IM and Presence 11
scr.sybex1
Dear,
I Have a Problem During Cisco IM and Presence 11 Installation Procsess and the error page that i attached here.
I didn't install that before and Like to see if someone told me about the pre-installation, installation and post-installation task I should do another thing is that i don't know whether i should do something on cucm before installation or not.
thanks regard,
NTP shows unsyncronised.
Just check for that.
regds,
aman
8 Replies 8
Suresh Hudda
You need to add it first in cucm (cucm admin page -> system -> server) as IM and Presence and then start the imp installation and make sure imp version should be exactly same as of cucm.
Suresh
I add server to CUCM from directory that you said but error page is after doing this job.
and my CUCM version is 11.0.1.20000-2 and IM and Presence is 11.0.1.10000-6 you think that is there any problem with the version.
IT  will work.
https://supportforums.cisco.com/discussion/12745711/cucm-and-cimp-compatibility
regds,
aman
Dear,
Is there any service or configuration required on cucm that i should do for that ?
thanks,
regds,
aman
Dear Sir,
Thank So Much for good and fast reposes. the Problem is because of NTP Shows unsync Status. and I add a Public NTP server to solve that Problem.
Thanks Regard.
In addition to what Suresh has told, u also need to check the NTP status on CUCM.
It should be accessible/synronised and stratum should be 5 or below.
IMP is syncronised to CUCM  for NTP and CUCM in turn is syncronised to NTP server.
rgds,
aman
The NTP Server Status is Accessible.
