ITSP SIP; CUBE 14.7 on ISR 8300 17.12.4 to CUCM 14.0.1
Hello all,
My team is deploying an ISR 8300 on 17.12.4 running CUBE 14.7 to connect to ITSP SIP (Masergy) for in-bound / out-bound E.164 calling. Our internal UC Cluster is version 14.0.1. We have E.164 DID TNs associated to 5-digit extensions for off-net callers to reach on-net user's VoIP phones.
At the moment, we are utilizing Masergy's "Test DID" (4633030297) to validate our configurations and their service.
Placing a call from a cell-phone to the Test DID yields ringing in cell earpiece till user picks up, followed by silence.
The VoIP phone will also ring, but answering yields silence on the desk phone as well. Once the call is answered at the VoIP phone, the CUBE router shows it as a live SIP call.
Here is a rough topology:
We have an ISR 4000 at the ISP boundary which is configured with NAT, PAT, a subinterface for the private-IP network on which the CUBE router resides, and Access Control.
Attached is the output of [debug voice ccapi {inout}; {error}] and [debug voice dialpeer {inout}; {error}] in "DEBUG_SIPGW" text file.
The below code-block is a trimmed output of the debug when calling the test DID from a cell-phone:
*Dec 16 13:02:18:  vsacount in free is 0
61734: *Dec 16 18:02:19.629: //88269/ADD15BBF85AA/
------------------ Cover Buffer ---------------
Search-key       = +17654271905:+14633030297:88269
  Timestamp      = *Dec 16 18:01:59.189
  CallID         = 88269
  Peer-CallID    = 88270
  Correlator     = NA
  Called-Number  = +14633030297
  Calling-Number = +17654271905
  SIP CallID     = BW1801592841612241161215979@MASERGY-ITSP-IP
  SIP SessionID  = 11bb7fe887cf54c09b3193e0ef4a8268
  GUID           = ADD15BBF85AA
  Tenant         = 0
  Cause-code     = recovery on timer expiry (102)
61565: *Dec 16 18:01:59.189: //88269/ADD15BBF85AA/CUBE_VT/SIP/Msg/ccsipDisplayMsg:
Received: SIP UDP message from MASERGY-UC-IP1:5060 to ROUTER-PRIVATE-IP:5060 on VRF SIP_UPLINK
INVITE sip:+14633030297@ISP-PUBLIC-GW-IP:5060;user=phone SIP/2.0
Via: SIP/2.0/UDP MASERGY-UC-IP1:5060;branch=z9hG4bKqmdsdv20b80n0due8j30.1
From: <sip:+17654271905@masergy.com;user=phone>;tag=2100542553-1734372119284-
To: "Test DID"<sip:+14633030297@masergy.com;user=phone>
Call-ID: BW1801592841612241161215979@MASERGY-ITSP-IP
CSeq: 676407675 INVITE
Contact: <sip:MASERGY-UC-IP1:5060;transport=udp>
Allow: ACK,BYE,CANCEL,INFO,INVITE,OPTIONS,PRACK,REFER,NOTIFY
Recv-Info: x-broadworks-client-session-info
X-BroadWorks-Correlation-Info: 0e91c2c1-6b4f-4a27-a92c-e5bd62213c53
Accept: application/media_control+xml,application/pidf+xml,application/sdp,multipart/mixed
X-Masergy-Correlation-Id: P-DCAO-304877743_104065111@67.231.9.110
Supported:
Max-Forwards: 69
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 309
v=0
o=BroadWorks 25824509 1 IN IP4 MASERGY-UC-IP1
s=-
c=IN IP4 MASERGY-UC-IP1
t=0 0
m=audio 51674 RTP/AVP 0 8 18 100
