm"|<:DEBUG>
01/24/2012 13:48:44 component_install|Execute "rpm  -iv --replacefiles /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-tzdata-2012c-1.el5.i386.rpm"|<:DEBUG>
01/24/2012 13:48:44 component_install|Execute "rpm  -iv --replacefiles /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform/platform-ipsec-1.0.0.0-1.i386.rpm"|<:DEBUG>
01/24/2012 13:48:44 component_install|Search path is /opt/cisco/install/ucplatform/scripts:/usr/local/cm/script|<:DEBUG>
01/24/2012 13:48:44 component_install|Checking command /opt/cisco/install/ucplatform/scripts/security_prepare|<:DEBUG>
01/24/2012 13:48:44 component_install|Execute "/opt/cisco/install/ucplatform/scripts/security_prepare L2 Migration 8.6.2.22900-9 8.6.2.20000-2 /usr/local/cm/ /partB/usr/local/cm/ /common/log/install/capture.txt"|<:DEBUG>
01/24/2012 18:48:45 security_prepare|Parse arguments|<:DEBUG>
01/24/2012 18:48:45 security_prepare|Validate arguments|<:DEBUG>
01/24/2012 18:48:45 security_prepare|Initialize global variables|<:DEBUG>
01/24/2012 18:48:45 security_prepare|Handle Security Information|<:DEBUG>
01/24/2012 18:48:45 security_prepare|Migrate security information|<:DEBUG>
01/24/2012 18:48:45 security_prepare|Migrate special account information|<:DEBUG>
01/24/2012 18:48:45 security_prepare|Migrating informix user password|<:INFO>
01/24/2012 18:48:45 security_prepare|Migrate login warning message|<:DEBUG>
01/24/2012 18:48:45 security_prepare|No login time warning message file|<:DEBUG>
01/24/2012 18:48:45 security_prepare|Migrate SFTP data|<:DEBUG>
01/24/2012 18:48:45 security_prepare|Copy SFTP Data|<:DEBUG>
01/24/2012 18:48:45 security_prepare|Migrate DRF data|<:DEBUG>
01/24/2012 18:48:45 security_prepare|Migrate CCM Service Data|<:DEBUG>
01/24/2012 18:48:45 security_prepare|Migrate IPSec Data|<:DEBUG>
01/24/2012 18:48:45 security_prepare|get_fips_status returning partB fips_cnf as 0|<:DEBUG>
01/24/2012 18:48:45 security_prepare|Migrate Racoon Data|<:DEBUG>
01/24/2012 18:48:46 security_prepare|Transfer Tomcat Data|<:DEBUG>
01/24/2012 18:48:46 security_prepare|Updated /usr/local/thirdparty/jakarta-tomcat/conf/server.xml with keystoreFile details|<:INFO>
01/24/2012 18:48:46 security_prepare|Successfully updated log configuration for tomcat|<:INFO>
01/24/2012 18:48:47 security_prepare|Successfully updated tomcat-users|<:INFO>
01/24/2012 18:48:47 security_prepare|Configure SFTP ownership|<:DEBUG>
01/24/2012 18:48:47 security_prepare|Execute upgrade product extensions|<:DEBUG>
01/24/2012 18:48:51 product_extensions|No ucm extensions found for security_sd_upgrade.sh.  Continuing normally.|<:INFO>
01/24/2012 18:48:51 security_prepare|security information prepare successful|<:INFO>
01/24/2012 13:48:51 component_install|Search path is /opt/cisco/install/ucplatform/scripts:/usr/local/cm/script|<:DEBUG>
01/24/2012 13:48:51 component_install|Checking command /opt/cisco/install/ucplatform/scripts/drf_migrate|<:DEBUG>
01/24/2012 13:48:51 component_install|Execute "/opt/cisco/install/ucplatform/scripts/drf_migrate L2 Migration 8.6.2.22900-9 8.6.2.20000-2 /usr/local/cm/ /partB/usr/local/cm/ /common/log/install/capture.txt"|<:DEBUG>
01/24/2012 13:48:51 component_install|Checking command /opt/cisco/install/ucplatform/scripts/migrate_cli_configuration|<:DEBUG>
01/24/2012 13:48:51 component_install|Execute "/opt/cisco/install/ucplatform/scripts/migrate_cli_configuration L2 Migration 8.6.2.22900-9 8.6.2.20000-2 /usr/local/cm/ /partB/usr/local/cm/ /common/log/install/capture.txt"|<:DEBUG>
01/24/2012 18:48:52 |migrate_cli_configuration: cliConfiguration.xml migration|<:INFO>
01/24/2012 18:48:52 |migrate_cli_configuration: /partB/usr/local/platform/conf/cli/cliConfiguration.xml session-timeout is 30|<:INFO>
01/24/2012 18:48:52 |migrate_cli_configuration: migrating session timeout values from /partB|<:INFO>
01/24/2012 18:48:52 |migrate_cli_configuration:  session timeout updated|<:INFO>
01/24/2012 18:48:52 |migrate_cli_configuration: migration complete|<:INFO>
01/24/2012 13:48:52 component_install|Search path is /opt/cisco/install/ucplatform/scripts:/usr/local/cm/script|<:DEBUG>
01/24/2012 13:48:52 component_install|Checking command /opt/cisco/install/ucplatform/scripts/security_postinstall|<:DEBUG>
01/24/2012 13:48:52 component_install|Execute "/opt/cisco/install/ucplatform/scripts/security_postinstall L2 PostInstall 8.6.2.22900-9 8.6.2.20000-2 /usr/local/cm/ /partB/usr/local/cm/ /common/log/install/capture.txt"|<:DEBUG>
01/24/2012 18:48:52 security_postinstall|Parse arguments|<:DEBUG>
01/24/2012 18:48:52 security_postinstall|Validate arguments|<:DEBUG>
01/24/2012 18:48:52 security_postinstall|Handle Security Information|<:DEBUG>
01/24/2012 18:48:52 security_postinstall|Upgrade security information|<:DEBUG>
01/24/2012 18:48:52 security_postinstall|Adding provider in /usr/local/thirdparty/java/j2sdk/jre/lib/security/java.security|<:INFO>
01/24/2012 18:48:52 security_postinstall|Added provider successfully in : /usr/local/thirdparty/java/j2sdk/jre/lib/security/java.security|<:INFO>
01/24/2012 18:48:52 security_postinstall|Add certificate hostname notification|<:DEBUG>
01/24/2012 18:48:52 security_postinstall|Successfully installed certificate hostname notification registry|<:INFO>
01/24/2012 18:48:52 security_postinstall|Create bulk certificate store|<:DEBUG>
01/24/2012 18:48:52 security_postinstall|Stop unnecessary services|<:DEBUG>
01/24/2012 18:48:52 security_postinstall|Stopping unnecessary services|<:DEBUG>
01/24/2012 18:48:52 security_postinstall|Add IPSec startup|<:DEBUG>
01/24/2012 18:48:52 security_postinstall|get_fips_status returning partB fips_cnf as 0|<:DEBUG>
01/24/2012 18:48:52 security_postinstall|Added ipsec start up to system|<:DEBUG>
01/24/2012 18:48:52 security_postinstall|Update IPSec for upgrade|<:DEBUG>
01/24/2012 18:48:52 security_postinstall|Update IPSec for Racoon|<:DEBUG>
01/24/2012 18:48:52 security_postinstall|open up DHCPv6 client port|<:DEBUG>
01/24/2012 18:48:52 security_postinstall|Updating tomcat|<:DEBUG>
01/24/2012 18:48:53 security_postinstall|Cleaned up demo, example, and sample files|<:INFO>
01/24/2012 18:48:53 |migrate_tomcat_settings.sh: web.xml migration|<:INFO>
01/24/2012 18:48:53 |migrate_tomcat_settings.sh: /partB//usr/local/thirdparty/jakarta-tomcat/conf/web.xml session-timeout is 30 and context-param session-timeout is 30|<:INFO>
01/24/2012 18:48:53 |migrate_tomcat_settings.sh: migrating session timeout values from /partB|<:INFO>
01/24/2012 18:48:53 |migrate_tomcat_settings.sh: /usr/local/thirdparty/jakarta-tomcat/conf/web.xml session timeout and context param session-timeout updated|<:INFO>
01/24/2012 18:48:53 |migrate_tomcat_settings.sh: migration complete|<:INFO>
01/24/2012 18:48:53 security_postinstall|Successful in updating tomcat's web.xml|<:INFO>
01/24/2012 18:48:53 security_postinstall|Execute product extensions|<:DEBUG>
01/24/2012 18:48:57 product_extensions|No ucm extensions found for secure_sd_postinstall.sh.  Continuing normally.|<:INFO>
01/24/2012 18:48:57 security_postinstall|security information postinstall successful|<:INFO>
01/24/2012 13:48:57 component_install|Execute "/usr/local/bin/base_scripts/init_net_snmpd_conf.sh L2 PostInstall 8.6.2.22900-9 8.6.2.20000-2 /usr/local/cm/ /partB/usr/local/cm/ /common/log/install/capture.txt"|<:DEBUG>
01/24/2012 13:48:57 init_net_snmpd_conf.sh|Creating net-snmp snmpd.conf ...|<:INFO>
01/24/2012 13:48:57 component_install|Command execution for ucplatform component is complete|<:INFO>
01/24/2012 13:48:57 component_install|Command execution for ucplatform component RTMTFinish|<:NOTICE>
01/24/2012 13:48:57 component_install|Initialize component data, mode upgrade|<:INFO>
01/24/2012 13:48:57 component_install|Initialize ucplatform_cluster "to" side version|<:INFO>
01/24/2012 13:48:57 component_install|Access "to" side API|<:DEBUG>
01/24/2012 13:48:57 component_install|Got version 8.6.2.22900-9|<:DEBUG>
01/24/2012 13:48:57 component_install|Initialize ucplatform_cluster "to" side version complete|<:INFO>
01/24/2012 13:48:57 component_install|Initialize ucplatform_cluster "from" side version|<:INFO>
01/24/2012 13:48:57 component_install|Component ucplatform_cluster available on active side|<:DEBUG>
01/24/2012 13:48:57 component_install|Access "from" side API|<:DEBUG>
01/24/2012 13:48:57 component_install|Got version 8.6.2.20000-2|<:DEBUG>
01/24/2012 13:48:57 component_install|Initialize ucplatform_cluster "from" side version complete|<:INFO>
01/24/2012 13:48:57 component_install|Initialize global data complete|<:INFO>
01/24/2012 13:48:57 component_install|Build the command list for ucplatform_cluster|<:INFO>
01/24/2012 13:48:57 component_install|Initialize command list|<:DEBUG>
01/24/2012 13:48:57 component_install|Build ucplatform_cluster install phase commands|<:DEBUG>
01/24/2012 13:48:57 component_install|Processing ucplatform_cluster install element|<:DEBUG>
01/24/2012 13:48:58 component_install|Processing ucplatform_cluster package element|<:DEBUG>
01/24/2012 13:48:58 component_install|Checking if RPM /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform_cluster/platform-clm-2.0.0.1-1.i386.rpm exists|<:DEBUG>
01/24/2012 13:48:58 component_install|Add "rpm  -iv --replacefiles /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform_cluster/platform-clm-2.0.0.1-1.i386.rpm" to command list|<:DEBUG>
01/24/2012 13:48:58 component_install|Checking if RPM /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform_cluster/platform-sso-2.0.0.0-1.i386.rpm exists|<:DEBUG>
01/24/2012 13:48:58 component_install|Add "rpm  -iv --replacefiles /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform_cluster/platform-sso-2.0.0.0-1.i386.rpm" to command list|<:DEBUG>
