Match inbound dial-peer CUBE
MrMartin
Beginner
Beginner
Hi!
I have a question regarding matching inbound dial-peer on CUBE.
I've read some example on the link below and wounder if it's possible to have wildcard in the "user-id" part, for example 123..*  or how would i type this?
And also if i only match "cisco" on the host part instead of cisco.com would that be possible?
https://community.cisco.com/t5/collaboration-knowledge-base/uri-based-outbound-dial-peer-configuration-on-cube/ta-p/3154361
Match based on the user-id portion of the uri
Received:
INVITE sip:12345@cisco.com SIP/2.0
voice class uri 1 sip
user-id 12345*
host cisco.com
Thanks in advance!
2 Accepted Solutions
b.winter
VIP Advisor VIP Advisor
VIP Advisor
I have never worked with "user-id" parameter, but without testing anything, I would use the "pattern" parameter instead.
It search the complete header, but you could use something like "pattern sip:1234" to target the user-part of the URI.
Roger Kallberg
VIP Expert VIP Expert
VIP Expert
This part of the linked to document should answer your question.
The host or user portion of a voice class uri can contain regular expressions (regex) patterns which greatly expands the possible values that can be matched.”
In Depth Explanation of Cisco IOS and IOS-XE Call Routing
Response Signature
6 Replies 6
b.winter
VIP Advisor
Roger Kallberg
VIP Expert
Response Signature
MrMartin
Beginner
Beginner
Thank's for your reply !
Now i think i can manage to get it configured correctly.
MrMartin
Beginner
Beginner
Hi!
Just an additional question. Is this a possible solution to match IP 10.10.0.(0-255) in the SIP URI  ?
Voice URI class: TEST
SNMP status = Active
Schema = sip
user-id =
host = 10.10.0(.*)
phone context =
dial-peer voice 100 voip
description inbound LAN
session protocol sipv2
incoming uri via TEST
Per the document that I shared with you the host part can contain a match with a regex pattern, so I think that what you have should work. However to know for sure I would recommend you to run a debug voip ccapi inout to verify that it matches as intended.
Response Signature
Great, i give it a try !
Recognize Your Peers