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:100 telephone-event/8000
a=fmtp:100 0-15
a=sendrecv
a=ptime:20
a=bsoft: 1 image udptl t38
61568: *Dec 16 18:01:59.189: //88269/ADD15BBF85AA/CUBE_VT/SIP/FSM/SPI-State-Change: Current State: STATE_NONE, Next State: STATE_IDLE, Current Sub-State: STATE_NONE, Next Sub-State: STATE_NONE
61569: *Dec 16 18:01:59.189: //88269/ADD15BBF85AA/CUBE_VT/SIP/MISC/Error: resolve_sig_ip_address_to_bind: Could not get the phone tag
61570: *Dec 16 18:01:59.190: //88269/ADD15BBF85AA/CUBE_VT/SIP/MISC/Matched Dialpeer: Dir: Inbound, Peer-Tag: 1
61571: *Dec 16 18:01:59.190: //88269/ADD15BBF85AA/CUBE_VT/SIP/FSM/Offer-Answer: Event: E_SIP_INVITE_SDP_RCVD, Current State: S_SIP_EARLY_DIALOG_IDLE, Next State: S_SIP_EARLY_DIALOG_OFFER_RCVD
61572: *Dec 16 18:01:59.190: //88269/ADD15BBF85AA/CUBE_VT/SIP/FSM/IWF: Event: E_SIP_IWF_EV_RCVD_SDP, Current State: S_SIP_IWF_SDP_IDLE, Next State: S_SIP_IWF_SDP_RCVD_AWAIT_PEER_EVENT
61573: *Dec 16 18:01:59.190: //88269/ADD15BBF85AA/CUBE_VT/SIP/MISC/Media Stream Parameters: Stream Type: voice+dtmf, Stream State: STREAM_ADDING, Negotiated Codec: g711ulaw, Negotiated DTMF Type: rtp-nte, Stream Index: 1
61574: *Dec 16 18:01:59.190: //88269/ADD15BBF85AA/CUBE_VT/SIP/API: cc_api_update_interface_cac_resource (0)
61575: *Dec 16 18:01:59.190: //88269/ADD15BBF85AA/CUBE_VT/SIP/API: voip_rtp_allocate_port (8372)
61576: *Dec 16 18:01:59.191: //88269/ADD15BBF85AA/CUBE_VT/SIP/MISC/Media Stream Parameters: Stream Type: voice+dtmf, Stream State: STREAM_ADDING, Negotiated Codec: g711ulaw, Negotiated DTMF Type: rtp-nte, Stream Index: 1
61577: *Dec 16 18:01:59.191: //88269/ADD15BBF85AA/CUBE_VT/SIP/API: cc_api_call_setup_ind_with_callID (0)
61578: *Dec 16 18:01:59.191: //88269/ADD15BBF85AA/CUBE_VT/SIP/FSM/SPI-State-Change: Current State: STATE_IDLE, Next State: STATE_RECD_INVITE, Current Sub-State: STATE_NONE, Next Sub-State: STATE_NONE
61579: *Dec 16 18:01:59.194: //88269/ADD15BBF85AA/CUBE_VT/SIP/Msg/ccsipDisplayMsg:
Sent: SIP UDP message from ROUTER-PRIVATE-IP:5060 to MASERGY-UC-IP1:5060 on VRF SIP_UPLINK
SIP/2.0 100 Trying
Date: Mon, 16 Dec 2024 18:01:59 GMT
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-17.12.4
Session-ID: 00000000000000000000000000000000;remote=2efd866518ed5a71a01d007967921e20
Content-Length: 0
61585: *Dec 16 18:01:59.195: //88269/ADD15BBF85AA/CUBE_VT/SIP/FSM/IWF: Event: E_SIP_IWF_EV_SET_MODE, Current State: CNFSM_CONTAINER_STATE, Next State: CNFSM_NO_STATE_CHANGE
61586: *Dec 16 18:01:59.195: //88269/ADD15BBF85AA/CUBE_VT/SIP/API: voip_rtp_create_session (0)
61587: *Dec 16 18:01:59.195: //88269/ADD15BBF85AA/CUBE_VT/SIP/API: voip_rtp_set_non_rtp_call (0)
61588: *Dec 16 18:01:59.195: //88269/ADD15BBF85AA/CUBE_VT/SIP/API: voip_rtp_update_callinfo (0)
61589: *Dec 16 18:01:59.196: //88269/ADD15BBF85AA/CUBE_VT/SIP/FSM/Event-Action: Event: SIPSPI_EV_CC_CALL_PROCEEDING, Current State: STATE_RECD_INVITE