01/24/2012 13:48:58 component_install|Building the command list for ucplatform_cluster is complete|<:INFO>
01/24/2012 13:48:58 component_install|Command execution for ucplatform_cluster component RTMTStart|<:NOTICE>
01/24/2012 13:48:58 component_install|Execute commands in the command list for ucplatform_cluster component|<:INFO>
01/24/2012 13:48:58 component_install|Execute "rpm  -iv --replacefiles /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform_cluster/platform-clm-2.0.0.1-1.i386.rpm"|<:DEBUG>
01/24/2012 13:48:58 component_install|Execute "rpm  -iv --replacefiles /common/rpm-archive/8.6.2.22900-9/RPMS/ucplatform_cluster/platform-sso-2.0.0.0-1.i386.rpm"|<:DEBUG>
01/24/2012 13:48:59 component_install|Command execution for ucplatform_cluster component is complete|<:INFO>
01/24/2012 13:48:59 component_install|Command execution for ucplatform_cluster component RTMTFinish|<:NOTICE>
01/24/2012 13:48:59 component_install|Installation of infrastructure component complete|<:INFO>
01/24/2012 13:48:59 platform_post_install|Disable services|<:INFO>
01/24/2012 13:48:59 platform_post_install|Calling "chkconfig gpm off"|<:DEBUG>
01/24/2012 13:48:59 platform_post_install|Calling "chkconfig smartd off"|<:DEBUG>
01/24/2012 13:48:59 platform_post_install|Failed to disable smartd|<:WARN>
01/24/2012 13:48:59 platform_post_install|Check if we need to turn on ipmi service|<:INFO>
01/24/2012 13:48:59 platform_post_install|Server model=VMware|<:DEBUG>
01/24/2012 13:48:59 platform_post_install|The server model does not have IPMI or is not an IBM server.|<:INFO>
01/24/2012 13:48:59 platform_post_install|Configuring /etc/logrotate.d/snmpd to not restart weekly ...|<:DEBUG>
01/24/2012 13:48:59 platform_post_install|Modifications to /etc/logrotate.d/snmpd completed.|<:DEBUG>
01/24/2012 13:48:59 platform_post_install|Turn off smartd service|<:INFO>
01/24/2012 13:48:59 platform_post_install|Calling "service smartd stop"|<:DEBUG>
01/24/2012 13:48:59 platform_post_install|Calling "/sbin/chkconfig smartd off"|<:DEBUG>
01/24/2012 13:48:59 platform_post_install|Created /etc/rc.d/init.d/ntpd.|<:INFO>
01/24/2012 13:48:59 platform_post_install|Added NTPD to inittab|<:INFO>
01/24/2012 13:48:59 rclocalmgr.sh|action type is add|<:DEBUG>
01/24/2012 13:48:59 rclocalmgr.sh|running add|<:INFO>
01/24/2012 13:48:59 rclocalmgr.sh|Adding /usr/local/bin/base_scripts/create_ntp_watchdog_cron_job.sh 2>/dev/null|<:INFO>
01/24/2012 13:48:59 rclocalmgr.sh|Add /usr/local/bin/base_scripts/create_ntp_watchdog_cron_job.sh 2>/dev/null to section 11|<:DEBUG>
01/24/2012 13:48:59 rclocalmgr.sh|Adding "/usr/local/bin/base_scripts/rclocalmgr.sh -commit_del"|<:INFO>
01/24/2012 13:48:59 rclocalmgr.sh|Add /usr/local/bin/base_scripts/create_ntp_watchdog_cron_job.sh 2>/dev/null to /etc/rc.d/rc.local complete|<:INFO>
01/24/2012 13:48:59 platform_post_install|Added /usr/local/bin/base_scripts/create_ntp_watchdog_cron_job.sh 2>/dev/null to rc.local.|<:INFO>
01/24/2012 13:48:59 platform_post_install|Check cron for root, should be empty|<:INFO>
01/24/2012 13:48:59 platform_post_install|updating rc.local RTMTStart|<:NOTICE>
01/24/2012 13:48:59 platform_post_install|Update rc.local|<:INFO>
01/24/2012 13:48:59 rclocalmgr.sh|Adding /usr/local/bin/base_scripts/sd_domainname 2> /dev/null|<:INFO>
01/24/2012 13:48:59 rclocalmgr.sh|Add /usr/local/bin/base_scripts/sd_domainname 2> /dev/null to section 10|<:DEBUG>
01/24/2012 13:48:59 rclocalmgr.sh|Add /usr/local/bin/base_scripts/sd_domainname 2> /dev/null to /etc/rc.d/rc.local complete|<:INFO>
01/24/2012 13:48:59 rclocalmgr.sh|Adding /usr/local/bin/base_scripts/server_specific_install.sh post-reboot /RPMS 2> /dev/null|<:INFO>
01/24/2012 13:48:59 rclocalmgr.sh|Add /usr/local/bin/base_scripts/server_specific_install.sh post-reboot /RPMS 2> /dev/null to section 10|<:DEBUG>
01/24/2012 13:48:59 rclocalmgr.sh|Add /usr/local/bin/base_scripts/server_specific_install.sh post-reboot /RPMS 2> /dev/null to /etc/rc.d/rc.local complete|<:INFO>
01/24/2012 13:48:59 rclocalmgr.sh|Adding /usr/local/bin/base_scripts/dbcfs-admin -m all -i 2> /dev/null|<:INFO>
01/24/2012 13:48:59 rclocalmgr.sh|Add /usr/local/bin/base_scripts/dbcfs-admin -m all -i 2> /dev/null to section 10|<:DEBUG>
01/24/2012 13:48:59 rclocalmgr.sh|Add /usr/local/bin/base_scripts/dbcfs-admin -m all -i 2> /dev/null to /etc/rc.d/rc.local complete|<:INFO>
01/24/2012 13:48:59 rclocalmgr.sh|Adding /usr/local/bin/base_scripts/restorecon_call.sh|<:INFO>
01/24/2012 13:48:59 rclocalmgr.sh|Add /usr/local/bin/base_scripts/restorecon_call.sh to section 10|<:DEBUG>
01/24/2012 13:48:59 rclocalmgr.sh|Add /usr/local/bin/base_scripts/restorecon_call.sh to /etc/rc.d/rc.local complete|<:INFO>
01/24/2012 13:48:59 platform_post_install|Adding command to rc.local to kill nash|<:INFO>
01/24/2012 13:49:00 rclocalmgr.sh|action type is add|<:DEBUG>
01/24/2012 13:49:00 rclocalmgr.sh|running add|<:INFO>
01/24/2012 13:49:00 rclocalmgr.sh|Adding pkill -9 nash|<:INFO>
01/24/2012 13:49:00 rclocalmgr.sh|Add pkill -9 nash to section 9|<:DEBUG>
01/24/2012 13:49:00 rclocalmgr.sh|Add pkill -9 nash to /etc/rc.d/rc.local complete|<:INFO>
01/24/2012 13:49:00 platform_post_install|Adding script to rc.local to change kdump vmcore file permission and limit no. of vmcores to 5 in CUCM and 1 in CUCMBE|<:INFO>
01/24/2012 13:49:00 rclocalmgr.sh|Adding /usr/local/bin/base_scripts/kdump_vmcores.sh|<:INFO>
01/24/2012 13:49:00 rclocalmgr.sh|Add /usr/local/bin/base_scripts/kdump_vmcores.sh to section 11|<:DEBUG>
01/24/2012 13:49:00 rclocalmgr.sh|Add /usr/local/bin/base_scripts/kdump_vmcores.sh to /etc/rc.d/rc.local complete|<:INFO>
01/24/2012 13:49:00 rclocalmgr.sh|Adding /usr/local/bin/base_scripts/rm_rpm_archive.sh 8.6.2.22900-9|<:INFO>
01/24/2012 13:49:00 rclocalmgr.sh|Add /usr/local/bin/base_scripts/rm_rpm_archive.sh 8.6.2.22900-9 to section 19|<:DEBUG>
01/24/2012 13:49:00 rclocalmgr.sh|Add /usr/local/bin/base_scripts/rm_rpm_archive.sh 8.6.2.22900-9 to /etc/rc.d/rc.local complete|<:INFO>
01/24/2012 13:49:00 platform_post_install|Adding GEN001280 to rc.local|<:INFO>
01/24/2012 13:49:00 platform_post_install|Updating rc.local RTMTFinish|<:NOTICE>
01/24/2012 13:49:00 platform_post_install|Applying workaround to detect duplicate IP addresses|<:INFO>
01/24/2012 13:49:00 platform_post_install|No /var/log/active/installed_options directory found|<:DEBUG>
01/24/2012 13:49:00 platform_post_install|Migrate network configuration files|<:INFO>
01/24/2012 13:49:00 platform_post_install|Calling "mkdir -p -m755 /etc/sysconfig/network-scripts"|<:DEBUG>
01/24/2012 13:49:00 platform_post_install|Migrating /etc/sysconfig/network-scripts/ifcfg-eth0 to inactive partition|<:DEBUG>
01/24/2012 13:49:00 platform_post_install|Copy /partB/etc/sysconfig/network-scripts/ifcfg-eth0 to /etc/sysconfig/network-scripts/ifcfg-eth0|<:INFO>
01/24/2012 13:49:00 platform_post_install|Calling "cp /partB/etc/sysconfig/network-scripts/ifcfg-eth0 /etc/sysconfig/network-scripts/ifcfg-eth0"|<:DEBUG>
01/24/2012 13:49:00 platform_post_install|Migrating /etc/sysconfig/network to inactive partition|<:DEBUG>
01/24/2012 13:49:00 platform_post_install|Copy /partB/etc/sysconfig/network to /etc/sysconfig/network|<:INFO>
01/24/2012 13:49:00 platform_post_install|Calling "cp /partB/etc/sysconfig/network /etc/sysconfig/network"|<:DEBUG>
01/24/2012 13:49:00 platform_post_install|Migrating /etc/hosts to inactive partition|<:DEBUG>
01/24/2012 13:49:00 platform_post_install|Copy /partB/etc/hosts to /etc/hosts|<:INFO>
01/24/2012 13:49:00 platform_post_install|Calling "cp /partB/etc/hosts /etc/hosts"|<:DEBUG>
01/24/2012 13:49:00 platform_post_install|Migrating /etc/resolv.conf to inactive partition|<:DEBUG>
01/24/2012 13:49:00 platform_post_install|Copy /partB/etc/resolv.conf to /etc/resolv.conf|<:INFO>
01/24/2012 13:49:00 platform_post_install|Calling "cp /partB/etc/resolv.conf /etc/resolv.conf"|<:DEBUG>
01/24/2012 13:49:00 networkFaultTolerance.sh|-d|<:DEBUG>
01/24/2012 13:49:00 platform_post_install|Network Fault Tolerance not detected.|<:INFO>
01/24/2012 13:49:00 platform_post_install|Migrate platform configuration file data|<:INFO>
01/24/2012 13:49:00 platform_post_install|chown tomcat:tomcat platformConfig.xml|<:DEBUG>
01/24/2012 13:49:00 platform_post_install|chmod 664 platformConfig.xml|<:DEBUG>
01/24/2012 13:49:00 platform_post_install|Calling the Install Wizard to update system information|<:INFO>
01/24/2012 18:49:00 InstallWizard|Platform Install: installWizMain.c@@/main/cm_8_6_2/2|<:INFO>
01/24/2012 18:49:00 InstallWizard|option 2 - UPGRADE_SYS|<:INFO>
01/24/2012 18:49:00 InstallWizard|Running from local disk|<:INFO>
01/24/2012 18:49:00 InstallWizard|initializeGlobalData|<:INFO>
01/24/2012 18:49:00 InstallWizard|found 469 entries from timezone translation file|<:INFO>
01/24/2012 18:49:00 InstallWizard|Populate country code select array with 240 entries|<:INFO>
01/24/2012 18:49:00 InstallWizard|Country code select array populated with 240 entries|<:INFO>
01/24/2012 18:49:03 InstallWizard|Product List:|<:DEBUG>
01/24/2012 18:49:03 InstallWizard|    CallManager|<:DEBUG>
01/24/2012 18:49:03 InstallWizard|Start data population.|<:INFO>
01/24/2012 18:49:03 InstallWizard|Populating config from file /usr/local/platform/conf//platformConfig.xml|<:INFO>
01/24/2012 18:49:03 InstallWizard|openPlatformXml: Parse existing xml document /usr/local/platform/conf//platformConfig.xml.|<:INFO>
01/24/2012 18:49:03 InstallWizard|ProductDeployment 'callmanager'|<:INFO>
01/24/2012 18:49:03 InstallWizard|Install or upgrade type 'Basic Install'|<:INFO>
