08-05-2021 12:21 PM
I am having a weird issue with CUCM 10.5 that has me scratching my head. Mobile connect calls stop ringing at the desk phone as soon as the remote destination starts ringing, and the call is not logged as missed. Caller ID does not follow the call to the cell and uses the external mask of the route pattern/route group.
This behavior is happening on SCCP and SIP Phones. Incoming calls and calls to remote destinations are using the same PRI.
Inbound call flow is PRI-GW -->CUCM XlationPattern-->User Phone
Remote destination profile is using the standard DEVICE_CSS which contains all of the PSTN Patterns with no blocking - for both Device CSS and Rerouting CSS. We have blocking PT's in BLOCK_INTL_CSS for example which we apply to the DN's
I'm just having trouble understanding why it stops ringing at the desk device and acts like a forwarded call, with no missed call in the logs.
08-06-2021 09:44 AM
Is there a short "ring no answer" time set on the DN?
Just because you send the original calling party to the PSTN doesn't mean that the carrier will accept the value you send. If it is a CUBE, you need to watch the "debug ccsip mess" output to see what you are sending. If it is a PRI, you need to watch the "debug isdn q931" output. If it isn't sending what you expect, look at translations in the route pattern, route details, and calling party transformation in CUCM. You might also check to see if there are voice translation profiles in play in the CUBE/PRI gateway.
08-07-2021 03:40 AM
Is this behavior common for calls coming from both internal and external ?
If you send Mobile number as caller-ID, ISP either drop the call or translate the calling number to DID pilot number. ISP does this for Billing purpose.
As @Elliot Dierksen mentioned, by running debugs on gateway you can confirm the calling information passed to ISP. Since your connection type is PRI, for debugs use debug isdn q931.
For extension mobility to use DID as calling information , we use below two parameters.
Service parameter>> call manager(Active)
Honor Gateway or Trunk Outbound Calling Party Selection for Mobile Connect Calls TRUE
On gateway>>Call Routing Information - Outbound Calls
To send the mobile number as calling-Number, make below changes.
Honor Gateway or Trunk Outbound Calling Party Selection for Mobile Connect Calls FALSE
Originator