61620: *Dec 16 18:01:59.297: //88269/ADD15BBF85AA/CUBE_VT/SIP/FSM/Event-Action: Event: SIPSPI_EV_CC_CALL_ALERTING, Current State: STATE_RECD_INVITE
61621: *Dec 16 18:01:59.297: //88269/ADD15BBF85AA/CUBE_VT/SIP/FSM/SPI-State-Change: Current State: STATE_RECD_INVITE, Next State: STATE_SENT_ALERTING, Current Sub-State: STATE_NONE, Next Sub-State: STATE_NONE
61622: *Dec 16 18:01:59.297: //88269/ADD15BBF85AA/CUBE_VT/SIP/Msg/ccsipDisplayMsg:
SIP/2.0 180 Ringing
To: "Test DID"<sip:+14633030297@masergy.com;user=phone>;tag=8AD03126-22DA
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
Remote-Party-ID: <sip:+14633030297@ROUTER-PRIVATE-IP>;party=called;screen=no;privacy=off
Contact: <sip:+14633030297@ROUTER-PRIVATE-IP:5060>
Session-ID: 11bb7fe887cf54c09b3193e0ef4a8268;remote=2efd866518ed5a71a01d007967921e20
Content-Length: 0
61631: *Dec 16 18:01:59.360: //88269/ADD15BBF85AA/CUBE_VT/SIP/FSM/IWF: Event: E_SIP_IWF_EV_PEER_CAPS, Current State: CNFSM_CONTAINER_STATE, Next State: CNFSM_NO_STATE_CHANGE
61632: *Dec 16 18:01:59.360: //88269/ADD15BBF85AA/CUBE_VT/SIP/API: cc_api_caps_ack (0)
61633: *Dec 16 18:01:59.360: //88269/ADD15BBF85AA/CUBE_VT/SIP/API: cc_api_caps_ack (0)
61646: *Dec 16 18:01:59.360: //88269/ADD15BBF85AA/CUBE_VT/SIP/FSM/IWF: Event: E_SIP_IWF_EV_PEER_MULTIMEDIA_CHANNEL_ACK, Current State: S_SIP_IWF_SDP_RCVD_AWAIT_PEER_EVENT, Next State: CNFSM_NO_STATE_CHANGE
61647: *Dec 16 18:01:59.360: //88269/ADD15BBF85AA/CUBE_VT/SIP/MISC/Media Stream Parameters: Stream Type: voice-only, Stream State: STREAM_ADDING, Negotiated Codec: g711ulaw, Negotiated DTMF Type: rtp-nte, Stream Index: 1
61648: *Dec 16 18:01:59.360: //88269/ADD15BBF85AA/CUBE_VT/SIP/API: voip_rtp_update_callinfo (0)
61649: *Dec 16 18:01:59.360: //88269/ADD15BBF85AA/CUBE_VT/SIP/API: cc_api_call_mode_update_ind (0)
61650: *Dec 16 18:01:59.360: //88269/ADD15BBF85AA/CUBE_VT/SIP/FSM/Media-State: Event: E_IPIP_MEDIA_SERV_EV_PEER_CHNL_ACK, Current State: S_IPIP_MEDIA_SERV_STATE_IDLE, Next State: CNFSM_NO_STATE_CHANGE
61652: *Dec 16 18:01:59.361: //88269/ADD15BBF85AA/CUBE_VT/SIP/API: voip_rtp_update_callinfo (0)
61653: *Dec 16 18:01:59.361: //88269/ADD15BBF85AA/CUBE_VT/SIP/API: voip_rtp_set_non_rtp_call (0)
61654: *Dec 16 18:01:59.361: //88269/ADD15BBF85AA/CUBE_VT/SIP/API: voip_rtp_update_callinfo (0)
61655: *Dec 16 18:01:59.361: //88269/ADD15BBF85AA/CUBE_VT/SIP/API: cc_api_bridge_done (0)
61656: *Dec 16 18:01:59.361: //88269/ADD15BBF85AA/CUBE_VT/SIP/API: ccsip_bridge (0)
61663: *Dec 16 18:01:59.362: //88269/ADD15BBF85AA/CUBE_VT/SIP/FSM/IWF: Event: E_SIP_IWF_EV_CALL_CONNECT, Current State: CNFSM_CONTAINER_STATE, Next State: CNFSM_NO_STATE_CHANGE
61664: *Dec 16 18:01:59.363: //88269/ADD15BBF85AA/CUBE_VT/SIP/FSM/Event-Action: Event: SIPSPI_EV_CC_CALL_CONNECT, Current State: STATE_SENT_ALERTING
61665: *Dec 16 18:01:59.363: //88269/ADD15BBF85AA/CUBE_VT/SIP/FSM/Offer-Answer: Event: E_SIP_INVITE_RESP_SDP_SENT, Current State: S_SIP_EARLY_DIALOG_OFFER_RCVD, Next State: S_SIP_EARLY_DIALOG_OFFER_ANSWER_COMPLETE