01/24/2012 18:49:03 InstallWizard|timezoneConfigEnabled: timezone='optional'.|<:DEBUG>
01/24/2012 18:49:03 InstallWizard|ApplUserUsername 'CCMAdministrator'|<:INFO>
01/24/2012 18:49:03 InstallWizard|Tag ApplUserPwCrypt not found.|<:WARN>
01/24/2012 18:49:03 InstallWizard|Tag ApplUserDbPwCrypt not found.|<:WARN>
01/24/2012 18:49:03 InstallWizard|NIC Auto Negotiate set to TRUE|<:INFO>
01/24/2012 18:49:03 InstallWizard|Host Name for this machine '30NC-LonCCM-Sub-01'|<:INFO>
01/24/2012 18:49:03 InstallWizard|Change MTU set to FALSE|<:INFO>
01/24/2012 18:49:03 InstallWizard|Is DHCP enabled for this machine 'no'|<:INFO>
01/24/2012 18:49:03 InstallWizard|Host IP0 addr for this node '172.22.97.5'|<:INFO>
01/24/2012 18:49:03 InstallWizard|Host IP0 mask for this node '255.255.255.240'|<:INFO>
01/24/2012 18:49:03 InstallWizard|Gateway for this node '172.22.97.14'|<:INFO>
01/24/2012 18:49:03 InstallWizard|Tag LocalHostDnsPrimary not found.|<:WARN>
01/24/2012 18:49:03 InstallWizard|Tag LocalHostDnsSecondary not found.|<:WARN>
01/24/2012 18:49:03 InstallWizard|LocalHostDnsSecondary duplicate of LocalHostDnsPrimary.  Value=.|<:WARN>
01/24/2012 18:49:03 InstallWizard|Value LocalHostDomain not found.|<:WARN>
01/24/2012 18:49:03 InstallWizard|First node in the cluster 'no'|<:INFO>
01/24/2012 18:49:03 InstallWizard|node does NOT have external NTP server(s)|<:DEBUG>
01/24/2012 18:49:03 InstallWizard|populateFromPlatformXml: NOT first node.|<:INFO>
01/24/2012 18:49:03 InstallWizard|Host Name for DataBase 'Colo-LonCCM-01'|<:INFO>
01/24/2012 18:49:03 InstallWizard|Host IP Addr for DataBase '172.22.97.20'|<:INFO>
01/24/2012 18:49:03 InstallWizard|PauseOnSuccessSubConnect 'no'|<:INFO>
01/24/2012 18:49:03 InstallWizard|Timezone for this node 'Europe/London'|<:INFO>
01/24/2012 18:49:03 InstallWizard|Administrator name for this node 'Administrator'|<:INFO>
01/24/2012 18:49:03 InstallWizard|Certification Signing Request Organization 'FITCH RATINGS'|<:INFO>
01/24/2012 18:49:03 InstallWizard|Certification Signing Request Unit 'IT'|<:INFO>
01/24/2012 18:49:03 InstallWizard|Certification Signing Request Location '30NC'|<:INFO>
01/24/2012 18:49:03 InstallWizard|Certification Signing Request State 'LONDON'|<:INFO>
01/24/2012 18:49:03 InstallWizard|Certification Signing Request Country 'GB'|<:INFO>
01/24/2012 18:49:03 InstallWizard|Tag SMTPHostName not found.|<:WARN>
01/24/2012 18:49:03 InstallWizard|A Special Install Mode for Testers which will ignore networking errors in the install process 'no'|<:INFO>
01/24/2012 18:49:03 InstallWizard|Data population complete. Start data validation.|<:INFO>
01/24/2012 18:49:03 InstallWizard|Validating fields|<:INFO>
01/24/2012 18:49:03 InstallWizard|clusterConfigEnabled: cluster='optional'.|<:DEBUG>
01/24/2012 18:49:03 InstallWizard|validateTimezone: no time zone validation performed for upgrade.|<:INFO>
01/24/2012 18:49:03 InstallWizard|mtuConfigEnabled: mtu='optional'.|<:DEBUG>
01/24/2012 18:49:03 InstallWizard|validateIpAddr: 172.22.97.5|<:DEBUG>
01/24/2012 18:49:03 InstallWizard|ipaddress after trimming=172.22.97.5|<:INFO>
01/24/2012 18:49:03 InstallWizard|validateIpAddr: 255.255.255.240|<:DEBUG>
01/24/2012 18:49:03 InstallWizard|ipaddress after trimming=255.255.255.240|<:INFO>
01/24/2012 18:49:03 InstallWizard|validateIpAddr: 172.22.97.14|<:DEBUG>
01/24/2012 18:49:03 InstallWizard|ipaddress after trimming=172.22.97.14|<:INFO>
01/24/2012 18:49:03 InstallWizard|runScript: Calling system("/usr/local/bin/base_scripts/validateNetworking.sh")|<:DEBUG>
01/24/2012 18:49:07 InstallWizard|runScript: 0 = system("/usr/local/bin/base_scripts/validateNetworking.sh")|<:DEBUG>
01/24/2012 18:49:07 InstallWizard|validateNetworking succeeded|<:INFO>
01/24/2012 18:49:07 InstallWizard|adminAcctConfigEnabled: admin='optional'.|<:DEBUG>
01/24/2012 18:49:07 InstallWizard|validateAdminCredentials: valid administrator id Administrator|<:INFO>
01/24/2012 18:49:07 InstallWizard|Updating /usr/local/platform/conf//platformConfig.xml|<:INFO>
01/24/2012 18:49:07 InstallWizard|2e 73 a9 94|<:DEBUG>
01/24/2012 18:49:07 InstallWizard|written 6547 bytes to /usr/local/platform/conf//platformConfig.xml|<:INFO>
01/24/2012 18:49:07 InstallWizard|finally salt = $5$lD/afP57$|<:INFO>
01/24/2012 18:49:07 InstallWizard|runScript: Calling system("/root/.security/unimmunize.sh >/common/log/install/capture.txt 2>&1")|<:DEBUG>
01/24/2012 18:49:07 InstallWizard|runScript: 0 = system("/root/.security/unimmunize.sh >/common/log/install/capture.txt 2>&1")|<:DEBUG>
01/24/2012 18:49:07 InstallWizard|runScript: Calling system("/usr/sbin/groupadd administrator >/common/log/install/capture.txt 2>&1")|<:DEBUG>
01/24/2012 18:49:07 InstallWizard|(CAPTURE) groupadd: group administrator exists|<:DEBUG>
01/24/2012 18:49:07 InstallWizard|runScript: 2304 = system("/usr/sbin/groupadd administrator >/common/log/install/capture.txt 2>&1")|<:DEBUG>
01/24/2012 18:49:07 InstallWizard|Created selinux security directory|<:INFO>
01/24/2012 18:49:07 InstallWizard|Opened selinux admin role shell script|<:INFO>
01/24/2012 18:49:07 InstallWizard|Added selinux admin role to shell script|<:INFO>
01/24/2012 18:49:07 InstallWizard|Added selinux admin login to shell script|<:INFO>
01/24/2012 18:49:07 InstallWizard|runScript: Calling system("/usr/sbin/adduser -s /usr/local/platform/bin/startcliscript.sh -g administrator -p '$5$lD/afP57$gNMvSHcveuS8HwS/3oJJrC4aHU9qO7j2DmLNL1PRQ42' Administrator >/common/log/install/capture.txt 2>&1")|<:DEBUG>
01/24/2012 18:49:07 InstallWizard|runScript: 0 = system("/usr/sbin/adduser -s /usr/local/platform/bin/startcliscript.sh -g administrator -p '$5$lD/afP57$gNMvSHcveuS8HwS/3oJJrC4aHU9qO7j2DmLNL1PRQ42' Administrator >/common/log/install/capture.txt 2>&1")|<:DEBUG>
01/24/2012 18:49:07 InstallWizard|runScript: Calling system("/usr/sbin/usermod -p '$5$lD/afP57$gNMvSHcveuS8HwS/3oJJrC4aHU9qO7j2DmLNL1PRQ42' adminsftp >/common/log/install/capture.txt 2>&1")|<:DEBUG>
01/24/2012 18:49:07 InstallWizard|runScript: 0 = system("/usr/sbin/usermod -p '$5$lD/afP57$gNMvSHcveuS8HwS/3oJJrC4aHU9qO7j2DmLNL1PRQ42' adminsftp >/common/log/install/capture.txt 2>&1")|<:DEBUG>
01/24/2012 18:49:07 InstallWizard|runScript: Calling system("/root/.security/immunize.sh >/common/log/install/capture.txt 2>&1")|<:DEBUG>
01/24/2012 18:49:07 InstallWizard|runScript: 0 = system("/root/.security/immunize.sh >/common/log/install/capture.txt 2>&1")|<:DEBUG>
01/24/2012 18:49:07 InstallWizard|runScriptPassive: Calling system("/usr/local/bin/base_scripts/sd_zoneinfo Europe/London >/common/log/install/capture.txt 2>&1")|<:DEBUG>
01/24/2012 18:49:07 InstallWizard|runScriptPassive: 0 = system("/usr/local/bin/base_scripts/sd_zoneinfo Europe/London >/common/log/install/capture.txt 2>&1")|<:DEBUG>
01/24/2012 18:49:07 InstallWizard|runScriptPassive: correcting rc per system/script call; returning rc=0|<:DEBUG>
01/24/2012 18:49:07 InstallWizard|set TZ='Europe/London' succeeded|<:INFO>
01/24/2012 18:49:07 InstallWizard|The time zone has been set.  Updating the system clock|<:INFO>
01/24/2012 18:49:07 InstallWizard|runScript: Calling system("/usr/sbin/hwclock --hctosys >/common/log/install/capture.txt 2>&1")|<:DEBUG>
01/24/2012 18:49:07 InstallWizard|runScript: 0 = system("/usr/sbin/hwclock --hctosys >/common/log/install/capture.txt 2>&1")|<:DEBUG>
01/24/2012 18:49:07 InstallWizard|ntpConfigEnabled: ntp='optional'.|<:DEBUG>
01/24/2012 18:49:07 InstallWizard|External NTP server? no|<:INFO>
01/24/2012 18:49:07 InstallWizard|runScriptPassive: Calling system("/usr/local/bin/base_scripts/sd_ntp -defaultConf")|<:DEBUG>
01/24/2012 18:49:07 InstallWizard|runScriptPassive: 0 = system("/usr/local/bin/base_scripts/sd_ntp -defaultConf")|<:DEBUG>
01/24/2012 18:49:07 InstallWizard|runScriptPassive: Calling system("/usr/local/bin/base_scripts/sd_ntp -add -s Colo-LonCCM-01 iburst burst")|<:DEBUG>
01/24/2012 18:49:07 InstallWizard|runScriptPassive: 0 = system("/usr/local/bin/base_scripts/sd_ntp -add -s Colo-LonCCM-01 iburst burst")|<:DEBUG>
01/24/2012 18:49:07 InstallWizard|runScriptPassive: Calling system("/usr/local/bin/base_scripts/ntp_one_shot.sh")|<:DEBUG>
01/24/2012 18:49:07 ntp_one_shot.sh|NTP servers list: Colo-LonCCM-01|<:INFO>
01/24/2012 18:49:09 ntp_one_shot.sh|ntpdate query response: server 172.22.97.20, stratum 2, offset 1.015820, delay 0.02606
24 Jan 18:49:09 ntpdate[2160]: step time server 172.22.97.20 offset 1.015820 sec (rc=0).|<:INFO>
01/24/2012 18:49:09 ntp_one_shot.sh|ntpdate Colo-LonCCM-01 response: 24 Jan 18:49:09 ntpdate[2171]: the NTP socket is in use, exiting|<:INFO>
01/24/2012 18:49:09 ntp_one_shot.sh|'nptdate' failed to Colo-LonCCM-01 (ntpdate rc=1).|<:WARN>
01/24/2012 18:49:09 ntp_one_shot.sh|ntpdate Colo-LonCCM-01 response: 24 Jan 18:49:09 ntpdate[2177]: the NTP socket is in use, exiting|<:INFO>
01/24/2012 18:49:09 ntp_one_shot.sh|ntpdate Colo-LonCCM-01 response: 24 Jan 18:49:09 ntpdate[2183]: the NTP socket is in use, exiting|<:INFO>
01/24/2012 18:49:09 ntp_one_shot.sh|File:/usr/local/bin/base_scripts/ntpUtilities.sh:559, Function: notification(), NTP time synchronization failed while trying to reach the primary node NTP server Colo-LonCCM-01. Verify the network connectivity, delay and jitter to the primary node and that the primary node NTP server is operational.  Use CLI 'utils ntp status' to verify NTP server status.|<:ERROR>
01/24/2012 18:49:09 ntp_one_shot.sh|NTP time snchronization successful.|<:INFO>
01/24/2012 18:49:10 ntp_one_shot.sh|Successfully set the HW clock to the system clock.|<:INFO>
01/24/2012 18:49:10 InstallWizard|runScriptPassive: 0 = system("/usr/local/bin/base_scripts/ntp_one_shot.sh")|<:DEBUG>
