09-24-2012 06:57 PM - edited 03-19-2019 05:35 AM
I'm being told that the voicemail ports are maxed with CUWL licensing (144 per server). Or, does CUWL automagically add the number of voicemail ports one needs baed on the number of users ordered? Or is neither true?
Kris.
09-24-2012 10:42 PM
Hi Kris
The last CUWL project I did got me a license for 3000+ users, and that granted 500 ports.
The actual built server supported less (I don't recall exactly) so it looks like they give you licenses for 500 and the actual count you get is based on your server or VM spec.
Principal Engineer at Logicalis UK
Please rate helpful posts...
09-25-2012 06:56 AM
Correct, the port licenses are free with CUWL and you can ask for as many ports as you desire, make sure you follow the design guidelines as supported number of ports depends on server and codec being used.
HTH,
Chris
01-15-2013 07:22 AM
Hi Kris Garner,
Please refer to the link as below.