61666: *Dec 16 18:01:59.362: //88269/ADD15BBF85AA/CUBE_VT/SIP/FSM/IWF: Event: E_SIP_IWF_EV_SENT_SDP, Current State: S_SIP_IWF_SDP_RCVD_AWAIT_PEER_EVENT, Next State: S_SIP_IWF_SDP_DONE
61667: *Dec 16 18:01:59.362: //88269/ADD15BBF85AA/CUBE_VT/SIP/FSM/SPI-State-Change: Current State: STATE_SENT_ALERTING, Next State: STATE_SENT_SUCCESS, Current Sub-State: STATE_NONE, Next Sub-State: STATE_NONE
61668: *Dec 16 18:01:59.362: //88269/ADD15BBF85AA/CUBE_VT/SIP/Msg/ccsipDisplayMsg:
SIP/2.0 200 OK
Supported: replaces
Supported: timer
Content-Length: 245
v=0
o=CiscoSystemsSIP-GW-UserAgent 8063 633 IN IP4 ROUTER-PRIVATE-IP
s=SIP Call
c=IN IP4 ROUTER-PRIVATE-IP
t=0 0
m=audio 8372 RTP/AVP 0 100
a=fmtp:100 0-15
a=ptime:20
61671: *Dec 16 18:01:59.862: //88269/ADD15BBF85AA/CUBE_VT/SIP/FSM/Timer-Action: Event: SIP_TIMER_CONNECT, Current State: STATE_SENT_SUCCESS
61672: *Dec 16 18:01:59.863: //88269/ADD15BBF85AA/CUBE_VT/SIP/Msg/ccsipDisplayMsg:
SIP/2.0 200 OK
Supported: replaces
Supported: timer
Content-Length: 245
v=0
s=SIP Call
t=0 0
a=fmtp:100 0-15
a=ptime:20
61675: *Dec 16 18:02:00.862: //88269/ADD15BBF85AA/CUBE_VT/SIP/FSM/Timer-Action: Event: SIP_TIMER_CONNECT, Current State: STATE_SENT_SUCCESS
61676: *Dec 16 18:02:00.862: //88269/ADD15BBF85AA/CUBE_VT/SIP/Msg/ccsipDisplayMsg:
SIP/2.0 200 OK
Supported: replaces
Supported: timer
Content-Length: 245
v=0
s=SIP Call
t=0 0
a=fmtp:100 0-15
a=ptime:20
61679: *Dec 16 18:02:02.863: //88269/ADD15BBF85AA/CUBE_VT/SIP/FSM/Timer-Action: Event: SIP_TIMER_CONNECT, Current State: STATE_SENT_SUCCESS
61680: *Dec 16 18:02:02.864: //88269/ADD15BBF85AA/CUBE_VT/SIP/Msg/ccsipDisplayMsg:
SIP/2.0 200 OK
Supported: replaces
Supported: timer
Content-Length: 245
v=0
s=SIP Call
t=0 0
a=fmtp:100 0-15
a=ptime:20
61683: *Dec 16 18:02:06.864: //88269/ADD15BBF85AA/CUBE_VT/SIP/FSM/Timer-Action: Event: SIP_TIMER_CONNECT, Current State: STATE_SENT_SUCCESS
61684: *Dec 16 18:02:06.865: //88269/ADD15BBF85AA/CUBE_VT/SIP/Msg/ccsipDisplayMsg:
SIP/2.0 200 OK
Supported: replaces
Supported: timer
Content-Length: 245
v=0
s=SIP Call
t=0 0
a=fmtp:100 0-15
a=ptime:20
61687: *Dec 16 18:02:10.864: //88269/ADD15BBF85AA/CUBE_VT/SIP/FSM/Timer-Action: Event: SIP_TIMER_CONNECT, Current State: STATE_SENT_SUCCESS
61688: *Dec 16 18:02:10.864: //88269/ADD15BBF85AA/CUBE_VT/SIP/Msg/ccsipDisplayMsg:
SIP/2.0 200 OK
Supported: replaces
Supported: timer
Content-Length: 245
v=0
s=SIP Call
t=0 0
a=fmtp:100 0-15
a=ptime:20
61691: *Dec 16 18:02:14.864: //88269/ADD15BBF85AA/CUBE_VT/SIP/FSM/Timer-Action: Event: SIP_TIMER_CONNECT, Current State: STATE_SENT_SUCCESS
61692: *Dec 16 18:02:14.864: //88269/ADD15BBF85AA/CUBE_VT/SIP/Msg/ccsipDisplayMsg:
SIP/2.0 200 OK
Supported: replaces
Supported: timer
Content-Length: 245
v=0
s=SIP Call
t=0 0
a=fmtp:100 0-15
a=ptime:20
61695: *Dec 16 18:02:18.864: //88269/ADD15BBF85AA/CUBE_VT/SIP/FSM/Timer-Action: Event: SIP_TIMER_CONNECT, Current State: STATE_SENT_SUCCESS