01/24/2012 18:49:10 InstallWizard|runScriptPassive: correcting rc per system/script call; returning rc=0|<:DEBUG>
01/24/2012 18:49:10 InstallWizard|Security password = Passed -- L2|<:INFO>
01/24/2012 18:49:10 InstallWizard|2e 73 a9 94|<:DEBUG>
01/24/2012 18:49:10 InstallWizard|Updating /usr/local/platform/conf//platformConfig.xml|<:INFO>
01/24/2012 18:49:10 InstallWizard|openPlatformXml: Parse existing xml document /usr/local/platform/conf//platformConfig.xml.|<:INFO>
01/24/2012 18:49:10 InstallWizard|written 6547 bytes to /usr/local/platform/conf//platformConfig.xml|<:INFO>
01/24/2012 18:49:10 InstallWizard|runScript: Calling system("/root/.security/sftp/update_sftpuser_pwd.sh >/common/log/install/capture.txt 2>&1")|<:DEBUG>
01/24/2012 18:49:10 InstallWizard|runScript: 0 = system("/root/.security/sftp/update_sftpuser_pwd.sh >/common/log/install/capture.txt 2>&1")|<:DEBUG>
01/24/2012 18:49:10 InstallWizard|Security configuration OK|<:INFO>
01/24/2012 18:49:10 InstallWizard|Data validation complete.|<:INFO>
01/24/2012 18:49:10 InstallWizard|Getting CallManager wizard|<:INFO>
01/24/2012 18:49:10 InstallWizard|Wizard not found for CallManager|<:INFO>
01/24/2012 18:49:10 InstallWizard|clusterConfigEnabled: cluster='optional'.|<:DEBUG>
01/24/2012 18:49:10 InstallWizard|'/usr/local/platform/bin/clm/clm_ctl set install_configuration_complete yes'  executed successfully|<:INFO>
01/24/2012 18:49:10 InstallWizard|written 6548 bytes to /usr/local/platform/conf//platformConfig.xml|<:INFO>
01/24/2012 18:49:10 InstallWizard|Exiting InstallWizard with return code 0|<:INFO>
01/24/2012 18:49:10 platform_post_install|Migrate platform certificates|<:INFO>
01/24/2012 18:49:10 platform_post_install|Get source and destination versions|<:DEBUG>
01/24/2012 18:49:10 platform_post_install|Calling "/usr/local/bin/base_scripts/env.sh /usr/local/bin/base_scripts/upgrade_platform_certs.sh 8.6.2.22900-9 8.6.2.22900-9"|<:DEBUG>
01/24/2012 18:49:12 platform_post_install|(CAPTURE) [12/01/24_18:49:10] /usr/local/bin/base_scripts/upgrade_platform_certs.sh: 8.6.2.22900-9 8.6.2.22900-9 8 8|<:DEBUG>
01/24/2012 18:49:12 platform_post_install|(CAPTURE) [12/01/24_18:49:10] /usr/local/bin/base_scripts/upgrade_platform_certs.sh: creating /usr/local/platform/.security/tomcat|<:DEBUG>
01/24/2012 18:49:12 platform_post_install|(CAPTURE) [12/01/24_18:49:10] /usr/local/bin/base_scripts/upgrade_platform_certs.sh: copying /usr/local/platform/.security/tomcat from /partB/usr/local/platform|<:DEBUG>
01/24/2012 18:49:12 platform_post_install|(CAPTURE) [12/01/24_18:49:10] /usr/local/bin/base_scripts/upgrade_platform_certs.sh: calling /usr/local/platform/bin/gen_tomcat_selfsigned.py -u|<:DEBUG>
01/24/2012 18:49:12 platform_post_install|(CAPTURE) Processing token in else 0 IT|<:DEBUG>
01/24/2012 18:49:12 platform_post_install|(CAPTURE) coutn is 1|<:DEBUG>
01/24/2012 18:49:12 platform_post_install|(CAPTURE) |<:DEBUG>
01/24/2012 18:49:12 platform_post_install|(CAPTURE) Update only. Not regenerating tomcat certificate but importing tomcat cert to its own trust store.|<:DEBUG>
01/24/2012 18:49:12 platform_post_install|(CAPTURE) executing import command /usr/local/platform/bin/CertMgmt.py op:import unit:tomcat-trust logfile:/tmp/tomcat.log resultfile:/tmp/tomcat.xml key-dir:/usr/local/platform/.security/tomcat/keys src-cert:/usr/local/platform/.security/tomcat/certs/tomcat.pem cert-dir:/usr/local/platform/.security/tomcat/trust-certs type:trust-certs|<:DEBUG>
01/24/2012 18:49:12 platform_post_install|(CAPTURE) Successfully imported tomcat self signed certificate to tomcat trust-store tomcat|<:DEBUG>
01/24/2012 18:49:12 platform_post_install|(CAPTURE) 2|<:DEBUG>
01/24/2012 18:49:12 platform_post_install|(CAPTURE) LEVEL 1 pass|<:DEBUG>
01/24/2012 18:49:12 platform_post_install|(CAPTURE) LEVEL 2 pass|<:DEBUG>
01/24/2012 18:49:12 platform_post_install|(CAPTURE) Successfully updated tomcat configfile|<:DEBUG>
01/24/2012 18:49:12 platform_post_install|(CAPTURE) [12/01/24_18:49:12] /usr/local/bin/base_scripts/upgrade_platform_certs.sh: Updated the ownership of files under directory /usr/local/platform/.security/tomcat|<:DEBUG>
01/24/2012 18:49:12 platform_post_install|(CAPTURE) [12/01/24_18:49:12] /usr/local/bin/base_scripts/upgrade_platform_certs.sh: creating /usr/local/platform/.security/ipsec|<:DEBUG>
01/24/2012 18:49:12 platform_post_install|(CAPTURE) [12/01/24_18:49:12] /usr/local/bin/base_scripts/upgrade_platform_certs.sh: copying /usr/local/platform/.security/ipsec from /partB/usr/local/platform|<:DEBUG>
01/24/2012 18:49:12 platform_post_install|(CAPTURE) [12/01/24_18:49:12] /usr/local/bin/base_scripts/upgrade_platform_certs.sh: Updated the ownership of files under directory /usr/local/platform/.security/ipsec|<:DEBUG>
01/24/2012 18:49:12 platform_post_install|(CAPTURE) [12/01/24_18:49:12] /usr/local/bin/base_scripts/upgrade_platform_certs.sh: sftp config not available|<:DEBUG>
01/24/2012 18:49:12 platform_post_install|(CAPTURE) [12/01/24_18:49:12] /usr/local/bin/base_scripts/upgrade_platform_certs.sh: copying /partB/usr/local/platform/conf/certMonitorConfig.xml|<:DEBUG>
01/24/2012 18:49:12 platform_post_install|modifying /etc/init.d/kudzu script to run in quiet mode|<:INFO>
01/24/2012 18:49:12 platform_post_install|succesfully modified /etc/init.d/kudzu script to run in quiet mode|<:INFO>
01/24/2012 18:49:12 platform_post_install|kerneldump - Successfully modified /sbin/mkdumprd to include libcrypto library for kerneldump ssh|<:INFO>
01/24/2012 18:49:12 platform_post_install|increased kerneldump start and stop priority; for dumping on local disk|<:INFO>
01/24/2012 18:49:12 platform_post_install|kerneldump successfully enabled by default|<:INFO>
01/24/2012 18:49:12 platform_post_install|Successfully updated /etc/modprobe.d/blacklist|<:INFO>
01/24/2012 18:49:12 platform_post_install|Post-install processing complete|<:INFO>
01/24/2012 18:49:12 platform_post_install|Platform Post-upgrade RTMTFinish|<:NOTICE>
01/24/2012 18:49:12 platform_post_install|Platform Post-upgrade successful|<:INFO>
01/24/2012 18:49:12 upgrade_manager.sh|Post-processing complete|<:INFO>
01/24/2012 18:49:12 upgrade_manager.sh|Platform install on inactive partition complete|<:INFO>
01/24/2012 18:49:12 upgrade_manager.sh|Stop iowait_monitor|<:INFO>
01/24/2012 18:49:13 upgrade_manager.sh|Start new iowait_monitor|<:INFO>
01/24/2012 18:49:13 upgrade_manager.sh|Starting upgrade monitor|<:INFO>
01/24/2012 18:49:13 upgrade_manager.sh|starting upgrade monitor in rpm_archive|<:INFO>
01/24/2012 18:49:13 upgrade_manager.sh|Upgrade monitor started|<:INFO>
01/24/2012 18:49:13 upgrade_manager.sh|Install applications on inactive partition|<:INFO>
01/24/2012 18:49:13 upgrade_manager.sh|Perform post-upgrade processing with chroot to /partB|<:INFO>
01/24/2012 18:49:13 upgrade_manager.sh|Calling chroot /partB /opt/cisco/install/bin/post_upgrade mode=upgrade |<:DEBUG>
01/24/2012 18:49:13 post_upgrade|Initialize product API|<:DEBUG>
01/24/2012 18:49:16 post_upgrade|Initialize hardware API|<:DEBUG>
01/24/2012 18:49:16 post_upgrade|Initialize api complete|<:INFO>
01/24/2012 18:49:16 post_upgrade|Calling "source /etc/opt/cisco/install/setup/apply_tzupdater.sh"|<:DEBUG>
01/24/2012 18:49:16 post_upgrade|Calling "source /etc/opt/cisco/install/setup/check_root_cron_job.sh"|<:DEBUG>
01/24/2012 18:49:16 post_upgrade|Calling "source /etc/opt/cisco/install/setup/configure_core_and_syslogd.sh"|<:DEBUG>
01/24/2012 18:49:16 post_upgrade|Calling "source /etc/opt/cisco/install/setup/configure_writecache.sh"|<:DEBUG>
01/24/2012 18:49:16 post_upgrade|Calling "source /etc/opt/cisco/install/setup/create_jdk_links.sh"|<:DEBUG>
01/24/2012 18:49:16 post_upgrade|Calling "source /etc/opt/cisco/install/setup/create_old_style_config_files.sh"|<:DEBUG>
01/24/2012 18:49:16 post_upgrade|Calling "source /etc/opt/cisco/install/setup/dell_init.sh"|<:DEBUG>
01/24/2012 18:49:16 post_upgrade|Calling "source /etc/opt/cisco/install/setup/disable_ntp_from_dhcp.sh"|<:DEBUG>
01/24/2012 18:49:16 post_upgrade|Calling "source /etc/opt/cisco/install/setup/disable_services.sh"|<:DEBUG>
01/24/2012 18:49:16 post_upgrade|Calling "source /etc/opt/cisco/install/setup/fix_issue.sh"|<:DEBUG>
01/24/2012 18:49:16 post_upgrade|Calling "source /etc/opt/cisco/install/setup/initialize_logging.sh"|<:DEBUG>
01/24/2012 18:49:16 post_upgrade|Calling "source /etc/opt/cisco/install/setup/install_chkpatch.sh"|<:DEBUG>
01/24/2012 18:49:16 post_upgrade|Calling "source /etc/opt/cisco/install/setup/install_master_rpm.sh"|<:DEBUG>
01/24/2012 18:49:16 post_upgrade|Calling "source /etc/opt/cisco/install/setup/install_platform_prefs.sh"|<:DEBUG>
01/24/2012 18:49:16 post_upgrade|Calling "source /etc/opt/cisco/install/setup/ipmi_service.sh"|<:DEBUG>
01/24/2012 18:49:16 post_upgrade|Calling "source /etc/opt/cisco/install/setup/net-snmp_service.sh"|<:DEBUG>
01/24/2012 18:49:16 post_upgrade|Calling "source /etc/opt/cisco/install/setup/populate_archive.sh"|<:DEBUG>
01/24/2012 18:49:16 post_upgrade|Calling "source /etc/opt/cisco/install/setup/prepare_log_area.sh"|<:DEBUG>
01/24/2012 18:49:16 post_upgrade|Calling "source /etc/opt/cisco/install/setup/product_info.sh"|<:DEBUG>
01/24/2012 18:49:16 post_upgrade|Calling "source /etc/opt/cisco/install/setup/relocate_java.sh"|<:DEBUG>
01/24/2012 18:49:16 post_upgrade|Calling "source /etc/opt/cisco/install/setup/setup_cli_access.sh"|<:DEBUG>
01/24/2012 18:49:16 post_upgrade|Calling "source /etc/opt/cisco/install/setup/setup_handle_modprobe_blacklist_file.sh"|<:DEBUG>
