jabber cannot control deskphone
Nishad Ismail
Hi All,
CUCM Version 11.X
IM/P Version 11.X
Jabber version 11.6
Jabber for windows not able to move to Deskphone mode ,Gives me error "Unable to connect  CJ:109:3" ,
Logs attached
Configuration:
-> UC service
CTI service 1 :FQDN(primary) and port 2748
CTI service 2 :FQDN(secondary) and port 2748
CTI service 3 :FQDN(Ter) and port 2748
->Service Profile
CTI:
Primary `: CTI service 2
Secondary: CTI service 3
Tertiery : CTI service 1
-> Cisco IP phone 7942
Owner ID "User ID"
Checked : "Allow Control of Device from CTI".
-> The end user id
Controll Device:
Cisco 7942(added)
Primary Extension :
Cisco IP phone extension number
group permissions included;
standard CCM end user.
Standard CTI enabled.
17 Replies 17
As your question, or whatever your post is meant to be, is off-topic to the OP it is advisable to create your own post to ask what you need help for.
If it is related to the OP question this post outlines what is needed to fix the error. https://community.cisco.com/t5/collaboration-applications/jabber-error-code-cj-109-3/td-p/2710197
Response Signature
RachelGomez161999
Complete these steps in order to resolve this problem:
Ensure that your Jabber-enabled PC is able to download a file from the TFTP server (Callmanager).
Enter the Tftp -i <cucm ip address> get <SEP>.cnf.xml command from your PC in order to download the TFTP file. In this instance, the name of the phone device is SEP, which is the MAC address.
Note: In order to ensure that your PC has TFTP-client enabled for Microsoft Windows, navigate to Control Panel > Program and Features > Turn Windows features on or off, check the TFTP Client check box, and click Ok.
If the file does not download, ensure that Windows Firewall or Physical Firewall do not block your access to port 69 or the Jabber application access. In order to ensure this, navigate to Control Panel > Windows Firewall > Allow a program or feature through Windows Firewall, and check the Cisco Jabber check box.
If the previous steps do not resolve this issue, log in to CUPS and navigate to Application > Legacy Clients > Primary TFTP. You must populate the TFTP address for the Primary (at a minimum).
Rachel Gomez
Also check the CCMCIP and TFTP profiles in the IMP server. The CCMCIP profile assigned to the user in IMP has IMP ask CUCM what devices the user controls so those devices can be displayed in the Jabber client.
Maren