61696: *Dec 16 18:02:18.864: //88269/ADD15BBF85AA/CUBE_VT/SIP/MISC/Call Disconnect: Initiated at: 0x1703BEC, Originated at: 0x1E000FD, Cause Code: 102
61697: *Dec 16 18:02:18.864: //88269/ADD15BBF85AA/CUBE_VT/SIP/API: cc_api_call_disconnected (0)
61698: *Dec 16 18:02:18.864: //88269/ADD15BBF85AA/CUBE_VT/SIP/FSM/SPI-State-Change: Current State: STATE_SENT_SUCCESS, Next State: STATE_DISCONNECTING, Current Sub-State: STATE_NONE, Next Sub-State: STATE_NONE
61699: *Dec 16 18:02:18.864: //88269/ADD15BBF85AA/CUBE_VT/SIP/FSM/SPI-State-Change: Current State: STATE_DISCONNECTING, Next State: STATE_DISCONNECTING, Current Sub-State: STATE_NONE, Next Sub-State: STATE_NONE
61700: *Dec 16 18:02:18.866: //88269/ADD15BBF85AA/CUBE_VT/SIP/API: voip_rtp_destroy_dp_session (0)
61701: *Dec 16 18:02:18.866: //88269/ADD15BBF85AA/CUBE_VT/SIP/FSM/Media-State: Event: E_IPIP_MEDIA_SERV_EV_XCODER_RESET_STREAM, Current State: CNFSM_CONTAINER_STATE, Next State: S_IPIP_MEDIA_SERV_STATE_IDLE
61702: *Dec 16 18:02:18.866: //88269/ADD15BBF85AA/CUBE_VT/SIP/API: voip_rtp_update_callinfo (0)
61703: *Dec 16 18:02:18.867: //88269/ADD15BBF85AA/CUBE_VT/SIP/API: cc_api_bridge_drop_done (0)
61707: *Dec 16 18:02:18.867: //88269/ADD15BBF85AA/CUBE_VT/SIP/Msg/ccsipDisplayMsg:
BYE sip:MASERGY-UC-IP1:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP ROUTER-PRIVATE-IP:5060;branch=z9hG4bK59821258
From: "Test DID"<sip:+14633030297@masergy.com;user=phone>;tag=8AD03126-22DA
To: <sip:+17654271905@masergy.com;user=phone>;tag=2100542553-1734372119284-
User-Agent: Cisco-SIPGateway/IOS-17.12.4
Max-Forwards: 70
Timestamp: 1734372138
CSeq: 101 BYE
Reason: Q.850;cause=86
Content-Length: 0
61709: *Dec 16 18:02:18.867: //88269/ADD15BBF85AA/CUBE_VT/SIP/MISC/Call Disconnect: Initiated at: 0x260070A, Originated at: 0x260070B, Cause Code: 102
61711: *Dec 16 18:02:18.867: //88269/ADD15BBF85AA/CUBE_VT/SIP/API: cc_api_update_interface_cac_resource (0)
61712: *Dec 16 18:02:18.867: //88269/ADD15BBF85AA/CUBE_VT/SIP/FSM/Event-Action: Event: SIPSPI_EV_CC_CALL_DISCONNECT, Current State: STATE_DISCONNECTING
61718: *Dec 16 18:02:18.961: //88269/ADD15BBF85AA/CUBE_VT/SIP/Msg/ccsipDisplayMsg:
SIP/2.0 200 OK
Via: SIP/2.0/UDP ROUTER-PRIVATE-IP:5060;received=ISP-PUBLIC-GW-IP;branch=z9hG4bK59821258
CSeq: 101 BYE
Content-Length: 0
61719: *Dec 16 18:02:18.961: //88269/ADD15BBF85AA/CUBE_VT/SIP/FSM/Event-Action: Event: SIPSPI_EV_NEW_MESSAGE, Current State: STATE_DISCONNECTING
61720: *Dec 16 18:02:18.961: //88269/ADD15BBF85AA/CUBE_VT/SIP/API: voip_rtp_delete_dp_session (0)
61721: *Dec 16 18:02:18.962: //88269/ADD15BBF85AA/CUBE_VT/SIP/API: cc_api_call_disconnect_done (0)
61722: *Dec 16 18:02:18.962: //88269/ADD15BBF85AA/CUBE_VT/SIP/FSM/SPI-State-Change: Current State: STATE_DISCONNECTING, Next State: STATE_DEAD, Current Sub-State: STATE_NONE, Next Sub-State: STATE_NONE