01/24/2012 18:49:16 post_upgrade|Calling "source /etc/opt/cisco/install/setup/setup_java_api.sh"|<:DEBUG>
01/24/2012 18:49:16 post_upgrade|Calling "source /etc/opt/cisco/install/setup/setup_kdump.sh"|<:DEBUG>
01/24/2012 18:49:16 post_upgrade|Calling "source /etc/opt/cisco/install/setup/setup_ntp.sh"|<:DEBUG>
01/24/2012 18:49:16 post_upgrade|Calling "source /etc/opt/cisco/install/setup/setup_ntp_watchdog.sh"|<:DEBUG>
01/24/2012 18:49:16 post_upgrade|Calling "source /etc/opt/cisco/install/setup/setup_root_access.sh"|<:DEBUG>
01/24/2012 18:49:16 post_upgrade|Calling "source /etc/opt/cisco/install/setup/setup_serial_console.sh"|<:DEBUG>
01/24/2012 18:49:16 post_upgrade|Calling "source /etc/opt/cisco/install/setup/smartd_service.sh"|<:DEBUG>
01/24/2012 18:49:16 post_upgrade|Calling "source /etc/opt/cisco/install/setup/swap_nic_if.sh"|<:DEBUG>
01/24/2012 18:49:16 post_upgrade|Calling "source /etc/opt/cisco/install/setup/TEMPLATE.sh"|<:DEBUG>
01/24/2012 18:49:16 post_upgrade|Calling "source /etc/opt/cisco/install/setup/temp_workaround.sh"|<:DEBUG>
01/24/2012 18:49:16 post_upgrade|Calling "source /etc/opt/cisco/install/setup/update_etc_profile.sh"|<:DEBUG>
01/24/2012 18:49:16 post_upgrade|Calling "source /etc/opt/cisco/install/setup/update_fstab.sh"|<:DEBUG>
01/24/2012 18:49:16 post_upgrade|Calling "source /etc/opt/cisco/install/setup/update_install_conf_unrst.sh"|<:DEBUG>
01/24/2012 18:49:16 post_upgrade|Calling "source /etc/opt/cisco/install/setup/update_iptables.sh"|<:DEBUG>
01/24/2012 18:49:16 post_upgrade|Calling "source /etc/opt/cisco/install/setup/update_rc_sysinit.sh"|<:DEBUG>
01/24/2012 18:49:16 post_upgrade|Calling "source /etc/opt/cisco/install/setup/update_tmpwatch.sh"|<:DEBUG>
01/24/2012 18:49:16 post_upgrade|Calling "source /etc/opt/cisco/install/setup/utils.sh"|<:DEBUG>
01/24/2012 18:49:16 post_upgrade|Parse argument mode=upgrade|<:DEBUG>
01/24/2012 18:49:16 post_upgrade|Post Upgrade Initialization RTMTStart|<:NOTICE>
01/24/2012 18:49:16 post_upgrade|Starting post_upgrade processing|<:INFO>
01/24/2012 18:49:16 post_upgrade|PRODUCT_TARGET is UCM|<:INFO>
01/24/2012 18:49:16 post_upgrade|PRODUCT_NAME is Cisco Unified Communications Manager|<:INFO>
01/24/2012 18:49:16 post_upgrade|PRODUCT_VERSION is 8.6.2.22900-9|<:INFO>
01/24/2012 18:49:16 post_upgrade|Calling "mkdir -p /mnt/floppy"|<:DEBUG>
01/24/2012 18:49:16 post_upgrade|Calling "mkdir -p /mnt/usb"|<:DEBUG>
01/24/2012 18:49:16 post_upgrade|Calling "mkdir -p /mnt/scratch"|<:DEBUG>
01/24/2012 18:49:16 post_upgrade|Installing platform prefs files|<:INFO>
01/24/2012 18:49:16 post_upgrade|Calling "/usr/local/bin/base_scripts/sd_prefs -set ALL"|<:DEBUG>
01/24/2012 18:49:18 post_upgrade|Calling "/usr/local/bin/base_scripts/sd_installprefs -set ALL"|<:DEBUG>
01/24/2012 18:49:18 post_upgrade|Platform prefs files install complete|<:INFO>
01/24/2012 18:49:18 post_upgrade|Checking if CLI disabling is supported ..|<:INFO>
01/24/2012 18:49:21 removeCliAccess.sh|The product Cisco Unified Communications Manager supports CLI (Command Line) access|<:INFO>
01/24/2012 18:49:21 post_upgrade|Install applications|<:INFO>
01/24/2012 18:49:21 post_upgrade|Calling /usr/local/bin/base_scripts/appmanager.sh -upgrade -basepath /common/rpm-archive/8.6.2.22900-9 -logfile /common/log/install/install_log_2012-01-24.18.41.35.log -resultfile /common/log/install/upgrade-results.xml|<:DEBUG>
01/24/2012 18:49:22 appmanager.sh|Appliation install RTMTStart|<:NOTICE>
01/24/2012 18:49:22 appmanager.sh|Parse argument -upgrade|<:DEBUG>
01/24/2012 18:49:22 appmanager.sh|Parse argument -basepath|<:DEBUG>
01/24/2012 18:49:22 appmanager.sh|Parse argument -logfile|<:DEBUG>
01/24/2012 18:49:22 appmanager.sh|Parse argument -resultfile|<:DEBUG>
01/24/2012 18:49:22 appmanager.sh|action type is upgrade|<:DEBUG>
01/24/2012 18:49:22 appmanager.sh|Application upgrade starting|<:INFO>
01/24/2012 18:49:22 component_install|Initializing xproduct.sh API|<:DEBUG>
01/24/2012 18:49:22 component_install|Initializing xcomponent.sh API|<:DEBUG>
01/24/2012 18:49:22 component_install|Initializing xplatformconfig.sh API|<:DEBUG>
01/24/2012 18:49:22 component_install|Parse argument type=infrastructure_post|<:DEBUG>
01/24/2012 18:49:22 component_install|Parse argument mode=upgrade|<:DEBUG>
01/24/2012 18:49:22 component_install|Install infrastructure_post component, mode upgrade|<:INFO>
01/24/2012 18:49:22 component_install|Initialize product data, mode upgrade|<:INFO>
01/24/2012 18:49:22 component_install|Initialize "to" side product version|<:INFO>
01/24/2012 18:49:22 component_install|Access "to" side API|<:DEBUG>
01/24/2012 18:49:22 component_install|Got version 8.6.2.22900-9|<:DEBUG>
01/24/2012 18:49:22 component_install|Initialize "to" side product version complete|<:INFO>
01/24/2012 18:49:22 component_install|Initialize "from" side product version|<:INFO>
01/24/2012 18:49:22 component_install|Access "from" side API|<:DEBUG>
01/24/2012 18:49:22 component_install|Got version 8.6.2.20000-2|<:DEBUG>
01/24/2012 18:49:22 component_install|Initialize "from" side product version complete|<:INFO>
01/24/2012 18:49:22 component_install|Initialize product data complete|<:INFO>
01/24/2012 18:49:23 component_install|Initialize component data, mode upgrade|<:INFO>
01/24/2012 18:49:23 component_install|Initialize thirdparty "to" side version|<:INFO>
01/24/2012 18:49:23 component_install|Access "to" side API|<:DEBUG>
01/24/2012 18:49:23 component_install|Got version 8.6.2.22900-9|<:DEBUG>
01/24/2012 18:49:23 component_install|Initialize thirdparty "to" side version complete|<:INFO>
01/24/2012 18:49:23 component_install|Initialize thirdparty "from" side version|<:INFO>
01/24/2012 18:49:23 component_install|Component thirdparty available on active side|<:DEBUG>
01/24/2012 18:49:23 component_install|Access "from" side API|<:DEBUG>
01/24/2012 18:49:23 component_install|Got version 8.6.2.20000-2|<:DEBUG>
01/24/2012 18:49:23 component_install|Initialize thirdparty "from" side version complete|<:INFO>
01/24/2012 18:49:23 component_install|Initialize global data complete|<:INFO>
01/24/2012 18:49:23 component_install|Build the command list for thirdparty|<:INFO>
01/24/2012 18:49:23 component_install|Initialize command list|<:DEBUG>
01/24/2012 18:49:23 component_install|Build thirdparty install phase commands|<:DEBUG>
01/24/2012 18:49:23 component_install|Processing thirdparty install element|<:DEBUG>
01/24/2012 18:49:23 component_install|Processing thirdparty package element|<:DEBUG>
01/24/2012 18:49:23 component_install|Checking if RPM /common/rpm-archive/8.6.2.22900-9/RPMS/thirdparty/cm-lib-1.0.0.0-1.i386.rpm exists|<:DEBUG>
01/24/2012 18:49:23 component_install|Add "rpm  -iv --replacefiles /common/rpm-archive/8.6.2.22900-9/RPMS/thirdparty/cm-lib-1.0.0.0-1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:49:23 component_install|Building the command list for thirdparty is complete|<:INFO>
01/24/2012 18:49:23 component_install|Command execution for thirdparty component RTMTStart|<:NOTICE>
01/24/2012 18:49:23 component_install|Execute commands in the command list for thirdparty component|<:INFO>
01/24/2012 18:49:23 component_install|Execute "rpm  -iv --replacefiles /common/rpm-archive/8.6.2.22900-9/RPMS/thirdparty/cm-lib-1.0.0.0-1.i386.rpm"|<:DEBUG>
01/24/2012 18:49:23 component_install|Command execution for thirdparty component is complete|<:INFO>
01/24/2012 18:49:23 component_install|Command execution for thirdparty component RTMTFinish|<:NOTICE>
01/24/2012 18:49:23 component_install|Initialize serviceability_core "to" side version|<:INFO>
01/24/2012 18:49:24 component_install|Initialize serviceability_core "to" side version complete|<:INFO>
01/24/2012 18:49:24 component_install|Initialize serviceability_core "from" side version|<:INFO>
01/24/2012 18:49:24 component_install|Component serviceability_core available on active side|<:DEBUG>
01/24/2012 18:49:24 component_install|Access "from" side API|<:DEBUG>
01/24/2012 18:49:24 component_install|Got version 8.6.2.20000-2|<:DEBUG>
01/24/2012 18:49:24 component_install|Initialize serviceability_core "from" side version complete|<:INFO>
01/24/2012 18:49:24 component_install|Initialize global data complete|<:INFO>
01/24/2012 18:49:24 component_install|Build the command list for serviceability_core|<:INFO>
01/24/2012 18:49:24 component_install|Initialize command list|<:DEBUG>
01/24/2012 18:49:24 component_install|Build serviceability_core install phase commands|<:DEBUG>
01/24/2012 18:49:24 component_install|Processing serviceability_core install element|<:DEBUG>
01/24/2012 18:49:24 component_install|Processing serviceability_core package element|<:DEBUG>
01/24/2012 18:49:24 component_install|Checking if RPM /common/rpm-archive/8.6.2.22900-9/RPMS/serviceability_core/cm-pi-0.0.0.1-0.i386.rpm exists|<:DEBUG>
01/24/2012 18:49:24 component_install|Add "rpm  -iv --replacefiles /common/rpm-archive/8.6.2.22900-9/RPMS/serviceability_core/cm-pi-0.0.0.1-0.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:49:24 component_install|Building the command list for serviceability_core is complete|<:INFO>
01/24/2012 18:49:24 component_install|Command execution for serviceability_core component RTMTStart|<:NOTICE>
01/24/2012 18:49:24 component_install|Execute commands in the command list for serviceability_core component|<:INFO>
01/24/2012 18:49:24 component_install|Execute "rpm  -iv --replacefiles /common/rpm-archive/8.6.2.22900-9/RPMS/serviceability_core/cm-pi-0.0.0.1-0.i386.rpm"|<:DEBUG>
01/24/2012 18:49:24 component_install|Command execution for serviceability_core component is complete|<:INFO>
