Showing results forĀ
Search instead forĀ
Did you mean:Ā
Integration of CP-6921-C-K9 and CP-7962G in CUCM 6.1.3
david_lozano
I need to integrate CP-6921-C-K9 and CP-7962G in CUCM 6.1.3. How can I integrate these new model of phones?
Do I need a Device Pack? How can I get this Device Pack?
David
ronpatel
Level 8
Level 8
Hi David,
CP-7962G :- Is supported in 6.0(1) and greater. So 6.1.3 has its supports by default.
CP-6921-C-K9 :- Supported in 7.1.2 and later using Skinny Client Control  Protocol (SCCP) and Supported in 7.1.5 and later using SIP. This can not be used in 6.1.3.
Ronak patel
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
8 Replies 8
ronpatel
Level 8
Level 8
Hi David,
Ronak patel
Hi Ronak,
Thanks for your help.
David
Hi Ronak,
I am looking for the matrix compatibity in CISCO web of these phones with the CUCM versions, but I donĀ“t fint it. I would like to send it to the customer.
Do you know where could I find this information?
Thanks for your help,
David
David,
Cisco Unified IP Phone 6900 Series
You can research Cisco Unified IP Phone 6900 Series compatibility with Cisco Unified Communications Manager releases by using the Cisco Unified Communications Compatibility Tool at the following URL:
http://tools.cisco.com/ITDIT/vtgsca/VTGServlet
Go to the preceding URL, select the Cisco Unified Communications Manager release that you want to research, then search the compatibility tool window to find the specific Cisco Unified IP Phone 6900 Series phone model you want, including the following:
ā€¢Cisco Unified IP Phone 6901
ā€¢Cisco Unified IP Phone 6911
ā€¢Cisco Unified IP Phone 6921
ā€¢Cisco Unified IP Phone 6941
ā€¢Cisco Unified IP Phone 6945
ā€¢Cisco Unified IP Phone 6961
Cisco Unified IP Phone 7900 Series
You can research Cisco Unified IP Phone 7900 Series compatibility with Cisco Unified Communications Manager releases by using the Cisco Unified Communications Compatibility Tool at the following URL:
Go to the preceding URL, select the Cisco Unified Communications Manager release that you want to research, then search the compatibility tool window to find the specific Cisco Unified IP Phone 7900 Series phone model you want, including the following:
ā€¢Cisco Unified IP Phone 7902G (End of sale November 29, 2006)
ā€¢Cisco Unified IP Phone 7905G (End of sale May 22, 2006)
ā€¢Cisco Unified IP Phone 7906G (End of sale July 23, 2010)
ā€¢Cisco Unified IP Phone 7911G
ā€¢Cisco Unified IP Phone 7912G (End of sale May 12, 2006)
ā€¢Cisco Unified Wireless IP Phone 7920 (End of sale June 14, 2007)
ā€¢Cisco Unified Wireless IP Phone 7921G
ā€¢Cisco Unified Wireless IP Phone 7925
ā€¢Cisco Unified IP Phone 7931G
ā€¢Cisco Unified IP Conference Station 7935 (End of sale November 14, 2004)
ā€¢Cisco Unified IP Conference Station 7936G (End of sale July 23, 2010)
ā€¢Cisco Unified IP Conference Station 7937G
ā€¢Cisco Unified IP Phone 7940G (End of sale July 23, 2010)
ā€¢Cisco Unified IP Phone 7941G and 7941G-GE (End of sale January 19, 2010)
ā€¢Cisco Unified IP Phone 7942G
ā€¢Cisco Unified IP Phone 7945G
ā€¢Cisco Unified IP Phone 7960G (End of sale July 23, 2010)
ā€¢Cisco Unified IP Phone 7961G and 7961G-GE (End of sale January 19, 2010)
ā€¢Cisco Unified IP Phone 7962G
ā€¢Cisco Unified IP Phone 7965G
ā€¢Cisco Unified IP Phone 7970G (End of sale August 1, 2008)
ā€¢Cisco Unified IP Phone 7971G-GE (End of sale August 1, 2008)
ā€¢Cisco Unified IP Phone 7975G
ā€¢Cisco Unified IP Phone 7985G (End of sale September 24, 2010)
Above details are from CUCM software comp matrix http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucm/compat/ccmcompmatr.html#wp51474
Pls rate helpful posts.
GP.
Also you can check SRND of respective CUCM and can refer " Unified Communications Endpoints" section. It will ist all the supported phones.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/8x/endpnts.html#wp1043531
You have to keep in mind that some of the ip phones may require firmware upgrade or latest device default installed etc.
regards
Ronak Patel
So, is there any way to make 6921 works with CUM 6.1? if I setup the phone to work with SIP, is that works?
Actually, I have been able to get a 6921 using SCCP working under CUCM 6.1. (in my case 6.1(5)).
Please note that this is officially unsupported and you do this at your own risk.
You need to install the "IP Phone QED Enabler" for the 69X1 phones, which enables the new device types in CUCM.
http://www.cisco.com/cisco/software/release.html?mdfid=282622815&catid=278875240&softwareid=282074289&release=9.3(1)&relind=AVAILABLE&rellifecycle=&reltype=latest
You will need download rights on CCO to be able to get this image. You will need to restart your cluster after applying this file.
Please again note that this is totally unsupported. Cisco's documents are clear in saying that you need to be at version 7.1(5) to make this work officially. I personally wouldn't do this in a production environment
HTH.
Barry Hesk
Intrinsic Network Solutions
Hello guys,
     I have a very similar situation, literature tells me that 6921 ip phone is the replacement of 7911, I know that this is not recomended by Cisco on 6.1.5, then.. what other ip phone can replace the 7911 on a UC 6.1.5?.. Thanks a lot