61723: *Dec 16 18:02:18.962: //88269/ADD15BBF85AA/CUBE_VT/SIP/MISC/Error: sipSPIFlushDeferredQueue: Invalid deferredQueue
61724: *Dec 16 18:02:18.962: //88269/ADD15BBF85AA/CUBE_VT/SIP/MISC/Error: ws_call_fork_cleanup: ws_info is NULL
61725: *Dec 16 18:02:18.962: //88269/ADD15BBF85AA/CUBE_VT/SIP/API: voip_rtp_release_port (8372)
61735: *Dec 16 18:02:19.630: //88270/ADD15BBF85AA/
Search-key       = +17654271905:+14633030297:88270
  Timestamp      = *Dec 16 18:01:59.195
  CallID         = 88270
  Peer-CallID    = 88269
  Correlator     = NA
  SIP CallID     = ADD26D52-BB0E11EF-85B0C729-4E918EF0@ROUTER-PRIVATE-IP
  SIP SessionID  = 2efd866518ed5a71a01d007967921e20
  GUID           = ADD15BBF85AA
  Tenant         = 0
  Cause-code     = normal call clearing (16)
61581: *Dec 16 18:01:59.195: //88270/ADD15BBF85AA/CUBE_VT/SIP/MISC/Matched Dialpeer: Dir: Outbound, Peer-Tag: 4
61582: *Dec 16 18:01:59.195: //88270/ADD15BBF85AA/CUBE_VT/SIP/FSM/SPI-State-Change: Current State: STATE_NONE, Next State: STATE_IDLE, Current Sub-State: STATE_NONE, Next Sub-State: STATE_NONE
61583: *Dec 16 18:01:59.195: //88270/ADD15BBF85AA/CUBE_VT/SIP/FSM/IWF: Event: E_SIP_IWF_EV_SET_MODE, Current State: CNFSM_CONTAINER_STATE, Next State: CNFSM_NO_STATE_CHANGE
61584: *Dec 16 18:01:59.195: //88270/ADD15BBF85AA/CUBE_VT/SIP/FSM/IWF: Event: E_SIP_IWF_EV_PRE_SETUP, Current State: S_SIP_IWF_SDP_IDLE, Next State: CNFSM_NO_STATE_CHANGE
61590: *Dec 16 18:01:59.196: //88270/ADD15BBF85AA/CUBE_VT/SIP/FSM/IWF: Event: E_SIP_IWF_EV_PEER_MULTIMEDIA_CHANNEL_IND, Current State: S_SIP_IWF_SDP_IDLE, Next State: CNFSM_NO_STATE_CHANGE
61591: *Dec 16 18:01:59.196: //88270/ADD15BBF85AA/CUBE_VT/SIP/MISC/Media Stream Parameters: Stream Type: voice-only, Stream State: STREAM_ADDING, Negotiated Codec: No Codec   , Negotiated DTMF Type: inband-voice, Stream Index: 1
61592: *Dec 16 18:01:59.195: //88270/ADD15BBF85AA/CUBE_VT/SIP/API: voip_rtp_allocate_port (8374)
61593: *Dec 16 18:01:59.195: //88270/ADD15BBF85AA/CUBE_VT/SIP/FSM/Media-State: Event: E_IPIP_MEDIA_SERV_EV_PEER_CHNL_IND, Current State: S_IPIP_MEDIA_SERV_STATE_IDLE, Next State: S_IPIP_MEDIA_SERV_STATE_INIT_XCODER_RESERVED
61594: *Dec 16 18:01:59.195: //88270/ADD15BBF85AA/CUBE_VT/SIP/API: ccsip_xcoder_reserve (-1)
61595: *Dec 16 18:01:59.195: //88270/ADD15BBF85AA/CUBE_VT/SIP/FSM/IWF: Event: E_SIP_IWF_EV_CONTINUE_PRE_SETUP, Current State: S_SIP_IWF_SDP_IDLE, Next State: CNFSM_NO_STATE_CHANGE
61596: *Dec 16 18:01:59.195: //88270/ADD15BBF85AA/CUBE_VT/SIP/FSM/IWF: Event: E_SIP_IWF_EV_INIT_CALL_SETUP, Current State: S_SIP_IWF_SDP_IDLE, Next State: CNFSM_NO_STATE_CHANGE
SIPGW-XX.XXX#
61732: *Dec 16 18:02:18.961: //88270/ADD15BBF85AA/CUBE_VT/SIP/MISC/Error: ws_call_fork_cleanup: ws_info is NULL
61733: *Dec 16 18:02:18.961: //88270/ADD15BBF85AA/CUBE_VT/SIP/API: voip_rtp_release_port (8374)
Also attached is a sanitized running config from the CUBE RTR. The below code-block is a trimmed output of just the SIP config.