01/24/2012 18:49:24 component_install|Command execution for serviceability_core component RTMTFinish|<:NOTICE>
01/24/2012 18:49:24 component_install|Initialize component data, mode upgrade|<:INFO>
01/24/2012 18:49:24 component_install|Initialize database "to" side version|<:INFO>
01/24/2012 18:49:24 component_install|Access "to" side API|<:DEBUG>
01/24/2012 18:49:24 component_install|Got version 8.6.2.22900-9|<:DEBUG>
01/24/2012 18:49:24 component_install|Initialize database "to" side version complete|<:INFO>
01/24/2012 18:49:24 component_install|Initialize database "from" side version|<:INFO>
01/24/2012 18:49:24 component_install|Component database available on active side|<:DEBUG>
01/24/2012 18:49:24 component_install|Initialize database "from" side version complete|<:INFO>
01/24/2012 18:49:24 component_install|Build the command list for database|<:INFO>
01/24/2012 18:49:24 component_install|Build database install phase commands|<:DEBUG>
01/24/2012 18:49:24 component_install|Processing database install element|<:DEBUG>
01/24/2012 18:49:25 component_install|Processing database package element|<:DEBUG>
01/24/2012 18:49:25 component_install|Checking if RPM /common/rpm-archive/8.6.2.22900-9/RPMS/database/cm-dbms-1.0.0.0-1.i386.rpm exists|<:DEBUG>
01/24/2012 18:49:25 component_install|Add "rpm  -iv --replacefiles /common/rpm-archive/8.6.2.22900-9/RPMS/database/cm-dbms-1.0.0.0-1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:49:25 component_install|Checking if RPM /common/rpm-archive/8.6.2.22900-9/RPMS/database/cm-dbl-1.0.0.0-1.i386.rpm exists|<:DEBUG>
01/24/2012 18:49:25 component_install|Add "rpm  -iv --replacefiles /common/rpm-archive/8.6.2.22900-9/RPMS/database/cm-dbl-1.0.0.0-1.i386.rpm" to command list|<:DEBUG>
01/24/2012 18:49:25 component_install|Processing database phase element|<:DEBUG>
01/24/2012 18:49:25 component_install|Processing database import element|<:DEBUG>
01/24/2012 18:49:25 component_install|Processing database migration element|<:DEBUG>
01/24/2012 18:49:25 component_install|Processing database script element|<:DEBUG>
01/24/2012 18:49:25 component_install|Add "cm-dbms-install L2 Migration 8.6.2.22900-9 8.6.2.20000-2 /usr/local/cm/ /partB/usr/local/cm/ /common/log/install/capture.txt" to command list|<:DEBUG>
01/24/2012 18:49:25 component_install|Add "cm-dbl-install L2 Migration 8.6.2.22900-9 8.6.2.20000-2 /usr/local/cm/ /partB/usr/local/cm/ /common/log/install/capture.txt" to command list|<:DEBUG>
01/24/2012 18:49:25 component_install|Processing database postinstall element|<:DEBUG>
01/24/2012 18:49:26 component_install|Processing database script element|<:DEBUG>
01/24/2012 18:49:26 component_install|Add "cm-dbms-install L2 PostInstall 8.6.2.22900-9 8.6.2.20000-2 /usr/local/cm/ /partB/usr/local/cm/ /common/log/install/capture.txt" to command list|<:DEBUG>
01/24/2012 18:49:26 component_install|Add "cm-dbl-install L2 PostInstall 8.6.2.22900-9 8.6.2.20000-2 /usr/local/cm/ /partB/usr/local/cm/ /common/log/install/capture.txt" to command list|<:DEBUG>
01/24/2012 18:49:26 component_install|Add "cm-dbl-ontape_backup-install L2 PostInstall 8.6.2.22900-9 8.6.2.20000-2 /usr/local/cm/ /partB/usr/local/cm/ /common/log/install/capture.txt" to command list|<:DEBUG>
01/24/2012 18:49:26 component_install|Building the command list for database is complete|<:INFO>
01/24/2012 18:49:26 component_install|Command execution for database component RTMTStart|<:NOTICE>
01/24/2012 18:49:26 component_install|Execute commands in the command list for database component|<:INFO>
01/24/2012 18:49:26 component_install|Execute "rpm  -iv --replacefiles /common/rpm-archive/8.6.2.22900-9/RPMS/database/cm-dbms-1.0.0.0-1.i386.rpm"|<:DEBUG>
01/24/2012 18:49:29 component_install|Execute "rpm  -iv --replacefiles /common/rpm-archive/8.6.2.22900-9/RPMS/database/cm-dbl-1.0.0.0-1.i386.rpm"|<:DEBUG>
01/24/2012 18:49:31 component_install|Search path is /opt/cisco/install/database/scripts:/usr/local/cm/script|<:DEBUG>
01/24/2012 18:49:31 component_install|Checking command /opt/cisco/install/database/scripts/cm-dbms-install|<:DEBUG>
01/24/2012 18:49:31 component_install|Checking command /usr/local/cm/script/cm-dbms-install|<:DEBUG>
01/24/2012 18:49:31 component_install|Execute "/usr/local/cm/script/cm-dbms-install L2 Migration 8.6.2.22900-9 8.6.2.20000-2 /usr/local/cm/ /partB/usr/local/cm/ /common/log/install/capture.txt"|<:DEBUG>
01/24/2012 18:49:31 component_install|Checking command /opt/cisco/install/database/scripts/cm-dbl-install|<:DEBUG>
01/24/2012 18:49:31 component_install|Checking command /usr/local/cm/script/cm-dbl-install|<:DEBUG>
01/24/2012 18:49:31 component_install|Execute "/usr/local/cm/script/cm-dbl-install L2 Migration 8.6.2.22900-9 8.6.2.20000-2 /usr/local/cm/ /partB/usr/local/cm/ /common/log/install/capture.txt"|<:DEBUG>
01/24/2012 18:49:40 component_install|Search path is /opt/cisco/install/database/scripts:/usr/local/cm/script|<:DEBUG>
01/24/2012 18:49:40 component_install|Checking command /opt/cisco/install/database/scripts/cm-dbms-install|<:DEBUG>
01/24/2012 18:49:40 component_install|Checking command /usr/local/cm/script/cm-dbms-install|<:DEBUG>
01/24/2012 18:49:40 component_install|Execute "/usr/local/cm/script/cm-dbms-install L2 PostInstall 8.6.2.22900-9 8.6.2.20000-2 /usr/local/cm/ /partB/usr/local/cm/ /common/log/install/capture.txt"|<:DEBUG>
01/24/2012 19:01:13 component_install|Search path is /opt/cisco/install/database/scripts:/usr/local/cm/script|<:DEBUG>
01/24/2012 19:01:13 component_install|Checking command /opt/cisco/install/database/scripts/cm-dbl-install|<:DEBUG>
01/24/2012 19:01:13 component_install|Checking command /usr/local/cm/script/cm-dbl-install|<:DEBUG>
01/24/2012 19:01:13 component_install|Execute "/usr/local/cm/script/cm-dbl-install L2 PostInstall 8.6.2.22900-9 8.6.2.20000-2 /usr/local/cm/ /partB/usr/local/cm/ /common/log/install/capture.txt"|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE) log4j:ERROR Could not create an Appender. Reported error follows.|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE) java.lang.ClassNotFoundException: com.cisco.ccm.serviceability.trace.CcmRollingFileAppender|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE)     at java.net.URLClassLoader$1.run(URLClassLoader.java:202)|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE)     at java.security.AccessController.doPrivileged(Native Method)|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE)     at java.net.URLClassLoader.findClass(URLClassLoader.java:190)|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE)     at java.lang.ClassLoader.loadClass(ClassLoader.java:306)|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE)     at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:301)|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE)     at java.lang.ClassLoader.loadClass(ClassLoader.java:247)|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE)     at java.lang.Class.forName0(Native Method)|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE)     at java.lang.Class.forName(Class.java:169)|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE)     at org.apache.log4j.helpers.Loader.loadClass(Loader.java:160)|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE)     at org.apache.log4j.xml.DOMConfigurator.parseAppender(DOMConfigurator.java:164)|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE)     at org.apache.log4j.xml.DOMConfigurator.findAppenderByName(DOMConfigurator.java:140)|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE)     at org.apache.log4j.xml.DOMConfigurator.findAppenderByReference(DOMConfigurator.java:153)|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE)     at org.apache.log4j.xml.DOMConfigurator.parseChildrenOfLoggerElement(DOMConfigurator.java:415)|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE)     at org.apache.log4j.xml.DOMConfigurator.parseCategory(DOMConfigurator.java:335)|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE)     at org.apache.log4j.xml.DOMConfigurator.parse(DOMConfigurator.java:781)|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE)     at org.apache.log4j.xml.DOMConfigurator.doConfigure(DOMConfigurator.java:666)|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE)     at org.apache.log4j.xml.DOMConfigurator.doConfigure(DOMConfigurator.java:616)|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE)     at org.apache.log4j.xml.DOMConfigurator.doConfigure(DOMConfigurator.java:584)|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE)     at org.apache.log4j.xml.DOMConfigurator.configure(DOMConfigurator.java:687)|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE)     at com.cisco.ccm.dbl.Log4j.initLogs(Log4j.java:80)|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE)     at com.cisco.ccm.dbl.Connector.(Connector.java:341)|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE)     at com.cisco.ccm.dbl.util.ProcessNodeId.setProcessNodeId(ProcessNodeId.java:104)|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE)     at com.cisco.ccm.dbl.util.ProcessNodeId.(ProcessNodeId.java:64)|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE)     at com.cisco.ccm.dbl.util.ReplHelper.run(ReplHelper.java:144)|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE)     at com.cisco.ccm.dbl.util.ReplHelper.main(ReplHelper.java:290)|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE) log4j:ERROR Could not parse input source [org.xml.sax.InputSource@12d3205].