Expressway C Certs
Nkechi Latunji
I previously had external Certs on my expressway and all was working fine, we changed our local CA and wanted to updated the certs on my UC apps. I have successfully done so for CUCM, IMP and CUC. When i tried expressway C I received the following error
Invalid certificate: The file provided does not have a client usage attribute. The certificate must be usable for both servers and clients for Unified Communications.
I successfully uploaded the root CA to the expressway, I signed the CSR with the CA using web server template but it's not uploading to the server. Can someone help
Jaime Valencia
Adjust your certificate template to have the Enhanced Key Usage of server and client authentication as the error says.
Web server ONLY has server authentication.
java
if this helps, please rate
7 Replies 7
Jaime Valencia
java
How have you fixed this issue?
The error was what I mentioned, the certificate template was not properly configured with the right Enhanced Key Usage that was required.
java
This is not configured on Expressway side or on Microsoft CA Server side?
On the CA, you probably want to read this before further questions
http://docwiki.cisco.com/wiki/Certificates_FAQ
java
same error i faced while building a EXpressways lab and am using one of my windows server as CA.
this is the policy you need to add for client authentication
**** Please rate helpful posts *****
Thanks !