application
 service default dsapp
 global
  service alternate default
voice service voip
 ip address trusted list
  ipv4 INTERNAL-UC-IP1
  ipv4 INTERNAL-UC-IP2
  ipv4 INTERNAL-UC-IP3
  ipv4 MASERGY-UC-IP1
  ipv4 MASERGY-UC-IP2
 mode border-element
 allow-connections sip to sip
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
 trace
 sip
  early-offer forced
  midcall-signaling passthru
  sip-profiles 1
voice class uri LOCALUC sip
 pattern (INTERNAL-SANITIZED-PATTERN)
voice class uri ITSPUC sip
 pattern (MASERGY-SANITIZED-PATTERN)
voice class codec 1
 codec preference 1 g711ulaw
 codec preference 2 g729r8
 codec preference 3 g729br8
 codec preference 4 g711alaw
voice class sip-profiles 1
 request ANY sdp-header Audio-Attribute modify "a=inactive" "a=sendrecv"
 request ANY sdp-header Audio-Attribute modify "a=recvonly" "a=sendrecv"
 request ANY sdp-header Audio-Attribute modify "a=sendonly" "a=sendrecv"
 response ANY sdp-header Audio-Attribute modify "a=inactive" "a=sendrecv"
 response ANY sdp-header Audio-Attribute modify "a=recvonly" "a=sendrecv"
 response ANY sdp-header Audio-Attribute modify "a=sendonly" "a=sendrecv"
voice class sip-profiles 2
 request ANY sip-header P-Asserted-Identity modify "@(.*)>" "@masergy.com>"
 request ANY sip-header Diversion modify "@(.*)>" "@masergy.com>"
 response ANY sdp-header Session-Owner modify "ROUTER-PRIVATE-IP" "ISP-PUBLIC-GATEWAY-IP"
voice class dpg 4
 dial-peer 4
voice class server-group 1
 ipv4 INTERNAL-UC-IP1 preference 1
 ipv4 INTERNAL-UC-IP2 preference 2
 ipv4 INTERNAL-UC-IP3 preference 3
voice class server-group 2
 ipv4 MASERGY-UC-IP1 preference 1
 ipv4 MASERGY-UC-IP2 preference 2
voice class sip-options-keepalive 1
 up-interval 30
 retry 2
voice iec syslog
voice register global
 default mode
 no allow-hash-in-dn
 max-dn 20
 max-pool 20
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
dial-peer voice 1 voip
 description ITSP-in-CUBE
 session protocol sipv2
 incoming uri via ITSPUC
 voice-class codec 1
 voice-class sip nat media-keepalive 10
 voice-class sip bind control source-interface GigabitEthernet0/0/1
 voice-class sip bind media source-interface GigabitEthernet0/0/1
 dtmf-relay rtp-nte
 no vad
dial-peer voice 2 voip
 description CUBE-out-CUCM
 huntstop
 destination-pattern +[1-9]..........
 session server-group 1
 voice-class codec 1
 voice-class sip bind control source-interface GigabitEthernet0/0/3
 voice-class sip bind media source-interface GigabitEthernet0/0/3
 dtmf-relay rtp-nte
 no vad
dial-peer voice 3 voip
 description CUCM-in-CUBE
 incoming uri via LOCALUC
 voice-class codec 1
 dtmf-relay rtp-nte
 no vad
dial-peer voice 4 voip
 description CUBE-out-ITSP
 huntstop
 destination-pattern +[0-9]T
 session server-group 2
 voice-class codec 1
 voice-class sip profiles 2
 voice-class sip options-keepalive profile 1
 dtmf-relay rtp-nte
 ip qos dscp cs5 signaling
 no vad
sip-ua
interface GigabitEthernet0/0/0
 vrf forwarding MANAGE
 ip address CUBE-MGMT-IP 255.255.255.0
 negotiation auto
 description SIP_UPLINK
 vrf forwarding SIP_UPLINK
 ip address ROUTER-PRIVATE-IP 255.255.255.248
 negotiation auto
interface GigabitEthernet0/0/2
 no ip address
 shutdown
 negotiation auto
 description SIP_INTERNAL
 vrf forwarding SIP_INTERNAL
 ip address LOCAL-VOICE-NET 255.255.255.0
 negotiation auto
interface GigabitEthernet0/0/4
 no ip address
 shutdown
 negotiation auto
interface GigabitEthernet0/0/5
 no ip address
 shutdown
 negotiation auto
ip forward-protocol nd
no ip ftp passive
no ip http server
no ip http secure-server
ip http client source-interface GigabitEthernet0/0/0
ip tacacs source-interface GigabitEthernet0/0/0 vrf MANAGE
no ip rsvp authentication
ip route vrf MANAGE 0.0.0.0 0.0.0.0 MGMT-NET-DEFAULT-GW
ip route vrf SIP_INTERNAL 0.0.0.0 0.0.0.0 VOICE-NET-DEFAULT-GW
ip route vrf SIP_UPLINK 0.0.0.0 0.0.0.0 ROUTER-PRIVATE-IP
Finally, attached is a PDF with screen shots of the SIP trunk and Profile between the internal UC and ISR8000 CUBE RTR.