|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE) java.lang.NullPointerException|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE)     at java.util.Hashtable.put(Hashtable.java:394)|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE)     at org.apache.log4j.xml.DOMConfigurator.findAppenderByName(DOMConfigurator.java:141)|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE) got exception while loading dblj trace config filenull|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE)     at com.cisco.ccm.dbl.Log4j.initLogs(Log4j.java:89)|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE) Tue Jan 24 19:01:16 GMT 2012:main:connect() SQLException|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE) log4j:WARN No appenders could be found for logger (com.cisco.ccm.dbl.Connector).|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE) log4j:WARN Please initialize the log4j system properly.|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE) Tue Jan 24 19:01:17 GMT 2012:main:|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE) Tue Jan 24 19:01:17 GMT 2012:main:handleConnectionException: ErrorCode is -761|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE) No processnode record|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE)     at com.cisco.ccm.dbl.util.ReplHelper.main(ReplHelper.java:294)|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE) log4j:ERROR Could not parse input source [org.xml.sax.InputSource@10382a9].|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE) Tue Jan 24 19:01:17 GMT 2012:main:connect() SQLException|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE) initial args in: sftpuser@Colo-LonCCM-01|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE) prompt: 0|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE) verify: 0|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE) fingerprint: |<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE) param in: sftpuser@Colo-LonCCM-01|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE) Calling sftp with arguments sftpuser@Colo-LonCCM-01|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE) spawn sftp sftpuser@Colo-LonCCM-01|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE) Connecting to Colo-LonCCM-01...|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE) sftp> sftp> lcd /tmp|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE) sftp> get /usr/local/cm/db/informix/etc/sqlhosts|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE) Fetching /usr/local/cm/db/informix/etc/sqlhosts to sqlhosts|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE) sftp> get /etc/services|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE) Fetching /etc/services to services|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE) sftp> get /home/informix/.rhosts|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE) Fetching /home/informix/.rhosts to .rhosts|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE) Going to delete file /usr/local/platform/conf/ims/prefs.xml |<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE) From saveAs () - Going to save file /usr/local/platform/conf/ims/prefs.xml |<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE) file to save is /usr/local/platform/conf/ims/prefs.xml |<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE)  I am in dblstart |<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE) dblstart a[l2] |<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE) dblstart a[--safe] |<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE) dblstart a[--nopreflight] |<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE) dblstart a[--log=/common/log/install/capture.txt] [/common/log/install/capture.txt] |<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE) su -c 'if [ -f /usr/local/cm/db/informix/local/ids.env ]; then source /usr/local/cm/db/informix/local/ids.env l2; fi ; /usr/local/cm/bin/cmoninit -w' - informix|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE) sftp> sftp> lcd /common/download|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE) sftp> get /common/ontape_backup.gz|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE) Fetching /common/ontape_backup.gz to ontape_backup.gz|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE) sftp> get /common/ontape_backup_done|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE) Fetching /common/ontape_backup_done to ontape_backup_done|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE) sftp> bye|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE) input param /usr/local/cm/script/cm-dbl-install L2 PO 8.6.2.22900-9 8.6.2.20000-2 /usr/local/cm /partB/usr/local/cm /common/log/install/capture.txt|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE) Log location [/common/log/install/capture.txt]|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE) Inside cm-dbl-install log location [/common/log/install/capture.txt]|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE) pub = [Colo-LonCCM-01]|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE) Inside getDataFromPub(Colo-LonCCM-01, True)|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE) localnode = [30nc-lonccm-sub-01]|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE) Before removing ONTAPE|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE) L2 value is [True]|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE) Inside the L2 case|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE) /home/sftpuser/sftp_connect.sh -b /usr/local/cm/db/sftp_batch sftpuser@Colo-LonCCM-01|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE) [(0, '783d2134838b003840cda9fc5fb5328f  /common/download/ontape_backup.gz')]  md5sum_pub = 783d2134838b003840cda9fc5fb5328f md5sum_local = 783d2134838b003840cda9fc5fb5328f|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE) ontape backup file version [ccm8_6_2_20000_2] db version on local box[ccm8_6_2_22900_9]|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE) Traceback (most recent call last):|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE)   File "/usr/local/cm/script/cm-dbl-install", line 1824, in ?|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE)     rc = doActionL2Update(gParams)|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE)   File "/usr/local/cm/script/cm-dbl-install", line 1782, in doActionL2Update|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE)     rc = doL2Post(params)|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE)   File "/usr/local/cm/script/cm-dbl-install", line 1626, in doL2Post|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE)     rc = doL2_migrateDB(params)             |<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE)   File "/usr/local/cm/script/cm-dbl-install", line 1538, in doL2_migrateDB|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE)     rc = installdb(params, dbfuncs, cntrig, True)|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE)   File "/usr/local/cm/script/cm-dbl-install", line 909, in installdb|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE)     rc = dbllib.getDataFromPub(pub, l2, isRU=ru)|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE)   File "/usr/local/cm/lib/dbllib.py", line 1426, in getDataFromPub|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE)     return retval|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE) UnboundLocalError: local variable 'retval' referenced before assignment|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE) mp/af* /tmp/shmem*|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE) Tue Jan 24 19:01:41 2012 cm-dbl-install.getPublisherFromPrefs  DEBUG:  -->|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE) Tue Jan 24 19:01:41 2012 cm-dbl-install.getPublisherFromPrefs  DEBUG:  Inside getPublisherFromPrefs...|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE) Tue Jan 24 19:01:41 2012 cm-dbl-install.getPublisherFromPrefs  DEBUG:  <--|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE) Tue Jan 24 19:01:41 2012 cm-dbl-install.shortHostName  DEBUG:  -->|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE) Tue Jan 24 19:01:41 2012 cm-dbl-install.shortHostName  DEBUG:  <--|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE) Tue Jan 24 19:01:41 2012 dbllib.getDataFromPub  DEBUG:  -->|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE) Tue Jan 24 19:01:41 2012 dbllib.getDataFromPub  DEBUG:  localnode = [30nc-lonccm-sub-01]|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE) Tue Jan 24 19:01:41 2012 dbllib.getDataFromPub  DEBUG:  Before removing ONTAPE|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE) Tue Jan 24 19:01:41 2012 dbllib.getDataFromPub  DEBUG:  L2 value is [True]|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE) Tue Jan 24 19:01:41 2012 dbllib.getDataFromPub  DEBUG:  /home/sftpuser/sftp_connect.sh -b /usr/local/cm/db/sftp_batch sftpuser@Colo-LonCCM-01|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE) Tue Jan 24 19:01:45 2012 dbllib.getDataFromPub  DEBUG:  [(0, '783d2134838b003840cda9fc5fb5328f  /common/download/ontape_backup.gz')]  md5sum_pub = 783d2134838b003840cda9fc5fb5328f md5sum_local = 783d2134838b003840cda9fc5fb5328f|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE) Tue Jan 24 19:01:45 2012 dbllib.getDataFromPub  DEBUG:  ontape backup file version [ccm8_6_2_20000_2] db version on local box[ccm8_6_2_22900_9]|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE) Tue Jan 24 19:01:45 2012 dbllib.getDataFromPub  DEBUG:  **********************************************************************************************************************|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE) |<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE) Tue Jan 24 19:01:45 2012 dbllib.getDataFromPub  DEBUG:  ontape_backup pulled from the pub is of a different version than running on this subscriber |<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE) Tue Jan 24 19:01:45 2012 dbllib.getDataFromPub  DEBUG:  please reupgrade the pub, this will regenerate the correct backup of the version that subscriber is being upgraded to |<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE) Tue Jan 24 19:01:45 2012 dbllib.getDataFromPub  DEBUG:  Install is going to fail now |<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE) Tue Jan 24 19:01:45 2012 dbllib.getDataFromPub  DEBUG:  calling os.remove to delete all the ontape_backup|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE) Tue Jan 24 19:01:45 2012 dbllib.getDataFromPub  DEBUG:  <--|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE) Tue Jan 24 19:01:45 2012 cm-dbl-install.installdb  DEBUG:  <--|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE) Tue Jan 24 19:01:45 2012 cm-dbl-install.doL2_migrateDB  DEBUG:  <--|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE) Tue Jan 24 19:01:45 2012 cm-dbl-install.doL2Post  DEBUG:  <--|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE) Tue Jan 24 19:01:45 2012 cm-dbl-install.doActionL2Update  DEBUG:  <--|<:DEBUG>