I would appreciate any assistance and will be happy to provide any additional details.
5 Replies 5
Here is the ladder diagram of the call based on the logs you shared. One question: did the call actually connect on both sides? Does it show that the call duration started on both ends? I don't see a full exchange of messages for a successful call in the log.
Why don't you terminate the ITSP link on the CUBE? Why do you introduce a NAT device between the ITSP and the CUBE?
Response Signature
As you're using NAT you'll need to do way more with you SIP profiles than you currently do. Below should be a good stating point.
voice service voip
 sip
  sip-profiles inbound
 rule 10 request ANY sip-header From modify "<internal interface IP>" "<external interface IP>"
 rule 20 request ANY sip-header From modify "<external interface IP>" "<NAT IP>"
 rule 30 request ANY sip-header Remote-Party-ID modify "Remote-Party-ID:(.*)(<sip:.*@.*>)" "Remote-Party-ID: \2"
 rule 40 response ANY sip-header Remote-Party-ID modify "Remote-Party-ID:(.*)(<sip:.*@.*>)" "Remote-Party-ID: \2"
 rule 50 request ANY sip-header P-Asserted-Identity modify "P-Asserted-Identity:(.*)(<sip:.*@.*>)" "P-Asserted-Identity: \2"
 rule 60 response ANY sip-header P-Asserted-Identity modify "P-Asserted-Identity:(.*)(<sip:.*@.*>)" "P-Asserted-Identity: \2"
 rule 70 request ANY sip-header Contact modify "(<.*)@<external interface IP>:(.*)>" "\1@<NAT IP>:\2>"
 rule 80 response ANY sip-header Contact modify "(<.*)@<external interface IP>:(.*)>" "\1@<NAT IP>:\2>"
 rule 90 request ANY sip-header Via modify "(SIP.*) <external interface IP>(.*)" "\1 <NAT IP>\2"
 rule 100 request INVITE sip-header Requested-By modify "(.*:)<external interface IP>>" "\1<NAT IP>>"
 rule 110 request ANY sdp-header Session-Owner modify "<external interface IP>" "<NAT IP>"
 rule 120 response ANY sdp-header Session-Owner modify "<external interface IP>" "<NAT IP>"
 rule 130 request ANY sdp-header Connection-Info modify "<external interface IP>" "<NAT IP>"
 rule 140 response ANY sdp-header Connection-Info modify "<external interface IP>" "<NAT IP>"
 rule 150 request ANY sdp-header Audio-Connection-Info modify "<external interface IP>" "<NAT IP>"
 rule 160 response ANY sdp-header Audio-Connection-Info modify "<external interface IP>" "<NAT IP>"
voice class sip-profiles 110
 rule 10 request ANY sip-header From modify "<NAT IP>" "<external interface IP>"
 rule 20 request OPTIONS sip-header SIP-Req-URI modify "<NAT IP>" "<external interface IP>"
 rule 30 request ANY sip-header To modify "<NAT IP>" "<external interface IP>"
 voice-class sip profiles 110 inbound
Response Signature
Hello Philip,
As the disconnect cause for the call is 86 which means:
Call Having the Requested Call Identity Has Been Cleared.
Indicates that the network has received a call resume request containing a call identity information
element indicating a suspended call that has in the meantime been cleared while suspended.
It looks you are missing some configuration in your CUBE/ISP router as suggested by @Roger Kallberg
Thanks.
Scott Leport
Level 7
Level 7
If the phones are ringing and the call is picked up, it suggests that the SIP signaling is good. However, it sounds like you may not be allowing the range of RTP ports from your ITSP's media servers. Do you have an ACL configured on your boundary router allowing this?
I had a similar issue when I upgraded a customer cube router from an ISR G2 to a 4K. The default RTP port ranges are different on the different platforms. Here is what I had to add to 4K to make it play nice with Centurylink.
voice service voip
 rtp-port range 16384 32766