01/24/2012 19:01:45 component_install|(CAPTURE) Tue Jan 24 19:01:45 2012 cm-dbl-install  DEBUG:  <--|<:DEBUG>
01/24/2012 19:01:45 component_install|File:/opt/cisco/install/bin/component_install:798, Function: execute_shell_cmd(), /usr/local/cm/script/cm-dbl-install L2 PostInstall 8.6.2.22900-9 8.6.2.20000-2 /usr/local/cm/ /partB/usr/local/cm/ /common/log/install/capture.txt failed (1)|<:ERROR>
01/24/2012 19:01:45 appmanager.sh|Internal Error, File:/usr/local/bin/base_scripts/appmanager.sh:191, Function: upgrade(), failed to upgrade infrastructure_post components|<:CRITICAL>
01/24/2012 19:01:45 post_upgrade|File:/opt/cisco/install/bin/post_upgrade:131, Function: install_applications(), /usr/local/bin/base_scripts/appmanager.sh -upgrade -basepath /common/rpm-archive/8.6.2.22900-9 -logfile /common/log/install/install_log_2012-01-24.18.41.35.log -resultfile /common/log/install/upgrade-results.xml failed (1)|<:ERROR>
01/24/2012 19:01:45 upgrade_manager.sh|File:/common/download/8.6.2.22900-9/upgrade_manager.sh:1435, Function: main(), Applications upgrade failed|<:ERROR>
01/24/2012 19:01:45 upgrade_manager.sh|Final exit processing with result 1|<:INFO>
01/24/2012 19:01:45 upgrade_manager.sh|Exiting with result 1|<:INFO>
01/24/2012 19:01:45 upgrade_manager.sh|Invalidate upgrade partition|<:INFO>
01/24/2012 19:01:45 upgrade_manager.sh|Clean up rpm any stale __db. files in rpmdb on the to side|<:DEBUG>
01/24/2012 19:01:45 upgrade_manager.sh|Removing any master RPM from /partB|<:DEBUG>
01/24/2012 19:01:46 upgrade_manager.sh|Removing any /partB/etc/opt/cisco/install.conf|<:DEBUG>
01/24/2012 19:01:46 upgrade_manager.sh|Invalidate any product configuration file|<:DEBUG>
01/24/2012 19:01:46 upgrade_manager.sh|Setting product and deployment version attributes in /partB/etc/opt/cisco/install/conf/callmanager_product.conf to 0.0.0.0000-0000|<:DEBUG>
01/24/2012 19:01:46 upgrade_manager.sh|Calling /common/download/8.6.2.22900-9/Cisco/bin/prepare_grub --phase L2 --action recovery --basepath /mnt/source/Cisco --logfile /common/log/install/capture.txt|<:DEBUG>
01/24/2012 19:01:46 upgrade_manager.sh|(CAPTURE) [12/01/24_19:01:46] prepare_grub: Preparing grub for phase: l2!|<:DEBUG>
01/24/2012 19:01:46 upgrade_manager.sh|(CAPTURE) [12/01/24_19:01:46] prepare_grub: Setting up GRUB for l2 for recovery action|<:DEBUG>
01/24/2012 19:01:46 upgrade_manager.sh|(CAPTURE) Mail notification cancelled - smtp server address for email not found! [/common/cisco/platformConfig.xml]|<:DEBUG>
01/24/2012 19:01:46 upgrade_manager.sh|IOWAIT monitor stopped|<:INFO>
01/24/2012 19:01:47 upgrade_manager.sh|Exit processing with result 0|<:INFO>
01/24/2012 19:01:47 preflight|Starting preflight|<:INFO>
01/24/2012 19:01:47 preflight|Validate preflight data|<:INFO>
01/24/2012 19:01:47 preflight|Preflight data validation complete|<:INFO>
01/24/2012 19:01:47 preflight|Determine upgrade type|<:INFO>
01/24/2012 19:01:47 preflight|Active RH version = 5Server|<:DEBUG>
01/24/2012 19:01:47 preflight|New os version(xml) = 5Server|<:DEBUG>
01/24/2012 19:01:47 preflight|Upgrade type = L2|<:DEBUG>
01/24/2012 19:01:47 preflight|Obtain product type|<:INFO>
01/24/2012 19:01:48 preflight|Obtained product type CallManager|<:INFO>
01/24/2012 19:01:48 preflight|Processing preflight cleanup mode|<:INFO>
01/24/2012 19:01:48 preflight|Clear preflight cancel utility|<:INFO>
01/24/2012 19:01:48 preflight|Removing /common/cancel_upgrade/preflight_cancel|<:DEBUG>
01/24/2012 19:01:48 preflight|Execute cleanup preflight commands for CallManager:L2 from /mnt/source/Cisco/install/preflight.xml|<:INFO>
01/24/2012 19:01:48 preflight|Found 7 preflight commands to execute|<:DEBUG>
01/24/2012 19:01:48 preflight|Execute preflight command (1/7): rm -rf /usr/local/platform/conf/dynamicConfig.xml|<:DEBUG>
01/24/2012 19:01:48 preflight|Preflight command returns 0|<:DEBUG>
01/24/2012 19:01:48 preflight|Execute preflight command (2/7): cp -f /common/preflight/CM/L2/dynamicConfig.xml /usr/local/platform/conf/dynamicConfig.xml|<:DEBUG>
01/24/2012 19:01:48 preflight|Preflight command returns 1|<:DEBUG>
01/24/2012 19:01:48 preflight|(CAPTURE) cp: cannot stat `/common/preflight/CM/L2/dynamicConfig.xml': No such file or directory|<:DEBUG>
01/24/2012 19:01:48 preflight|Preflight command did not complete (1). Continuing command processing...|<:WARN>
01/24/2012 19:01:48 preflight|Execute preflight command (3/7): rm -rf /usr/local/thirdparty/jakarta-tomcat/webapps/cmplatform/WEB-INF/pages/install/dynamic.jsp|<:DEBUG>
01/24/2012 19:01:48 preflight|Execute preflight command (4/7): cp -f /common/preflight/CM/L2/dynamic.jsp /usr/local/thirdparty/jakarta-tomcat/webapps/cmplatform/WEB-INF/pages/install/dynamic.jsp|<:DEBUG>
01/24/2012 19:01:48 preflight|Execute preflight command (5/7): rm -rf /usr/local/thirdparty/jakarta-tomcat/webapps/cmplatform/WEB-INF/pages/install/install-confirm-content.jsp|<:DEBUG>
01/24/2012 19:01:48 preflight|Execute preflight command (6/7): cp -f /common/preflight/CM/L2/install-confirm-content.jsp /usr/local/thirdparty/jakarta-tomcat/webapps/cmplatform/WEB-INF/pages/install/install-confirm-content.jsp|<:DEBUG>
01/24/2012 19:01:48 preflight|Execute preflight command (7/7): rm -rf /common/preflight/CM/L2|<:DEBUG>
01/24/2012 19:01:48 upgrade_manager.sh|Cleanup RAM disk|<:INFO>
01/24/2012 19:01:48 upgrade_manager.sh|Unmount /common/mnt/product_img|<:DEBUG>
01/24/2012 19:01:48 upgrade_manager.sh|Cleanup mounted DVD or ISO|<:INFO>
01/24/2012 19:01:48 upgrade_manager.sh|Found mount point "/mnt/source" for source filesystem /dev/hdc|<:DEBUG>
01/24/2012 19:01:48 upgrade_manager.sh|Unmount /mnt/source|<:DEBUG>
01/24/2012 19:01:48 upgrade_manager.sh|Ejecting DVD (/dev/hdc)|<:DEBUG>
01/24/2012 19:01:48 upgrade_manager.sh|Refresh CLI product properties cache|<:INFO>
01/24/2012 19:01:48 upgrade_manager.sh|Refresh hardware cache|<:INFO>
01/24/2012 19:01:49 ServerApiManager|INITIALIZE: sam_legacy_mode_init=1|<:DEBUG>
01/24/2012 19:01:55 ServerApiManager|INITIALIZE: sam_hssi_mode_init=0|<:DEBUG>
01/24/2012 19:02:05 upgrade_manager.sh|Cleanup exiting - Cached Data: [Vendor= VMware, Inc.
HWModel=VMware
CPUCount=1
CPUType= Intel(R) Xeon(R) CPU E5-2640 0 @ 2.50GHz
CPUSpeed=2500
MEMSize=4096
BIOSVer=PhoenixTechnologiesLTD 6.00 06/22/2012
ObjectId=1.3.6.1.4.1.9.1.1348
OSVersion=UCOS 5.0.0.0-2
SerialNumber= VMware-42 02 f0 b7 39 f5 be 34-74 af 9e c5 1b 6e 10 96
VendorOID=1.3.6.1.4.1.674]|<:INFO>
01/24/2012 19:02:05 upgrade_install.sh|Cleaning up download...|<:INFO>
01/24/2012 19:02:05 upgrade_install.sh|Cleanup upgrade source area.|<:INFO>
01/24/2012 19:02:05 upgrade_install.sh|Ejecting DVD (/dev/sda1)|<:DEBUG>
01/24/2012 19:02:05 upgrade_install.sh|Removing /common/download/8.6.2.22900-9|<:INFO>
01/24/2012 19:02:06 upgrade_install.sh|Started auditd...|<:INFO>
01/24/2012 19:02:07 upgrade_install.sh|Started setroubleshoot...|<:INFO>
01/24/2012 19:02:07 upgrade_install.sh|Changed selinux mode to enforcing|<:INFO>
01/24/2012 19:02:07 upgrade_install.sh|Cleaning up rpm_archive...|<:INFO>
01/24/2012 19:02:07 upgrade_install.sh|Removing /common/rpm-archive/8.6.2.22900-9|<:INFO>
01/24/2012 19:02:11 upgrade_install.sh|File:/usr/local/bin/base_scripts/upgrade_install.sh:599, Function: main(), Upgrade Failed -- (1)|<:ERROR>
01/24/2012 19:02:11 upgrade_install.sh|set_upgrade_result: set to 1|<:DEBUG>
01/24/2012 19:02:11 upgrade_install.sh|is_upgrade_lock_available: Upgrade lock is not available.|<:DEBUG>
01/24/2012 19:02:11 upgrade_install.sh|is_upgrade_in_progress: Already locked by this process (pid: 12774).|<:DEBUG>
01/24/2012 19:02:11 upgrade_install.sh|release_upgrade_lock: Releasing lock (pid: 12774)|<:DEBUG>
Hi chukkaedovia,
I had a similar problem once and had tried the following:
  1. Upgraded the PUB to the new version but did not switch
  2. I then upgraded the SUBS to the new version but did not switch
  3. Switched the PUB to the new version
  4. Then switched the SUBS to the new version
  5. Confirmed that the DB Replication was ok within the cluster.
All the best and please check with TAC as well if the issue persists. They might have encountered it before and therefore will save you some time.
Richard Simmons
Level 3
Level 3
Did this ever get resolved, i have a similar issue where i am unable to upgrade to 9.1.2
